PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. FF9 throttle setting?
  2. High voltage affect on servos
  3. Using Eclipse 7 w/other brands ie airtronics
  4. Flutter on the ground!!!
  5. FMA co-pilot 8chanel
  6. Beta test my JR XP8103 Data Sheet
  7. Volz Servos
  8. Computer radio question
  9. ServerCity combos
  10. ultra stick servo
  11. DAD Pro+ servo gears?
  12. Futaba S9153 and S9152 Digital Servos
  13. Sweeper for Interference
  14. Hitec Supreme 8 with Futaba Crystal?
  15. JR radio compatability
  16. Airtronics Help
  17. Futaba FP-8SSAP
  18. Good & Bad News at Horizon
  19. Beware of low priced computer radios.
  20. Good Deal on JR 8611 Servos
  21. Looking for servos in Montreal (Canada)
  22. does torque increase proportionally with weight?
  23. What does the speed of a servo mean??
  24. Futaba 8AU with Hitec 72 Mhz module?
  25. 7CAP/Ultra Stick
  26. Servo Selections
  27. Regulator needed for Hitec digitals?
  28. Buddy box, need help!
  29. NEW RADIOS
  30. Hitec 555 in a 40 size nitro plane?
  31. Airtronics PCM RX problem
  32. Airtronics Infinity 600a?
  33. Futaba PCM with Hitec digitals?
  34. Crystal failure
  35. ? Changing frequencies
  36. Power output of different brands
  37. increase range (power output) of tx
  38. No signal! need help
  39. Evo Gurus help please!!!!!!!!!!!!!!!!!!!!!
  40. Hitec programmer
  41. can i use a plane radio in my boat????
  42. giant stinger servo choice?
  43. Recommended servo size for a GP Spectra EP glider?
  44. Futaba 148DF Micro or Hitec Supreme 8
  45. Futaba Challenger conversion buddy interface
  46. Futaba Conquest 4-Ch is narrow band, right? (I hope)
  47. Spoileron Servo Matching
  48. Not impressed with Futaba 3010S servo
  49. Temp range for JR 662
  50. Flaperons adjustment with JR421EX radio
  51. futaba 7 manual
  52. Futaba 9153 or J.R. 8611
  53. Retract Servos
  54. Posi or Neg.. .. stupid question
  55. post homemade transmitter tray pics
  56. Servo range of movement
  57. Need Help with Flap Maricle Y Problem??
  58. Digital Servos -- what's the advantage?
  59. How do I identify Futaba RX Low vx High
  60. What a Bummer...8103 Charger Problem
  61. Futaba 9cap ergonomics compared to JR?
  62. 8U futaba rec. options
  63. Large aluminium case??
  64. Futaba crystal identification
  65. 72 mgz AM/FM what's the difference?
  66. Spectra glider - what servos - radio desisons....
  67. Futaba 7CAF TX only?
  68. Replacement for Futaba 9ZWCII
  69. Problem when programming Kontronik Beat 40-6-18 in car-mode 2
  70. JR 4735 vs 4131
  71. Iterfernce "i need help"
  72. Hitec HS-635HB Servos?
  73. Question about the RANGE on a RADIO???
  74. Hitec Eclipse 7 problem
  75. Can I use this Tx and Rx together ? (Futaba)
  76. JR XP6102 or Futaba 7C?
  77. Cheapest place to buy Hitec?
  78. Why Do You Use Like A 9 Channel System When We Really Don't Use That Many??
  79. Servo binding or broken?
  80. My apologies to 9C users.
  81. 7C vs 6102
  82. Best Source for buying Hitec Rxs
  83. dual elevator servos servo selection
  84. Y harness
  85. QUestion about futaba 6xa and 3003 servos
  86. FUTABA cap-7 cap-9 rubber grips
  87. Futaba pcm
  88. How many channels?
  89. Motor interference
  90. Rx Crystal compatibility
  91. Computer Radio question
  92. Rquired Airtronics 94102 servo gear set
  93. Futaba 9CAP
  94. Dielectric grease
  95. Skid Steer Control
  96. Kraft plastic frequency module plug-in dome
  97. Futaba/Hitec When are they coming out with new radios besides the 9CAF and Ecloipse??????????????
  98. Are they anygood???
  99. RD6000 CROW function
  100. Thought you'd guys would like to know!!!!
  101. Looking for GOOD 60+ oz and 90+ oz servos....suggestions
  102. Airtronice RD6000 super/Voyager E
  103. Whats the Best RX???
  104. Futaba Receiver working voltage
  105. FM receiver and digital servos
  106. Futaba 2PL Question
  107. Kraft information wanted
  108. AM and FM
  109. Servos Futaba or JR
  110. Receiver Good Or Bad
  111. servos glitching
  112. Airplane servo torque requirements.
  113. Questions about Ham Band, 50Mhz, channels, etc.
  114. JR or FUTABA
  115. Kraft plug in frequency modules
  116. Aero Arms - Interchangable?
  117. Jr or Hitec
  118. contact cleaner
  119. Futaba 9CHP question
  120. Battery cycler necessary?
  121. Multiplex 4000 Got My Stick End Buttons
  122. servo wheel differental
  123. FCC 'type acceptance' and modules
  124. Servo Bounces when Centering
  125. JR FLEXEQUIP ?
  126. 9CAP is reversed
  127. Graupner MC-24 "Gold Edition" ! ! !
  128. Futaba S3305 or Hitec HS605?
  129. Hitec HB-635 - used one yet
  130. Single-stick radios all gone?
  131. DOH!! Antenna cut - HELP!!
  132. Futaba S3305 servo's
  133. First Radio!! Need Advice--Please Help!!!!
  134. Servos for a NONFLYING F-16
  135. hi all skysport 6vh
  136. Kraft questions
  137. CHoosing a flight pack battery
  138. RX611 Sanwa/Airtronic Receiver Problem
  139. can I use servos bought in US here in Sweden
  140. noob help me plZ helios???
