PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Who has experience w/ this switch?
  2. Hi Tec servo jitters
  3. Futaba 3010 servos and ni-cads
  4. A few questions from a beginner
  5. Programming 9Z
  6. Will Futaba wake up?
  7. Futaba 6XA dual rate problem
  8. Futaba S9152 Aluminum Horns ??
  9. Farthest reaching radio?
  10. Help!!! Trainer cord problems
  11. jr max net-w125h
  12. elevator channel reversal
  13. Futaba Gyro for Airplane
  14. 7CAP flaperon mixing question
  15. Radio Question
  16. Ultra Stick setup with 9C
  17. Need help with replacing Accelerator servo
  18. 8U Cross Trims???
  19. Royal Evo 9 with WORKING shift select...
  20. Trainer cord problems?
  21. Replacement case sets for JR servo's
  22. servo gears for coreless JR 4021's
  23. AIRTRONICS RADIO QUESTION??
  24. Enough Power?
  25. Royal Evo
  26. Help ! Need english manual for graupner MC22 or MX22 !
  27. Gold Sticker Futaba FG "Legal?"
  28. JR Radios High or Low Band?
  29. Hitec 555 and eclipse spectra
  30. Channel Assignments 92186Z Airtronic PCM RX RD8000
  31. Futaba 9CAP - Mixing Help ?
  32. chrystals
  33. GWS servos
  34. Airtronics Digital Servos?
  35. 1 TX multiple Cars
  36. JR 652 QUESTION
  37. repaireing reciever antennas!
  38. Hitec 56xx servos
  39. Airtronics Quasar
  40. increase servo rotation
  41. (Areohawk) what crystal’s can I use for its controller and helicopter
  42. JR 649 / 8310 dual elevator setup help
  43. Faraday Cage
  44. MSA-10 or Matchbox
  45. JR xp6102. some questions
  46. Futaba's 3050 digitals??
  47. 27 Mhz cable length
  48. Analog, Digital, Coreless, 3-Pole, 5-Pole Same Stats???
  49. JR switch replacement
  50. all the huff and now nothing
  51. HS-5245MG Hitec servo's
  52. Servo Low Rates
  53. Servos for Funtana...
  54. Interference
  55. PDF manual dor PCM9
  56. CCPM mixing in X-388s
  57. JR X-378 switch positions
  58. can you extend the range of your radio???
  59. 72 MHz with range of 200 ft?
  60. Emcotec DPSI RV Users.....
  61. Returned 5945 Hitecs
  62. Jittery rudder servo? Even after replacing.
  63. I'm looking for a HFP-10 expert
  64. Hitec RX crystal in a Futaba RX. Is that ok.
  65. 18g servos on auction site
  66. Should I buy this?? futaba super 7 FP-TZ Transmitter
  67. Is my reciever shot?
  68. Any online shops with FUTABA 7-CAP's Transmitter only?
  69. Receiver Battery Charging
  70. 8611s of 6v?
  71. 8301 switch from mode-2 to mode-1?????
  72. Download Futaba 9CAP Manual
  73. 3004's on 6 volts pretty snappy!
  74. radio interference HELP
  75. JR PCM 10 SX Upgrade to Sx II
  76. 4 channel ham band mini reciever?
  77. Setting up twin throttle servos on a JR PCM9X
  78. New servos... no spline is centered???
  79. Adjusting (analog) servo center point
  80. Hitec HS 5945 servo melt down.
  81. Airtronics RD6000 on sale....
  82. FM vs PCM
  83. Servo Reversing cable versus Computer Radio
  84. Futaba 7C vs 9C
  85. PCM 10SX II Airplane Manual
  86. Can't Discharge Futaba T6XAS Batteries
  87. How long do the batterys hold the charge?
  88. transmitter case
  89. metal gear servos
  90. Servos: importance of correct setting - graphic calculator
  91. Help w/ flaperons on Futaba 7C
  92. Hitec Flash 5 & REVO mixing
  93. FUTABA CONQUEST FP-T6NFK
  94. Futaba 7c
  95. Royal serv --> JR Connector
  96. Upgrade servo?
  97. Pro's & Con's of 6V vs 4.8V
  98. Radio and Servo Setups
  99. JR dual conversion crystal
  100. MX-3S
  101. JR PCM Receivers
  102. AIRTRONICS PC INTERFACE NEED HELP !!!
  103. Servo feedback pot cleaning
  104. Possible JR PCM9 bug
  105. Tower Hobbies S2000 servos [yea or nea]?
  106. Edenburg book and the 7uaf
  107. Old radio
  108. Bad glitches in OMP Edge
  109. Crystal Swap- Hitec ch.35
  110. Servo Slow?
  111. receiver antenna wire got cut
  112. Help! Servos not travelling the same distance...
  113. radio controller needed
  114. CAMPAC Programming with PC
  115. futaba 8uap quits!!
