PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Please help
  2. Can I do it in this way?
  3. Info needed on FP-T6FG and FP-R107Q
  4. Did I just blow it?....
  5. Futaba 6xh t. trim
  6. rubber duck antenna and electronic ingnition engines
  7. Transmitter radiation pattern
  8. Info on glitch counter BC-6
  9. Multiplex Servos for 40%, I'm A Neophyte
  10. Hitec or FMA receiver for Futaba 9C?
  11. Campac for Futaba 9CAP
  12. Changing from Ch 44 to 35 Futaba?
  13. Futaba 3fr Fm R114f Receiver
  14. Futaba 401 Gyro + dig servo
  15. True redundency
  16. AM Receivers ? ?
  17. How/Where to run antenna on sail boat??
  18. buddy box cable
  19. air/heli
  20. A dumb Rx question
  21. Question about mid 1980's radio
  22. Trainer Switch
  23. Tail bouncing problem
  24. Futaba 8UAPS pcm or Futaba 9CAF 9-Channel FM
  25. Eclipse 7 or RD 6000 compatibility question
  26. Glitching servo on Ultra Stick 60
  27. how to program new model into radio
  28. Receiver and Transmitter mixing
  29. Glitching at full thottle!!
  30. question on 6.0volt reciever battery
  31. AM tx to FM rx
  32. 1,500 and still climbing
  33. CCPM mode on a JR8103?
  34. Do I need another channel....?
  35. New Radio?????
  36. Old and new servo leads
  37. Futaba G transmitter fried... HELP
  38. Airtronics Quasar Help Please.
  39. ********CLOSED*********
  40. Airtronics Quasar Help Please.
  41. Airtronics Quasar Help Please.
  42. Switching from 600mAh RX battery to 700mAh. What will happen?
  43. Do I need another channel....?
  44. RF and Servo transmission specs
  45. MPX mc3030 vs. Royal evo 9
  46. FMA Co0Pilot
  47. Futaba 6XAS PCM to PPM question
  48. What is different about 9cap (air vision) (heli version)?
  49. Did I screw up???
  50. Electrifly 5 ch. rcvr wi built in 30 A ESC
  51. 9cap- They Say It Will Do Both ,pcm & Fm
  52. 9cap 9zap
  53. Servo Twitching
  54. An idea to increase Control Surface speed
  55. JR PCMS Receiver
  56. AM Receivers
  57. What do I need to fly on different freq's? Futaba 9C
  58. problem with 9zap (two elevator servos setup)
  59. Elevators pich down with full rate
  60. Tons of radio problems. Hitec radio, please help.
  61. I think I fried my radio!!!
  62. JR X378 FM 7 compatibility
  63. sanwa pin designations
  64. First Radio...
  65. Hitec 605 servos
  66. can Focus 6 use for heli?
  67. GWS Recevers
  68. high speed servos
  69. synthesized downside
  70. synthesized downside
  71. 4.8v battery to 6v battery, do I need regulator?
  72. 3PJS Frequency query
  73. Change Mode1 to Mode 2 on Sanwa
  74. easy servo reversing
  75. JR700 reciever any good?
  76. Futaba receiver w/ JR servo. Any power issues?.....
  77. Extreme Rookie Question...
  78. Thinking of the future...
  79. Futaba radio question from a rookie
  80. DSP4 SC receiver
  81. Multiplex Pico TX probelm - Pse Help!
  82. Servo connectors.
  83. JR 537 replacement gears
  84. dual servos on aileron and flaps help setup
  85. Using JR servo with Futaba receiver. Can I do it?
  86. Swapping out switch for a pot
  87. Futaba Connector Part Numbers
  88. What exactly is a digital servo?
  89. Changing crystals
  90. Looking for comparison - Graupner mc24 vs Multiplex 4000
  91. How they tune the rx and tx
  92. How to mount a servo
  93. How do I make a y connector?
  94. Narrow Band
  95. MPX 3030 Question
  96. World Engines Expert 7ch and parkflyers?
  97. Futaba 9CHP timer question
  98. fail safe / range test
  99. 9Z Conditions
  100. Need to slow down a servo.....HELP!!
  101. PCM micro reciver for Hitec Challenger 550
  102. PCM Question
  103. airtronics stylus
  104. Tower System 2000 Servos
  105. Help with Futaba Super 8
  106. Rubber servo mounts...what do you use?
  107. Micro radio pacs
  108. Homebrew 9C to FM adapter for Realflight, help.
  109. Graupner MC15
  110. Kraft RX??
  111. single RX and two antennas ???
  112. major servo twitch HELP!
