PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92
  1. Buying a used Futaba Radio what reicever will work?
  2. Multiplex Royal Evo 9 Battery
  3. modification of servos
  4. 6000 super
  5. replacement for HS-300 servos
  6. Futaba trainer box and a hitec flash
  7. 2-pole, 5-pole coreless...SAY WHAT?!
  8. F/S Futaba 2PCKA Magnum Junior
  9. Futaba 3PDF
  10. 9zwc2
  11. Newbie to RC and radios
  12. Airtronics trainer boxes and cord
  13. upgrade to eclipse 7
  14. 9c pit and throttle curve
  15. JR 347 Charger?
  16. Cheapest place for hitec digitals?
  17. R700 JR Receiver Info please
  18. Problems with JR DS8411 ?
  19. Futaba radio -Hitec receiver?
  20. HS-85BB's OK for Ailerons?
  21. 3 Pole Digital vs Analog Coreless servo
  22. new xp8103 pcm heli help!!
  23. Digital vs analog please help
  24. Futaba 6XAS vs JR 662
  25. anyone using MPI servos ??
  26. Shaken elevator on futaba 8u
  27. Futaba 8U Programming question?
  28. Mode 1 or mode 2?
  29. Newbie radio recommendations?
  30. Hellllpppp!!!! Servo Problem!
  31. Diablotin XL: servo torque???
  32. Anybody have the specs for the Cirrus CS-09 and CS-18 servos?
  33. How to reverse a futaba 148 servo?
  34. Differences between the 9CAF & the 9CHF
  35. Help !! Jr X-378
  36. FMA Servos
  37. 4.8 vs. 6.0 servos
  38. substitute servos
  39. Am I safe with mid '90s frequencies???
  40. Wattage IC-380
  41. Can the new generation of computer radios do this ?
  42. Servo reversor and Y harness causing problem
  43. Hitec flash 4 or 5
  44. HITEC FLASH 4 or 5
  45. hitec 5735 giant digital
  46. JR transmitter and Hitec receiver. HELP!
  47. Coming back
  48. Hobbico CS-61 Servo Question
  49. Electronic servo reversing...
  50. servo reverser magick
  51. Just ordered some HS-475's
  52. Servo Fly Leads
  53. Airtronics System Question
  54. JR 4721 problem
  55. JR 950s receiver
  56. Carden 35% Edge: Servo Torque??
  57. Metal Servo Gears Wearing
  58. Datasafe 2 install problems
  59. Futaba PA-2
  60. Servo Jitter
  61. Need info in English on Graupner MC-22
  62. JR servo lead size too small for extension
  63. Hitec-Futaba Compatibility
  64. Modules for Futaba 8UAF & 9C
  65. Bolt on stand/ legs for metal Tx handle
  66. Where is The Cheapest Place to BUY !!!
  67. JR Hitech Futaba Airtronics ?
  68. What is the latest Futaba 9Z Radio?
  69. JR 2721 servos?
  70. radio
  71. Futaba transmitter with Hitec receiver
  72. Airtronics/Sanwa VG400 mods.
  73. Aluminum Foil around RX ?
  74. 8103 PCM or FM
  75. Needs help for Hitec digital servo
  76. Best Futaba 9206 prices
  77. Looking for a first Radio
  78. Super 8 crystal
  79. Futaba super 8
  80. Parallax Basic Stamp inputs from RX
  81. Futaba 9C : Using sticks in programming
  82. Futaba 9CAP Questions?
  83. Ds 811
  84. How do RC and Gyros work...
  85. Ds Jr8411
  86. RD8000 Airtronics?
  87. Help
  88. HiTec digial 5645 reversing?
  89. Question...
  90. 6v regulators
  91. Which servos to use??
  92. Futaba T6VH Tx with with twitch-service?
  93. Futaba 8UAFS...Change Point Mixers to Regular Mixers
  94. 9CAP bristling with switches ...
  95. Jr 9x?
  96. How Far can I fly?
  97. Futaba 9ZAP question? (new pics after first flight added)
  98. Need some Heathkit help
  99. 10x neck strap
  100. 9C flaps & elevator
  101. 9C TX Only
  102. Got my new mc4000
  103. First Radio
  104. Jr R610m
  105. Help with radio Xmas gift
  106. Run both a HH gyro and FMA Co Pilot on 6 channel radio?
  107. Jr10x and Hitec receivers
  108. Servo comparision
  109. Battery melted!
  110. Futaba T8UPs manual
  111. Receiver aeriel length
  112. GYA352 neutral signal memorization
  113. ? For those who have ordered from Servo City...
  114. Ace Noise Trap questions
  115. Why does my 8-ch. Rx only have 7 servo slots?
  116. Duralites
  117. FW: MULTIPLEX Press Release
  118. MPX Cockpit - weird behaviour
  119. Is there any difference in range between a standard rx and a micro rx?
  120. Citizen-Ship Tx & Rx instructions
  121. GWS (JP) Servos it is good or bad?
  122. Citizen-Ship Tx & Rx instructions
  123. My 10 channel Futaba transmitter! Yes, it is in fact a 10Z!
  124. Stripped gears in Hitec 225BB
  125. radio interference with engine running
  126. jr421 skematic
  127. HS 81 blues
  128. 10x Keeps Going Into Failsafe On The Ground?????/
  129. hi tec crystal in futaba receivers
  130. Swapping crystals in futaba Rx
  131. add proportional channel?
