PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
  1. Single Stick Xmtr?
  2. Where do I start? I need your help!
  3. What receivers will work with a Futaba 3PM-2.4G?
  4. Futaba 8uaf to 2.4
  5. spektrum A6150
  6. Minima 6s won't bind
  7. Transmitter Question
  8. 645 MG with plastic spline?
  9. Anyone using a JR DS8900G tail servo?
  10. Window
  11. I got ahold of a hpi savage 21 and I dont know what transmitter I need to look for.
  12. DX7s Newbie: 4 Ch Rx Question
  13. Futaba 7C 2,4 Fasst ???
  14. Aurora 9 and Anylink
  15. DX7s: Extra Receivers
  16. Anyone have any experience with Endurance RC & Servo Commander?
  17. Spectrum DX7 and simulators
  18. Traxxas receiver board pin repair
  19. JR 28X / JRs Flagship Radio!
  20. 12fg total reset??
  21. Need A 3 Channel Radio System And Servo
  22. Servo Problems?
  23. Futaba s9151 on 6v regulated?
  24. Window
  25. artronic servos be plugged into futaba recevier
  26. Fr Sky Taranis
  27. Will DX8 aircraft downloads be accepted by DX9
  28. RC 10 T looking motor swap
  29. Which receiver
  30. Upgraded Toys R Us "Baja Spider" motor to 12v motor, Need 12v Transmitter and Receive
  31. Servo gears...
  32. Can you guys figure out the problem with this R/C. *Pics included*
  33. JR 921 DSMX receiver dual battery hook up ?
  34. Are 8411 and 8611 gears interchangeable?
  35. Hitec Servos
  36. Problems with the Futaba "made in china" servo's, recievers, etc.?
  37. JR ST125MG servos
  38. tactic anylink
  39. savox SC-1233sg problem looking for some insight.
  40. Servo end point
  41. Jeti DC-16 mixer flaperons question
  42. Futaba 7c
  43. jr8411 servos whistling
  44. Graupner/SJ MC-20 Hott with OrangeRX DIY Module
  45. What is the current radio tech?
  46. 12FG Tx not communicating with PCMG3 RECEIVER
  47. Pin polarity
  48. Help needed for Annsmaan Virus 3.0
  49. Deans 3 Pin Connector Servo Adapters
  50. new futaba 8fg help ?
  51. Dual elevator servos
  52. Transmitter FS th9x
  53. ORX T-6 Range test.
  54. Taranis radios
  55. Hitec/FrSky receivers
  56. Transmitter unresponsive
  57. Ace micropro 8000 transmitter question
  58. Ace micropro 8000 transmitter question
  59. blown receiver
  60. Anyone using Tactic radios for big planes?
  61. futaba 8fgh will it work for a plane
  62. JR Servos and slop
  63. Pro Line battery charger.
  64. Converting an old 72Mhz radio to 2.4Ghz
  65. airtronics mx-3
  66. JR DMSS Module and receivers
  67. Question about old FM radios vs new radios
  68. Tactic TTX 650
  69. Electric motors for sale cheap!
  70. IR pistol grip Tx?
  71. servo reversing question?
  72. Switching the Switch T12FG
  73. Need help programming jr 9303
  74. Replacement for Futaba 12fg
  75. T14SG Ailevator function
  76. Futaba 6014vwith smart fly
  77. Micro Servos For The Tactic TR424 Rx...........connectors ?????
  78. Airtronics Aquilla radio- Why?
  79. LHS servos
  80. Rebuilding my Rustler XL-5
  81. help, car wrong stop!
  82. Jeti-Duplex DC/DS-16
  83. ganging servo's
  84. Nomadio React Desktop software - help !
  85. Special servo plug
  86. 9503 Idle Up
  87. cgy750
  88. What servos for Seagull mxsr 91
  89. Question about high voltage power lines and 2.4 radios
  90. Wald Good-TTPW ground bassed tranmitter with control box no Receiver
  91. Tactic Servo info
  92. Receivers compatible with Futaba 6EX FASST
  93. Airtronics M12 thoughts?
  94. Futaba receiver prices
  95. Turnigy 9x dragonlink issues
  96. Problems with Value Hobby Servos and Batteries .... any suggestions?
  97. new switch?