  141. Futaba 6XHs - Any comment?
  142. New Futaba 7 CH Radio
  143. I need electronics......all of them!
  144. 7th channel
  145. ACE MicroPro Code
  146. Channel set up on HFD-08rd receiver
  147. aeromaster c.g.
  148. hi band vs low band
  149. new radio needed
  150. Kraft question
  151. Helios Help
  152. Futaba receiver question
  153. Sanwa RD6000 Sport usage, please help!
  154. Airtronics RD 6000 Super
  155. 10sx woes
  156. servo draw for retracts with a twist!!!
  157. JR662 + Hitec HS75BB retract - throw adjustments?
  158. FM or PCM??
  159. Futaba CAP7
  160. jr digital servos
  161. Gas Throttle Servo Question.
  162. Your radio transmitter or favourite radio (if you own more than one)
  163. Servo connectors
  164. JR 9X questions
  165. Metal geared servos and gas engines-- a no-no ?
  166. Best price and your experience Hitec 5975?
  167. Need info on cleaning and servicing servos
  168. deleted
  169. H9's metal servo arm for JR servo
  170. matchbox
  171. 9 ZAP Programming
  172. Servo hook up
  173. 6102 JR
  174. Futaba 6EXA or JR 6102????
  175. Futaba servo signal levels
  176. Expert & FMA Servos
  177. Coreless vs Cored For Sport Flying
  178. Digital trims : Yes or No ?
  179. Need receiver advice
  180. tx:aero mode 2 and heli mode 2
  181. 10X & Mixing Without a Matchbox )-:
  182. Futaba 9C vs Hitec Eclipse 7
  183. Futaba 9z WC2 and JR digital servo
  184. Cannon R/C Systems
  185. Trimming with Royal EVOS hel please
  186. DrangonFly Servos ?? Any good?
  187. smoke pump with Eclipse 7
  188. best way to store radio crystals?
  189. Airtronics RD6000 trim memory functioning
  190. mini 27mhz receiver wont work???
  191. servo's
  192. 2 position switch activated Flap on Fut 8U
  193. JR 8611s, how they holding up
  194. Futaba / FMA servo splines ?
  195. Wire Qeustion?
  196. Futaba 6EXA Mixing
  197. More T6XA Problems
  198. How to change mode in Sanwa RD8000?
  199. wrong channels?
  200. Smokin' deals at servocity
  201. New Firmware for Royal Evo 9 & 12 !!!
  202. futaba 3305 vs. hitec645 - DP edge
  203. FMA M-5 opinions?
  204. Hitec Rcvr with JR 10SX II transmitter
  205. WM-P51 Retracts - 180 degree servo not working
  206. micro receivers
  207. JR Datasafe Ultra - I was disapointed until I saw the price...
  208. New radio
  209. 400 oz-in Servo
  210. Shielding a transmitter from interference?
  211. Airtronics RD6000 Upgrade
  212. Servo Sizing???
  213. WAR: jr9xpcm vs futaba9cpcm
  214. Changing Tx Crystals
  215. JR !0SX II - single or dual conversion
  216. Reciever antenna setup
  217. 2packs1reciever
  218. Is JR 9x balanced?
  219. C/F pushrod ends.
  220. Servo post extention
  221. Futaba 9C radio, defective exchange
  222. 6EXA Question
  223. futaba servos
  224. Sanwa Independent Throttle Control on Twin
  225. Check out the site
  226. Switching old Airtronics servo wire to use Futaba Receiver.
  227. JR 10SX II trans
  228. Singe and Dual conversion receiver
  229. how much do you spend on servos
  230. What Connectors?
  231. servo deflection
  232. ailevator mixing? JR xp662
  233. Design your own Expo circuit
  234. Futaba 6EXA charging diode location-found
  235. Jittery servos with HiTec RCD3200 receiver
  236. rubberduck r/c antenna
  237. Micro Servos--Info Needed
  238. D&M Electronics
  239. Which Reciever?
  240. Long (48") servo leads- Myths & Facts
  241. Polk Tracker II vs. Hitec Eclips 7 with Spectra
  242. What has changed in the last 20 years?
  243. Servo doesnt like moisture.
  244. Receiver antenna for my airtronics RD6000
  245. NEED TO MIX UP TO SPEEDCONTROLLERS - HELP
  246. MC24 manual ?? and vtail mc24 question?? Please
  247. looking for schematics
  248. Opinions on 10 channel (or more) radios
  249. Futaba MSA 10
  250. My helicopter won't recognize my Throttle!!!
