PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. How do I get a hitec radio serviced?
  2. JR 610 reciever
  3. Coreless Servos
  4. Horrible Range - Blame Stock RTR Radio?
  5. xp8103 promo? Can it upgrade to PCM later?
  6. What is a BEL ESC
  7. Tower wiring woes.
  8. programming spoileron on JR 10X
  9. futaba receivers
  10. Cleaning Tx?
  11. JR 8103 and the Co-Pilot
  12. How to determine low/high on unmarked reciever?
  13. connecting an old motor to a transmitter
  14. Flap Servo's--What Kind?
  15. autopilots
  16. hitec servos.
  17. Why isnt my Futaba working with Jr receiver?
  18. Spastic 605 Hitec
  19. Radio Charger Question
  20. throttle servo problem
  21. Problem with Airtronix vg400 radio tx
  22. GOIn CRazy w/Futaba 6xs and Corona120
  23. JR XP662
  24. Servo- junk or is it me?
  25. Does Monokote Chrome interfere with radio reception??
  26. QPCM
  27. Are Futaba J type connectors compatible with Jr receivers?
  28. JR 8103 FM Air Tx -> how HOT is your module?
  29. Futaba 9450/9451 difference?
  30. FMA 5 channel receiver
  31. Profi 4000 Programming
  32. HAL Autopilot experience
  33. JR9X English Manual LQQK inside
  34. ff9 VS. MX-22
  35. servo twitchs?
  36. RX antenna question
  37. Servo arm cross reference
  38. Throttle cut on a FF9CHP help!
  39. Throttle servo jittering??
  40. Futaba 6XAPS Dual Elevators?
  41. Using two onboard rx packs
  42. JR Nes 8001 servo..??
  43. Crow/Butterfly
  44. Hanger 9 Extra Easy JR Servo/Radio Problems
  45. WHAT RADIO CAUSED THE MOST CRASHES
  46. My flaps think they're ailerons !!
  47. 72MHz Low, 72MHz High????
  48. radio suggestion for kadet senior arf
  49. Have any of you used this switch?
  50. Hitec Eclipse 7
  51. SERVO repair as well as Rx repair after crash?
  52. Servo Case Demensions ----Are They The Same??
  53. eclipse 7 programming
  54. Berg-5*DSP Receiver with Digital Signal Processing
  55. FMA FS5 – Is it a 5 or a 4 channel receiver?
  56. Rciever Repair
  57. FP-T6FG/K
  58. Great factory service from Futaba...and a bonus!
  59. Which channel --> which servo function
  60. Hi Tec Eclipse 7
  61. What do I need to use the same Radio w/another airplane?
  62. How do I cycle my transmitter batteries?
  63. JR 10 SX Transmitter install Ham Module
  64. MPI servos arms, what else do they fit?
  65. JR XP652 BATTERY CONNECTOR
  66. JR 662 Heli or Plane
  67. JR 8103 and 10X battry issue. Please help.
  68. FG series charger/battery
  69. Servo extenction
  70. FM receiver
  71. need radio advice
  72. Futaba FX18 - throttle/pitch curve
  73. Receiver Problem - Uncontrolled Servo movement
  74. HEY SERVO MANUFACTURERS - Servo lead location!!!!
  75. Does radio range differ between systems?
  76. Stacking batteries ?
  77. Assymetric here also.
  78. Sanwa RD6000Super Setup
  79. what servo's would you use?
  80. Programmable Transmitters ???
  81. Hitec Digital recommendations
  82. asymmetric travel on JR 537 servo
  83. Servo arm compatibility?
  84. Need some advice on installing hayes whip antenna.
  85. Polk's Hobbies Customer Service
  86. Trainer switch
  87. how much torque
  88. rx tx compatiable
  89. Orbit system value
  90. Futaba 3PJS PCM crystals ??
  91. what is a transmitter module in futaba?
  92. Can I use a Futaba radio with Jr receiver?
  93. Transmitter Tray
  94. How about a cheesy rudder servo for excitement?
  95. Opinions
  96. Servo reverser problem
  97. Wide ban AM radio
  98. Anyone post pic of Futaba 6yf please?
  99. Shift mod for GWR-4P Rx
  100. Futaba 9CAP in Europe?
  101. JR Receivers
  102. Servo Extensions limit
  103. Royal Evo Scanner Compatibility
  104. Damaged RX Crystal?
  105. Odd radio hit after 92 flights on gasser... any idea's?
  106. Has anyone used these hi torque metal gear servos (seen on ebay)
  107. Radio interference
  108. JR 631 or Hitec Eclipse 7? Advice Please
  109. Trade JR #48 RX crystal for JR #54
  110. Tracker II Elevator Problems
  111. servo humming???
  112. Range check question
  113. A tip for setting up Hitec digital servos
  114. Futaba 9c owners ... plz help.
  115. Spreadsheet for recording Futaba 9C programming is available
  116. What to Do
  117. Strange servo ext?
  118. servo data
  119. Hi-tec servo user's info please
  120. Which Futaba 6 Channel?
  121. Can I use a 7.2v battery with reciever and servos?
  122. Futaba 128 servo
  123. Voltage regulators
  124. Where to Buy RC/Sailpane in Miami
  125. Servo leads interference
  126. Servo leads interference
  127. 6axs flaps programing ?