  113. Batteries for old Kraft radio
  114. looking forolder airtronic servo specs
  115. raido ?quasar 6
  116. Channel Statistics
  117. Best all-around digital Servo?
  118. Unassembled Connector Source?
  119. How many servos are enough?
  120. Help with JR G450 gyro..
  121. MPX 1020 -manual instruction?
  122. Radio Question
  123. Help with a T9CAP & ailerons
  124. Best price on 9ZAP WC II?
  125. Futaba Digital Servo
  126. Graupner MC15
  127. Flash 5 or Laser 6?
  128. Hitech 555 problems ????
  129. Best Servo Arms???
  130. Anyone know of a way to flip 1 switch and reverse all the throws on a Futaba 8U Super
  131. Airtronics Radio Question?
  132. What size battery??
  133. hi-band.........lo-band?
  134. Virgin Batteries and an Old AM Radio
  135. saving wet radio parts
  136. hitec digital "+" symbol?
  137. Gyro Question
  138. Anybody make their 9C shift selectable
  139. I Need Help Please
  140. Ferrite Beads, Noise Traps, Wire Gage
  141. what ch is it
  142. receiver tuning
  143. Power Pacer battery cycler
  144. Silver wire servo wires.
  145. JR783 pcm crystal swap????
  146. how hard is the 9c to opperate
  147. Good Service.
  148. servo extension wire type?
  149. adding a 5th channel
  150. What Setup and Is a Matchbox or MSA necessary?
  151. Where to buy Futaba 9C Transmitter only.
  152. help decide which radio (PLEASE)!!!!
  153. Futaba 8U Super Question???
  154. problem with chanell 5 switch in 6XAS
  155. Jr Max6
  156. Radio Noise
  157. Information about JR PCM 9X / MX-22
  158. TSS-51 servos comparable to?
  159. Legal Radio Freqs
  160. Range check ??????????
  161. Hitec Flash 5 "System X
  162. Futaba 9C Help
  163. Servo dilemma
  164. Multiplex Pico Line - TX Programing
  165. Sanwa RD 6000 Super
  166. Jr Xp642
  167. any one had problem with service at servo city?
  168. Need Help... "Mixed-up"
  169. GWS Xtals in Futaba recievers
  170. Another Datasafe 2 Interface Problem
  171. hitec feather receiver question
  172. Wiring a 33% aerobat
  173. Rec. crystal
  174. single stick 4 channel
  175. Futaba 9C and Flaperon Question
  176. Hitec Focus 4 Vs JR F400
  177. Multiplex Pico-Line TX manual wanted....
  178. airtronics receiver xtals
  179. Which receiver - servos to buy?
  180. 72 MHZ or 50 MHZ
  181. Futaba 9z Or 9c or 8uap
  182. Its Gona Coast How Much
  183. Your next TX purchase will be a ....
  184. what brand radio do you use
  185. Toggle switch replacement
  186. Old-school newbie here......
  187. switch interrupt servo lead?
  188. mastering the 9Z ?
  189. JR and channel 13 ?
  190. picture of REvo with tray
  191. Antenna load on a Tx
  192. Radio Range - Begginer's Question
  193. First time buyer needs help
  194. Futaba 9C or Multiplex EVO9 or JR Propo 9X???
  195. Did I crash or was it the RECEIVER
  196. help my max6
  197. HS-81 servos don't center when off
  198. Futaba Digtal Servos ????????
  199. A couple Futaba 9C questions, Please help.
  200. Changing from 2ch electric over to gas power
  201. Futabe 9CH or 9ZH
  202. hard carry case for Tx
  203. Best deal on JR Servos ?
  204. Lubricated receiver
  205. Jr Pcm 9x Radio Information
  206. Glitching Problem?
  207. JR 8411 Digital Servos
  208. Servo Differences
  209. Hitec Servo
  210. Cirrus CS-10BB servo gear train
  211. steering
  212. servo amplifier
  213. Cheap receiver
  214. wide band / narrow band
  215. HELP!!! JR TX, Airtronics RX compatiblility Question
  216. Jr 8103
  217. operating range of radios
  218. crossed wire's on hitec receiver
  219. Futaba 9Z sticks for JR radios.
  220. Hobbico recievers - info?
  221. Classic radio suggestions
  222. Making long extensions Help
  223. Please close
  224. Replacing geartrain in Hitec 605BB
  225. Futaba Ailevator problem.
  226. Futabs 9001's. How are they??
  227. rudder / gyro ?
  228. Which Radio to buy
  229. Futaba J plugs and wire
  230. Voltage drop in cold weather?
  231. Is it legal to Mod a transmitter (US)?
  232. Question regarding Crystals
  233. Looking for the correct Futaba receiver
  234. Hitec 8ch Rx Question
  235. Airtronics 28 Vanguard
  236. FMA Co-Pilot - Who has the best price?
  237. 53.2 Mhz Receiver needed!!
  238. GPS Transmitter
  239. Hitec Service
  240. What Servo Would you Use
  241. Why do my Hitec servos have more travel than my Futaba's
  242. Artronics trainer cord
  243. Someone please give me a clue!
  244. Analog vs Digital
  245. Kraft radio trove
  246. Manuals And Schematics
  247. Jr10sxii
  248. Hitec flash 5X or Futaba 6YG, what do you recomend?
  249. JR Circus Illegal ?
  250. 309DPS-battery into DSC port
