PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Where is The Best Place To Buy Servo Lead Parts???
  2. Radical RC (Update)
  3. Sticky Sticks on my TX
  4. Receivers
  5. JR662 Dual Rates and Buddy Box
  6. Servo Screw replacement
  7. Radio Setup, Ultra Stick, Rd6000
  8. programmable surface freq radio
  9. Futaba 8uaps owners question ?
  10. JR XF 631 throttle cut not working
  11. boost range of TX
  12. boost Range of TX
  13. JR XF 631 problem-Help!
  14. How Fast is "Fast Enough"?
  15. Futaba 9c antenna problems
  16. slight servo chatter
  17. jr xr 2?
  18. Which Radio (662, RD8000, Eclipse 7)
  19. Question: flaps and elevator mix.
  20. Servo Mixing
  21. bringing old batterys to life
  22. high or low band?
  23. Futaba to Jr Connector
  24. Futaba R114H compat.??
  25. Hitec receiver - only rudder has glitch?
  26. Need info on a DAD Interceptor 2000 Rx
  27. What should JR radio voltage be?
  28. servos
  29. modify Futaba T4VH skysport
  30. New Rx or new Radio?
  31. Whats the diffeant betwen JR 8411 &8411SA
  32. Futaba 9C- where to buy
  33. NEW 9 CHnl JR radio???
  34. differences in sevo input using Y harness
  35. How to synchronize and reverse servos on split elevator
  36. Changing Freg. ?
  37. Dumb Radio & RX Question.
  38. Eclipse 7 for HH/norm & co-pilot on/off
  39. 1ST computer radio, XP662, 6XAPS, OR 9CAF?
  40. matching digital servos
  41. Fut T6xa Dual rate help
  42. Hi Tec Aristocraft connectors
  43. Bad Connections: Receiver Current
  44. Charging Batteries? What Milli-amp
  45. Is it possible to have full throw on just left with mixing?
  46. Linear Servo v.s. Todays Servo
  47. Futaba 9cap or 6xhs
  48. Is it worth it repairing servos?
  49. Radio for my bird.....?
  50. JR 591 problems
  51. Hitec HS 425BB vs. Futaba S3001 Servos
  52. Hitec Digital servo noise
  53. JR Trainer Cable
  54. FMA 355 Servos ... anyone with experience with these?
  55. 662 vs RD8000 vs Eclipse 7
  56. Battery Cutoff Voltage
  57. 6V vs. 4.6V torque
  58. Split elevator-Prisim programming ????
  59. Difference in Initial Position and Binding
  60. futaba receivers
  61. Old Radio HELP!!
  62. Futaba receiver High or Low Band---???????
  63. Neutral
  64. How long will a radio last??
  65. PC interface Cockpit MM
  66. Pros/Cons for High Band vs. Low Band?
  67. VOTE! Airtronics-Futaba-Jr-Hitec
  68. WANTED: Source for VERY LARGE Servos
  69. Hi Tech reciever with Futaba Cristal?
  70. Futaba's recommendations?
  71. Y harness
  72. Can I use Futaba 9C with Hitec flight pack?
  73. channel that u use
  74. when to use filters with extensions?
  75. will an expert rx work with other tx
  76. Digital servo? Why, it's only .05 faster...
  77. futaba fm to pcm?
  78. hoverin throttle curve mpx 4000
  79. need help here on what TX talk to what RX
  80. airtronics RD6000 mode conversion help..
  81. T8UHP questions??
  82. 9Z - PMX & ALV question. Please help!
  83. Which Radio?
  84. lose antenna --- interference
  85. How many channels??
  86. airtronics servos priceing
  87. Futaba Gold Series
  88. Slop in metal gear servos
  89. Loose antenna base!
  90. Hitec receiver
  91. Rd8000 Vs Jr 8103
  92. Hitech digital servos , any good ?
  93. GWS servo arms
  94. Hitec Eclipse vs Futaba 9C
  95. 662 vs. RS6000
  96. 662 vs RD6000
  97. Airtronics -vs- JR
  98. Soldering wires
  99. flaperon and normal configuration.....?
  100. New crystal or not
  101. I have a prolem with glitching on my GWS reciever
  102. Crystal swap - Hitec to Futaba
  103. Need help w/ 9CHP as master and Super 7 as buddy
  104. Servo City, Talking about service!
  105. Servo requirements?
  106. coreless servo advantage?
  107. source for 'rubber ducky' antennae?
