PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. t6xa problem
  2. Servo plug ends?
  3. RX Pack Interference Question
  4. Crystals
  5. Futaba 9z full hardware reset
  6. Whats good heavy duty switch harness for 25% CAP?
  7. Extra 300s .60 Set up
  8. Servo arms and splines. Is 90 degrees possible?
  9. Aluminum Servo Arms
  10. multiple batteries
  11. V-Tail on a Super 7
  12. graupner servos
  13. JR 10SX
  14. FMA Extreme 5 Rx "dropout"
  15. Broke Futaba Receiver...
  16. adding a 7th channel to a 6 channel radio
  17. Which way for switch?
  18. Helicopter Gyro
  19. ko propo mars.......
  20. Airtronics / futaba
  21. airtronics vg6000/rd6000 comptuer interface?
  22. Slave on 7C or XP6102?
  23. Airtronics Rx & Tx Batteries
  24. Crystal Confusion.....
  25. hitec 555 maddness
  26. New Futaba 7C
  27. radio component compatability
  28. V-tail setup?
  29. Single vs. Dual Conversion Receivers
  30. Multiplex royal evo 12ch
  31. Futaba 9CAP or Airtronics Stylus
  32. Hitec Flash 5 for Hovercraft
  33. Possible Futaba 9CAP recall
  34. How can I hook two elevator servos together
  35. Noise difference between different JR NES-537 servos
  36. Rx antenna length?
  37. Hitec 5945x 5645 too much money difference for few torque more!
  38. Futaba T8UAF
  39. New Radio and Digital Servos...need help
  40. Glitches on 9CAP with 127DF (PPM mode)
  41. Futaba fp-T7UAP
  42. Is the Futaba 9C shift selectable?
  43. 3151 Futaba, why can't you use 6v?
  44. S&T SRX-M8 Receiver
  45. Heathkit GDA-19 Servos
  46. Extension cables
  47. the Best Radio (PCM version)
  48. Range Check / Output Transistor
  49. Heavy Duty Charge Leads?????
  50. T6XAS and Hitec feather Reciever?
  51. 50mhz radios
  52. Futaba 9151 and 9206
  53. JR CRYSTAL
  54. IPD or PCM with Gas planes?
  55. Emcotec Powerbox vs. Powerbus Pro
  56. 50 MHz Futaba Flight Pack?
  57. Expert Receiver and Molex connectors
  58. airtronics receiver---servos question
  59. Futaba 6xas Throttle Trim
  60. traxxas stampede servo
  61. Antenna routing in .46 custom plane
  62. JR leads on Futaba servos
  63. Multiplex royal evo 12ch
  64. JR XP 8103 Data Sheets
  65. Eclipse 7 throttle cut
  66. True range of RC signal
  67. Harry Higley's Programming Futaba's 9CA
  68. AM or FM and what to use?
  69. Royal Evo
  70. Newbie Questions on Servos
  71. Hitec Eclipse NIB = No Ch 6 ?
  72. Different receivers??
  73. Tracker II website
  74. Replacement servo
  75. futaba and hitec digtal servos
  76. 9Z - AFR v Dual Rates
  77. 9z or 9c ???
  78. Giving the 4VF SkySport more channels?
  79. Second Radio Advice
  80. JR642
  81. Coiled ant. wire VS. straight
  82. JR642
  83. another receiver question
  84. Hitech digital servos
  85. How much can I draw through a 149DP?
  86. Expo
  87. TX freq change
  88. US 40 Done, ready to go..almost.. help
  89. Seeker ll 72 mHz receiver
  90. transmitter and receiver interchangeability
  91. Ace Oly 5 Radios and Receivers
  92. Older Futaba and Hitec FM transmitters
  93. trainer cord on 7cap
  94. 36MHZ Crystal useability in RX from USA?
  95. Questions regarding "MICROPRO 8000"
  96. Need help on Radio setup for 4 Star 60
  97. "7C" Can anyone help??
  98. Hitec 5945 vs 8611 difference ?
  99. Crow on 6 channels? (JR XP662)
  100. Futaba 9chp
  101. GWS Servos in a 60 any comments ?
  102. Mode 1 vs. Mode 2
  103. Battery for 8 servo setup?
  104. has anyone heard this?
  105. help-i cut my receiver antenna
  106. Hitec Aggressor CRX trim problem
  107. Radio / Servo experts please help..
  108. How are YOUR Hitec 56XX Servos doing?
  109. 8611 Voltage
  110. best esc for a m18
  111. JR 10x vs. JR XP8103
  112. JR D/C crystals
  113. 9C and Flaps
  114. please help with 7cap setup!!
  115. Kraft Radio - Sport Series - for sale
  116. multiplex royal evo 12 synth module?
  117. Royal Evo mixer set up
  118. futaba 9cap
  119. JR matchbox
  120. Servo Horn not going on...
  121. Futaba/Hitec servo connector
  122. futaba 9cap mix program for airbrake- flap and elevator
  123. HELP - Charging XMtr Battery
  124. SERVO REVERSERS
  125. 6 Servos on a 4.8 volt, 700mAh Sport Battery???
  126. kraft complete radio sys.
