PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Eclipse 7 Question
  2. Hitec/Futaba trainer cord problems
  3. Interference
  4. What's an Airtronics "Z" connector?
  5. Ace Nautical comander crystal problems
  6. 3 or 4 channel....what am I missing
  7. Multiplex Profi 4000 Question
  8. how to connect 2 servo to elevtor
  9. help w/ radio/servo
  10. Help with Futaba trainer cord !!
  11. Combining 2 channels
  12. needed, servo class 101
  13. Advice please! Airtronics Championship Radio
  14. Nicad vs Nimh? Which is better?
  15. Newbie needs help
  16. IS it hard to change over a mode 1 radio
  17. How do you program your "Fail Safe"?
  18. will pcm fix my problem?
  19. Has anyone done this (adding missing channels)?
  20. Futaba receiver w/old style Airtronics servos....
  21. JR PCM9X
  22. PPM 6/7 Channel Receiver
  23. Futaba 6XAS
  24. HiTec Eclipse Transmitter Battery - Fast Drain
  25. What kind of batteries do you like?
  26. Need help to find the smallest full range receiver?
  27. Wierd servo glitch, Any Ideas???
  28. hitec neon
  29. Futaba low band or hi band ?
  30. RADIO CASE
  31. SAE to Metric servo spec conversions
  32. JR servo specs
  33. Txmtr vs. Recvr compatibility?
  34. Messed up servo
  35. Changing Tx module for Pcm 1024z
  36. 9C and Snap Roll programming
  37. Idea for a power board for large scale!!!
  38. Y-connector or Y-harness on GP 202 ARF?
  39. crystal exchange
  40. hitec challenger 720
  41. Channel change
  42. How often do you 3D guys replace metal gears?
  43. Range Checks...
  44. Where to plug ESC into receiver?
  45. Shift selectable
  46. Lose memory when you remove batteries to cycle?
  47. Which linkage "stars" should I use?
  48. Flaperon or Ail-Dif for 9c set-up??
  49. Has any one bought servos from this guy?
  50. Hitec Servo gone bad
  51. futaba 6exa
  52. Setting up dual servos
  53. Futaba Servo connectors
  54. HiTec Super-Slim Supreme, Good or Bad?
  55. 12 volt receiver
  56. Airtronics unidentified radio... please help!
  57. Digital servo buzz
  58. Can I make this work?
  59. Airtronics RD6000, poor range?
  60. JR 347 Setup problem
  61. Futaba transmitter repair
  62. Futaba radio-JR rcvr
  63. 8103 or 9c
  64. JR XS3 channels ? Please help
  65. futaba home page states that all of their fm radios
  66. Hitec E7
  67. Old cirrus radio
  68. Will this work?
  69. You can link car products directly to our product guide and other posts now!
  70. Learning to Mix on Futaba 9CAP
  71. Hi Tech Flash 5
  72. Small electronic ignition gas engine with servo leads?
  73. Dual rates set up
  74. Older Airtronics Radio
  75. learning the 9C
  76. Are Hitec and Futaba buddy cord compatible??
  77. receiver replacement
  78. Futaba 6EXA or 6XAS or Something else??
  79. JR 8103 FM questions (need help please)
  80. Where does everyone get the nifty velcro setups
  81. Futaba Receiver Repair & Servo Connectors
  82. 9C Flaperon question
  83. jr xs3
  84. tower cs-65 high torque servo
  85. Switch with Battery Charge Lead
  86. Hitec Eclipse QPCM
  87. 128 Ultrapac DIP switches?
  88. ? concerning tower servos
  89. How do you tell if a MG servo needs new gears (HS5945/DS9411)?
  90. I won't be bothering you anymore...
  91. Futaba 9C programmimg/help
  92. I got it! I got it! I got it!
  93. Help me spend my money!!
  94. New FMA computer friendly receivers- looking for field info
  95. Cutting servo leads
  96. HiTech Focus 6 ?
  97. Can someone help this person out?
  98. What happened to the Royal Evo CD manual?
  99. Antenna Length of Hitec RCD 3500 Receiver?
  100. radio
  101. Royal Evo Soft Update v. 1.26
  102. Manual for JR x-347 radio
  103. leave Tx on with ant. down..why does this matter??
  104. MPI charge Switches?
  105. Lowest price on the web to buy JR radios?
  106. Exponential Question
  107. 8UAP, 7UAP, 8UAPS... quick question...
  108. airtronics rd 8000 CHARGING
  109. Kyosho MINI Z HELP!!!
  110. 6v with Airtronics 94322 servos??
  111. Choosing the right ESC for my motor?
  112. 6V twiching on control surfaces
  113. Throttle jumps open when touched.
  114. Radio frequency choice?
  115. Futaba J type Plugs
  116. Help Cirrus Cs60 Discontinued
  117. Do you have to use all one brand radio parts?
  118. Supra Retracts
  119. voltmeter question
  120. Differential Problem....
  121. 9C screen
  122. mode 3 ccpm with hitec E7
  123. FP R116 FB Receiver
  124. Weird screen on Royal Evo when turning it off
  125. Beginner Radio
  126. rx comapibility
  127. JR DS811 Digital servos
  128. what setup are all of the different modes in?