  108. how many volts for a dz8550
  109. controlling servos by computer/rs-232
  110. storing your computer radio
  111. Conversion of Realflight DB15 controller to a Futaba buddy box
  112. Are there any good things to say about PCM Rx??
  113. T6XA Radio Help
  114. XR3 JR reciever help
  115. Hitec - Trainer cord Futaba Compatible?
  116. Vision 8P Vrs Eclipse 7
  117. Futaba 9C - Now Shipping with Free CAMPac?
  118. Futaba 6 channel conquest
  119. Airtronics RD 6000 ......help!
  120. Explain features for JR XS3, please??
  121. Training cord MULTIPLEX Cockpit MM
  122. This wont happen at the field...... but interesting.
  123. 7sp
  124. Eclipse 7 Q-PCM with Spectra Module
  125. futuba 9cap
  126. Great Deal
  127. Elevon/V-Tail Mixing and ATV
  128. hitec Flash 5
  129. Grounding Metal Components - Will It Help?
  130. 9cap compatable pcm recievers
  131. Crystal Compatibility for RF Decks
  132. Multiplex Profi Car 301,403, 707
  133. Servo connectors
  134. T6XAS plane and heli?
  135. GWS for Giant Scale
  136. Eclipse Programming Problem?
  137. *possible* better prices on Horizon's torroid rf filters at BGmicro.com
  138. Futaba 9Z WC2 Vs. New Multiplex R. Evo 12
  139. 4 or more Channel Radio with 75Mhz Synthesizer Tx and Rx
  140. Circus RX question
  141. JR 10X heli/airplane question
  142. What receiver is compatible with Jr radios.
  143. New Futaba 9Z WC2
  144. FM Radio Glitch / Gas Engines / is this a bad mix?
  145. RD6000 and Sirius Pro charger
  146. "dry" battery pack
  147. heli on wrong radio band
  148. Which radio and servos?
  149. Digital servo help
  150. KRAFT Radios
  151. JR Racing XR2 Radio
  152. JR Max AM radio
  153. 8u super and csm 400 setup
  154. airtonics rd 6000, give me the scoop
  155. metal gears
  156. Wiped out by my 9ZAP WC
  157. Zapped by a 9ZAP WC
  158. Zapped by a 9ZAP WC
  159. Buddy boxing the Stylus???
  160. theres a guy that sells gws servos who
  161. "Buddy Boxing"
  162. Ace MicroPro 8000 SS systems
  163. Fast charge (peak charge) JR radio with diode?
  164. Hitec Prizm Low Voltage Warning Go Off much to soon.
  165. 8U super price?
  166. JR and Futaba compatability
  167. newbie/same reciever same crystal?
  168. Eclipse 7 PCM?
  169. hitec Eclpise 7
  170. What do I need for my new car?
  171. JR charging jack
  172. receivers
  173. Are their TrackerII flying?
  174. What type transmitter for KRAFT?
  175. rx chatter
  176. servo torque rating?
  177. Are the multiplex IPD recievers the best ones to use?
  178. battery charge
  179. where can i find the best jr products?
  180. new JR 9 chanel
  181. new JR 9 channel
  182. ridiculous prices for used radios...
  183. Futaba 9ZAP WC2 Question?
  184. Tuning TX and RX to a specific channel?
  185. JR XF631 Radio question
  186. looking for 4 ch transmitter
  187. GWS R4P Pico Type Receiver(single conversion),w Eclise 7 transmiter
  188. JR 8103 vs. Futaba 9C (for Heli)
  189. please help: control surfaces "jump" (?)
  190. NEW Airtonics RD8000 8 Channel Computer System
  191. Difference between the heli and fix-wing version of JR 8310
  192. 6V battery problem
  193. r c radio
  194. Crystal Protective boot
  195. Hi-Tec SuperSlim - will it work?
  196. delete thread
  197. Damage to Transmitter?
  198. Throttle channel becomes elevator channel plz help
  199. Programming the JR 8103
  200. Multiplex Receiver Crystal Question
  201. Antenna Interference
  202. JR Servo Question
  203. Repairing broken TX antenna?
  204. Old Radios
  205. Threaded Brass 4-40 Pushrod Connectors???
  206. 8 ft Beaver - extensions
  207. Buddy Box, JR Quattro & JR 662 ?????
  208. making servo extensions
  209. JR R600 Receiver with problem
  210. Airtronics Radiant Transmitter ?
  211. Delete
  212. R/C newbie looking for opinions-cheap radio!
  213. A question about compatibility
  214. Futaba FF9 Set Up Advice
  215. servo lead
  216. Recommended Radio's
  217. Futaba Channel Expander
  218. Any way to extend my range?
  219. Hitec Member Club!!
  220. Futaba 9151 Servos
  221. JR 4001 servo specs?
  222. Airlines and Radio Gear
  223. Any PC programmers use JR?
  224. Multiplex - Where can I buy connectors
  225. Jr 4721
  226. Mini Manta - What RC Equipment - Newbie
  227. Is there a good source of info for Tx/Rx compatiblity accross diff manufacturers?
  228. Hi Tec 615MG servo question
  229. Futaba s130 servo
  230. Servo Eyelets
  231. Polk's Hobby Tracker II
  232. newbie shopping for servos
  233. Tracker Ii User Comparisons,comments And Observations
  234. hitec prism 7x is this a good tx
  235. Flapperon programming on the JR XP8103
  236. Using RD8000 & RD6000 on Buddy Cord
  237. Polyswitch info
  238. Cox Cadet Digital Proportional Radio Transmitter
  239. NEW Airtronics VG6000 computer radio info
  240. Need help JR 10x Rx Probl.
  241. help on 8UHP LCD contrast adjustment
  242. Futaba buddy box tip
  243. Futaba 3PK HRS Crystals, HUH?
  244. Please help - New to this, making a giant RC car...
  245. Quick question aerodynamics.
  246. What is the difference between PCM and FM Radios?
  247. Airtronics spectra PCM7
  248. Airtronics spectra
  249. Trainer cord use
  250. Idle Up 'stuck' on Hi Tech Eclipse 7
