PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. ACE servo cycle
  2. Multiplex - Programming Profi 4000 for Ultra Stick 60
  3. Proper Charge capacity for..
  4. Radio setup help for a Heli
  5. double servo for elevator
  6. Eclipse 7 PCM
  7. Quality & Centering Ablity Of Hitec 5625's
  8. Multiple servos
  9. Can you repair servos yourself?
  10. How to Program Flaps on 9c
  11. which servos?
  12. Does Channel Matter on 72 MHZ FM System
  13. eclipse 7, servo reversing
  14. JR/Futaba compatibility?
  15. 9C setup for flaperon and crow?
  16. Futaba 6xas- or JR 622
  17. Futaba buddy Hi Tech?
  18. Will a T6xhs operate a airplane?
  19. HiTec Focus-6 systems.
  20. Cheap 5V Power for R/C Setups & Bench Adjustments
  21. Micro Rx.
  22. Nimh pack for T-Maxx not charging
  23. Dual Recivers
  24. Tune radios
  25. new futaba six channel on market
  26. Airtronics TX and Rec.
  27. Futaba 4003 servo centering slop
  28. Futaba WC2
  29. Digi-Switch Harness(HELP)
  30. crystals
  31. I bought a Futaba Super 7 and I have a question.
  32. Futaba 6XAS vs. Hitec Flash 5
  33. computer radios
  34. Split Elev On 10sx
  35. upgrade jr 783 with ccpm ?
  36. Mysterious JR
  37. Aileron and elevator glitching in new Great Planes 1/3 Scale Pitts
  38. MPX 4000 & Switch ergonomy
  39. Interference?
  40. What radio do you use?
  41. JR XP662 User Manual
  42. Another crystal question..
  43. AM airtronics ..gold sticker?
  44. sold
  45. release date for the JR10X
  46. Airtronics Stylus question
  47. 9cap pcm rx question
  48. parts for challenger 720
  49. Need Eclipse 7 help!!
  50. SERVOS JR & Futaba
  51. Using model memories for backup
  52. Throttle cut set-up
  53. JR 8103 DT airplane version
  54. Futaba or Hitec?
  55. Fused Link Questions ?
  56. NiMh battery question
  57. Need receiver help
  58. Futaba 8U
  59. Rate Gyro as hdg hold?
  60. Need info on JR Vegas 5 ch heli radio
  61. Changing channels
  62. Hitec Eclipse 7 Heli set up
  63. Metal Gears For S3102 Fit Into S3101?
  64. Crystal Swap - Airtronics
  65. Support Equipment for NiMH batteries???
  66. Other uses for 9C Dials/ sliders??
  67. Airtroincs RD6000 Hellp
  68. FM and PCM
  69. Hitec receivers Fut/Air
  70. Whats the best aftermarket reciever
  71. 4721 to 2721 conversion?
  72. Whats the difference betwwen JR's 10,10s,10sx,10sxII
  73. Installing Xtals
  74. Hitec Eclipse 7
  75. MAX radio information
  76. Simple radio questions
  77. Hitec HS-81 on throttle?
  78. Pcm?
  79. Hi Tec HS -700 question
  80. Searching Harry Higley manual book for jr 8103 programming
  81. Robbe FS 500 Servo problem
  82. 10x question?
  83. Radio on European frequencies?
  84. BB or not BB for Ailerons and Rudder
  85. JR NES 331 Mini -- What Type of Servo is This?
  86. Charging Rx batteries
  87. JR 10x or Futaba 9Z
  88. HS-225BBs have no business in a 40 sized Fun Fly
  89. help please
  90. XS3 vs. 3PK
  91. Anything New With Radio's I Should Know
  92. SuperTec seros
  93. Anyone using FMA servos?
  94. weird aux servo problem
  95. gws transmitters
  96. Futaba Fp-t8sgap/moderator- please delete this thread
  97. GWS servos thats the deal with these
  98. GWS Receivers
  99. Servo Jitter when Glow Driver present, but Tx off
  100. 3pjs
  101. + & - shift switching
  102. Warning: BAD service from Servo City
  103. Will expensive servos really fly better?
  104. Set Up Guide Futaba FF9
  105. wiring on royal "super sport" sevros
  106. Factory installed smoke?
  107. WANTED: Used mini gear
  108. Did anyone ever use the Futaba MSA-10 servo device.
  109. Need advice for my first radio. Any Suggestions
  110. Is Horrizon the only place to get JR-R610M
  111. Can I use my Futaba radio and a JR reciever???
  112. Mixing trouble
  113. Cut the conduit on my antenna, help.
  114. Hitec servos w/ Futaba receiver?
  115. Crystal Questions
  116. 652 flap to elevator mix?
