PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Dual Elevator servos operate at different speeds.... Best cure?
  2. M8 Synth Module
  3. Transmiter gets warm
  4. Poll:DELETE
  5. Hitec/Futaba difference??
  6. new radio
  7. Futaba 8UA Radio - Need Flap Programming Help
  8. Reciever question ?
  9. Homemade Futaba Training Cord?
  10. New computer radio
  11. JR transmitter versus other receviers
  12. JR, Airtronics or Futaba FM
  13. Kraft electric retracts
  14. Shorting Tx diode
  15. Re-use older transmitter?
  16. programming XP 8103
  17. Futaba rx antenna wire length?
  18. Ace and Royal Titan Servos, Are They Worth Using??
  19. Hitec HS-81 jitters
  20. Hitec Electron 6 modification question
  21. Hitec Electron 6 modification question
  22. 8103 Program ?
  23. 8103 Kill Switch Mix
  24. Airtronics or Futaba
  25. f/t futaba 4ch am/fm (radio only)
  26. manual for an old m series futaba
  27. Need your thoughts on a remote
  28. New transmitter/charging question
  29. Stick problem
  30. Do standard peak chargers work properly with diode???
  31. Digatal or analog servos
  32. Graupner Mc-22 users : testmonies needed !
  33. Volz Wing Maxx HP noise question.
  34. What lube for a servo gear change?
  35. Futaba what model should I buy
  36. JR 652 programming - Please help a newbie!
  37. Programming end points
  38. Buddy Boxes for a FUTABA 6DA
  39. best price on...
  40. rubber sealant glue
  41. newbie questions on expo and dual
  42. Futaba T6EXA Elevon Mixing Flaw
  43. Batteries for old Futaba FP-T5FG Tx
  44. Radio systems with ABS
  45. Hl/1 Hl/2 ???
  46. What frequency in France
  47. engine shut off! Need help!
  48. Crystals do break!!
  49. Anyone tried GWS standard high torque servo's??
  50. Servo Controller
  51. Compatability problem
  52. Thoughts on JR/Futaba/Airtronics
  53. Airtronics or Futaba
  54. Futaba FF6 Flap question
  55. futaba trasmitter for airtronics receivers?
  56. Misuse of HS225BB?
  57. Horrible Futaba Service Experience
  58. Servo Arms
  59. FM crystals in an AM reciever
  60. Hitec 6xx servos
  61. Kraft RF Modules Wanted for 53 Mhz
  62. Futaba 6EXA diode jump?
  63. Plastic parts with my radio
  64. 8UAP Flaperons
  65. MCR AC/DC charger
  66. antenna
  67. Futaba 9ZAP
  68. First Computor Radio
  69. Need some help with Duel Aileron hook-up
  70. EVO Radio
  71. JR PCM 10X vs MPX Royal Evo 12
  72. Zhen Hua / FEDA Dragonfly /Futaba
  73. i got a quick question about digital servos and PCM radios....
  74. Hitec HS-475HB ? New servos
  75. Multiplex Mini DS - IPD receiver
  76. Hitech Servos
  77. JR R1 TX/RX dillema
  78. Where do I mount the charging plug?
  79. R700 and 6 volt pack??
  80. Tracker II problems
  81. GWS mini servos
  82. 64k campac question
  83. Futaba 9Z Transmiter
  84. Question
  85. can u make a futaba compatibale with a JR?
  86. Airtronics at 6.0 Volt? Ok or not?
  87. Kraft Radio
  88. Own a JR? please read!!!!!!!REPLY!!!!
  89. Old Futaba FP-T5 NLH
  90. Explain Servo torque figures
  91. Futaba FP-T9VAP display
  92. FF7 or FF8?????
  93. What reciever for JR radio?
  94. Inflation or a taste of things to come?
  95. problems with my jr xr2i
  96. servo recommendation 1/4 sig cap
  97. HS-5245 High pitched whine
  98. 2 Crystals - one RX
  99. Rd6000 Ic
  100. Basic Stamp and EEPROM Write/Read?
  101. Circus Hobbies Rx.......?
  102. Futaba Tx has no RF.
  103. jr dummy box
  104. savage ss radio help
  105. Do nicad rec. packs need to be discharged?
  106. Fly Helis with 9CAP ?
  107. 9CAP ailevator question
  108. Crystal Color Code
  109. What's wrong with the radio?
  110. where can I get connectors for hitec a narrow band receiver
  111. Airtronics 3PS Problems
  112. Tx choice criteria : servos line
  113. flappersons with a JR x-347
  114. Futaba TX 6XAS Repair
  115. Xtals
  116. Radio question
  117. RD 6000 IC
  118. Jr Servos Help
  119. Newbee Crystal Problems
  120. Futaba 9206
  121. Servo Central the badest site out
  122. What Servos
  123. crystals jr 15 tx,rx brand new
  124. Which Radio Part Deux - synthesized radios
  125. Airtronics receivers
  126. PCM to FM
  127. GWS Picos
  128. Graupner radio sets... anyone familiar with them?
  129. Matchbox?
  130. Futaba FP-7UAF
  131. Hitec Eclipse 7 Qpcm vs JR XP783
  132. .
