PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Jr XP 631 Elevator Trim
  2. t6xa
  3. Servo Problem - CEN TR4 w/ srm-102 servo
  4. servo jitter on range check please help
  5. radios
  6. Is it possible to make my own reciver?
  7. Jr PCM 9X
  8. ANY FUTABA FM RADIO Changing it from 72mhz to 75mhz, IS IT POSSIBLE?
  9. When do you quit flying?
  10. Can you use the same transmitter for 2 cars?
  11. JR vs. Futaba
  12. Sanwa RD6000 Problem
  13. High Band - Low Band:: Need help
  14. throt cut on 8uaf
  15. t6xhs
  16. My Servos have a mind of their own !!
  17. General Info on RC Radios
  18. 6xas
  19. Futaba 6XAS
  20. Redundant switch question
  21. Can I put a channel 52 Rx crystal into a channel 12 Rx?
  22. mini servo on nitro?
  23. All FM transmitters legal?
  24. Meed 1/4 scale servo parts.
  25. Eclipse 7QPCM- works with Futaba FM Rx?
  26. antenna Routing: Top, Bottom, or Inside?
  27. Airtronics/Sanwa RD6000 Sport schematics wanted.
  28. JR Century 7 Radio System - good deal or not?
  29. Gymbals- L/R,R/L ? JR X378
  30. which radio to get nead to know fast
  31. Setting up throttle servo
  32. Help really needed
  33. Diferential throw on surfaces -- How to get rid of it!!!
  34. Opinion on Hitec Laser 6
  35. Hitec 7 SWASH Numbers
  36. PowerBox and Pulse Amplifiers
  37. RadioSouthRC does tune ups, anyone try them?
  38. Need an UltraPac or a Service Menu Enabler
  39. Futaba 3010 servo
  40. 9c
  41. Tower has Royal Evos in stock!
  42. Futaba reveiver voltage question...
  43. Ace Olympic V Xmit and "ProStar" Rcvr.
  44. A (mild) rant about Tower
  45. switchin Hamm to FM
  46. What is the difference of the JR xp662 and the xf631
  47. Mixing radio equipment
  48. Looking for JR ch 46 (72.710)
  49. Futaba WC1 9ZAP and R129DP receiver
  50. New Multiplex will buddy box to any brand
  51. Which JR PCM 10X Tx radio (heli or plane)?
  52. Is the technology used in digital servos adequately mature to warrant buying them?
  53. Rare OS minitron Radio System
  54. Will this cause interference?
  55. Is JR 331 ok for Magic Extra 46 Ailerons ?
  56. Burn In
  57. jr service
  58. FMA Receiver?
  59. Looking for info on buddy-box system...
  60. JR Radio help
  61. Battery Idea
  62. gws servo's
  63. whats going on!!??
  64. Futaba Conquest
  65. JR Tx Won't enter Programming mode
  66. Can Airtronics radio be charged with hitec charger?
  67. FMA servos
  68. WANTED: Kraft Tx RF module(s) 72.160 MHz
  69. reversing servos
  70. !! LOOKING FOR airtronics cx2p BATTERY COVER
  71. Futaba/hitec I'm so confused
  72. JR 649S Receiver Q
  73. Sanwa M8 VIII English Manual Needed
  74. best way to run a multple battery plane
  75. RF Interference
  76. which rx to use?
  77. 72 mHz RX antenna
  78. Converting 4 channel to a 5 channel radio?
  79. OOPS...It's a "G" plug!!!!
  80. PCM glitch counter
  81. New here. Question about crystals and programmable radios
  82. Triton charger (01) memory question
  83. rc frequencies vs crystal numbers
  84. Futaba Charger and Switch Harness
  85. Help!!!!!!!!
  86. Airtronics VG6DR
  87. Futaba TX & Hitec RX help needed please..
  88. Buying Radios off Ebay???
  89. Need help to DIY whip antenna for 36 MHZ RX
  90. Airtonics RX and Hitec Servos Help????
  91. which radio? Airtronics or JR?
  92. Torque for ailerons
  93. new radio
  94. how many onces of torque does a cirrus cs-63bbmg give out?
  95. radio glitches on gas engines
  96. Programming Snap Ailerons on 9C
  97. Multiplex 4000 instructions manual
  98. JR programming issue
  99. JR radio that comes with Xtra Easy II
  100. Delayed turn on...
  101. Crystal "ReInstall"
  102. S134 servo
  103. GS servo saver
  104. Help with Mode1 and mode2 radio's
  105. Servo dimensions?
  106. JR servo Jitter??
  107. Hitec HS-55 current question.
  108. Programming Hitech servos?
  109. Radio recommendations- upgrading
  110. JR PCM10 Instruction Manual
  111. JR X347 heli problem
  112. 9206 gear sets
  113. Looking for RC Radio Link
  114. why doesn't tower hobbies carry JR?
  115. PPM or PCM, single or dual Conversion ?
  116. will this chrystal work, Sing;e radio with Dual chrystal
  117. Reciever and Crystal
  118. No 50MHz support from Hitec
  119. Futaba 9ZAPS Module pinout
  120. best price Hitec 5925 and 5945?
