- jr - won't power on
- Experiencing Radio Interference Problems?
- Anybody having trouble with digitals
- Rudder servos for 35% edge
- Rudder sevos?
- I cann't use Ch 20 in my area, how I can changed to Ch 19?
- TX battery charging problem!
- Confused about Mode 1 or 2
- Tx/Rx battery ma's
- Futaba Receiver Compatibility
- Multicon Amp. compatable w/modern radio?
- If you had $350 for a radio system...?
- Gears - Futaba S5101
- 9c Question???
- Programming Futaba Super 7 with Stick
- Can't get to full flaps with JR 8103 landing switch
- 9c aielerons/elevator questions
- Need help with my Electric Razor (Zagi)
- Kraft Kp-5 Sport Series
- help! with servo extentions!!
- My Longitudinal & Latitudinal Range is Different ???
- Futaba 9C question
- crystal identification
- JR 8103 Prices
- what is the range ?
- Which expanded scale loaded voltmeter to use
- Recommend a radio
- Standard wall wart capability
- Trainer module for MC12
- fma m5 rx antenna torn need pic
- disabling the ch.6,7,8 knobs on an 8UAPS?
- Airtronics RD6000 vs JR XP662 vs Hitec Eclipse 7
- Where does one find replacement switches for their TX?
- One radio for one receiver?
- Question about my battery pack:
- Hitec Servos??????
- Airtronics to Futaba Buddy Cord
- High Band Rx, Low band Tx..
- Failsafe
- Does Graupner rx R600/R700 have AGC?
- Programming A Jr-r1 Pcm Radio
- 9Z WCII - Removable Tx Battery?
- hitec focus 6 , good or bad?
- different gears for hs-300
- XP8103 Vtail - Rud/Elev question...
- Are Cirrus and Futaba the same?
- Dual receivers cause reduced range?
- Anyone use the Hitec Prism PCM rx?
- Futaba S3004
- Hitec Transmitter Battery Connector ?????????/
- JR XP8103 1650mA Upgrade Help Needed
- Are there aftermarket gimbles?
- Futabta & engine turn off
- Royal Evo 7 channel
- Hitec HS-77BB servos
- Radio Battery Cycling How Often is It Needed?
- Multiplex Mixer questions
- Tx crystals - The truth about swapping (worldwide question)
- How Come This Don't Work??
- Is PPM Rx safe with TME Smoke pump?
- Receivers and crystals?????
- What?
- Synthesized Module Question
- Am I the only one that flys with Airtronics??
- Retract Servos
- JR Max meter reading
- Servos for TT Champion 45 S
- need a copy of a csmv10 disk
- servos in wing - howto
- Buying a new radio
- Help Needed Badly
- Changing lead on Airtronics servos
- JR X-378 Mode 1 to Mode 2 ?
- Buying a New Radio
- Z connectors.....What's the deal?????
- AM TX & Rx
- Servo help needed
- Dual Elevator Servos With an RD6000 - SOLVED!
- Swapping out recievers ... Will one brand work on another brands transmitter?
- computrized RC
- 8103 rudder set up
- Hitec Electron 6 receiver - good/bad/excellent?
- changing from mode 1 to mode 2
- gy401 and Jr receiver
- PCM vs PPM (Falkon ignition to blame?)
- looking foe futaba mcr-4a receiver
- Wondering where I can get JR Rx crystals on 41MHz
- Recievers. Single VS. Dual conversion
- Hitec recievers
- Eclipse 7....AM?!
- Hitec Eclipse 7
- mrc single stick system
- Hitec Service
- Help With Sanwa Servo Wiring
- What Is It??
- Custom Electronics - Excellent Prices on Airtronics Servos
- Need 9zap Help ASAP
- cheapest way to buy radio gear?
- Voltage drop @ full deflection
- Good $50-$60 receiver
- DAD intercepter 2000info? crystal?
- JR X3810 adt
- Which radio would you buy?
- 6 V vs 4.8 V on Flight Packs
- AM antenna, minimum height from surface?
- Kraft FM modules
- Talk about Strange things going on
- A nit picky question about my JR 662.....
- Elcipse w/ simulator question?
- Dsc
- Futaba R127DF Receivers - Work with computer radio's?
- Kuddos to servocity, now thats service
- ultra stick 40 + eclipse = crow?
- radio signal amplification
- Old AM servos on new FM Radios
- 20 or 22 gauge wire ???
- PPM to PCM for Super 7
- PCM 1024 Reciever will work with what?
- JR 378 battery charging
- Is there a Tracker II ?