  133. 10x program issue
  134. Jr Xp783 What Pcm?
  135. 1 1/4" servo arms?
  136. Jammed Tx
  137. futaba 9Z question
  138. ts-65 average current draw.
  139. which radio
  140. Airtronics M 8
  141. programing 8103 dual rudder
  142. JR Rx crystal trouble
  143. Rx HELP FAST
  144. Servo mounted on firewall Pro's & Con's
  145. Hey, You JR Gurus!
  146. receiver antenna
  147. Need Manual for JR XP783 Radio
  148. PCM Receiver?
  149. Hitec Electron 6 receiver
  150. Hope This Wont lead to a war!
  151. Help with identifing this radio
  152. Hitec 5475 Servo
  153. How offen do I need to......
  154. "rubber"antenna for my jr
  155. Synthesized Radios
  156. Kraft KPT-5c frequency problems
  157. JR Radio with R600 reciever - can it take 6v Batt Pack
  158. Circus Hobbies Radio help
  159. Single Conversion / Dual conversion
  160. Receiver question
  161. graupner mc22/24 discussion
  162. eclipse 7 throttle stick
  163. servo jitter when load applied
  164. Antenna stopper out of fus
  165. I am confused...
  166. Difference between 8UAPS and 8UAFS?
  167. Another which radio do I choose?
  168. JR RS300 Synthesized 27MHz?
  169. Ace Noise trap
  170. on board glow mixing
  171. Switch on buzzer
  172. Hamm Radio Frequency Pro/Cons...
  173. Help My Airtronics Quasar 6A Has the jitters
  174. Newbie question- Diff. bet. Futaba & JR
  175. Hi tec475HB servos
  176. Next radio after this one
  177. Nylon gears for Hitec 945s ?
  178. Newbie?Futaba servos with Novak RX
  179. Need help with servos hiccup on electric airplane
  180. radio choice
  181. mixing or thumbing? what is the advantage?
  182. Futaba T9CAP Radio
  183. Hitec/Jr ?
  184. Who to buy Nimh recvr batteries from?
  185. Pitch Changes on Throttle Hold on 8U
  186. Expert 4 Channel Fm Transmitter
  187. servo recomendation
  188. Challenge for HarryC (MPX 3030 question)
  189. 6XAPS Futaba any BEEF?
  190. Interference???
  191. 5945 oscillation
  192. JR Radio crystals. Red/black? Confused on how to buy
  193. Help! Servo Reversing on JR Racing Cobra
  194. 6.0 or 4.8v? Need your help!!!
  195. Old Airtronics connectors?? Signal wire??
  196. Servos to Receivers......HELP
  197. MY JR10X will not charge! HELP!!!
  198. JR century 7 parts
  199. futaba 3pdf problum need ?'s answered asap!
  200. Changing RX crystals
  201. Futaba failsafe??
  202. Making your own servo extentions?
  203. Futaba Question
  204. Futaba Question
  205. futaba expo. ?
  206. What radio?
  207. Software version of Hitec Eclipse
  208. Newbie - Which 55 oz servos would you suggest
  209. Multiplex? <swoon>
  210. is this futaba 3pk a knockoff?
  211. Searching for some CIRRUS servo-to-receiver plugs, Please help
  212. What are the advantages/disadvantages?
  213. Eclipse 7 - w/ 5 channel Rx
  214. Strange question
  215. Is my JR screwed?
  216. Need Schematic for Airtronics Vanguard VG6DR
  217. Multiplex 3030 - Throttle Pitch Compensation
  218. Need a Manual for a JR 388
  219. Did I Fry My Receiver??
  220. Eclipse & RD8000- Dual rates/Expo
  221. looking for RD6000 Manual
  222. Positive or negative shift?
  223. HELP w/ Hitec FLASH 5 Tx - charging
  224. Futaba Service
  225. Gold sticker Tx. Rx?
  226. Urgent An Ongoing Radio Problem Help
  227. futaba 9Z
  228. long distance control
  229. hitec hs-55 servo problems
  230. Increase pico rx range??
  231. Futaba FP-T5NLH Trainer Cord
  232. Futaba FP-T5NLH Trainer Cord
  233. HIGH or LOW
  234. Difference btwn PCM and FM (PPM) ???
  235. Futaba T6XA / Flaperons / Flap adjustment
  236. Mods please close....
  237. Servo ideas for Lancair and DP Ultimate
  238. ESC and Receiver Help Please…
  239. Thinking about a "universal" radio
  240. Futaba 8U Throttle cut problem?
  241. Hitec Focus 4 newbie
  242. 1989 Futaba Gold box
  243. Futaba radio decision
  244. Reducing Servo travel...Help
  245. Monitor ?
  246. Difference between R138DP and R148DP
  247. My servos went crazy too !
  248. PCM Radio
  249. Multiplex
  250. JR 537 servo ball bearing question
