PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. whip antenna
  2. JR x-378 radio problem
  3. Futaba Digital servo matching
  4. Do you lub your TX antenna?
  5. Beginner with a 9c
  6. Servo Gear Sets
  7. making a simple receiver
  8. Making a receiver
  9. SUCCESS WITH MULTIPLEX
  10. Futaba Skyport 6YG vs Futaba Skyport 6VA...
  11. battery power failure to Rx and servos
  12. JR8103
  13. Hi vs. Low Frequency
  14. Current draw?
  15. Good 3-channel pistol?
  16. What PPM-reciever
  17. GWS rx with a a 8uaf?
  18. JR8103: BEWARE: Possible failure mode with fuse
  19. how to adjust gyro gain on the 9C
  20. JR 8611
  21. Help adding 2nd aileron servo
  22. 9CAF
  23. Servo Lead Power Loss
  24. DuraTrax IntelliSpeed AutoSport Forward ESC
  25. No "Hi/Lo" with Hitec Rx???
  26. Airtronics RD8000 compatible w/fut/Hitc Rxs?
  27. changing xtals
  28. How are modules and receivers tuned to specific frequencies?
  29. anyone thought of lubricating your servos
  30. Futaba frequency changing module like Spectra?
  31. Can I test radio signal output?
  32. RADIO SOUTH is #1
  33. Extreme xtal swapping!
  34. Futaba 9C...sweet
  35. Futaba 8U Super radio with Hitec Receiver
  36. SITE FOR 9C WIRING DIAGRAM?
  37. JR™ 10-SX=II
  38. servo y spliter
  39. Where in the USA can one buy a Profi 4000 transmitter?
  40. The Futuba REBATE
  41. expert x-25 servos help
  42. Shop gave me JR378H rather than A - I fly planes!
  43. 9C prices
  44. hitec 4wing ?
  45. JR 8103 + GY502 questions....
  46. 50MHz 9C
  47. digatal servos for a 50 size heli
  48. what to buy Futaba vs Airtronix
  49. Airtronics RD8000 vs. Futaba 9c
  50. Futaba Dual Servo Reverser or Expert Electronics Reverser
  51. solar flares
  52. Need Radio
  53. MPX/Hitec Evo -v- 3030
  54. 6 meter antenna question
  55. Cheapass micro servos wanted.
  56. How do you choose a servo?
  57. 9206 Best price?
  58. Need radio I can grow with
  59. Help me buy servo's!!!!
  60. Futaba T6XA Trim Memory
  61. AM on the 9C
  62. Do I have enough batteries?
  63. Multiplex servo timing.
  64. Gyro for maintain airplanes altitude
  65. Which servos
  66. 9C or 6X ??
  67. FMA Direct Co-Pilot, How does it works?
  68. How much more juice do digital servos use vs analog servos?
  69. hitec superslim RX
  70. Futaba 9451s?
  71. How in the world did this happen??? No one can figure it out!
  72. CS-234 Jumbo servo
  73. Quantum 8 Sub Micro Receiver
  74. Servo SPAZ!
  75. Flight Packs
  76. possible radio channel change?
  77. Using Hitec SP-1010 ESC for a speed 400 7.2v motor
  78. Futaba Crystal/Rx Question
  79. Reversing a Hitec Servo
  80. Transmitter layout
  81. JR 10sx ?'s ?'s
  82. Frequency Choice
  83. PCM?
  84. JR DS-8411 in higher quantities needed
  85. Are servos interchangeable?
  86. Futaba 9C Gimbals
  87. To PCM or to not PCM
  88. 9CAP vs 9CAF
  89. Airtronics new 94758Z Digital Servo Comparison
  90. Futaba S9001 Coreless or Hitec HS-5475HB Digitals?
  91. Hitec servos in 1/4 scale giles, but which ones?
  92. Have you ever been/seen frequency shot down?
  93. how 2 install twin batts
  94. Graupner Servos/Futaba Gear
  95. Hitec 475HB
  96. will reciever battery be OK 5 servos
  97. Glitch problems on only 1 channel?
  98. BERG 5 or FMA M5
  99. VQ P-38 flap servos
  100. programming 9c for dual ailerons and dual elevators.
  101. Flight Pack or 4CH radio?
  102. attack-4 battery power
  103. RANGE PROBLEM?
  104. eclipse heli pilots
  105. can i trust hitech 700 servos on D.P edge? - please help
  106. 9c vs 8u worth changing
  107. Will JR sticks fit my Futaba 9c?
  108. PCM v PPM v HRS
  109. Buy now or wait
  110. Watch your step with this advertising!
  111. laser 6
  112. Would this work??
  113. futaba with hitec
  114. Channel 21 - Is this to be avoided?
  115. JR vs Other transimitter /receivers / servos ?
  116. 1/4" tall micro servos... can't find info
  117. Reversing opposing Flap servos
  118. Need a new (first) radio. Questions.
  119. 9C & 127DF RX
  120. Power?
  121. 9C a good beginner radio?
  122. Mode II to Mode I
  123. Best Futaba 9C Price
  124. Multiplex help with glitching
  125. delete.
  126. Looking for Fast 900Mhz Serial Telemetry Sugestions
  127. 9Z WC-2 replacement battery?