  117. How much torque for a 120 sized plane?
  118. Can a Hitec servo programmer be used on Digital & Analog servos
  119. About to spend a chunk of change on servos!!!
  120. HiTec rcvr compatability
  121. Using an "air" radio for "surface" vehicles
  122. Servo lead chafing
  123. Best neck strap for 10x ?
  124. Digital Servo Durability
  125. Paperwork
  126. 9zas Wcii
  127. [Deleted]
  128. 2 receiver setup
  129. Great accesory for your radio system
  130. [Deleted]
  131. Crystals and Modules... What are they??
  132. FMA AM Receivers
  133. Twisted wire on Hitec servos????
  134. What Radio Futaba Vs Jr
  135. How should "on" "off" switch be positioned?
  136. 8311 or 8411?
  137. xtals
  138. Servo City 4:1 gearbox...anyone used one yet?
  139. chatter buster ? anyone know which magazine had the article ?
  140. transmitter modules
  141. Tracker II at 50mhz
  142. Royal Electronics Servos
  143. Weird 9C problem
  144. What to do with 3rd channel...
  145. Can carbon fiber cause radio interference?
  146. Dz8550?
  147. i4C V-Tach?
  148. Which Servos?
  149. which PCM radio to get for FMA co-pilot use?
  150. strong servo
  151. Which Servos for my new 1/8th?
  152. futaba 8UHAP manual
  153. Molex connectors
  154. Graupner MC-24
  155. Which way to go?
  156. Ham Radios
  157. which servo
  158. Flash 5 to Focus 4 via Futaba Cord - Watch out!!
  159. R-1 Guide in Spanish
  160. Radio controls....
  161. Crow?
  162. manual wanted for a Heathkit 1205 Tx system
  163. Where are you guys buying servos from?
  164. Dual Receiver Questions
  165. JR & Hitec
  166. JR PCM9 Manual
  167. anyone know what's up with RD8000?
  168. Help with esc (bec working motor won't run)
  169. Good Quality Standard Servo?
  170. need help with radios
  171. 2nd battery for back up
  172. futaba 9c
  173. vtail mixer overheating
  174. the better radio
  175. Who knows SIMPROP, what happened to them( radio gears)??.
  176. Orbit Electronics
  177. Cirrus 9gram Servos????
  178. This worked for me
  179. Futaba and Hitec Buddy Linked?
  180. 2.6mm screws - where to buy?
  181. Jr Radio Channels
  182. JR 8103 3+1 digital trim transmitter
  183. can u use 72mhz AM anymore?
  184. Futaba T6HXS Problems
  185. Stumped!
  186. Traducción del manual de la emisora JR R-1 al español
  187. Futaaba 9C Tx Flap Operation
  188. R-1 Transmitter Guide in Spanish
  189. Futaba 6Xas PCM or PPM Version??
  190. rea time airspeed data
  191. Servo and Receiver Interference
  192. Flying Site Spacing/Radio Interference
  193. Tuning receivers
  194. RX and TX channel change
  195. Airtronics VG600 6-Channel FM
  196. Pros & Cons of Putting All planes on One Radio???
  197. Servo Brands
  198. GWS Digitals
  199. Servo Question
  200. Gidderiing Servos?
  201. Why is the Futaba 148 servo so popular for throttle?
  202. Aluminum Diamond Dust Spars?
  203. JR receivers don't ALL s***
  204. S9201s jittery, have repaired or pitch?
  205. RCS Servo controllers?
  206. There is a tracker ll
  207. problems with voltz servos and long leads
  208. 180 Degree Proportional Servos?
  209. World engines Expert Radios
  210. Testing with a different crystal
  211. Dumb newbie Question
  212. Multiplex receiver
  213. changing tx crystals
  214. Futaba 6XAS Programming
  215. newb battery question
  216. Optical Coupled Servos ???
  217. I accidently cut my antenna wire, can I solder it?
  218. buzzing servos?
  219. AM vs. FM
  220. Crystals
  221. Antenna question
  222. Profi 3030 question
  223. Lots of radio questions!
  224. One channel Xmitter & Recvr for Freeflight
  225. is RD8000 a good heli radio?
  226. JR Horn Supports
  227. what voltage for JR R610m receiver
  228. Has anyone ever had a Rx repaired?
  229. Cockeyed control stick on JR radio.
  230. Crystal brands ... any difference ?
  231. reciever problems
  232. Servo Centering?
  233. Older Futaba FM
  234. Pinouts and specs for 9C trainer jack.
  235. Futaba 9CAP vs. 9CHP (Again????)
  236. compatible servos
  237. antenna
  238. 9c
  239. Hitec's Eclipse 7 PCM
  240. 8103 spoiler mixing
  241. Futaba 8u super series
  242. JR super servo and digital servo
  243. Futaba R148 & FMA Co-Pilot mating to Quad Flaps
  244. Futaba 9CAP Questions
  245. Umm Ok. (servocity.com)
  246. Hitec Featherweight receiver question
  247. Adding Flaperon and other Mixes to Airtronics Vanguard
  248. Servo Isolation
  249. Umm. REALLY strange problem.
  250. battery to powersupply
