PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Reducing Servo travel...Help
  2. Monitor ?
  3. Difference between R138DP and R148DP
  4. My servos went crazy too !
  5. PCM Radio
  6. Multiplex
  7. JR 537 servo ball bearing question
  8. FCC Legal User swappable crystals! Multiplex Profi 4000?
  9. Futaba 9CAH
  10. Power Panel glow driver causing interference... HELP!!
  11. Tx/Rx Field Chargers: Which to buy?
  12. Buying a new TX
  13. hitech and futaba
  14. Cirrus Servo Horns
  15. Broken TX Antenna!
  16. Interceptor 2000 Rx by DAD/JIT
  17. Receiver Whip Antennas
  18. Micro servos on an ultra stick 40?
  19. Futaba servo gear train alignment
  20. Interference from airports?
  21. Monitoring dual batteries
  22. In flight voltage and Digitals
  23. Transmitter volt meter
  24. Hitec Eclipse w/ Spectrum Module (problems?)
  25. wire looms or holders?
  26. Airtronics RD8000 info:
  27. zip zap range
  28. Lipoly's up and coming.
  29. Radio Glitches ?
  30. Futaba 9C + 7 Channel RX= Ailevators?
  31. Wanted: R127DF Low band Reciever
  32. Radio interference between different channels
  33. Question about receiver for futaba
  34. Hitec servo programmer
  35. What the heck is this ?
  36. JR / Futaba / Hitec / Aitronics: Which to buy?
  37. JR x347
  38. S9451 Voltage?
  39. Futaba 9206 on 6V
  40. help
  41. JR Max 6 elevon mixing
  42. JR 421 transmitter case
  43. Will my receivers work?
  44. 3 channel receiver?
  45. Price for a used JR 8103?
  46. 50.900 Digital Proportional
  47. Servo selection for Kyosho Giles 202
  48. Forget servo centering, what about transmitter centering?
  49. Problem with different brands of Tx & Rx
  50. Are JR servos compatible with a Futaba Rx?
  51. Using different brand tx and rx
  52. Which Futaba radio to buy?
  53. Airtronics VG6000 vs Airtronics Radiant
  54. Eclipse PMix - Always on?
  55. Futaba Conquest FP-6NFK
  56. JR 10SX Lnd switch
  57. One Heck of a Radio Glitching Problem
  58. servos glitching
  59. Help!! Good throttle servo
  60. Great service from Servo City
  61. EK Logictrol schematics
  62. Need Help on Selecting Reciver
  63. eclispe problems??
  64. AM , FM and computer TX
  65. Futaba FF7 Wiring Diagram
  66. Clear electronic casings/shells
  67. JR radios Best prices
  68. black stains on wires
  69. Need Help with Battery Selection
  70. Hitec HS-5625MG
  71. JR & Futaba - buddy ?
  72. Futaba 9206's JUNK??!!??
  73. Gws R4p
  74. JR 10x use in the UK
  75. rcd rec problem
  76. Kudos to Hitec
  77. Charging Tx Battery Externally
  78. Newbie here, needing help!!
  79. Range checks on giant P-47
  80. Receiver damage?
  81. Contol Knobs - Multiplex Cockpit
  82. Help me program my 9CA and my Seagull Edge.
  83. Servo identification
  84. What receiver with JR Quattro
  85. Help - Interference with Hitec Electron 6
  86. Freq Change Ability
  87. Wanted : Transmitter and accessories
  88. Servos and wiring
  89. Transmitter question
  90. FUtaba 9CA Raido Reading?
  91. Need End Caps For Futaba Fg Series Tx
  92. Tower is selling Multiplex??? Gasp.
  93. Need help wiring servos and other stuff
  94. new servos
  95. Ace /Hitec Nautical commander Problems help!
  96. reciever antenna
  97. Where are the new Futaba trainer cords in stock?
  98. Hitec Programmer Article
  99. Old and new servos
  100. Two Crashes in Two Weeks
  101. new build
  102. what radio system??
  103. Trying to do programmed curve mix rud->elev on 9C
  104. Gyro Instalation
  105. Whats the Futaba Equivilent or the JR 2721?
  106. Hitec 225 mighty mini mg problem
  107. Source for Model Scan Sl-72
  108. Hitec Hs 805BB xtra battery?
  109. Servos and other various electronics
  110. FUTABA SKYSPORT 6A range info
  111. have gy502 gyro --- need servo for it
  112. Radio choices
  113. Hitec Electron 6 - Is it normal?
  114. reciever question
  115. Jr 8103 broken antena..can i get new one from Radio Shack?
  116. Help programing JR 8103
  117. What Servos to use on a Patern ship 1.20 size
  118. Here is a weird one for ya..
  119. Crystal swap problem?
  120. Plane landed in water! Submerged!
  121. Hitec HS-645MG Servo Screw
  122. Need 2 retract servos for heli
  123. Using 6V receiver pack instead of 4.8V
  124. Multiplex servo parts ?
  125. servos with long extensions and y harness
  126. Shift select on 9c
  127. Gyro
  128. I need a Manual for a JR century 7 radio, or just some tips on how to useits failsafe
  129. ESC??I got it wet :( SR
  130. Dead power-line interference question
  131. Radio feature comparisons
  132. Receiver AM crystal in Frequency module ?
  133. 6xas or 6exa ??