  98. setting up a zyx gyro in a dx8
  99. Futaba 14SG on Flying Wing
  100. JR Z270 vs Futaba 3004
  101. What servos for Ripmax WOT4 Xtreme
  102. Specktrum DSM2 2.4 Air Module DM9
  103. Futaba T6J - Throttle hesitation
  104. FlySky GT3B - defeat reverse function?
  105. Tail Dragger RC Triple Servo Wing harness's (3 servo's, one plug)
  106. Hitec Optic 6 Sport 2.4
  107. New, Need help with TX, RX questions
  108. Dual MPI Switches
  109. Help Please!
  110. need help bad.. blade sr
  111. A little help..
  112. Feetech 28g/ 7kg/ .12 sec Digital Servo for Glider Wing
  113. Hobby King receiver
  114. Receiver advice
  115. Dont know what one to get
  116. Syren 10 - Sabertooth 2X25 Help needed
  117. counterfit servos?
  118. Futaba PCM compatibility
  119. reciever problems
  120. JR XP8103 update 2.4 or upgrade to new radio?
  121. Question about Futaba 12fg and Dji Phantom combination
  122. gas ignition TX/RX interference
  123. Is six Hitec HS 5955TG thru a JR 921RX to much
  124. Question about servo's and batteries.
  125. 14 mz programming advice needed
  126. The good (?) old reed systems days111
  127. Programming Spektrum DX 7, AR 7000 ?
  128. Dsm2??????
  129. Need tiny servos
  130. Affordable 2.4 receiver
  131. Blade 300x Receiver alternate?
  132. R770S 7channel 53mhz PCM Slimline receiver.
  133. Getting back in RC can any of my Transmitters be converted to 2.4
  134. Spectrum modules and receivers- 1st gen?
  135. Futaba 7c tx help
  136. HK 3axis stablizer V2 setup problem
  137. Jeti-duplex-ds-16-2.4-ghz
  138. Bms-620mg ??
  139. Why do Spectrum radios use Satellite Recievers and Futaba radios do not?
  140. 2.4 module on a 10X
  141. Beginner intro and a couple of questions
  142. Micro Radio Gear
  143. Am I wrong dual converstion
  144. Swap gimbals from Futaba Conquest to Futaba TUAFs?
  145. can a 72 mhz modular hitec transmitter be converted to a 2.4ghz
  146. adding channel to Hitec Laser 4 transmitter
  147. DSX11 - Electric glider, V tail, No ailerons, spoiler
  148. S-bus question
  149. Anybody ever seen, owned, used on of these receivers?
  150. Momentary loss of control
  151. FS-TH9X A-10 setup
  152. Beginnner - Need Advice for a Radio..
  153. servoes
  154. 3 axis gyro location
  155. Frysky 8 channel rx's for hitec radios
  156. Spectrum dx 3r
  157. Futaba 12FG radio - Switching recievers channels are all mixed up
  158. Interference resulted in crash. Need a new radio!
  159. Beware HITEC Aurora 9 users with gas engines
  160. Hitec Digital 6635 weird problem
  161. ESky 2.4ghz TX/RX use in Radian glider
  162. Securing Rx
  163. Range of 2.4GHz vs 72mz radios
  164. JR 11X quickie question. Please help.
  165. dx-7s end point adjustment is backwards
  166. Eagle Tree Guardian 2D 3D problem
  167. Flaps possible?
  168. JR 12X will not work in cold weather.
  169. JR 11x Programming Question
  170. I like the servos XQ-S4308D
  171. Telemetry radios
  172. Remote 12volt Engine Start Switch
  173. Airtronics Caliber 3ps to 2.4ghz conversion help wanted
  174. Need help, JR 10S heli OR Futaba 8UAF non-super for long term