  127. Futaba/Airtronics Compadibility (VG600)
  128. Second Reciever Question
  129. JR EP652 RADIO W/ DIFF. RECEIVER
  130. Mode 2
  131. Will I get RF????
  132. New Dual Frequency System from Graupner
  133. Anyone up to a challenge for programming 8UAF?
  134. Can I use a JR receiver with a Futabe 9CAP
  135. Futaba 7CAP - problems after setting up timer
  136. JR 8103
  137. Where to get Red Anodized stick ends for Futaba Radios?
  138. Airtronics MX 3, Ko Propo EX 1, JR Racing XS 3 or Futaba 3 PDF-X
  139. Trouble programing 8U with Futaba Gyros
  140. Intresting Fact about the 9C
  141. S3010 doesn't work with NiMH? Nope.
  142. redundant radio systems
  143. extensions on rx battery pack
  144. Glitch counters and PCM
  145. 2 Aileron servos without MATCHBOX?
  146. XP642 BROKEN THROTTLE STICK
  147. Need 'stuff'
  148. Futaba DSC Compatability
  149. Programming rd8000
  150. Futaba 9C batteries
  151. Reversing an S130
  152. JR 8103 gimbal stick tension
  153. differential thrust
  154. Hitec HS 225 question
  155. Rado setup for Extra 330L
  156. Receiver shootout (part 1)
  157. Futaba 8u problems with Hitec Frequency module HELP!
  158. 10X vs 9Z
  159. NEW 9C synth
  160. Projeti cut my Antenna
  161. Futaba 8U question
  162. throttle ratchet
  163. Jr 4000 Servos
  164. what is the best servo for my application
  165. Jr 8411's buzzing
  166. ACE Silver Seven Receivers
  167. multiplex
  168. multiplex
  169. Maxx Products New LED Switch Harness
  170. Bad servo glitching question
  171. R700 CH 36 ???
  172. JR servo ,L501,L4001 How much are they worth and there Torque?
  173. What is your stupid radio story?
  174. Futaba 7CAF ..placing order monday morning...read...
  175. Just upgrading to digitals?????
  176. JR 8103 Timer?
  177. Futaba 8uaps
  178. Throttel cutoff in Royal evo
  179. Help with 8UAF auxilary channel set up please
  180. Airtronics Freq swap
  181. Futaba 6EXA / Saito 30 throttle-cut switch setup?
  182. Cheap Micro Servos - Dragonfly - Any Good?
  183. Reversing S9402 servo
  184. RD-8000 with Ultrastick-60 -- HELP!
  185. 18 AWG extensions
  186. JR RADIO
  187. How many radio do you all have?
  188. How does it work?
  189. Good first computer radio?
  190. Dula Rates on Throttle
  191. which is the best radio of these 2
  192. Hitec 625mg's
  193. 4 Segment wings and the Futaba 9C
  194. XP 8103 VS PCM 9X
  195. JR PCM 9X
  196. Servo extention question!
  197. receiver question
  198. FUTABA SERVO QUESTION
  199. 9CAP 4 servo aileron programing
  200. Futaba Radio Question !!!!!!!!
  201. Frequency "bleed"
  202. What gives?
  203. Older recivers compatibility
  204. 9Z newbie question--first of many, I'm sure...
  205. 9 CAP programming book..the one for "Dummies"
  206. emcotec
  207. Futaba 9 vap - Please post.
  208. PREFERRED CHANNEL ON PICCOBOARD PLUS
  209. I.D. Transmitter 2
  210. I.D. Tranmitter
  211. futaba 9c question(set up trick)
  212. fail safe receiver switch?
  213. Can old FP-7FGK be narrow banded?
  214. Futaba Reciever problem
  215. T6xa elevator trim problem
  216. 9CAP Throttle Mix
  217. BERG STAMP RX with PICOBOARD
  218. Futaba 9CAF ok for heli?
  219. 56mhz?
  220. Antenna for micro flight
  221. Where can I buy a stripped HITEC FLASH 5 Radio?
  222. Multiplex charging
  223. JR 8103 Promo servo Flutter
  224. kopropo EX-10 HElios help?
  225. battery in backwards on Futaba 127DF
  226. Servo synchronizer or Servo reverser?
  227. 1oz low voltage, 4 standards
  228. My Take On The Futaba 7CAP
  229. Futaba Crystal Experiment...FMA Crystal
  230. 4 Channel Radio/5channel receiver??????
  231. Receiver Problem
  232. TX with 5th Proportional Channel
  233. RADIO FOR PICCOLO
  234. Futaba FP-T8SGH-P question
  235. Left handed mode 1 on hitec flash 5 ?
  236. Who's using FMA Servos?
  237. UNI Vs MPX in MUltiplex RXs
  238. How do I program 9CAP so throttle is less sensitive?
  239. Radio Crystal question
  240. FMA Direct Fortress == Futaba???
  241. old airtronics servo connectors...
  242. Airtronics VG6000
  243. servo plugs
  244. futaba 6xas
  245. Higher frequencys better ...?
  246. Antenna must be full out
  247. MicroStar 2000 parts
  248. New JR 10X Air
  249. Charger voltage for RD6000 TX
  250. JR XP6102
