- Joystick controller
- Cirrus Servos
- 4.8 volt battery with "G" plug!
- Swapping Tx batteries
- Hitec digitials- the saga continues.....
- Setting up Flaps on a Futaba 9C
- Aaahhhh...the mad robot face....
- hitec servos - how good are they (700)
- Help settle Hitec aurgument
- Need some antenna help please.
- Fried my Futaba!
- JR XP783 radio - need your opinion please.
- Can any other TX buddy with JR378 ?
- Futaba FF6 with R136F RX
- Where can I get cheap micro servos.
- 6EXA or VG6000 or used Radio?
- PCM or not????
- beginner questions
- Wiring a J-Plug Battery
- Adapting Futaba Skyport 6 for sailplane use?
- Servo linkage
- How to use a capacitor in a long servo lead
- Radio nicads
- 6exa
- lookin for new radio equipment
- nasty glitch
- Can I use two Battery packs together
- jr 642 centering problems
- Jr 8103
- chanel 8 on 8uaf?
- Kraft 2ch radio?
- JR 8231 servo chatter
- "Best Way" to set up servo throws
- Expert SL300 for 40 size 3d plane?
- Futaba - Fp T T7uap ? How To Change Models # S
- 3 Questions
- What does it mean - "Twisting Servo Leads"
- Hitec Laser 4
- Having problems with homemade Servo Extensions
- multiplex profi mc 3010 vs hitec flash 4
- HiTec 422 Servo Arm Screw
- JR Mixing for flaps problem
- Futaba 6YG help
- Servo Shutdown
- Setting up throttle cut 9C
- JR 8103 help please
- JR 8103 or JR 10sx
- Cracked servos - A Near-Crash Experience.
- Dual reciever setup. Do they have to be the same kind?
- BEWARE! Futaba 9C Tx - Mix offsets changing in flight
- FP-7UAP Super motor trim
- What frequencies can be used in USA?
- what servos to buy
- newbie is confused
- :o
- Can I use the interface cord from my Real Flt G2 as a buddy cord?
- JR 8103 w/Digital trims
- 8UAP vs 9CHP
- Multoplex EVO 9 Chan Tx.
- Futaba S3003 servo mounting
- newbie question
- FP-7uap engine trim
- Hitec HS5735MG Info.
- 9CAP and Bad Solder Joints. Help please!
- JR Radio
- ACOMS Techniplus 27MHz RX Antenna . .
- Beginner getting into RC planes
- Switch Designation For Dual Rates
- Hitec "Karbonite" servo's
- Jr 9x?
- JR radio
- Manual for Futabe R136F Receiver
- Who sells 4.8v regulators
- Airtonics charger with Futaba plug battery?
- NiMH batteri charge amps
- Need some info for JR 642 radio
- servo reverser question.....
- Where to buying a crystal for hitec focus 4?
- Jrf400
- Help
- Where to buy?
- dig with analog servos
- Another newbie crystal question.
- Polk Seeker II rcvr - single conversion?
- Airtronics and problems
- Help with Trainer Switch on Futaba 6VH
- 4 channel transmitter to 5 channel Reciever?
- With shift change TX do RX crystals have to be same brand?
- Radio Channel
- futaba pa-2 with airtronics rd6000?
- Best price for a HiTec flight Kit? Suggestions?
- Will airtronics servos work with Hitec plug RX
- Futaba Rx - high or low??
- Looking for cased or uncased .19 ounce servo?
- Servo Life
- Servo Ticks about every 30 seconds?
- hello you
- 9202 why???
- Single stick radios
- Dual vs Single conversion JR 945 vs 955
- Wierd Tramission/Reception Problems with Futaba 6x Super Radio
- Futaba radio/antenna problem
- seeker reciever polk hobbies
- Airtronics Infinity 660
- max # servos one receiver?
- do it yourself tuning?
- jr ..hitec compatibility
- eBay Idiots & Airtronics RX Active Channels
- Extra Credit Question for JR gurus
- cockpit mm heli mixes
- Hitec Servo Programmer
- Newbie radio JR X-378 or XP8103 ?
- T6xa and U-Can-Do
- Midair interference hits
- Skysport with 9C as Master......
- new radio
- Determing frequency of older JR radio
- JR 10X or JR8103
- xmitter repair cost
- Idea for more reliable switch
- Jr XP 631 Elevator Trim
- t6xa
- Servo Problem - CEN TR4 w/ srm-102 servo
- servo jitter on range check please help
- radios
- Is it possible to make my own reciver?
- Jr PCM 9X
- ANY FUTABA FM RADIO Changing it from 72mhz to 75mhz, IS IT POSSIBLE?
