- Zhen Hua PCM-4CH Radio
- voided my warranty?
- JR 10 SX-- Programing rates to one switch
- Airtronics Or JR
- MPX Cockpit MM
- JR 10SX and Ultra stick programming
- New RX and TX
- Airtronics/Sanwa 92777 FM Rcvr
- New servos and equipment? Toledo show
- Interfearance Frustration
- RX repair? Or buy another.
- emcotec power box
- Mixing Ailerons and elevators
- Standard servo current draw.
- JR Faling apart
- does this exist (making sozbot)
- Disassembling A 9ZAP WCII
- HELP PROGRAMMABLE MIXERS 6XAs/T6XA
- new servo binding?
- 9CAP cancer warning
- Futaba 7C How do I change frequency
- Tail servo chatter
- Futaba to Airtronics Trainer Cord
- Servo Testing
- New 9c confusing me
- Rubber Duck Transmitter antenna
- Can I use a different radio on a reciever?
- futaba pcm 1024 fp-r129dp failure
- RX antenna monocoat interference?
- Servo torque convension?????
- The reliability factor- a study from Europe
- Help me spend my money!
- How Does RC Work? NEED HELP
- A Demon in my 9Z
- Servo reversing
- reciever effecincy vs. Rocket speed ????
- Is a 72 oz. torque CORELESS Servo stronger then a 99 oz torque standard servo?
- Servo reversing on Futaba S3151 digitals
- Futaba 127DF info request
- Dual Servo?
- precisely matching two 5934 servo's movement possible?
- Servo strength
- GWR-4P Receiver Hookup?
- airtronics spectra 7 pcm heli manual
- MPX Evo -any good for a scale -modeller ??
- 9 CAP, capable of throttle point curve programming?
- jr 9x or m.plex evo? need to make a choice
- WooHoo Royal Evo 12 showed up... !
- shaving Tower servos/Airtronics rec.
- PCM Receiver Problem
- Futaba 6XAS Reversing throttle feel to bottom of throw
- signal tap
- Looking for Hitec Focus 4 or 6
- conversion of servo torque?
- Royal Evo mix question
- Futaba 9CAP or JR 9X which one is better.
- Futaba 6EXA or Hitec Eclipse 7
- Airtronics Radiant Manual
- Source of Radio Glitches???
- jr 8103 question
- Help with JR X-347 needed
- Strength of signal and 3IM
- Newbie needs help selecting radio>>>>
- Li-po's for receiver and servos only.
- USB cable for Radio?
- |Ungret| VG6DR Mixes
- Expert servos
- 7C or XP6102
- HERE COMES THE FUTURE IN RC RADIOS
- SLOW GITTERS
- I lost my Futuba Fieldforce 6 manual.
- Futaba 9Zaps WCII Help!!
- Pcm Vs Fm?
- Horns Identified
- How low to you run your TX battery
- changing channels. Is it safe?
- Futaba/JR Transmitter With Airtronics Receiver?
- 2nd Radio?
- 4 Chan. AM RX
- GWS mini servos on a 40 sized plane?
- Jr10x heli version
- How do I activate my Elevators dual servos
- 8u question
- Futaba T6XA Problems
- GWS manuals?!? eg: Slow Stick and reciever
- Sheilded cable
- Futaba 7c vs. 9c ?
- Rx antena wire size?
- Pistol To Futaba 2ER?
- what is in a servo?
- I WANNA SMASH IT!!!!!!!!!!!!!
- Programming 7UAP PCM
- JR 388S No Elevator Trim
- IPD receiver questions
- Reciever Frequency Question
- Futaba 5101 Servo
- Hitec or Futaba RF schematic
- Acoms Servos
- R127DF Receiver - Unusual Behavior
- mode 4
- Hitec Trainer cord Pin Connections?
- RC Radio antenna (special application)
- Transmitter battery leads
- Idle up with 9c
- 9zap TX battery upgrade guestion
- FuntanS 40 ARF stripping 3004 servos issue
- Is PCM worth the extra $50
- Radio for SS with 4 wheel steering
- t6xa problem
- t6xa problem
- Servo plug ends?
- RX Pack Interference Question
- Crystals
- Futaba 9z full hardware reset
- Whats good heavy duty switch harness for 25% CAP?
- Extra 300s .60 Set up
- Servo arms and splines. Is 90 degrees possible?
- Aluminum Servo Arms
- multiple batteries
- V-Tail on a Super 7
- graupner servos
- JR 10SX
- FMA Extreme 5 Rx "dropout"
- Broke Futaba Receiver...
- adding a 7th channel to a 6 channel radio
- Which way for switch?
