PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. futaba programming
  2. Replacement Lego RC Transmitter
  3. Redcat rc car wont go forward
  4. futaba fu-t7auf programming
  5. Castle Creations 20Amp BEC
  6. Advancing from RTF to TxR & ARF - RC Simpleton
  7. My Lovingly Mini Drone Hubsan X4 RC Quadcopter With 2MP Camera
  8. Bavarian Demon Cortex Gyro for airplanes
  9. Hobby King 2.4 JR Recivers
  10. Futaba 18MZ updates?
  11. Futaba 7c reversed battery polarity won't work now
  12. Crimping your own servo wires
  13. Stock HPI Steering Servo Burned up in 2 minutes?
  14. My Sweet Elfish--WLtoys V915 RC Helicopter RTF
  15. Looking into new radio. Need opinions on Futaba 10JA and 10CAG specifically
  16. Futaba 9Ch 72mz - Flaperon Question
  17. AR9110 port question
  18. ServoCity Motor Controllers Blowing...why?
  19. Traxxas Revo 2.5r
  20. JR SX600 where can i find replacement tx rx battery packs for this radio
  21. Hitec 7975 servo: swap gears and case for MG?
  22. Flysky fs gt2 problem
  23. Spektrum dx2e problem
  24. Spektrum Question
  25. Servo moving without input
  26. Spektrum DX6i brown out issues.
  27. Corona 2.4ghz shooting Corona 2.4ghz down!
  28. Servo goes to extreme when radio turned on.
  29. Servo plug safety clips
  30. Futaba 18mz - transmitter output wattage
  31. How to configure to run dual brushless motors, ESC's on separate channels
  32. HPI TX-2 Info
  33. Servo Power Distribution Board
  34. Transmitter update help
  35. Futaba T6J or 6EX
  36. Futaba transmitter 6j
  37. any 2.4Ghz radio and receiver
  38. DX 9 switch for throttle safe
  39. transmitter set up using a Fautabs j6
  40. OrangeRX 3-Axis Flight Stabilizer V3 HELP
  41. Hitec BRUSHLESS servos
  42. Spektrum DX 7 Programming
  43. Motor will not run just twitch....
  44. Kraft Radios
  45. Be Alert - shorted servo cost me a receiver and battery
  46. TacTic t-40 sevro
  47. Anyone have any good information on this radio? Controlaire
  48. Need some advice on transmitter, etc
  49. 14SG owners please read
  50. Hitec HS645MG Servos in Airplanes
  51. perplexing problem
  52. flap servo reversing
  53. Long, Steel pushrods - Problem for modern 2.4gHz radios?
  54. Futaba 12FG Programming dual Elivators and Flaperon functions
  55. Futaba MSA-10
  56. Futaba R7008SB Receiver mode changing problem.
  57. Hitec Aurora 9
  58. New DX6 help
  59. FT-T6FG 6 channel
  60. 3.5CH Rx Receiver board with built-in brushed ESC Basic
  61. Is this Rx SLT
  62. Spektrum DX6i and AR400 problem
  63. Any Issues between Futaba 6014FS vs 6014HS Receivers
  64. Futaba T10 3 position Switch Programing
  65. Ps3 transmitter build help
  66. Turnigy Yellow Box, Batteries ?
  67. New build electronics question
  68. Throttle servo location? What's too close
  69. HItech HS5645MG servos ???
  70. HK-T6A V2 + T6 Config settup for tank! Help!
  71. 2.4 GHZ Transmitter question
  72. vintage. pro line receiver with old servos ...how much volts?
