PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Hitec 5735
  2. Need help - Opening a box's lid
  3. Co-pilot and PA-1
  4. expert radio
  5. radio repair
  6. Dual Elevator Servo's - Y or Y-Not?
  7. voltmeter
  8. Futaba 138 Receivers - Vibration
  9. ??wise To Place Rudder\elevator On Same Chan.
  10. JR R600 antenna length
  11. multi channels radios
  12. Futaba 6XAS... pros? cons?
  13. Crystals- the more I learn, the less.......
  14. 6.0v with Futaba 350 gyro?
  15. tough one--JR TX/Airtronics RX ??
  16. 5625 Hitec Dig.servo
  17. JR XP8103 for gliders
  18. Servo Control horn compatability
  19. That's it, never buying from Tower again...
  20. Servo power requirements
  21. Question about Radios (RC Begginer)
  22. Why the difference in price?
  23. JR 622 programming
  24. JR R600 receiver - Is it good?
  25. futaba 9chp
  26. To Cold To Fly
  27. European 72MHz frequencies ?
  28. Futaba 9c, Can I Slow My Retract Servo Down??
  29. FMA receivers comp w/Hitec crystals?
  30. PCM/PPM signal capture
  31. Futaba 9C and Airbrake function
  32. Expert retract servo
  33. Jr 8103 Tx
  34. Futaba 9c
  35. Which Charger/cycler is best
  36. Futaba Fc-28
  37. 6 UAX Futaba Shutters
  38. Digital Servos
  39. HELP ME BOYS!!! FUTABA 9Z or JR 10X
  40. Did the falcon shoot us down??
  41. 9c flap vs full length ailerons
  42. futaba 9C and 6 volts?
  43. Switch servo leads to aluminum?
  44. JR Tx Module Question...
  45. Servo by Expert, are they made by JR?
  46. Rx antenna, HELP!
  47. mostly synthesized tx/rx use in Japan??
  48. Airtronics "Quasar" Transmitter
  49. Royal Evo - what do you want to know about it?
  50. Tracker II
  51. RD 6000 spoilerons
  52. new multiplex Pico for 34.99
  53. mini receiver for Futaba 9Z help
  54. Futaba Contest FP-R7L
  55. 9252 servo crapped out
  56. Micro Recievor Help?!?!?!?
  57. Purpose of Diode on TX for Charging
  58. Trying to Locate Online Reseller of Transmitter Trays
  59. Single Stick Radio?
  60. futaba t9cap
  61. Using two Batteries with a single receiver
  62. Comparing the 8103DT to the 9CH
  63. interference from another TX
  64. What Frequency to use
  65. need JRxf421
  66. 2000mAh Battery packs?
  67. How many channels is enough?
  68. another what radio question
  69. EK Radios
  70. Battery Question Airtronics RD6000 Sport
  71. Which mode???
  72. Confused: Changing Internals from Mode 2 to Mode 1
  73. Kraft Gold Spectrum 6
  74. Help with Hitec Focus 6
  75. Negative and Positive Shift?
  76. What do you think of the JR R955 receiver?
  77. AM Tx as buddy-box to FM Tx??
  78. Does the RD 8000 have dual rates for rudder?
  79. FMA Quantum 8 Sub Micro Receiver
  80. Futaba servo problem?
  81. Need help to id: JR narrow band vs wide band TX
  82. Question about Futaba 9c 50 mhz output.
  83. Upgrading Old Heathkit 8ch ss
  84. heli radio with servos
  85. FM or PCM?
  86. How to test servos for damage?
  87. Old radio - from 60's or 70's?
  88. Hitec digital Servos vs JR 8411's
  89. 9CAP TX LCD problem
  90. Help needed - Kraft Multicons
  91. Kraft FM modules
  92. Boy just once
  93. What size servo
  94. JR question sooo confused?????
  95. Cool Joystick for Microstar based Transmitter
  96. range on my radio
  97. voltmeters
  98. modifying old tx for aileron rudder coupling
  99. onboard mixer?
  100. Radio Questions
  101. Receiver Antenna Routing
  102. Unable to contact Multiplex/Karlton
  103. Jr 783
  104. Futaba 9CAP RF Modules.
  105. Here we go another newbie ??
  106. hitec receiver futaba radio
  107. Futaba crystals in old Airtronics???
  108. NEON upgrades
  109. HH gyro's "other" uses
  110. Is 29.xxx MHz a legal channel for RC?
  111. BEC w/jeti 110 and airtronics mini reciever
  112. Opinions on JR MAX 6
  113. CamPac on 9C
  114. Futaba 9C Radio
  115. Frequency question
  116. MicroStar Conversion
  117. JR Quattro Buddy Box - Burned up?
  118. any info on a Cirrus baja 250
  119. Dual servo's
  120. I've heard a lot of negative talk about Hitec servos...whats the true story with them
  121. Where can I get AM receiver crystals
  122. futaba flight pack with a hitec radio????