  132. Great price on Hitec Supreme receivers
  133. radio
  134. 9C Stick Tension Question
  135. Microstar Conversion
  136. Re: Futaba T4VF JUNK??
  137. hobbico tx case
  138. Trainer cord question - Futaba mode 1 with Mode 2
  139. what is Futaba sequence?
  140. receiver current too much? WHY
  141. ServoCity is Cool!
  142. 9C Question re: campac Xfer.
  143. Futaba 4VF & flight sim
  144. Help Me! What is this monster?
  145. newbie w/ odd project, seeking advice+help
  146. 9c swash setup
  147. 6.0V syst blowing JR Y Harness?
  148. Multiplex news
  149. futuba and airtronics together???
  150. crystel change
  151. Which servos to get?
  152. How often must I let my TX & Reciever Bat run Totaly Flat?
  153. Airtronics RD 6000 Super Question
  154. Normal Switches vs Heavy Duty Switches
  155. Range checks ...
  156. Where to buy Futaba 9CAP radio?
  157. Airtronics RD6000 manual
  158. Futaba Service
  159. cirrus 900fm 5 ch
  160. Radio Mixing
  161. Question on the Futaba 8UAF
  162. MPX 3 pin servo compatible with Tamiya equipment?
  163. Very Very Begginer help
  164. Slow Retraction Of Landing Gear
  165. Is MPX 3 Pin servo plug compatible with a Tamiya plug
  166. 8UAPS Tx Problem
  167. Futaba 4 ch 4VF-FM
  168. Futaba Super 8U use with Hitec Receiver
  169. New Hitec 5475 servo..anyone use them yet?
  170. Explanation of "Flight Conditions"
  171. Hitec HFP-10 Servo Tester
  172. JR Y Harness..
  173. Repeated beep on Jeti speed controller
  174. Servo plug & wiring
  175. Bec receivers[ HELP]
  176. Bad AMP on Hitec Digital?
  177. Airtronics (Sawana) RD-8000 vs. JR & Futaba
  178. Models of GWS Rx
  179. Soldering servo leads
  180. Please help
  181. Near miss due to Low Voltage
  182. Any 4 channel FM to 5/6 ch. mods in the net?
  183. servo center moves on its own
  184. Crystal
  185. Multiplex Positive/Negative Shifting
  186. Hitec 5645 Jan 02 v1.03....?
  187. where to purchase JR d/c crystals?
  188. Gws Rec Questions
  189. Fiber Optic?
  190. Gws-airtronics
  191. Changing crystals - R127DF
  192. Radio Input Needed
  193. JR 8103 Heli setup
  194. manual needed
  195. jr 347
  196. JR 8103 Radio on Ch 00 - 50 mhz Ham Band??
  197. Servo Torque
  198. Clearing model memory
  199. Clearing model memory
  200. XP8103 Warning Message
  201. 9C transmitter stand??
  202. speed controlers as backups
  203. Swash AFR
  204. Servo Head Question?
  205. JR charger question
  206. Futaba FP-T8SGA 8ch prog. help needed
  207. Dual radio setup
  208. 6TXAPs ... Flaps do not work ?
  209. Need help with jr 8103a radio PCM
  210. German/US frequencies
  211. an the Throttlle on a Mutiplex Cockpit MM Transmitter
  212. New Hitec NEON??
  213. Multiplex Txs, choices, choices
  214. A Private Line For RC Control
  215. Futaba GY401 Gyro Setup
  216. Instruction Manual for Airtronics cx29
  217. Digital servos - help summarize pros & cons....
  218. The islolator by i4c products
  219. Hitec PowerServo Gearbox
  220. JR 9011 servos - gear train strength?
  221. Airtronics 94357Z opinions
  222. JR matchbox question
  223. JR 756 radio WANTED
  224. 9C vs. 8103
  225. Futaba S3302 heavy-duty servo
  226. FMA Servos?
  227. Need to modify a Servo...
  228. Can a Airtronics servo be used with JR?
  229. What reciever to buy?
  230. Polk synthesized RX
  231. Where can I buy servo wire and connectors
  232. Should I up grade? Or is the GWS radio okay?
  233. GWS servos
  234. Polarity of plugs
  235. Sanwa RD 6000 Super Computer
  236. Use of US Spec Radio in Germany
  237. FM vs. PCM trainer compatibility ??
  238. Airtronics Super Micro 9GM Z
  239. Profi 3030 for Helicopters?
  240. Hitec 225 nylon to metal gear conversion
  241. Jr 9x Tx
  242. Modify to Futaba J connecter
  243. New to this forum
  244. Synthesized receiver for hitec
  245. Glitchy
  246. 50mhz radios
  247. Futaba 6XAPS online?
