PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Recievers and transmitters
  2. Long Antenna Tube
  3. Royal evo 12 feedback, heli?
  4. 6XAS and Flapersons
  5. Any issues with Hitec HS-5475HB Heavy Duty Digital Servos?
  6. Hitec Electron6 receiver fails after six flights.
  7. KO Propo Digital Servo Question
  8. 9 CAP Tx Possible to convert from 72 Mhz to 36 Mhz
  9. Easiest To Program 9C or Evo 9 ?
  10. Opinions about servo failure
  11. What Servo brand is best? POLL
  12. Servo, Rx on 6 volts
  13. Modifying servos for continuous rotation
  14. Transmitter Modification
  15. Bogey Transmitter
  16. Dual elevator servos with 7C
  17. adjacent chan interference problem & range checks
  18. Royal Servo
  19. On-Off switch for old Futaba
  20. GP extra300s 60 servos?
  21. 4ch Tx + Rx ???????
  22. Help Please - what radio do I have/Need receiver
  23. Out-of-control servos, help!
  24. JR8103 Programming
  25. futaba 7c ?
  26. Futaba trainer setup confusion
  27. 23 Year-Old Futaba - Is it Legal?
  28. using 20 radios at one time
  29. RX crystals.
  30. Airtronics VG6DR servo reverse problem
  31. Changing Tx Crystals
  32. Spectra Module
  33. Royal Ev0 new model, servo conf. please help
  34. JR Receivers on 53MHz
  35. New Hitec servo... You asked for it, you got it!
  36. Servo Glitch
  37. can I mix 1 and 6, plus 2 and 5
  38. GP Skybolt 4 micro wing servos
  39. Advice needed for setting up new plane with new radio
  40. JR XF631
  41. GWS Micro MG servos ??
  42. Somethin Extra Servos
  43. Futaba 7C
  44. Radio channels question
  45. Need help programming 8103 dual elevator servos
  46. Multiplex 9 channel synth Rx has arrived.
  47. Dual band Transmitter w/Single band Reciever?
  48. Receiver Glitches ????
  49. Hitech trainer cord
  50. JR783 Data Sheet in spreadsheet?
  51. Unable to reverse Channel 3 on 6XAS Xmtr
  52. Flight Systems Receiver
  53. Can I replace my receiver wire???
  54. Proline diode equipped battery schematic?
  55. Futaba 7C - Programming mixes
  56. Futaba 9c CAMPac
  57. JR vs. Futaba --- which is best?
  58. JR xp662 spoileron question
  59. x-378 or eclipse 7?
  60. Old Airtronics Rx vs. New Airtronics Rx?
  61. When did Jr 955 reciever come out?
  62. sub trim question
  63. Hitec eclipse on 50 MHz
  64. JR XP6102 or X-378 (Just got the 378)
  65. 7.2V RX/Servos ???
  66. Futaba 9ZWCII Compac Question
  67. Tx crystal swapping!
  68. Multiplex EVO Concerns
  69. EX-11 presto manual
  70. Hi! i have a question about
  71. SERVO REVERSING
  72. Berg 6 DSP 111
  73. Crystals in Tx
  74. Futaba 9C screen blanking problem, anybody else?
  75. Futaba 9zap W2 range check
  76. Dual Conversion xtal in R700 receiver
  77. To Evo or Not To Evo?
  78. WHY DO MY SERVOS GROWL.
  79. Watch OUt for NorthEast SailPlanes
  80. jr xp662
  81. running to the LHS in a few Hours HEEELP
  82. newbie: What is the Gyro and how it works?
  83. increase the range of JR Beat Gear radio???!!!!1
  84. help!!!
  85. Wayne Miller - JR 8103 instructions
  86. JR 537 Std Servo and 6 volt battery question
  87. Futaba 9C engine torque counteract program
  88. Whats up with JR 9X
  89. JR web page
  90. eclipse 7 mode 2 to mode 1
  91. FP-TP-FM in 35 Mhz
  92. HiTec 5245's, are they ok?
  93. Old Kraft radios
  94. Best price on 8611s?
  95. 3305 Backlash??? I think.......
  96. Futaba T6XH Discontinued?
  97. rd 6000 super reviever type question
  98. Futaba 9CHP
  99. Multiplex
  100. Airtronics M8 Fuse size ???
  101. Stay with 50MHz or switch to 72MHz
  102. Wanted!!!
  103. Futaba skysport Tx ?
  104. Jaguar 8217 ACE R/C radio questions
  105. 4.8 and 6 volt Rx batteries
  106. Ace Silver Seven Crystals
  107. Airtronics Servo Disassembly
  108. 20 year old radios
  109. Expert RF600
  110. Major differences between the JR 378, 6102, 8103?
  111. KE Programming on a 9C
  112. Who can swap my crystals
  113. Airtronics Servo's
  114. Futaba FP-T4NL
  115. Programmer - Pulse Measurement Acceptable Flux
  116. 9c replacement battery
  117. Strong servos !
  118. Futaba....3010's
  119. Receiver OK?
  120. Freq No's
  121. JR NER-327X (The missing channel)
  122. Eclipse 7 sticks are reversed
  123. servo help!!!!! please
  124. Horizon Hobby Service!!!
  125. how to set up airtronics styl. for U.S. .40
  126. Futaba Keeps nixing my responces and Questions
  127. Futaba 9350?
  128. Multiplex IPD RX failure...
  129. Specs for Hitec HS-101 servos wanted
  130. Replace royal titan servo?
  131. Light weight but high torque servo hard to find?
  132. Single conversion?
  133. servo reversing
  134. After Market Memory Module
  135. JR 6102 or futaba 7c
  136. Somenzini holding a radio on belt?
  137. Antenna concerns for Transmitter
  138. GWS 4ch receiver hack/mod, add one more ch.
  139. Flying with retracted antenna ETOC
  140. Why do you buy JR?
  141. Zhen Hua PCM-4CH Radio
  142. voided my warranty?