  73. Are receivers made for 40mhz able to run with a 75 mhz cristall?
  74. Parkzone Delta Ray
  75. Old RC car with msc
  76. Dynam 72Mzh radio NE-KO 4 receiver needs crystal
  77. Rxcel Opto Kill switch
  78. Switch harness quality
  79. Can't find an Aurora 9X in Miami
  80. nRF24l01+PA+LNA range and performance
  81. Want Futaba PCM 512 RX
  82. Servo Problem
  83. What size esc for 380 boat motor
  84. ARE ALL ESC's CAPABLE OF FORWARD AND REVERSE
  85. Trying to Set-up Flaps for the first time. HELP !
  86. Servo Advice
  87. Futaba T8FG super display screen has gone!
  88. Hitec Flash 5 throttle trim not working.
  89. Hitec Flash 5 throttle trim not working.
  90. Dual Rate to limit throttle on ESC?
  91. 2.4GHz Telemetry feedback question
  92. futaba 9 chp mixing problem
  93. servo s killed
  94. switch harness and wire length
  95. Futaba brushless servos - anybody using them?
  96. Need help with Futaba 14SG channel setup
  97. New Futaba 14SG Ver 4.0 software released
  98. New student pilot, no PC knowledge - training setup?
  99. Futaba 8u Super low voltage
  100. Turnigy 9x antenna
  101. Airtronicss manual
  102. Radio set up for dual rates need help manual seems to be opposite of the norm
  103. A n00by question about a radio for my 1st nitro truck
  104. JR 12X MV Abnormality
  105. 2.4 and AR6100
  106. ReBorn Again Beginner - Radios?
  107. Can I change my Crystal 72 Mhz
  108. Esc 50A Hobby King not working with Futaba 7C
  109. Hitec Eclipse Pro 7 Problems
  110. Heavy Duty ? Why not try all metal case servo.
  111. 14 sg duel rates on twin servos
  112. reversing non programable servo
  113. Do you think what's the most important when you choose a servo for your models?
  114. Kingmax brushless servo
  115. Futaba Crystals in Hitec 72mz Receivers?
  116. Futaba 14SG
  117. Futaba 8FG - Labeling switches and knobs
  118. What would you do ?
  119. Turnegy 9xr good or bad
  120. Servo ideas
  121. 14SG Malcom Holts book on Amazon!I have it but now can't accesss it!!
  122. Please Help!
  123. Fatubu 4kpsr dual steering servos!?
  124. Where have all the 72mhz RX's gone?
  125. FrSky suppliers?
  126. FrSky TFR8SB Faast Receivers and 14mz
  127. Problem with FrySky TFR6
  128. Help required with a waggling tail on my KDS 450sd
  129. doubts servant Beast 60E
  130. airtronics rx500 reciever antenna broken
  131. Futba 12FG - triple rate setup help
  132. Walkera Wk-2402 Blank Screen Problem Please Help
  133. dx 18 JR 370A Gyro Setup
  134. Strange issue with Hitec 645MG servos on a dual pull-pull setup, Rudder and Elevator.
  135. Switches
  136. Flysky fs it4 telemetry and sensor placement HELP
  137. Futaba 8fg charging issue
  138. 2.4 JR 9303 Replacement Battery Concern
  139. Aloft Hobbies - A great company to buy from - FrSky - top knotch products
  140. Running tx off 12v wall charger.
  141. Proper gauge for RX battery charging
  142. High Torque Servo 23 NMs
  143. Carbon Z servo problems
  144. Trainer: Spektrum DX8 master with Futaba 7CAP slave
  145. TQ receiver to to TQ Radio?
  146. Servo "waving"
  147. Power HD 1214TH Servo Using alot of current
  148. Speed Controlls
  149. DX6i to DX6i "Buddy Box" ? How to please
  150. GT Power LED LIGHTS (Blinkers dont work)
  151. flybarless receiver
  152. interested in developing combination receiver/servo for rc application
  153. Park flyer receivers.
  154. Tactic 625 Receiver
  155. Where can I find A "GOOD" Screen Protector
  156. FrSky Taranus and companion software
  157. DX6i / Parkzone Radian Pro Motor Problem
  158. Is Airtronics pulling out of the RC market?
  159. servo voltage question
  160. Gear servo cycling
  161. orange tx
  162. Aileron and rudder trim is reversed on T8FG
  163. 18MZ Question for Futaba Gurus
  164. JR RG831B Receiver Weirdness
  165. We modify Hitec servos for you!
  166. DX-18 question
  167. WFLY TX module antenna
  168. Dual receivers in a 1/3 scale airplane
  169. servo with lots of torque cheap ????