  129. Hitec round aluminum serovo arms
  130. Converting 72 to 36 Mhz - going to Australia
  131. Joystick controller
  132. Cirrus Servos
  133. 4.8 volt battery with "G" plug!
  134. Swapping Tx batteries
  135. Hitec digitials- the saga continues.....
  136. Setting up Flaps on a Futaba 9C
  137. Aaahhhh...the mad robot face....
  138. hitec servos - how good are they (700)
  139. Help settle Hitec aurgument
  140. Need some antenna help please.
  141. Fried my Futaba!
  142. JR XP783 radio - need your opinion please.
  143. Can any other TX buddy with JR378 ?
  144. Futaba FF6 with R136F RX
  145. Where can I get cheap micro servos.
  146. 6EXA or VG6000 or used Radio?
  147. PCM or not????
  148. beginner questions
  149. Wiring a J-Plug Battery
  150. Adapting Futaba Skyport 6 for sailplane use?
  151. Servo linkage
  152. How to use a capacitor in a long servo lead
  153. Radio nicads
  154. 6exa
  155. lookin for new radio equipment
  156. nasty glitch
  157. Can I use two Battery packs together
  158. jr 642 centering problems
  159. Jr 8103
  160. chanel 8 on 8uaf?
  161. Kraft 2ch radio?
  162. JR 8231 servo chatter
  163. "Best Way" to set up servo throws
  164. Expert SL300 for 40 size 3d plane?
  165. Futaba - Fp T T7uap ? How To Change Models # S
  166. 3 Questions
  167. What does it mean - "Twisting Servo Leads"
  168. Hitec Laser 4
  169. Having problems with homemade Servo Extensions
  170. multiplex profi mc 3010 vs hitec flash 4
  171. HiTec 422 Servo Arm Screw
  172. JR Mixing for flaps problem
  173. Futaba 6YG help
  174. Servo Shutdown
  175. Setting up throttle cut 9C
  176. JR 8103 help please
  177. JR 8103 or JR 10sx
  178. Cracked servos - A Near-Crash Experience.
  179. Dual reciever setup. Do they have to be the same kind?
  180. BEWARE! Futaba 9C Tx - Mix offsets changing in flight
  181. FP-7UAP Super motor trim
  182. What frequencies can be used in USA?
  183. what servos to buy
  184. newbie is confused
  185. :o
  186. Can I use the interface cord from my Real Flt G2 as a buddy cord?
  187. JR 8103 w/Digital trims
  188. 8UAP vs 9CHP
  189. Multoplex EVO 9 Chan Tx.
  190. Futaba S3003 servo mounting
  191. newbie question
  192. FP-7uap engine trim
  193. Hitec HS5735MG Info.
  194. 9CAP and Bad Solder Joints. Help please!
  195. JR Radio
  196. ACOMS Techniplus 27MHz RX Antenna . .
  197. Beginner getting into RC planes
  198. Switch Designation For Dual Rates
  199. Hitec "Karbonite" servo's
  200. Jr 9x?
  201. JR radio
  202. Manual for Futabe R136F Receiver
  203. Who sells 4.8v regulators
  204. Airtonics charger with Futaba plug battery?
  205. NiMH batteri charge amps
  206. Need some info for JR 642 radio
  207. servo reverser question.....
  208. Where to buying a crystal for hitec focus 4?
  209. Jrf400
  210. Help
  211. Where to buy?
  212. dig with analog servos
  213. Another newbie crystal question.
  214. Polk Seeker II rcvr - single conversion?
  215. Airtronics and problems
  216. Help with Trainer Switch on Futaba 6VH
  217. 4 channel transmitter to 5 channel Reciever?
  218. With shift change TX do RX crystals have to be same brand?
  219. Radio Channel
  220. futaba pa-2 with airtronics rd6000?
  221. Best price for a HiTec flight Kit? Suggestions?
  222. Will airtronics servos work with Hitec plug RX
  223. Futaba Rx - high or low??
  224. Looking for cased or uncased .19 ounce servo?
  225. Servo Life
  226. Servo Ticks about every 30 seconds?
  227. hello you
  228. 9202 why???
  229. Single stick radios
  230. Dual vs Single conversion JR 945 vs 955
  231. Wierd Tramission/Reception Problems with Futaba 6x Super Radio
  232. Futaba radio/antenna problem
  233. seeker reciever polk hobbies
  234. Airtronics Infinity 660
  235. max # servos one receiver?
  236. do it yourself tuning?
  237. jr ..hitec compatibility
  238. eBay Idiots & Airtronics RX Active Channels
  239. Extra Credit Question for JR gurus
  240. cockpit mm heli mixes
  241. Hitec Servo Programmer
  242. Newbie radio JR X-378 or XP8103 ?
  243. T6xa and U-Can-Do
  244. Midair interference hits
  245. Skysport with 9C as Master......
  246. new radio
  247. Determing frequency of older JR radio
  248. JR 10X or JR8103
  249. xmitter repair cost
  250. Idea for more reliable switch
