PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Futaba Attack 4 4.8v or 6.0v?
  2. RD8000 modulation choices?
  3. 3pj tx module
  4. FP-T8UAF
  5. Nicad Charger and Royal Evo
  6. radio crudd/ green stuff
  7. Testing a crystal
  8. Advice on Digital Servos for drive by wire throttle
  9. Old Radio in A New Country
  10. Power usage Hitec 645 MG vs Digital 9645
  11. is there a futaba synthesizer reciever?
  12. Futaba 9c dimensions
  13. 9C-Airbrake Stuck on Switch C?
  14. Old Airtronics radio
  15. Battery for Hitec focus 4??
  16. C???HOW TO DELETE ALL INFO TO FACTORY DEFAULT
  17. Where to buy gaupner mc-22/24 in Asia?
  18. HiTec 3500 'S' Receiver
  19. Futaba switches problematic?
  20. futaba--hi or low band?
  21. airtonics stlyus vs. other hi end radios
  22. Whats it worth..
  23. FMA receiver???HELP
  24. newbie with servo installation
  25. Changing crystals
  26. switching from 4.8v to 6v
  27. Help, 75 MHz!!
  28. i4C isolator vs. powr bus pro
  29. S-PCM Z-PCM whats the difference ??
  30. airtronics rd6000super
  31. TX needed to use the Ultrasticks Flaps
  32. Dean's base loaded Rx antennas????
  33. Servo extensions? Where to buy
  34. Eclipse setup Question?
  35. Another 9C question before I buy one!!
  36. poor radio range
  37. Hitec Eclipse Expo Question
  38. multiple receivers and batteries
  39. 9C Vs. 9Z
  40. Micro receiver with Standard Servos?
  41. Hitec 475 servos
  42. MPI switches
  43. Futaba s9303 specs
  44. Matchbox with analog servos???
  45. Were is the BEST PLACE TO BUY HITEC EQUIPMENT?
  46. Hitec 555 reciever with JR transmitter
  47. Fut S9001 Servo &Dubro Fut longServo arm
  48. PCM 8103
  49. just bought hitec flash 5 at swap meet...
  50. From 72 or 75Mhz to Ham
  51. Futaba 9C question
  52. Airtronics Z Switch ..Problems
  53. extra batt pack
  54. radios
  55. What are Coreless?
  56. 9Z Flaperon Question
  57. possible reverse polarity damage
  58. p-51 1/5 scale servos
  59. 3D Servo Arms
  60. JR PCM 10
  61. Strain Relief
  62. RADIO QUESTIONS AM & FM
  63. 9ZAP
  64. 9ZAP Synthesized, What Micro Receiver?
  65. FMA M5 receiver with Pixie 7-P speed controller not shutting down motor with loss of TX
  66. FOUND: good cheap extentions
  67. Radio Help
  68. Rx Crystal
  69. JR 8103 & THE ROO
  70. Hitec receiver with JR TX
  71. DP Extra servos
  72. Radio to control a Crane
  73. Can you program mixes with a ppm rx?
  74. How to reset 9ZAP WC2
  75. Servo Jitter on long cable runs
  76. who sells servos at good prices?
  77. Hitec/Futaba Conversion
  78. Futaba 8CH TX and Hitec Supreme 8 reciever problems
  79. Repair
  80. jr 10x has been discontinued in Europe?
  81. Help setting up flap feature on 8UAF please
  82. Multiplex Cockpit MM V2.1 120 Degree Swash
  83. receiver antenna
  84. Which Radio To Buy
  85. dismantled Coreless motor?
  86. How do I Prevent Servo Gear damage?
  87. How to Program Reverse Differential in JR 8103?
  88. Rudder servo
  89. Servo power
  90. Comparison! Need info on the new 9x to compare to the 10x!
  91. servo torque needed for Flaps
  92. What crystal?
  93. Futaba 9CAP or CAF
  94. JR's New 9 Channel, 10X Synthesizer
  95. Expert Electronics
  96. Futaba 7UAPS EXP & D/R errors
  97. URGENT HELP FLASH 5 ( not the s or sx )
  98. Servo motor problem
  99. What is the best new 6 channel computer radio?
  100. JR Radio batteries?/symptoms
  101. Hitec 5945's??.... Thinking about trying..but..
  102. Overcoming "Infant Mortality".......
  103. Futaba 7U gimbal pot replacements
  104. Servo Extensions
  105. HItec 55 mounting
  106. FS8 copilot from FMA
  107. JR 662 Throttle Cut
  108. JR 4131 and 6v?
  109. 9zwc2 dual rate programming?