  116. Programming Futaba 7CAP Help
  117. Throttle-Cut trouble with futaba 8UAP
  118. How do you trim a Multiplex?
  119. travel adjustment on JR transmitter
  120. Dumb Futaba 9C ?
  121. MPI Miracle Y is a POS!
  122. futaba 8u tx
  123. Multiplex EVO system?
  124. Power Stick short antenna
  125. Anyone using Futaba 3151 dig servos?
  126. Royal EVO Rudder to Aileron Mix
  127. Mixin two elevator servos on Futaba T8UPS
  128. Positive/Negative shift
  129. Programming JR 8103 transmitter
  130. Airtronics RD6000 Super
  131. a 4 channel radio controller needed
  132. HiTec Servos
  133. JR TX nicads
  134. Is this older Futaba radio legal?
  135. a good 27Mhz AM mini receiver
  136. JR PCM Max 6 Radio
  137. Online JR 783 manual??
  138. linking Aileron Servos on 4 Channels...
  139. JR DS559 digitals
  140. 2 questions regarding futaba and hitec rx
  141. EPA vs Dual Rate
  142. 9CAP DR assignable to throttle position?
  143. Strange "glitch" with 9C... please help...
  144. 1 Servo Aerilon & Rudder
  145. Do servo connectors cause a drop in voltage?
  146. futaba servo plugs
  147. PPM or PCM???
  148. Does the Futaba 8uafs support both shift types?
  149. Flash 5 problem
  150. Wide Band Receiver
  151. Transmitter Question
  152. Best Servos for Nitro Stadium Truck
  153. n00b question about Futaba FP-T4NBF
  154. TX Question
  155. jr 8103 questions
  156. Need to know how to wire a servo for microswitch controll
  157. JR PCM 9X Transmitter
  158. futaba & GWS crystals from the same store ?
  159. RX dual conversion crystal frequency
  160. Different # of Rx and Tx channels
  161. Mixing Transmitters / Recievers
  162. Connection
  163. Help me with the PCM 9X please :)
  164. Mode 1 or Mode 2
  165. Update Futaba FP-S34 High Torque Servo
  166. Opinions, Hitec Digital Servo Failures
  167. Fixing Rx antenna lead ?'s...
  168. Dual elevator servos not 100% in sync with Futaba 8U radio
  169. PROGRAMMING 9C FOR US60
  170. Air tronics quaser 6a radio
  171. Largest wire that can be crimped ?
  172. Is the JR XF631 a good radio?
  173. Jumper for 6EXA?
  174. Compatibility
  175. Airtronics Stylus programing problem
  176. 9Z WC3??
  177. Tx Rx battery help Y adapters
  178. Airtronics Quasar Problem
  179. Airtronics RD 6000 Super programing
  180. simprop servo info req'd
  181. who sells pcm 512 rx?
  182. Throttle servo close to headers
  183. PCM transmiter/receiver question
  184. Xmtr Analyser/Recorder/Active cable
  185. Multiplex Evo on tower
  186. Faulty s3004 servo
  187. JR XP6102 PCM or Futaba 9 Channel PCM 1024ZA
  188. Glitching,twisted wires??
  189. 6965-68HB Servos
  190. Will any Rx/Tx work with BEC?
  191. AM Cross's 9C manual!
  192. Futaba Micro Buddy Cord
  193. Made the plunge, got a 9C finally!
  194. 9cap
  195. cheapest flight pack
  196. voltage issues
  197. 4 aileron servos
  198. Multiplex & Carlton Spindal/Critter Bits
  199. JR 10x?
  200. Futaba 9CH or Hitec Eclipse 7?
  201. Cheapest place to buy a Futaba 9c?
  202. Airtronics Vanguard 6 Channel
  203. replace futaba 7uaf battery
  204. Multiplex IPD
  205. Seeker II and Futaba 9Z synthesis module
  206. Royal Evo and JR digital servos HELP PLEASE!
  207. Voltage Range for the 9C
  208. JR 10X Switch Assignment
  209. Dual Elevator Servos
  210. JR R610M Help
  211. 7CAP and GWS Reciever Problems
  212. JR XF622 Elevons Help !!
  213. Futaba Radio to Australia
  214. Futaba FP-R118GP PCM RX
  215. Futaba Radio to Australia
  216. Hitec 635 vs. Futaba 3010
  217. Flaperon set up on JR XP8103
  218. new radio
  219. JR NER 326-X receiver any good?
  220. Which servo where?
  221. Retuning Receiver
  222. how much is to much
  223. 9C Programming Question
  224. frustrated
  225. 9ZAP case replacement
  226. Is this servo beefy enough for nose gear steering?
  227. HiTec 5995 Digitals Any word or info?
  228. JR xp6102 Vs. FUTABA 7c
  229. JR Buddy Cord
  230. Retracs channel
  231. JR XP8103 programming question...
  232. New Products from Futaba
  233. EVO Price Confusion?
  234. wanna trade your airplane century for my heli type?
  235. anyone ever use Mcdaniels go slow servo slower?
  236. Futaba 9C with Campac issue.
  237. Compatibility for a new radio
  238. Opnion about new 9 Channel Radio
  239. Long Battery Leads
  240. Airtronics Vanguard 7g6p
  241. Hitec HS-77BB user opinions....
  242. Does lead tail weights affect RX reception?
  243. Ham Band - OK to let others fly??
  244. futaba 6 exa vs jr xp662-
  245. Seperate elevator channels?
  246. Changing Transmitters
  247. Hitec Eclipse 7 battery life
  248. Horizon Customer Service
  249. Futaba conquest
  250. Hitec Electron 6 channel
