PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Hitec Servos ? ? ? ?? ? ? ?
  2. Profi 4000/servo question
  3. Antenna Wire
  4. Need help setting up quad flap with jr378
  5. old servos
  6. 9C throttle ratchet
  7. RX crystal question
  8. Futaba 129DP om 6 volts
  9. throttle servo
  10. MPX Cockpit MM
  11. FS Futaba FP-R148DF
  12. futaba help
  13. more Kraft stuff
  14. Kraft radios,,any interest???
  15. Need schematic diagram please !
  16. servo jittering help!
  17. Hobbico Rx.
  18. Futaba FG "gold case" parts?
  19. Interference at the local field
  20. Best deals on JR 10x ?
  21. JR 378 programming for Ultra Stick
  22. How do I know which servo to use?
  23. Help Identifying Receiver Component
  24. RC Universe Crystal Exchange Swap forum
  25. New Futaba Release
  26. receiver glitching!?
  27. Kraft radios,,any interest???
  28. flying wire interference???
  29. JR R900 Receiver
  30. JR to Futaba
  31. servo comparable to the jr 537
  32. Futaba servo source,$$$
  33. jr 378 additional channel
  34. JR radio
  35. Bypass charging diode Prism 7x
  36. JR662 and Ultra Stick quak flap setup
  37. Charging Rx Batteries
  38. rd 8000
  39. Servo test function? Help.
  40. Multiplex 3030
  41. wet radio gear
  42. Help Me
  43. HS 605 bb hitec servo
  44. prizm 7 programing
  45. Great Do-it-yourself electronics site
  46. Servo's
  47. FM TX 27MHz
  48. Hi-Tec Challenger 4000
  49. questions about hitec digitals
  50. rx antenna routing
  51. Problems With Futaba FF8 radios
  52. Royal EVO reset
  53. is it possible to add more channels to the futaba 4vf?
  54. Stupid Question
  55. Help!
  56. Servo Reverse Scematic
  57. HS-81 servo problem
  58. Inverted flight with a mix ?
  59. Powering LEDs from a RX chan?
  60. FUTABA 6AS super(PCM) antena question
  61. 6XAS and twin elevator servos?
  62. Servo bounce
  63. Dan JR part for TX
  64. Transmitter Range Check
  65. Eclipse 7 setup for Ultrastick 40
  66. I messed up charging my JR 662 Tx
  67. Dual Frequency Tx and Rx.
  68. hi or low
  69. Phone #
  70. JR-TX fuse holder problem
  71. Have some questions, should I get FM or PCM?
  72. 6V with futaba rx and hitec servos?
  73. What is the difference between the older JR 10sx and the new 10x radio?
  74. HELP. Reciever or Gyro problem.
  75. testing servos
  76. switch jr servo to futauba question
  77. Looking for a nice Radio/RX for $200-$300
  78. Battery / Servo Question
  79. Receiver Question
  80. Opinions Pleazzzz
  81. Sanwa 6000 super or the JR 3810?
  82. JR XP8103 UK / USA frequencies
  83. Please Help with Servo Question
  84. Hitec Digital Servos
  85. receiver compatability
  86. Fp electro'Dynamics
  87. RX Antenna, Can you double length?
  88. Radio tuning
  89. Strange Radio noise.
  90. new radio
  91. AM > FM interference
  92. Which Hitec servo for heli ?
  93. Antenna inside CF reinforced fuselage. OK?
  94. Changing Rx shift?
  95. Battery for Futaba R127DF
  96. How much does a Futuba cost ?
  97. HS 5645 Problems
  98. FMA Direct receivers with Hitec crystals?
  99. Deans loaded Whip antennas
  100. Eclipse 7 programming
  101. Difference between High Band, Low Band Rx?
  102. Ever program your TX in the air?
  103. anyone have pinouts for Hitec (Prism 7x) Trainer Jack?
  104. wiring aileron servos
  105. Cracked RX casing
  106. Dual Motors
  107. Gas Engine & insulated servo leads
  108. Crystal Cover
  109. Question about 8103 ATV settings
  110. Frequency tag
  111. help!
  112. radio advice
  113. hitec receiver futaba radio
  114. Broken TX Advice -- XF622
  115. Servo Power Connection
  116. 3 pin deans/servo wire
  117. JR 622 only shows 0 Volts.. Can anyone Help
  118. Need radio advice
  119. Steering
  120. centering a servo
  121. Zhen Hua radio question
  122. Gyros-mechanical or piezo?
  123. Crystal changes Hitec Eclipse ?
  124. What size battery??
  125. must use dual conversion crystal with daul converion RX ?
  126. What's this spare cable for on the gyro?
  127. futaba FM will not pass range test ??
  128. Radio Channels
  129. Graupner MC 18/20
  130. Airtronics RD8000 Recall
  131. Hitec prices
  132. soldering servo wires
  133. Power for strobe lights
  134. Help!
  135. What are specifications for Airtronics 94151 & 94735?
  136. jr 610 RECIEVER IN .40 GAS PLANE?
