PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92
  1. will a fut t6xa tx work with a pcm 8 ch rec?
  2. graupner 16/20 and jr rx
  3. Gyros and aeroplanes ...
  4. Darn 72 mhz frequency
  5. Futaba SR10 servo reverser
  6. Airtroincs RD8000
  7. Charger
  8. Supertec servos
  9. JR 3421 Servos
  10. What happened to JR 3121??
  11. vacuum metalising - rf interference or not?
  12. 9C Programming for the Ultra Stick????
  13. JR 507 glitching with diff battery.
  14. Does Airtronics TX when used as a Buddy Box need Crystal and BAtteries?
  15. best source for crytals
  16. Nelson Glo Drivers. Good stuff?
  17. What are good ways to switch electrical accessories on/off with servo connections?
  18. Hitec Eclipse with an Ultrastick
  19. Left Handed Royal Evo?
  20. Does JR have a website?
  21. JR glitches aileron servos
  22. Airtronics (Older Vanguard FM 6-channel)
  23. Compatibility Question
  24. can any radio do this ??
  25. Tower Receiver Question
  26. 9c Manual
  27. transmitter to pc
  28. Does anyone fly the standard size GWS servos???
  29. Internal receiver antenna
  30. Frequency Scanner
  31. Jr 652
  32. Build your own micro-RX?
  33. Question about Hitec 5945
  34. Futaba 8U question
  35. Simprop servo
  36. Programming 9CA
  37. 8U Stick Tension
  38. JR servos-Futaba receiver?
  39. Expert 8 channel radio
  40. What Channel is 40.240mhz?
  41. Channel five glow switch
  42. hitec servo's
  43. Wanted: Flyers experienced with JR Matchbox
  44. what difference
  45. Switching Dual Rates
  46. 'Y' with only 1 servo?
  47. What crystal is this?
  48. Battery and reciever placement
  49. BIG PROBLEM WITH RECIVER OR TRANSMITTER
  50. PCM with RD6000
  51. Kraft talk/questions
  52. jr 700 glitches
  53. Futaba Servo Question
  54. Y-Harness w/ reverser?
  55. Question about Rx connector types and interchangeability
  56. Radio equipment after a crash...?
  57. Carrying Case Foam
  58. Multiplex servo question
  59. Is there a "user friendly" manual available for the FP-9ZAP???
  60. Glow driver and receiver
  61. Graupner C5077 servos
  62. Don't like digital trim feel
  63. Thanks
  64. Can I use this Y cord
  65. compter tx's with mechanical trims
  66. help dont no much
  67. Ever wonder what comes out of your receiver?
  68. Futaba Module question
  69. Bowden Cables
  70. Do you have to have a PCM radio to fly a gasser?
  71. Hello to radio GWS/Futaba
  72. Futaba Stupid Questions ...
  73. Need info on temporary use of radio in other countries
  74. Hitec 32625 S for JR
  75. What servo & size ?
  76. Futaba 6xas
  77. MPX 3030 Heeeeeeeelp
  78. Futaba 9c and Hitec Synthesized Module
  79. Hi tec reliablility
  80. Futaba 9CAF Servo setting question
  81. Swaping an 8UAP for an 8UAPS is it worth it?
  82. Futaba servo jitter
  83. JR Circus IV servo reverse???
  84. 53 Mhz
  85. JR Matchbox need help
  86. Typical transmitter RF output power?
  87. Suggestiions for Beginner
  88. Flap Control
  89. damaged s-148 ?
  90. Servos Question????
  91. Old Airtronics / New Airtronics(Z)
  92. Futaba and what servos will work with it
  93. JR 378-What do you think???
  94. Eclipse 7 problem
  95. Futaba 9CA
  96. Good Newbie Radio?
  97. Futaba 9VHP Question
  98. changing chrystal in rec. tx?
  99. Price on JR gear
  100. shielded servo leads
  101. RC Aircraft Transmitters & distance
  102. Futaba & Hitec Servo ????
  103. Help: Adding Dual Rate
  104. This is really Old Old Servos,anyone knows about them?
  105. Radios!!!!!!!!!!!!!!!!!!!!!!!!!!
  106. radio setup
  107. Mpx mc4000, mc3030, evo - communication protocol
  108. Futaba 8UHPS, Realflight G2, Raptor 30
  109. Problems with JR8411/Emcotech/Multiplex
  110. Futaba 9CAF TX battery
  111. high band and low band Futaba receivers
  112. Hitec digital or Futaba coreless. Which one is better
  113. The right Servo ?
  114. Whats a good $50 servo
  115. Jr652 Into 7 Channel?
  116. FUTABA 8UAP-S
  117. 2 ch am Shredder micro receiver HELP!
  118. Heli Programming the Futaba T9CHP?
  119. DUAL reciever set up?
  120. 53 Mhz
  121. Eclise 7 - Any Good?
  122. Hitech Eclipse 7 Question
  123. Manual for a JR PCM 10
  124. Eclipse settings when removing battery...
  125. Jr 9 Channeltx??
  126. Mixing Different Brands
  127. servos for 60 size edge 540/saito 100
  128. Scrambling Device???
  129. Tower Hobbies Servos any good for 1/4 scale?
  130. Spoilerons on a Futaba 8u - How do you setup
  131. can you 'Y' your Rx charger??