  128. Duel Recievrs
  129. *newbie* Flight pacs as expensive as a new radio??
  130. receiver/ignition/battereys interfearance on petrols help
  131. kadet senior arf question
  132. Multiplex evo 12 or Jr 10x
  133. JR378 buddy question.
  134. FUTABA PCM RADIOS
  135. battery in a channel
  136. RD6000 super
  137. Old Futaba Transmitter Plus new JR NER 549 reciver
  138. Crash caused by possible inteference from ignition battery?
  139. 4 Aileron Servo Set-up
  140. Shipping Charges???!!!
  141. First programmable radio. JR XP662
  142. Should I buy an 8103?
  143. Airtronics 92777 Receiver
  144. JR Radio Compatibility
  145. PC to servo interface
  146. Screwy battery pack causes twitching?
  147. 7UAP TX module to be used on 9ZAP
  148. Old Futaba FP-7FGH helicopter radio for use with airplane
  149. the perfect reciever? FMA Direct FS5A?
  150. Diode Bypass For Futaba T6EXA Please
  151. Servos stop moving intermittantly- Update...
  152. Radio interference/ power
  153. Which Receiver?
  154. Two servos for elevator
  155. Stalled Servo (s)
  156. Ko EX11 presto
  157. New JR Servo!!!!! WOW!
  158. Dual Receivers
  159. Futaba Transmitter Questions
  160. Less expensive crystals coming
  161. futaba 3PK dummie crystal question
  162. Cirrus again.....
  163. Servo Torque
  164. Hitech Flash 4 vs Flash 5
  165. reciever for a futaba t8uaf?
  166. Futaba - to - JR
  167. Futaba 4VF trainer switch?
  168. Ignition Switch with built in Charge Jack & LIGHT
  169. GRAUPNER MC 24-ENGLISH MANUAL
  170. Gear set for JR3301
  171. Looking for a new Futaba 9303 servo
  172. Superstar select Bad Servo?
  173. 6 channel TXs and 4 channel RXs
  174. need a charger
  175. Futaba 6Xas Problems?
  176. Information of very old rc equipment
  177. Lithium Polymers
  178. Problem with EPA and aribrakes in T9CP
  179. Airtronice ESC help
  180. Thanks SERVOCITY.COM
  181. 9C Snap Roll Switch
  182. General Radio Freq/crystal question.
  183. Did this hurt my radio gear?
  184. Futaba 4vf
  185. UK Mail Order?
  186. Is a futaba conquest fp7nfk anygood?
  187. Any work on a Tracker III?
  188. Old Receiver and BEC PLEASE HELP!
  189. radio help
  190. Hitec Feather RX Antenna
  191. Hitec HS-500 details please
  192. lesson learned
  193. Charging through Cermark DSC Switch?
  194. DIGITAL SERVOS?
  195. How to program split elevator servos on JR 8103?
  196. Radio Set-up fot Giant Scale
  197. Futaba 9CAF or 9CAP??
  198. Dual Batterey Pack connection
  199. base load antenas
  200. Does any radio handle split elevators?
  201. Is anybody using the SpringAir radio tray?
  202. Which is better between JR PCM9X and Futaba 9CHP?
  203. RECEIVER AND BATTERY TOGETHER?
  204. Mixing with Futaba FF8
  205. FM or PCM Rx Help
  206. AM radios still usable?
  207. beginner looking for a sugg on what controler to get?
  208. JR xf631 question
  209. MOVED: RC Universe
  210. RD6000 Flap Switch Conversion ????
  211. Hitec coreless or hitec digital?
  212. How many channels really?
  213. JR 8411 v 8425
  214. Discontinued Futaba radios...
  215. Setting idle cut off and other
  216. Charging 50mah Rx pack?
  217. New Futaba 12 channel
  218. Futaba 6XAs and spoilerons
  219. Crystal swapping
  220. 2 servos
  221. How to set up dual rudder servos, Push-Pull
  222. Difference in receivers
  223. Can I use digital servos?
  224. Futaba 7UAP radio, what is it worth?
  225. Need RF Module for FP-T3EGX
  226. interchange
  227. stripped screw: removing horns from servos?
  228. Spoiler / elevator mixing on Futaba 6xa
  229. 1-1/4" servo arms?
  230. PCM or FM, please help...
  231. Standard servos
  232. 9CAP battery
  233. rc auto pilots
  234. HiTech svo reverse
  235. Futaba T6EXA Diode Bypass
  236. OLd A.M. FP-T3EGX Boat XMTR
  237. Ace Albin super regenerative receiver schematic
  238. 9CAF vs 9CAH
  239. Comparison of MC-12, Multiplex Pico & Futaba FC-16 & FX-18
  240. servo selection
  241. Jr 622 & quad flaps...
  242. Futaba DA flaperon not working
  243. AM vs FM frequency question
  244. Which radio?
  245. Exchanging new crystals for unwanted old ones
  246. Servo specs
  247. Switches that fail in the "on" position?
  248. Tower really Futaba??
  249. Aerial Length for a Futaba 138DF PPM 8Ch Rx
  250. Graupner MC 22