- FMA Direct Servo arms
- JR/Futaba Compatibility
- Futaba servo wiring
- Futaba FP-4FN
- JR Cobra radio help
- FMA DIRECT M5 Sub Micro Receiver
- Goldberg Extra 300 Elevator servo.
- 2 channel Futaba
- Diode Jumping?
- Futaba RX FP-R6L
- Hitec Servos
- glitch problem
- 9CAP and Webra (6 channel Rx) GLID1FLP program
- antenna placement question
- Vibration of servos and/or receiver
- FUTABA FP-R112JE receiver ???
- How long is too long for servo extensions
- Hi/Lo Band Rcvr's
- Jr-r1 Vs. Futaba T3pk?
- MPI servos
- Hitec Eclipse
- Futaba Module Question
- rec fut. or air't will it work
- JR R610 recievers-problems/success
- Looking for a Fast Hi-Torque steering servo for a buggy
- VG6DR Manual
- JR 622 ElevonMix
- Difference between rd6000 super and original
- JR Radios. Who manufactures them? Are they good quality?
- What's the difference between JR 662 Air and JR 662 heli radios? .......
- Anybody try the new Hitec HS-5475 servos yet?
- 2 servos on one surface 9zap
- JR Digital Servos Hunting
- Can you use ferrite rings around servo wire to block out radio interference
- I got some free stuff and wonder if it is any good any more
- Campac 64 K on 9C
- Radio glitching problems
- Airtronics 94358/94359z Servos ....GOOD,BAD,OPINIONS?
- Digital Servos
- Modular Radios
- Changing reciever crystals
- Changing crystals in Futaba radios
- help needed
- TRANSMITTER TRAY
- Radio freq
- Switch Recommendations
- an you switch hitec an futaba
- Xtals
- JR or Futaba? 4 Channel air
- Current draw
- Different Types Of Servo Connectors
- Looking for Linear servo
- GWS servos 100oz torgue
- replace joystick with a button...
- jr8411 vs HS5945
- Computer controlled RC plane
- I'm thinking of going with JR radio, but I have two questions:
- Crystal swapping
- HELP!!! Trying to decide between two radios:
- receivers high or low ?
- Warm hands
- Hitec HS-5625MG ?
- ESC's how to determine their motor limits
- Hitec servo flutter
- What is "Crow"?
- 9Z futaba transmitter 35 mhz ????
- Servos buzzing
- JR retracts servo dimensions. Help needed !
- 2 Battery Redundency
- Pulse Proportional
- Servos GLitch When Close
- JR 649 PCM Receiver & Crystal
- Carbon fibre fus -- interference
- HELP !! Two engines programing on 6XAS!!
- Low Band -high Band Advise
- elevon mixer
- Hitec Press Release Regarding Multiplex acquisition
- Coreless, Digital, etc, etc.
- HS 85BB question
- Transmitter and Receiver only
- Tower TS 71's
- Tower/Hobbico servos?
- Hobby-lobby Flash 5 Package
- Batteries to use in Futaba 2 PEK
- Best Mini Digital?
- Kraft Gold spectrum 6
- Ace R/C receiver info
- in need of the best pistol radio made...
- Jr 8103?
- Question about programming?
- Voltwatch and y-connector
- advice on computer radio
- need work done on MP8000
- Gws ?????
- Question Re: Airtronics gear
- Gyros-101?
- Is this Radio any good?
- Futaba T6XA Programming
- what 10kg strength servo ?
- Should i buy this Radio? It is complete...
- Your experience with the new Hitec Eclipse 7
- dual recievers, a bit different?
- Please Help Me With Mixing 2 Channels Please!
- Buying a new transmitter
- Hitec Flash 5 Throttle problem HELP !!
- Will Futaba 149DP receiver work with 8SU radio?
- Why doesn't JR662 have proportional flap knob?
- Matching servo arms
- Yet another long lead question
- HELP-WHat Radios are made for LEFTIES?????
- stripped servo
- coreless vs. 3 pole servo
- JR match box servo controler
- Differential aileron mixing
- Futaba Super 8 Programing
- 6XHS Aileron mixing ch 1 & 5
- Opinions on RD6000 Sport?
- Need micro servos for a HOB Laser Stick
- Radio or Servo Problem??
- 3 frequencie Question's
- Changing 53 MHz to 72 Mhz?
- antenna on rx(the wire has turned black)
- Hitec 5X Flaperons...help?
- Price difference
- Short soft antenas
- Frequancy/crystals etc
- Kraft Servo
- H E L P !!! question on servos
- Hitec MPX announcement?????
- Transmitters and flight packs