  123. 138DP vs 148DP
  124. Simple? MPX Profi 4000 ?
  125. XP8103 Heli
  126. New JR Radio?
  127. Futaba digital servo works in JR radio system?
  128. Why are Multiplex users so darned evangelical about it?
  129. Futaba 9CAF Pros and Cons
  130. Mounting Servo Under Cowl
  131. Futaba PCM/4 S3001 Servos strong enough?
  132. 8103 mixing
  133. jr - won't power on
  134. Experiencing Radio Interference Problems?
  135. Anybody having trouble with digitals
  136. Rudder servos for 35% edge
  137. Rudder sevos?
  138. I cann't use Ch 20 in my area, how I can changed to Ch 19?
  139. TX battery charging problem!
  140. Confused about Mode 1 or 2
  141. Tx/Rx battery ma's
  142. Futaba Receiver Compatibility
  143. Multicon Amp. compatable w/modern radio?
  144. If you had $350 for a radio system...?
  145. Gears - Futaba S5101
  146. 9c Question???
  147. Programming Futaba Super 7 with Stick
  148. Can't get to full flaps with JR 8103 landing switch
  149. 9c aielerons/elevator questions
  150. Need help with my Electric Razor (Zagi)
  151. Kraft Kp-5 Sport Series
  152. help! with servo extentions!!
  153. My Longitudinal & Latitudinal Range is Different ???
  154. Futaba 9C question
  155. crystal identification
  156. JR 8103 Prices
  157. what is the range ?
  158. Which expanded scale loaded voltmeter to use
  159. Recommend a radio
  160. Standard wall wart capability
  161. Trainer module for MC12
  162. fma m5 rx antenna torn need pic
  163. disabling the ch.6,7,8 knobs on an 8UAPS?
  164. Airtronics RD6000 vs JR XP662 vs Hitec Eclipse 7
  165. Where does one find replacement switches for their TX?
  166. One radio for one receiver?
  167. Question about my battery pack:
  168. Hitec Servos??????
  169. Airtronics to Futaba Buddy Cord
  170. High Band Rx, Low band Tx..
  171. Failsafe
  172. Does Graupner rx R600/R700 have AGC?
  173. Programming A Jr-r1 Pcm Radio
  174. 9Z WCII - Removable Tx Battery?
  175. hitec focus 6 , good or bad?
  176. different gears for hs-300
  177. XP8103 Vtail - Rud/Elev question...
  178. Are Cirrus and Futaba the same?
  179. Dual receivers cause reduced range?
  180. Anyone use the Hitec Prism PCM rx?
  181. Futaba S3004
  182. Hitec Transmitter Battery Connector ?????????/
  183. JR XP8103 1650mA Upgrade Help Needed
  184. Are there aftermarket gimbles?
  185. Futabta & engine turn off
  186. Royal Evo 7 channel
  187. Hitec HS-77BB servos
  188. Radio Battery Cycling How Often is It Needed?
  189. Multiplex Mixer questions
  190. Tx crystals - The truth about swapping (worldwide question)
  191. How Come This Don't Work??
  192. Is PPM Rx safe with TME Smoke pump?
  193. Receivers and crystals?????
  194. What?
  195. Synthesized Module Question
  196. Am I the only one that flys with Airtronics??
  197. Retract Servos
  198. JR Max meter reading
  199. Servos for TT Champion 45 S
  200. need a copy of a csmv10 disk
  201. servos in wing - howto
  202. Buying a new radio
  203. Help Needed Badly
  204. Changing lead on Airtronics servos
  205. JR X-378 Mode 1 to Mode 2 ?
  206. Buying a New Radio
  207. Z connectors.....What's the deal?????
  208. AM TX & Rx
  209. Servo help needed
  210. Dual Elevator Servos With an RD6000 - SOLVED!
  211. Swapping out recievers ... Will one brand work on another brands transmitter?
  212. computrized RC
  213. 8103 rudder set up
  214. Hitec Electron 6 receiver - good/bad/excellent?
  215. changing from mode 1 to mode 2
  216. gy401 and Jr receiver
  217. PCM vs PPM (Falkon ignition to blame?)
  218. looking foe futaba mcr-4a receiver
  219. Wondering where I can get JR Rx crystals on 41MHz
  220. Recievers. Single VS. Dual conversion
  221. Hitec recievers
  222. Eclipse 7....AM?!
  223. Hitec Eclipse 7
  224. mrc single stick system
  225. Hitec Service
  226. Help With Sanwa Servo Wiring
  227. What Is It??
  228. Custom Electronics - Excellent Prices on Airtronics Servos
  229. Need 9zap Help ASAP
  230. cheapest way to buy radio gear?
  231. Voltage drop @ full deflection
  232. Good $50-$60 receiver
  233. DAD intercepter 2000info? crystal?
  234. JR X3810 adt
  235. Which radio would you buy?
  236. 6 V vs 4.8 V on Flight Packs
  237. AM antenna, minimum height from surface?
  238. Kraft FM modules
  239. Talk about Strange things going on
  240. A nit picky question about my JR 662.....
  241. Elcipse w/ simulator question?
  242. Dsc
  243. Futaba R127DF Receivers - Work with computer radio's?
  244. Kuddos to servocity, now thats service
  245. ultra stick 40 + eclipse = crow?
  246. radio signal amplification
  247. Old AM servos on new FM Radios
  248. 20 or 22 gauge wire ???
  249. PPM to PCM for Super 7
  250. PCM 1024 Reciever will work with what?
