PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Futaba 8UAFS Ailevator Problem
  2. 8C-9C Swap
  3. Website for radio mixes???
  4. RCD Apollo 15 giant scale servos
  5. Futaba 9C Range Problems...
  6. newbie radio question
  7. cheap small servos for futaba
  8. hobbico gyro for airplanes
  9. Should PCM receivers really cost more?
  10. Is this possible?
  11. Help with Left / Right Stick Swap
  12. testing 6v system ?
  13. Weird Servo problem - after winter storage HS-81 cycles back and forth?
  14. Radio feature questions
  15. Using 2 Rx with 1 Tx (Futaba)
  16. Question: Trainer Cable to PC (USB?) Joystick adaptor?
  17. futaba raido help
  18. Futaba 9z wc2 conditions help please
  19. computer radio?
  20. Servo extension cord
  21. 9C on Ham Freq?
  22. GWS 4P receiver problem
  23. radio
  24. confused about rabio for beginner
  25. confused about radio
  26. Part # for ball cup end?
  27. Motor won't run continually
  28. new JR Crystal does not work, why?
  29. JR Pulse Glint 5ch TX?
  30. lost signal, futaba receiver problems
  31. Need Help, Fast!
  32. help
  33. help , calculation
  34. help
  35. Futaba 9CAP and Flaps setup - help
  36. Flash 5 SYSTEM X
  37. Y harness
  38. JR Trans Modules ?
  39. Radio problem.. any Ideas?
  40. Can't Decide Futaba 6X or 9C?
  41. Can a Futaba Transmitter opperate a JR Reciver of same frequency?
  42. JR/Futaba marriage help needed
  43. J R radoiXF622
  44. Hitec Buddy Cord Pin Out?
  45. you can change tx crystals in fm radios right??
  46. which is better jr10x or futaba 9CAP
  47. Ugh..Need a real answer
  48. Great deal on a beginner's radio at HobbyPeople
  49. Narrow Band Documentation
  50. reciever antenna length
  51. 6ch tx with lesser ch rx
  52. Carbon Graphite - Interferance?
  53. digital servo + mechanical gyro = bad idea?
  54. Soft mount switches?
  55. What kind of Heavy Duty servo extensions to use?
  56. FF8 manual
  57. Speed control probs
  58. broken crystal?
  59. Single conversion And Dual conversion
  60. JR rx, heard bad things
  61. Dual Conversion ? Compatable
  62. Hitec Crystals in Futaba Receivers
  63. Why digital sevos?
  64. Hitec programmer battery
  65. SOMEONE HELP*** Changing crystal in Rx. What seperates high/low Band
  66. jr347 heli/plane version
  67. Help !!! - Futaba FP-7MAG radio
  68. hitech flash 5
  69. Nosen 108" Citibria
  70. antique tx's in need of a home
  71. servos
  72. RD6000 sport help
  73. Is it advisable to use Futaba receiver with JR transmitter?
  74. Tower Hobbies Radios and Servo's
  75. Futaba Conquest end travel mod?
  76. JR 662 & Delta/Elevon set-up help please.
  77. FMA servo help
  78. Move over Futaba 9C, Hello JR PCM 9X!
  79. Helo Setup for Futabs 9CHP
  80. Connector types
  81. Futaba 6XH Radio-TX mixing up channels
  82. Need help, Rudder to Elev mix with 9C
  83. Eclipse 7 with Spectra Module
  84. Anyone use the 1800 oz/in servo from seiko?
  85. flight packs
  86. BEC Question
  87. Hitec tx and rx,using JR servos
  88. Custom electronics servo driver
  89. JR Buddy box question
  90. Hitec PPM 8ch RX and servos
  91. Eclipse 7 Mode1 to Mode2
  92. Resetting M8
  93. HiTec Master 7 TX Battery Voltmeter
  94. Help with 6-channel radios
  95. Will this Work? Together
  96. Is a FUTABA CONQUEST FM RADIO FP-T4NBF, narrow band?
  97. Futaba 3 channel power
  98. Reversing "Y" Harness'?
  99. Hitec radio w/ futaba receiver
  100. GWS Servos - Should I use them?
  101. Radio Servo Extension Cords
  102. fried??
  103. Help with 6-Channel radios
  104. Old futaba servos... any way to cheaply convert to new style connector?
  105. Futaba 9c
  106. Polk radios?
  107. Trainer Cable Pinout
  108. mid-flight chanel changer?