- When do you quit flying?
- Can you use the same transmitter for 2 cars?
- JR vs. Futaba
- Sanwa RD6000 Problem
- High Band - Low Band:: Need help
- throt cut on 8uaf
- t6xhs
- My Servos have a mind of their own !!
- General Info on RC Radios
- 6xas
- Futaba 6XAS
- Redundant switch question
- Can I put a channel 52 Rx crystal into a channel 12 Rx?
- mini servo on nitro?
- All FM transmitters legal?
- Meed 1/4 scale servo parts.
- Eclipse 7QPCM- works with Futaba FM Rx?
- antenna Routing: Top, Bottom, or Inside?
- Airtronics/Sanwa RD6000 Sport schematics wanted.
- JR Century 7 Radio System - good deal or not?
- Gymbals- L/R,R/L ? JR X378
- which radio to get nead to know fast
- Setting up throttle servo
- Help really needed
- Diferential throw on surfaces -- How to get rid of it!!!
- Opinion on Hitec Laser 6
- Hitec 7 SWASH Numbers
- PowerBox and Pulse Amplifiers
- RadioSouthRC does tune ups, anyone try them?
- Need an UltraPac or a Service Menu Enabler
- Futaba 3010 servo
- 9c
- Tower has Royal Evos in stock!
- Futaba reveiver voltage question...
- Ace Olympic V Xmit and "ProStar" Rcvr.
- A (mild) rant about Tower
- switchin Hamm to FM
- What is the difference of the JR xp662 and the xf631
- Mixing radio equipment
- Looking for JR ch 46 (72.710)
- Futaba WC1 9ZAP and R129DP receiver
- New Multiplex will buddy box to any brand
- Which JR PCM 10X Tx radio (heli or plane)?
- Is the technology used in digital servos adequately mature to warrant buying them?
- Rare OS minitron Radio System
- Will this cause interference?
- Is JR 331 ok for Magic Extra 46 Ailerons ?
- Burn In
- jr service
- FMA Receiver?
- Looking for info on buddy-box system...
- JR Radio help
- Battery Idea
- gws servo's
- whats going on!!??
- Futaba Conquest
- JR Tx Won't enter Programming mode
- Can Airtronics radio be charged with hitec charger?
- FMA servos
- WANTED: Kraft Tx RF module(s) 72.160 MHz
- reversing servos
- !! LOOKING FOR airtronics cx2p BATTERY COVER
- Futaba/hitec I'm so confused
- JR 649S Receiver Q
- Sanwa M8 VIII English Manual Needed
- best way to run a multple battery plane
- RF Interference
- which rx to use?
- 72 mHz RX antenna
- Converting 4 channel to a 5 channel radio?
- OOPS...It's a "G" plug!!!!
- PCM glitch counter
- New here. Question about crystals and programmable radios
- Triton charger (01) memory question
- rc frequencies vs crystal numbers
- Futaba Charger and Switch Harness
- Help!!!!!!!!
- Airtronics VG6DR
- Futaba TX & Hitec RX help needed please..
- Buying Radios off Ebay???
- Need help to DIY whip antenna for 36 MHZ RX
- Airtonics RX and Hitec Servos Help????
- which radio? Airtronics or JR?
- Torque for ailerons
- new radio
- how many onces of torque does a cirrus cs-63bbmg give out?
- radio glitches on gas engines
- Programming Snap Ailerons on 9C
- Multiplex 4000 instructions manual
- JR programming issue
- JR radio that comes with Xtra Easy II
- Delayed turn on...
- Crystal "ReInstall"
- S134 servo
- GS servo saver
- Help with Mode1 and mode2 radio's
- Servo dimensions?
- JR servo Jitter??
- Hitec HS-55 current question.
- Programming Hitech servos?
- Radio recommendations- upgrading
- JR PCM10 Instruction Manual
- JR X347 heli problem
- 9206 gear sets
- Looking for RC Radio Link
- why doesn't tower hobbies carry JR?
- PPM or PCM, single or dual Conversion ?
- will this chrystal work, Sing;e radio with Dual chrystal
- Reciever and Crystal
- No 50MHz support from Hitec
- Futaba 9ZAPS Module pinout
- best price Hitec 5925 and 5945?
- PCM or Fm
- Servo won't center...
- JR MatchBox setup problem
- Dual Aileron Servos in EACH wing, Help
- CS10BB servo or equivalent
- Knowledge Hungry
- cheap receviers and servos - HELP
- Can 4ch Tx Slave for 6ch Master?
- Vexa Controls - Servo Exciter
- raido