  170. What type of battery setup is required?
  171. How to find an equivalent servo
  172. Why satellite receivers?
  173. Help! Need replacement remote for out of production r/c
  174. broken antenna help
  175. Data log
  176. Receiver,ESC, and servo problem
  177. Looking for advice on Auto pilots
  178. Jr XG14 transmitter programming pls help
  179. DX6i
  180. New Full Range"Anylink"
  181. FUTABA GYA430 -vs- JR G370A Gyro Comparisons
  182. Binding DX6i to Ares Gamma 370
  183. Servos operate off servo Tester But Only One Operates When Pluged into a Reciever
  184. need help , i can control my rc
  185. FS TH9X programing 3 way switch.
  186. Back in the hobby after 20 years, School me on the new radios please?
  187. Which replacement TX batteries?
  188. Need help with retract servo
  189. AVCS vs NORMAL Gyro Mode for Airplane Rudder Control on Take Offs
  190. hd servoes
  191. FrSky TFR6 question
  192. im back !
  193. Mini-HOWTO: Futaba Student-Trainer wireless setup
  194. Airtronics RDS8000 Parts Help
  195. Hobbyking tough electric servo reversimg
  196. Registering dx7
  197. Anyone use a JR 2.4GHz DMSS module (TG2.4XP)? Poor fitting on TXs.
  198. Tactic "Fuill Range Anylink" (pardon me....I guess!!!!!!)
  199. Radio brand
  200. Futaba GODS Futaba 7uaf super/pcm
  201. Jr 12 channel dsm rx
  202. Byron corsair flap servo set issues
  203. 2 servo Elevator does not stop at the same time?
  204. savox servos
  205. futaba 3003's and 3004's
  206. HobbyKing (Turnigy?) servos - RotorStar vs AeroStar
  207. Programming a Delta Vortex with a Futaba T14SG Need help with Elevons
  208. Jeti duplex ds16 / receiver r9
  209. DX18 can I use a PPM encoder? Connecting to Pixhawk flight control.
  210. 27 mhz synthesized tx?
  211. Help with Flysky FS-IT4
  212. What kind of radio problems can I expect with a steel tube fuselage plane?
  213. Endurance PCTx... NEVER ANSWERING EMAIL QUESTIONS!!!!
  214. Please identify old transmitter
  215. 72 mh Hitec cyrstals
  216. FS-T6 new
  217. Help Matching ESC to Motor, Battery, Manual Controls
  218. Receiver FS or HS mode - need help
  219. Futaba 9Z Transmitter Battery
  220. JR 8103 w/Spektrum ( mod ) ?
  221. Activating Eflite Retracts with Futaba 8FG
  222. Dx6i transmitter
  223. JR servo's VS. Spektrum servos
  224. hitec HS525BB servos-won't respond
  225. Old AM Transmitter to mate with my Airtronics 92123 receiver
  226. Help identify this ESC or Motor problem - Video included
  227. mato 8108r
  228. Can I assign a slider for throttle up on Futaba 10C?
  229. Power HD analog servos - pricing?
  230. Cleaning out elderly parent's house I found two 'digimite 4' boxes
  231. Fataba 8UAF setup Question
  232. Futaba
  233. fly sky gt3b binding issues
  234. New Spektrum DX6 with Telemetry
  235. Older Radios
  236. Jeti DS-16 transmitter charge jack polarity for field 12V charging
  237. DX7 Fail safe
  238. FX TH9X 9 Channel transmitter
  239. Need help don't know where to start
  240. Dymond R/C 01 D 1.5 Submicro Servo
  241. FS-TH9X Flysky, no throttle
  242. binding question
  243. Tower Pro SG90 Servo Centering Problem
  244. Single Stick Xmtr?
  245. Where do I start? I need your help!
  246. What receivers will work with a Futaba 3PM-2.4G?
  247. Futaba 8uaf to 2.4
  248. spektrum A6150
  249. Minima 6s won't bind
  250. Transmitter Question