  132. Polks Tracker Two radio
  133. plug wire orientation on JR servo and Rx??
  134. Hitec Servo Arms
  135. Airtronics servo gear alignment.
  136. Airtronics VG 400 5th channel
  137. Futaba "GOLD" FM value ?
  138. what's better futaba 9c or JR8103
  139. Futaba 10x ?
  140. GWS mini servo
  141. Super 8 Mixing, dual elevator problems
  142. Airtronics 94358Z servo
  143. Futaba r138dp problem
  144. hitec servo
  145. fma direct co-pilot
  146. Polk Hobby / Tracker Radios
  147. Hitec buys Multiplex
  148. Help with problem for newbie
  149. 1/3 PITTS has a glitch
  150. looking for web page on radios
  151. Hitec servos
  152. Is 6 volts okay with Futaba digital servo S9151?
  153. Jr 783 will work with which Rx?
  154. Futaba S9204
  155. Sanwa SRM-206 Gyro details (Mechanical)
  156. help on initial flaperon set up
  157. HiTec Eclipse w/ Spectra or Jr X-378
  158. Make A Jr Wired Servo Work With Futaba?
  159. Precious Manual EX-1
  160. Precious Manual
  161. Airtronics RX and JR TX?
  162. Anyone using different TX Knobs?
  163. Mpx Evo - socket on rear face
  164. differental throw on ailerons
  165. New Generation Futaba Servos
  166. Servos - Analogic x Digital - Coreless?
  167. show-offs with RoyalEVO
  168. Adjusting trims-which hand do you use?
  169. Can I do that: Plugging 4.8 V pack and one 6V pack on my receiver?
  170. 9C programing issue.
  171. Servo throw limit of mc4000
  172. Futaba 6XAS discontinued?
  173. NEED HELP!! EXPERT NEEDED Futaba
  174. Futaba Skysport 6A and FP-R127DF Receiver channel #32
  175. Hitec Rx
  176. Futaba AM vs. Futaba FM w/Hitec Mod
  177. really old futaba
  178. radio education
  179. Help JR XP 783
  180. What to do with extra antenae wire?
  181. 10X bugging! ? need help
  182. Question for hitec eclipse experts.....
  183. HiTech Servo Spline Drawing
  184. Hitec digital question
  185. RX crystal going dead
  186. radio probs
  187. Hitec Flash 5 Programming
  188. Multiplex servo simulator
  189. Maxx Products Servos?
  190. JR 549 incompatible with 8411's?
  191. Know how to reverse HS-55?
  192. Is an 8411 enough?
  193. Old JR Servo Question?
  194. DSC connection
  195. jr652 and ultra stick 40
  196. JR Servos and 6V
  197. Changing channels on a TX
  198. Buddy box question,...
  199. JR single stick wanted
  200. Radio AM or FM
  201. 8103 V Tail Help
  202. Rd6000/8000
  203. digital jr servos
  204. Help with Sanwa radio?
  205. 4.8v or 6.0v
  206. Where to buy RD8000
  207. Servos - Decisions
  208. SERVOS.....Gear lube question???
  209. RC Transmitter and Pacemaker Interference
  210. Hitec HS-81MGJ Servo Micro J
  211. 9CHP Change the picture?
  212. Futaba 4VF 4-Channel FM
  213. JR Matchbox - Hitech Programmer Question
  214. Flaperon mixing in the Hitec Flash 5X
  215. Quick Servo Question!
  216. Futaba 8U (FF8) with Hitec FOCUS 4 FM
  217. Selectable TX????
  218. MPX 4000 setup for 3D
  219. Older Sanwa transmitters manual?
  220. 3PK Traction Control problems?
  221. 9ZAP WCS Freq Change
  222. Direct Servo Controler CB
  223. Futaba 9403
  224. Wtb-good Jr662 Or Jr652 Transmitter
  225. good/heavy duty servo wire-where?
  226. New Radio time - I'm sooo confused!
  227. WTB, JR X-388s Trasmitter
  228. Futaba 9CHP question
  229. 331/341
  230. Single conversion crystal problem
  231. Servo Current ?
  232. Seeker Rx
  233. Digital Throttle Trims
  234. airtronic digital economy servo
  235. Dual Rates on JR 8103
  236. dog collar interference?
  237. JR PCM 9 single stick wanted
  238. Radio Equip. Not working
  239. Anyone know were I could get the new Hitec Neon System?
  240. Cockpit MM conecting to Win XP - Problems
  241. New Hitec Eclipse 7
  242. Eclipse 7
  243. running RX antenna internally around pull-pull cables... Interference???
  244. FMA Co-Pilot
  245. JR5000 Gyro and RD6000 Radio
  246. FMA Direct Co Pilot
  247. Will Futaba and Hi-Tec receiver crystals swap?
  248. JR 652 Flaperon set-up problem
  249. JR NER-D940S Receivers