  110. rudder gyro
  111. Colco setup/adjustment
  112. polk seeker
  113. Used 10X module seems to be swapped
  114. Hitec/JR compatibility
  115. Plus Expo
  116. JR 8103 on GP 300 PW elevator servo set up
  117. JR 10X elevon set up for 4 servos
  118. single axis rate Gyro help
  119. I need some advice about a Radio Controller...
  120. Fut. S9153 vs. JR DS8411, what's the best???
  121. Radios sitting for 2 years, resurection ??'s
  122. G2 Interface Cord used as a trainer cord?
  123. Decisions...
  124. Long story
  125. Radio for both plane and Heli's
  126. Can you use a hitec chrystal?
  127. Hitec reliability?
  128. JR 8103 HELP
  129. Setting up a JR 9X with flaps and ailerons
  130. Transmitter Case
  131. FMA S3601 MG coreless servos
  132. Got my new 9cap
  133. 3pdf-x vz mx-3
  134. Futaba 9001: Why so cheap?
  135. MOVED: need help please
  136. Hitec 225 for DP Ultimate ailerons?
  137. Quick Charger
  138. Follow Up: 9 Gram Ebay servo
  139. Next Computer Radio after Futaba 6EXA for Helis and Airplanes?
  140. Futaba Field Force 5
  141. can i add more voltage to my futaba servo.
  142. Skysport 4 vs Focus 4
  143. FMA FS8 anybody???
  144. Servo Connectors to a 4 Channel Reciever
  145. POWERBOX and LED Question
  146. Servo Question
  147. Tower Hobbies System3000...6 volt?
  148. New Futaba radio?
  149. Servo Torque Question
  150. 5 cell reciever pack
  151. Charge Rate thru Transmitter
  152. PC program for programming digital servos?
  153. The best PCM reciever
  154. Airtronics Infinity Tx Module Freq. Change?
  155. Flap Programing on Eclips 7
  156. Jr radio and fm/pcm receivers
  157. changing radios
  158. Futaba 7uaf
  159. reversing servos
  160. Futaba 6XAS Dual Rates on Rudder
  161. futaba 9c throttle cut
  162. Futaba 9Z & GY401 setup
  163. JR 8103
  164. new wheel on remote???
  165. Battery interference?
  166. Do you re-use RX and servos after a hard crash?
  167. Futaba S148 vrs S3004 Servos
  168. Servo City - Products and Service
  169. Receiver compatibility with RD 6000 TX?
  170. 2 servos for airlerons ?
  171. transmitter damage with antenna down while on (?)
  172. JR RS300 with M8?
  173. CO-PILOT
  174. Single Stick TX with Rudder???
  175. FUTABA 9C AND 7 SERVOS QUESTION.
  176. Source for Frequency Stickers
  177. Good servos at 6v
  178. What about the Hitech 7
  179. Futaba reciever w/ JR radio
  180. Futaba 8UAF
  181. Jr 378 on FMS
  182. Eclipse 7 Mode Change (Mode 1 to Mode 2)
  183. Max travel programmed for Hitec Digital servos
  184. 10x and 8103 JR question.
  185. Charger for field box battery
  186. old futaba radio
  187. pcm9x vs 9za
  188. JR Crystals--3 dot printed on them
  189. Stupid Servo extension question, Hitec to JR
  190. Futaba 6EXA Question !!!!!!!
  191. JR G500T vs Futaba GY401
  192. Futaba 9CHP vs. Multiplex Royal EVO 9
  193. New guys first post
  194. JR 8611 on 6 volts
  195. TX crystal(freq.) change
  196. Shilded wire as servo cable
  197. Futaba Development contact
  198. antenna lenght
  199. Rx Question !!!!!!!!!
  200. JR Propo vs Graupner part numbers
  201. Switches and Extensions - Hey look what I found
  202. world engines Rx question??
  203. most used freq chart?
  204. Grand Wing Servos information
  205. Cirrus joule micro flight pack, Anyone trying it yet?
  206. range check with antenna down?
  207. JR Verses Hitec
  208. Airtronics' M8 or Futaba 3PK
  209. New JR 9x VS 10x. Which is better?
  210. 605's are gone!!!
  211. Hitec Platinum Receiver
  212. Reciever Antennae..good/bad
  213. Holding power torque vs. regular (?) torque
  214. standard vs hi-torque servos in a bipe
  215. rx and tx frequency changes?
  216. Questions about Futaba s131s servos
  217. Buying 9ZHP Wc2
  218. Not your typical Coreless question
  219. modifying Hitec servo for 180 degree travel
  220. GWS Crystal Question
  221. Mode change instructions for Hitec Eclipse
  222. Duralite Plus Owners....
  223. 9CAP setup for crow
  224. crystals
  225. Quick Servo Question
  226. Question for electronics guru's
  227. Servo turning problem
  228. Futaba 9C compac how to copy?
  229. Servo compatibility question
  230. unassembled servo connectors
  231. a new crystal doesnt work, why?
  232. Futaba FF7 UAPS Mod for external power
  233. Antenna Replacement
  234. Switch testing method ?
  235. Proximity of servos to receiver?
  236. Manual Graupner MC-16
  237. swap jr crystals
  238. combining digital and nondigital servos on Y
  239. hitec hs-605 bb servo problem
  240. I cant figure it out!!!
  241. Servo direction reversal
  242. EDR 111 Pow'r bus pro
  243. Anything wrong with these servos?
  244. elevator mixing problem
  245. What could I trade in Futaba S3004BBs for Futaba high speeders for aileron
  246. Futaba digitals on 5 cell packs???
  247. Comp. radio 6ch question
  248. Value for older Airtronics gear.
  249. Do's and Dont's for Long Servo Leads?
  250. JR8103 TO JR421FOR BUDDY BOX???