  137. Computer radio programing lititure?
  138. JR Servos with Futaba Tx/RX
  139. Y Harness wont work with five cell pack
  140. PPM versus PCM
  141. Transmitter Stick Extensions?
  142. What is the equivalent to a Hitec Eclipse in th JR range?
  143. Futaba Servo Repair
  144. micro servo's
  145. Dual receivers?
  146. Correct Servo for 1/4 Scale Lazer
  147. JR X-378 Aux switches
  148. Buddy Box
  149. Crystal Change
  150. Changing crystals?
  151. Royal evo software
  152. Servo City
  153. Ground check problems?
  154. Gyro's
  155. The FINAL argument for Futaba's Superiority
  156. futaba FP-T7FG/k battery help
  157. Futaba 6YG Vs Hitech Lazer 6
  158. Need a service menu enabler (second post)
  159. Futaba 9C & trim Memory
  160. 4* 60 Servo Extensions
  161. Best Place to order Radio From
  162. jr propo10 in ppm mode jr rx's not working?help
  163. AM to FM Module
  164. Cleaning your Radio
  165. How many digitals max?
  166. Strobe Lights radio enterference
  167. JR 8103 Programming
  168. Servos for F3J wing's elevons
  169. Flaperons/Airbrakes
  170. RD6000 switch charge plug
  171. JR 8103 Transmitter
  172. Hitec HS-605BB servo problem
  173. 91 Legal or gold sticker am radio's, are they legal
  174. Radio buying question ?
  175. Aitronics crystals
  176. Acoms Receiver Short Range
  177. JR F400 Parts
  178. Futaba Vs JR Radios for Sailplane Application - Which is better?
  179. Need your opinion. futaba9c or hitec eclispe7?
  180. HELP WITH 6XAS and PA1 PILOT ASIST
  181. Newbie to digital servos question
  182. Gws Servos
  183. COMPUTER RADIO HELP
  184. receiver crystal
  185. Radio Technical Help
  186. Hitec VS Futaba Reveiver....?
  187. Airtronics Non-Z receiver & Hitec servo (Help)
  188. air combat system
  189. JR 631 Servos/RX/TX ? Twitching Bad
  190. istalling servos
  191. Futaba gyro/6v battery?
  192. Servo reversing ---Help!!!!
  193. Left radio on all night.
  194. Radio Brands - New vs Used - Any Advice?
  195. Battery and Speed Controller question
  196. Airtronics Z connector help?
  197. Tx with module recommendations wanted
  198. Futaba 9 CA Buying one today..who has THE BEST price on TX only?
  199. newcomers question & answers
  200. PCM specs
  201. Airtronics Stylus Flap and Spoiler
  202. Airtronics PCM/PPM Question HELP !!
  203. Old Receiver ESC Help
  204. Futaba Receiver
  205. transmitter circuit required
  206. Info on the old FG series Futabe radios
  207. Compltible RXs for 6XAS D/C PPM????
  208. servos
  209. 9CAP Throttle stick inputs reversed??
  210. Hitec Servos/Great Service
  211. Tips to remove Futaba servo plugs from receiver?
  212. Need to borrow a service menu enabler
  213. JR 517 Servos
  214. HiTec Feather receiver in a T-Hawk
  215. Rc plane & Rc car frequancy problems?
  216. Hitec Service is the BEST
  217. FUTABA R127DF RX bought used HIGH or LOW???????
  218. Servo: oz/in to pounds
  219. AIRPLANE receiver options for 9CHP?
  220. Does anybody really know?
  221. My new RD-8000
  222. Receiver battery lead length????
  223. airtronics receiver Z connector?
  224. Hitec servo, Futaba plug, JR receiver?
  225. Graupner/JR Magic Box Matchbox
  226. Graupner/JR Magic Box Matchbox
  227. Ace Olympic 5 to 5 channel?
  228. singal or dual conversion
  229. Transmitter memory...???
  230. Mixing Guidelines?
  231. Airtronics module 7P help
  232. Y vs. mixing
  233. Custom Electronics - Contact Info
  234. Need help with Tx & RX frequency
  235. Not name brand stuff, but need tech advice.
  236. Futaba 3PDF-X vs. Airtronics MX-3
  237. Hitec Digital Problems?
  238. electric heli and radio.
  239. Servo City...
  240. Licensed operation on 72 MHz LONG!!!
  241. HELP! Miracle-Y not so miraculous after all
  242. Programming the Futaba T8AUF for dual flap servos
  243. What Device Should I Use For Complex Articulation
  244. Intermittant 9CAP Operation
  245. Hitec 5475 econo digi servos...Any good?
  246. Hey AnnMarie--you are back!!!!!
  247. A few radio Qs' from a beginner
  248. Airtronics, Futaba, JR
  249. Futaba FF9, 9CHP and JR PCM9X