  121. PCM or Fm
  122. Servo won't center...
  123. JR MatchBox setup problem
  124. Dual Aileron Servos in EACH wing, Help
  125. CS10BB servo or equivalent
  126. Knowledge Hungry
  127. cheap receviers and servos - HELP
  128. Can 4ch Tx Slave for 6ch Master?
  129. Vexa Controls - Servo Exciter
  130. raido
  131. Already been Crashed Servos
  132. 3rd party servos?
  133. Very Familiar with JR8103? Q here
  134. Best 9c radio
  135. Antenna length
  136. Noisy servos
  137. JR 10X programmable mix problem!
  138. Service
  139. Futaba vs. JR
  140. 5945 servo
  141. Graupner / JR MX-22 Question??
  142. Trainer compatiblity
  143. problems w/ JR XR3i
  144. Aileron Mixing problems
  145. Futaba 8UHP Need Pictures
  146. HUGE price difference on servo ???
  147. Hitec Receiver for Jr8103?
  148. radio help/suggestions
  149. Fly near airport question....
  150. servo question
  151. 6exa
  152. JR 8411 different centering
  153. Just ordered a Lynx 3D
  154. 8UAFS 3 position switch controlling 7th channel
  155. Royal Evo
  156. Changing frenquency Xtals
  157. Best prices on Hitec 5945's???
  158. HiTec Neon as Trainer Box to Fut 6EXA
  159. JR PCM 10X radio and MD2 question.
  160. T6xa radio
  161. Programmingt Hitech servos.
  162. Receiver check out
  163. Must receiver freq. equal crystal freq?
  164. Hitec Eclips and Spectra
  165. Futaba 9C and Ultra Stick problem
  166. Radio Glitching
  167. Metal Gear Servos & Loctite
  168. Servo bobble
  169. Cleaning a 9ZAP
  170. Jr X-347
  171. just bought an mx-3, i was wondering what is the best way to use the mx-3 w/my 2 cars
  172. vg-400
  173. Futaba 3FR-AM
  174. which radio for heli?
  175. Ikarus gyros?
  176. JR PCM 9x manual in English??
  177. Futaba 9C 7 Servo GP Extra 300S Configuration
  178. conversion of receivers
  179. Which Crystal Set
  180. Hitec programmer
  181. Eclipse 7 Glitch........
  182. MPX 3030 program challenge
  183. JR 378 Radio, Mode 1 to Mode 2 Change
  184. All Your Channels Are Belong To Us
  185. Hitec 5645s
  186. Which DC converter for a Triton charger?
  187. Radio Receiver Compatability - Airtronics
  188. Where do I sell a Futaba FP-R127DF, 75mhz Receiver????
  189. Futaba Receiver Question
  190. 8uaf help!
  191. I Knew Better And Did It Anyway--IT GETS WORSE!!!
  192. I need a littel help
  193. rc peanut...........anyone?
  194. What servos for 71" Ultimate
  195. servo ratings
  196. hitec 5945 digital
  197. 3 point vs 5 point curve
  198. Digital or Analog Servos with Futaba 3PK
  199. The village idiot is here
  200. digital servo noobie
  201. Switch placement
  202. Futaba 9 Cap, setting up spoilers
  203. Futaba S3003 & S3004
  204. How about a servo comparison test by RCU??
  205. New 6CH Radio....No response from Servos
  206. record altitude attempts
  207. I need help with savage ss radios
  208. Severe GLITCH !
  209. Hitech servo arms.
  210. Kraft Radio
  211. Futaba 6x
  212. Futaba high torque servo question
  213. Wanna Bypass Diode in New T6EXA HELP PLEASE
  214. Is The Futaba 9c A Good Radio For A Begginer?
  215. Futaba 6EXA or Hitec Flash 5 for first radio?
  216. which controller is better? airtronics mx-3 or the futaba 3pdf?
  217. JR Receiver NER-226X
  218. How many channels do you guys use for Electric Park flyers?
  219. Does anyone know the differance?
  220. Hitech VS Futaba servos
  221. Pitch Servo problem
  222. GB Sukhoi needs servo advice?
  223. FATAL ERROR in airtronics M8
  224. The JR XF421EX
  225. airtronics mx-3, how do you use this controller with multiple rc cars?
  226. will airtronics rx handle 6 volts
  227. jr 10 sx manual
  228. Servo Chattering - Glow plug
  229. Convert Futaba Skysport 4 to 5ch
  230. Soaked Wet Receiver..what can be done??
  231. Servo Chatter
  232. Is Dual elevators on a Super 8 Radio with 7 CH RX possible?
  233. JR servos?
  234. Good Places to Sell radios
  235. servo gear replacement
  236. 3 channel 14 gram reciever?
  237. Broadband on Power Line Interference
  238. Quality of Multiplex?
  239. Futaba 9151 servo
  240. Airtronics Servo to Futaba Receiver
  241. Airtronics vg6000 and V-tail glider ...
  242. Proline Radio Poll
  243. T6XA - Flaperons reversing
  244. 72 Mhz Low band vs High band?
  245. Best 4 channel for the buck?
  246. Did I screw up my TX when I shorted the diod?
  247. metal to metal contact
  248. HS-55 not centering
  249. Smartch Aerohawk problems--please help!
  250. the mc 4000 red button blue`s