  128. 9C TX Battery
  129. JR Buddy Box Help
  130. Pistol Gripo FM 3 channel - Futaba 3PDF-X or Airtronics MX3, which one is the best?
  131. Help, 9C won't take my info
  132. Testing TX XTAL
  133. Help with extremely weird range check
  134. Servo Stress..cant decide..
  135. NiCad vs. NiMh??
  136. AM & FM Same channel interfearance???
  137. Multiplex Receivers IPD
  138. Memory
  139. Cheapest place to get a 9C
  140. PPM control system info needed
  141. receiver help
  142. single or dual conversion
  143. Multiplex Mixing HEEEELP
  144. Mouse-proofing the 8411
  145. What gauge wire do the Hitec HS-59**MG come with?
  146. Servo Brands
  147. What is the difference between a s3004 an a s3001?
  148. HITEC 605BB servos chatter...
  149. Radio equipment in store bought rc vehicles?
  150. Best place to buy 10X
  151. Wich radio Futaba MEGATECH3PK or KO PROPO HELIOS EX10
  152. Futaba 9c compatabilty with vintage 129DP
  153. Futaba 9451s?
  154. Miracle Y won't work on 6 volts. Why?
  155. Futaba s3010...nicads only??
  156. Thoughts on JR X-378?
  157. basic receiver set up
  158. Cost of radios
  159. Futaba 9C throttle curve
  160. JR 8103 Replacement capabilities?
  161. Hitec Eclipse 7 and Ultrastick quad-flap...
  162. 6EXA
  163. programming failsafe?
  164. Change Cox 3-1 machine frequency
  165. Futaba s3106 Submicro
  166. need help with JR 10x set up for flaps
  167. Miracle Y and Hitec 5625
  168. need tx crystal for megatech radio...where?
  169. I'm getting bad glitching
  170. Servo Trim & Centering ?'s
  171. New Futaba 9C Synth Module
  172. JR servos
  173. z
  174. Expert servo to Jr servo end wiring diagram?
  175. Smoother gimbal tops for super 8?
  176. Futaba S3305 Servo
  177. 3PK / M8 vs MX3 / 3PDF
  178. crystals for ACE receivers?
  179. Futaba 8U mixing problem
  180. JR Radios: Carry a spare fuse....
  181. Servo Help Please!
  182. Switching crystals/channels at the field? a no-no?
  183. Can 7U Super do as much as an 8U?
  184. GWS servos-Sport flying-go or no?
  185. Manual for Graupner MC16/20
  186. Graupner C-507
  187. sw warning on JR PCM9X
  188. Vintage RC equipment
  189. twin receiver and battery setup/ Help
  190. airtronics HELP
  191. Dual Elev/Rudder Servos
  192. Need help
  193. in flight ONLY alerion servoes not stable
  194. New JR XS3 System question
  195. crystal exchange 5 different jr and 2 diff gws
  196. Masking the receiver crystal
  197. 9c timer beep too quiet...
  198. High and Low-Band ? Why ?
  199. Cheap eBay battery packs... good or bad?
  200. Are S148s outdated? maybe not?
  201. Charging Futaba TX at the field
  202. Control Horn Mounting with Cap Screws
  203. Voltwatch any good for a 6 volt battery
  204. FP-R149DP Micro RX
  205. Need specs on the FMA Direct S60 Servo
  206. can the eclipse 7 be used to do aerobatics on aCCPM heli?
  207. Airtronics receiver crystals
  208. Rx Packs
  209. Which Radio To Buy??
  210. RX Antenna Placement
  211. Making your own extensions
  212. RX /Servo Battery Voltage and Updates
  213. Bug on JR X 8103
  214. When will there be a new update for the 9c
  215. HITEC or AIRTRONICS
  216. 6EXA Charger
  217. New to computer radios.
  218. Antenna length for JR PCM receiver
  219. PCM or PPM for Gasser
  220. r/c system preferences
  221. Should we begin to look into new radio technology for RC use?
  222. Interfacing between Ftuaba / JR and a pc's paralle port
  223. can't find the servo!!!
  224. how to set up ailerons for 2 servos
  225. IS THIS A GOOD TRANSMITTER? CIRRUS RC-5JKP PCM
  226. jr xp652 instructions?????
  227. Hitec feather with futaba transmitter?
  228. What could be the cause?
  229. Jr servo`s
  230. Two planes, One Non-computer Tx
  231. What channel for second Transmitter?
  232. 8411 Blue Dot
  233. Futuba T6XA v. T6XH
  234. AM receiver won't drive JR servo
  235. McDaniel Glo Driver Jitters
  236. Trade JR #48 for JR #54 rx crystal
  237. how long does your futaba 9cap battery last?
  238. Who makes a great long lasting battery for the Futaba 9Z WCII?
  239. TX Encoder Resolution.
  240. New Transmitter
  241. PCM?
  242. Aileron Servo problem
  243. help me with this intermitant servo problem
  244. kraft servos 4.8/6v torque
  245. New JR 8611 Digital Servo
  246. UK-US compatability
  247. Help with Futaba Receiver!!
  248. Nicad or NIMh
  249. Twin Hitec HS-5125 for elevators
  250. Need help now... maiden flight???