  109. Please Close - Got the answer
  110. Daul conversion/Single conversion crystals?
  111. Futaba SkySport 6
  112. JR 10X battery question?
  113. servo arm compatibility
  114. JR Datasafe 2 Interface
  115. Futaba FG Series
  116. Whats better JR XF631 or Futaba T6XH
  117. Hitech HS-311 servo constantly vibrates
  118. HELP. 2packs 1 ESC?
  119. Jr or Airtronics
  120. MPX4000 switch for flap
  121. Velcro receiver attachment.
  122. interference with a gws naro 4-channel receiver
  123. Anyone have good/bad recomendations for Tower servos?
  124. servos squeal
  125. Guillow RC Recommendations
  126. Is PCM needed for gas plane?
  127. Heavy Duty Switch Recommendations?
  128. Futaba Buddy Box?
  129. Futaba T6XH Transmitter battery upgrade
  130. Futaba 6YG trans-w-Air Vang reciever?
  131. Miracle Y...not really a miracle
  132. The best Radio for R/C is ..............
  133. Futaba 9C, Mixing questions...
  134. Have you encountered this?
  135. Oil pipeline (pig)
  136. jr 3810 or 8103 question
  137. My Rx got a little wet.
  138. Futaba Tx. with a Hitec Rx???
  139. Dual Receiver Batteries and the Glitch Buster
  140. Airtronics Infinity vs Radiant Transmitter
  141. Crystal
  142. reciever shift
  143. Aluminium strut interference?
  144. Use of JR servoes on Futaba, possible ?
  145. Futaba Rx Question.. Whats best
  146. Berg crystal question?????
  147. Eclipse 7 problem
  148. OH NO Fried my Futaba Receiver
  149. Receiver Question??
  150. 8uhs 9zwc2 copy
  151. 8103 problem
  152. FMA Co-Pilot plane application Y ail output?
  153. Radio quirks
  154. Futaba 6XH radio can it do airplanes too
  155. What shift are older EXPERT radios?
  156. radio switches snapping off!!!???
  157. JR priceing
  158. Futaba FP-T6FN
  159. Eclipse 7 mods
  160. Receiver ant. length for JR 549X
  161. Does the JR Quattro radio has DSC?
  162. Radio reps- get moving
  163. Seperate Channel or Mixer
  164. Eclipse 7 QCPM xmtr w/Spectra $209.95
  165. 9C gasser kill sw from dual rate on Throttle
  166. Crystal Prices
  167. Hitec 5925 servo goes nuts when I hook up to RX
  168. anybody beat $154 for Hitec Laser 6 radio with 4 standard servos??
  169. buddy cable
  170. i need a huge servo
  171. Futaba Buddy cord conflict?
  172. JR X-378 Display Problem
  173. Which Transmitters hold their memory on a PC
  174. 4 or 5
  175. JR 8103 Exponential Question
  176. ACT SmartScan receiver
  177. Airtronics Radiant Transmitter - HELP
  178. Python/Airtronics Question
  179. Jr 460t Gyro Schematics
  180. where can i get the best deal on hitec digital 5945mg servos
  181. is futaba gy401 gyro ok for an airplane
  182. what computer radio to buy
  183. Question about Receivers
  184. Need info on servo hookup, no radio?!?
  185. Question about Receivers
  186. New end on old aritronics servo?
  187. Cirrus Transmitters
  188. Reversing a Servo
  189. futaba fp-5uap transmitter
  190. how firmly do you attach the servos?
  191. Old FG Radio Battery Help
  192. Futaba T6XH crystal???
  193. 9Z TX Synthesizer for CH60-80 35 MHz Band A
  194. servo swapping
  195. 6v with hitec receiver and futaba servos jittery?
  196. what determins "full range"
  197. trainer cord between different modes
  198. Radio Repair help
  199. 2 ganged servos for rudder?
  200. Servo ends
  201. is 1100 mah enough for 5 8100's +
  202. Interference from cell phone towers
  203. Switch
  204. purchasing radio's online
  205. reciever help
  206. AM/FM Radio difference????
  207. 4-ch. with a settable servo?????
  208. jr-347 programming issue
  209. Receiver Specs - Airtronics 92265
  210. Have I damaged this hitec225MG seriously?
  211. Futaba 8UAF and Tamiya R/C tank - programming question
  212. Where to buy?
  213. Can the Channel 7 knob on 8uap be turned off?
  214. best frequency
  215. Where to get servo plugs
  216. voltwatch question
  217. Futaba gold got Hot
  218. Wire Gauge
  219. Newbie questions about servo, rx, battery setup
  220. Dual batt/switch setup on one Rx?
  221. Tracker II flaperon work-around
  222. Multiplex - Programming Profi 4000 for Ultra Stick 60 Part II
  223. Wedding ring/ 9C Radio Case Causes Glitching
  224. How long has your JR Backup battery lasted?
  225. New Futaba Radio
  226. Ever heard of BMS servos?
  227. RAM simple cycler
  228. RD6000 Delta Mixing Help
  229. New Transmitter Batteries?
  230. Receiver question
  231. NES-371 submicro servo noisy
  232. flash 5 y-harness
  233. DP tailwheel springs causing radio interferance...
  234. Convert ratchet style throttle to heli smooth style
  235. Glitches when transmitter is off on my new JR R610
  236. Pcm?
  237. RC Servo extensions. Why do they cost so much!?
  238. Radio Glitch
  239. The 6 Volt Queston
  240. raptor 60
  241. JR 811 servos
  242. Hitec Eclipse 7 questions
  243. new futaba servo
  244. What The?
  245. Newby having RX problems
  246. futaba rx fp-r127df
  247. Stylus use w/ Hitec pcm rx
  248. Futaba Conquest 6ch
  249. Where is The Best Place To Buy Servo Lead Parts???
  250. Radical RC (Update)