- Helicopter Gyro
- ko propo mars.......
- Airtronics / futaba
- airtronics vg6000/rd6000 comptuer interface?
- Slave on 7C or XP6102?
- Airtronics Rx & Tx Batteries
- Crystal Confusion.....
- hitec 555 maddness
- New Futaba 7C
- radio component compatability
- V-tail setup?
- Single vs. Dual Conversion Receivers
- Multiplex royal evo 12ch
- Futaba 9CAP or Airtronics Stylus
- Hitec Flash 5 for Hovercraft
- Possible Futaba 9CAP recall
- How can I hook two elevator servos together
- Noise difference between different JR NES-537 servos
- Rx antenna length?
- Hitec 5945x 5645 too much money difference for few torque more!
- Futaba T8UAF
- New Radio and Digital Servos...need help
- Glitches on 9CAP with 127DF (PPM mode)
- Futaba fp-T7UAP
- Is the Futaba 9C shift selectable?
- 3151 Futaba, why can't you use 6v?
- S&T SRX-M8 Receiver
- Heathkit GDA-19 Servos
- Extension cables
- the Best Radio (PCM version)
- Range Check / Output Transistor
- Heavy Duty Charge Leads?????
- T6XAS and Hitec feather Reciever?
- 50mhz radios
- Futaba 9151 and 9206
- JR CRYSTAL
- IPD or PCM with Gas planes?
- Emcotec Powerbox vs. Powerbus Pro
- 50 MHz Futaba Flight Pack?
- Expert Receiver and Molex connectors
- airtronics receiver---servos question
- Futaba 6xas Throttle Trim
- traxxas stampede servo
- Antenna routing in .46 custom plane
- JR leads on Futaba servos
- JR XP 8103 Data Sheets
- Eclipse 7 throttle cut
- True range of RC signal
- Harry Higley's Programming Futaba's 9CA
- AM or FM and what to use?
- Royal Evo
- Newbie Questions on Servos
- Hitec Eclipse NIB = No Ch 6 ?
- Different receivers??
- Tracker II website
- Replacement servo
- futaba and hitec digtal servos
- 9Z - AFR v Dual Rates
- 9z or 9c ???
- Giving the 4VF SkySport more channels?
- Second Radio Advice
- JR642
- Coiled ant. wire VS. straight
- JR642
- another receiver question
- Hitech digital servos
- How much can I draw through a 149DP?
- Expo
- TX freq change
- US 40 Done, ready to go..almost.. help
- Seeker ll 72 mHz receiver
- transmitter and receiver interchangeability
- Ace Oly 5 Radios and Receivers
- Older Futaba and Hitec FM transmitters
- trainer cord on 7cap
- 36MHZ Crystal useability in RX from USA?
- Questions regarding "MICROPRO 8000"
- Need help on Radio setup for 4 Star 60
- "7C" Can anyone help??
- Hitec 5945 vs 8611 difference ?
- Crow on 6 channels? (JR XP662)
- Futaba 9chp
- GWS Servos in a 60 any comments ?
- Mode 1 vs. Mode 2
- Battery for 8 servo setup?
- has anyone heard this?
- help-i cut my receiver antenna
- Hitec Aggressor CRX trim problem
- Radio / Servo experts please help..
- How are YOUR Hitec 56XX Servos doing?
- 8611 Voltage
- best esc for a m18
- JR 10x vs. JR XP8103
- JR D/C crystals
- 9C and Flaps
- please help with 7cap setup!!
- Kraft Radio - Sport Series - for sale
- multiplex royal evo 12 synth module?
- Royal Evo mixer set up
- futaba 9cap
- JR matchbox
- Servo Horn not going on...
- Futaba/Hitec servo connector
- futaba 9cap mix program for airbrake- flap and elevator
- HELP - Charging XMtr Battery
- SERVO REVERSERS
- 6 Servos on a 4.8 volt, 700mAh Sport Battery???
- kraft complete radio sys.
- Futaba/Airtronics Compadibility (VG600)
- Second Reciever Question
- JR EP652 RADIO W/ DIFF. RECEIVER
- Mode 2
- Will I get RF????
- New Dual Frequency System from Graupner
- Anyone up to a challenge for programming 8UAF?
- Can I use a JR receiver with a Futabe 9CAP
- Futaba 7CAP - problems after setting up timer
- JR 8103
- Where to get Red Anodized stick ends for Futaba Radios?
- Airtronics MX 3, Ko Propo EX 1, JR Racing XS 3 or Futaba 3 PDF-X
- Trouble programing 8U with Futaba Gyros
- Intresting Fact about the 9C