  175. Futaba T14SG & KK2 Quad Newbie
  176. Can I buddy box a dynam 2.4ghz with a radiolink 2.4ghz?
  177. Futaba Rx 2.4 help
  178. Hobby King servos HKS-9650 - center position moves 45 deg by its self w/temp change?
  179. Spektrum DX5e Power switch repair
  180. New Tactic Receiver TR625
  181. Power HD 1214TH Unregulated?
  182. Futaba Magnum 3PK Super.
  183. 1978 Futaba Fp-4fn
  184. Gens Ace LiPo for Spektrum Transmiiers - Pros/Cons
  185. DSM2 or DSMX
  186. The smoke escaped!
  187. Hitec Aurora and receivers
  188. FrSky TFR8 SB 8ch 2.4Ghz S.BUS Receiver FASST Compatible - Is the Range same as Futab
  189. Help with on/off feature of gyros on Hobby King orange reciever with DX7
  190. Jr 12x 2.4 problem
  191. Servo Resolution
  192. citzenship 10 channel new radio inquiry
  193. JR PROPO Xbus center hub
  194. Modifying zero-points of servo's with FlySky FS-TH9X
  195. Feetech Servos?
  196. can the bind port on receiver be used to power LED lights??
  197. Tf-40 controller
  198. Futaba FASST R6014-FS Receiver with 'WHITE DOT'
  199. Flaps on the throttle stick
  200. DX7s & Radian Pro
  201. 12x DSMX Upgrade
  202. Issues with Futaba Fasst 6014FS vs 6014HS Receivers
  203. JR 12X Transmitter and JR7010 Receiver.
  204. Futaba repair service turn around time?
  205. Alternative to on/off switches
  206. Eagel Tree Systems
  207. Need Help for powering up on board equipment - 30cc Pitts Bipe
  208. New Futaba 7 ch Tx ONLY
  209. touchpad on my Aurora 9 Radio
  210. Futaba R6014HS reciever stops recieveing after a short time
  211. RX voltage question
  212. Mini receivers
  213. 2.4g Transmitters
  214. Compatible receivers - any type - like to hear your experience
  215. Eagle Tree Guardian harness
  216. Dx7s battery
  217. Futaba 7c switchglo pro on throttle channel
  218. Stupid question for someone new to 2.4ghz
  219. Hobby King High End Servos??
  220. Powerbox Competition
  221. DSM2 Rx Smaller Than AR400, Full Range
  222. JR 12X vs. Spectrum DX18
  223. Blue bird servos
  224. tactic servo feed back
  225. Altitude telemetry and TaranisTX
  226. Spektrum receivers and JR servos?
  227. Walkera Devo 12S Radio
  228. Assan receivers
  229. tactic TR624 6 channel SLT receiver
  230. Futaba Airplane Gyro Compatability
  231. Hitec 7975HB
  232. Aloft Hobbies and FrSky......Be careful dealing with these people! (RESOLVED)
  233. Servo Amperage
  234. Hitec Optic 6 Sport control delay
  235. So ya have to check every little things these days
  236. Next gen R/C radios?
  237. fr sky radio 175.00 ??????????
  238. Problems with Spektrum AR635 Receiver
  239. New 14SG software V2.0
  240. MJX F645 Brushless upgrade sets only sale 35.99usd
  241. Tower hobbies junk customer support
  242. 9303 Duel Alierons Aux one
  243. JR 9303 Gimbals - A question for anyone who has this radio.
  244. update Futaba FP-8UAP
  245. new slash raptor with castle creations issue.
  246. Are RC events getting too large to be safe? Is anyone studying band saturation?
  247. Clarification on RX, TX, and ESC
  248. JR Matchbox & Futaba Radio/Hitec Servos
  249. DX 18 UPGRADES
  250. Spektrum 9X New