  143. JR 10 SX-- Programing rates to one switch
  144. Airtronics Or JR
  145. MPX Cockpit MM
  146. JR 10SX and Ultra stick programming
  147. New RX and TX
  148. Airtronics/Sanwa 92777 FM Rcvr
  149. New servos and equipment? Toledo show
  150. Interfearance Frustration
  151. RX repair? Or buy another.
  152. emcotec power box
  153. Mixing Ailerons and elevators
  154. Standard servo current draw.
  155. JR Faling apart
  156. does this exist (making sozbot)
  157. Disassembling A 9ZAP WCII
  158. HELP PROGRAMMABLE MIXERS 6XAs/T6XA
  159. new servo binding?
  160. 9CAP cancer warning
  161. Futaba 7C How do I change frequency
  162. Tail servo chatter
  163. Futaba to Airtronics Trainer Cord
  164. Servo Testing
  165. New 9c confusing me
  166. Rubber Duck Transmitter antenna
  167. Can I use a different radio on a reciever?
  168. futaba pcm 1024 fp-r129dp failure
  169. RX antenna monocoat interference?
  170. Servo torque convension?????
  171. The reliability factor- a study from Europe
  172. Help me spend my money!
  173. How Does RC Work? NEED HELP
  174. A Demon in my 9Z
  175. Servo reversing
  176. reciever effecincy vs. Rocket speed ????
  177. Is a 72 oz. torque CORELESS Servo stronger then a 99 oz torque standard servo?
  178. Servo reversing on Futaba S3151 digitals
  179. Futaba 127DF info request
  180. Dual Servo?
  181. precisely matching two 5934 servo's movement possible?
  182. Servo strength
  183. GWR-4P Receiver Hookup?
  184. airtronics spectra 7 pcm heli manual
  185. MPX Evo -any good for a scale -modeller ??
  186. 9 CAP, capable of throttle point curve programming?
  187. jr 9x or m.plex evo? need to make a choice
  188. WooHoo Royal Evo 12 showed up... !
  189. shaving Tower servos/Airtronics rec.
  190. PCM Receiver Problem
  191. Futaba 6XAS Reversing throttle feel to bottom of throw
  192. signal tap
  193. Looking for Hitec Focus 4 or 6
  194. conversion of servo torque?
  195. Royal Evo mix question
  196. Futaba 9CAP or JR 9X which one is better.
  197. Futaba 6EXA or Hitec Eclipse 7
  198. Airtronics Radiant Manual
  199. Source of Radio Glitches???
  200. jr 8103 question
  201. Help with JR X-347 needed
  202. Strength of signal and 3IM
  203. Newbie needs help selecting radio>>>>
  204. Li-po's for receiver and servos only.
  205. USB cable for Radio?
  206. |Ungret| VG6DR Mixes
  207. Expert servos
  208. 7C or XP6102
  209. HERE COMES THE FUTURE IN RC RADIOS
  210. SLOW GITTERS
  211. I lost my Futuba Fieldforce 6 manual.
  212. Futaba 9Zaps WCII Help!!
  213. Pcm Vs Fm?
  214. Horns Identified
  215. How low to you run your TX battery
  216. changing channels. Is it safe?
  217. Futaba/JR Transmitter With Airtronics Receiver?
  218. 2nd Radio?
  219. 4 Chan. AM RX
  220. GWS mini servos on a 40 sized plane?
  221. Jr10x heli version
  222. How do I activate my Elevators dual servos
  223. 8u question
  224. Futaba T6XA Problems
  225. GWS manuals?!? eg: Slow Stick and reciever
  226. GWS manuals?!? eg: Slow Stick and reciever
  227. Sheilded cable
  228. Futaba 7c vs. 9c ?
  229. Rx antena wire size?
  230. Pistol To Futaba 2ER?
  231. what is in a servo?
  232. I WANNA SMASH IT!!!!!!!!!!!!!
  233. Programming 7UAP PCM
  234. JR 388S No Elevator Trim
  235. IPD receiver questions
  236. Reciever Frequency Question
  237. Futaba 5101 Servo
  238. Hitec or Futaba RF schematic
  239. Acoms Servos
  240. R127DF Receiver - Unusual Behavior
  241. mode 4
  242. Hitec Trainer cord Pin Connections?
  243. RC Radio antenna (special application)
  244. Transmitter battery leads
  245. Idle up with 9c
  246. 9zap TX battery upgrade guestion
  247. FuntanS 40 ARF stripping 3004 servos issue
  248. Is PCM worth the extra $50
  249. Radio for SS with 4 wheel steering
  250. t6xa problem