  134. Question about European-US compatibility
  135. Need Reciever
  136. Occasional RF Interference @ our field
  137. 401 gyro on caliber 30
  138. futaba 6EXA
  139. JR 10SX Air manual
  140. Can You Get Interference From a Mobile Radio in a Work Truck
  141. Jr 9x radio
  142. graupner mc24
  143. Recording radio transmissions on PC
  144. futaba product support number??????
  145. twin radio sysytems
  146. 9ZWCII Need Help!!!!!!!!!
  147. What is wrong with my recivers?????
  148. Hitec Micro 555 on glow engine planes
  149. Why is the Futaba 9CH* more expensive then the 9CA*?
  150. Multiplex Pico 4/5 range
  151. Help centering servo arm...
  152. JR PCM10 S Cristal
  153. Hitec Focus 4
  154. What the heck is wrong with this servo?????
  155. How to get a JR 642 repaired
  156. PCM10S xtal
  157. JR 8103 TX incident
  158. Tx, Rx, and servo compatibility
  159. JR8103 falling apart!! Help!!
  160. problem fixed, thanks.
  161. What Radio should I get?
  162. Need Airtronics Ch24 rcvr crystals
  163. 6EXA Futaba Trainer Cord question
  164. Futaba 9C Trainer Cord Setup?
  165. Multiplex 3030 - Is It Possible to Slow Down a Switched Function?
  166. Programming JR 10x for flaperon
  167. JR x378 aileron differential
  168. Is anyone else having trouble with new feather weight recievers?
  169. Super 8 Throttle ID
  170. Berg receivers ?
  171. Dropping the battery???
  172. 6XA Radio reported "back" ???
  173. Looking For More Advanced Radio
  174. 9cap
  175. Futaba 8UAP servo reversing
  176. Radio overhaul
  177. Galloping Ghost
  178. Futaba Service is trying to Rip me Of !!
  179. Futaba GYA 350 gyro
  180. JR Receivers
  181. Hobbico Receiver
  182. Chokes on leads and Y's
  183. New JR radio
  184. Hitec Sevo Programmer
  185. Futaba S9206 Servo, 4.8 or 6.0 volt?
  186. Did I Do Right?
  187. Spark ignition - which RX to use???
  188. Battery "Fuel Gage"
  189. Advantages of Digital Servos
  190. Need good 4 channel Radio
  191. have reciever and servos for sale
  192. Lost Channels
  193. JR XP-662. Is dual rate possible on Auxiliary channel if it's mixed with Elevator?
  194. AM Radios
  195. Charging Ni-MH
  196. Motor speed control with Kraft
  197. 6.0 volts
  198. Another Futaba 9C timer question
  199. Blue Bird servos from Balsa Products
  200. multiplex cockpit mm ???
  201. How do you use mixing to lower flaps in stages XP652
  202. Multiplex jumbo servo
  203. Futaba 7UHF Manual
  204. JR 378 Transmitter with Futaba R138DF Receiver
  205. What's on tap at Futaba?
  206. Thinking about a JR 8103
  207. Radio Range
  208. Question re Hobbico Air Alert
  209. how many servos per receiver
  210. Which servo to use? JR Radio / Hitec 425 vs jr 537
  211. Futaba 9CA and the Ultra Stick
  212. one piece wire connecter removal
  213. Recommend a good intermediate radio for Heli/Aircraft
  214. Rudder servo center
  215. Multiplex Servos....What heavy duty servo arms fit ?
  216. Help... I've got the digital "jitters."
  217. Rudder servo zero
  218. Is it legal???
  219. Help: FP-R4F Mode-II
  220. need advice on choosing a radio
  221. Futaba gold case radios
  222. Dodged a Silver Bullet
  223. Do You Use A Spectra Synthesized Module In Any Other Transmitter Than Hi-tec
  224. Hitec servo hs-81 for aileron duty
  225. radio case
  226. Help with coupling Ailerons and Rudder
  227. Newbie requesting radio advice
  228. Partial Control During Combat Flying Heat?
  229. Should I be worried??
  230. Hobbico CS-12 Micro Servo as Throttle
  231. Futaba 3FR FM radio, how limited is the range?
  232. Airtronics 94510 Servos
  233. Servo pulsates at neutral
  234. no trainer socket can i add one???
  235. Lost my charger...can anyone help??
  236. JR 10x Air
  237. Help! I don't know what happened...
  238. How obsolete is an old Futaba AM transmitter?
  239. Hitec Eclipse 7
  240. How to run redundant switch and battery?
  241. Hitec Receiver
  242. Hitec 475HB broke
  243. changing crystal on JR receiver
  244. Servo Connectors & Cables
  245. FP-R112JE decoder chip
  246. Need Specs for JR Servos...
  247. looking for a frequency scanner
  248. pcm question
  249. Wrong spot
  250. Expert Receiver
