PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92
  1. New JR radio?
  2. The good ole days .......
  3. Laser 2000
  4. Radio Poll
  5. got my first heli
  6. Aluminum Control Arm With Metal Clevis
  7. PCM vs PPM in gas/ign planes
  8. Flash 5 Voltage display adj.?
  9. Futaba 8UAP for helis I'm New to this
  10. JR XP8103 FM Air
  11. What to buy?
  12. Cirrus radio service
  13. Futaba 9ZAS/9Z WC2 Synthesized Transmitter
  14. horn screw stuck
  15. Modifing a stock servo
  16. JR R610M receiver - good or bad ?
  17. Tiger Moth-flying Wires
  18. For Sale NEW JR R700 Never Used
  19. 4 NEW JR DS8231 Digital Servos
  20. ServoCity has come competition...
  21. futaba 9chs
  22. JR python and cox .049 engines
  23. Best Deal On 9 Cap Futaba
  24. 8411 torque at 6v
  25. Carbon Rod interference
  26. 9250 bad?
  27. Need Advice
  28. Airtronics Rx Futaba TX
  29. Tx Range
  30. Co-Pilot by FMA Direct Hopefully the product works well because their customer serv
  31. Discharging an Airtronucs VG600
  32. 9Z assistance please.
  33. Failsafe settings
  34. 9c vs 9z is it worth it
  35. **futaba Servo Data Updated!!**
  36. Hitec digitals servos. Pros vs Cons
  37. reciever battery
  38. Servo/radio advice for Giles 17.5%
  39. Frequencies?
  40. HELP!!
  41. Futaba FP6335 IC (Data Needed?)
  42. DADS Radio
  43. Is this modification possible?
  44. Changing crystals in modules?
  45. Jr rcvrs used with Airtronics RD 600- super
  46. Buddy Box Issue with JR
  47. Servo reverser?
  48. Whats a good Digital servo ?
  49. Eyecam opinions wanted
  50. futaba 9151 vs hs 5945 info ?
  51. FM vs. PCM?...
  52. ABC & W Vs. Dual Conversion Technologies
  53. servo torques
  54. Looking for a local repairman in Chicagoland
  55. Airtronics servos
  56. where can i get a good metal case for the futaba 9c tx?
  57. What use is DSC?
  58. Help w/Hitec Feather Rx and Futuba Tx!
  59. Help w/Hitec Feather Rx and Futuba Tx!
  60. gws micro reciver
  61. Help With Flap-r-on Jr 421
  62. Having radio problems with my new Zero. Help please?
  63. JR 10X Battery Problem
  64. A quetion about receivers
  65. R127DF RX with an 8uap tx
  66. airtronics championship series 7ch
  67. Question about Futaba receivers
  68. Airtronics 94141 Servos with JR
  69. Cycling Futaba 9CAF
  70. High or Low? band
  71. Futaba FP-T6JN manual
  72. Airtronics rec's wide band ??????
  73. Servos for .25 Bipe?
  74. Airtronics Stylus
  75. Futaba SUPER 7 (FP-T7UHFS) TX Antenna
  76. digital servos
  77. Ok.......Hitec Eclipse.Futaba 6AXS,Or What?
  78. Big Thumbs-Up for AIRTRONICS Tech Support
  79. dual Rx:s on one whip aerial
  80. Mpx 3030 Servo Centers
  81. Receiver that comes with Mig-27 target drones, is it usable?
  82. Need help with my mixing options on Hitec Flash 5X
  83. freq. change
  84. Repairing antennae ?
  85. Rubber Duck Antenna
  86. Rubber Duck Antenna
  87. MFG of servo connector-JR type
  88. 8uap vs 8uaf differences
  89. JR 331 Micro Servo for throttle
  90. reciever w/ different radio
  91. Crystal Identification
  92. Anyone had any luck with the Hitec HS-70BB Servos?
  93. what radio lets you control bulit in trim tabs
  94. Futaba/JR compatability question
  95. S9001 vs S9202 and Futaba specs
  96. JR Matchboxes
  97. Smoke switch and my Futaba
  98. What in the world causes this to happen??????
  99. Futaba and Tower radios
  100. Servo Wire Lead length
  101. Problems with Airtronics Stylus
  102. buddy box in pcm
  103. New Futaba 9ZAP
  104. Gear Set for Airtronics 94322 Servo
  105. Where Bulk Survo Wire ?
  106. Futaba Radio & Hi Tech / JR Receiver .
  107. receiver aerial length
  108. Transmitter reliability
  109. Futaba 9CAF(P) Info
  110. Best Place to Buy Futaba 9C FM ???
  111. Anyone know about Kraft radios?
  112. JR PCM Transmitter w/FM Receivers
  113. 6 Volts
  114. What Servo's for a four star 60?
  115. fma new 5ch receiver
  116. Airtronics Stylus twin throttle set-up Question
  117. Bad range check?
  118. Gyro for a TwinStar
  119. Using non computer radio as buddy box with a computer radio
  120. Does Anyone Have a New KO PROPO EX-1 Mars or Mars R?
  121. JR 703 Servo problem
  122. Futaba RC FP-7NFK Radio 7 ch
  123. Programming help
  124. "4" hitec 300s servos "Cheap"
  125. which radio?
  126. New JR PCM 9X Radio ROCK at Tokyo Hobby Fair!!
  127. New JR PCM 9X Radio ROCK at Tokyo Hobby Fair!!
  128. Servos shorting???
  129. JR transmitter
  130. What do you use your Flight Modes for?
  131. Futaba FP-T8UHP-battery drains quickly? or does it?
  132. Radio Frequency Scanners
  133. Hitec Eclipse 7...
  134. R148DF on 6v?
  135. Need Stronger Transmitter Stick Springs
  136. Hitec 555 Interference With a Train
  137. Jr 8103/How to inhibit gear switch
  138. More Questions?
  139. Hitec eclipse 7...
  140. PCM or NOT to PCM?
  141. What radio to use in my Application ??
  142. Flight Pack
  143. 9c trainer connectors
  144. 9C trainer plug?
  145. Hitec Digitals and Battery voltage
  146. Multiplex Royal Evo - facts or fiction?
  147. Help!!
  148. Radio Frequency ?
  149. Nimh Rx
  150. Frequencies - number - flag colour
  151. Channel 12???
  152. Hs-81/ Hs-85
  153. Frequencies used in other countries
  154. Certain Frequency???
  155. Trainer Cord....
  156. Diff. Between 8UAFS and 8UHFS
  157. Help with JR 662
  158. Cool radio Knobs
  159. tx battery question
  160. Have you noticed????
  161. Pcm ???
  162. 7uaps And Rx And Servos???
  163. What Xtal for a ZebraDirect rcvr???
  164. Warning! JR Y harness/amp
  165. Futaba 149 DP as Dual receivers
  166. Multiplex 4000 - create your own base model
  167. Jr X-3810 Spcm - Fail Safe
  168. Can I use my OLD Tx and Rx?
  169. Best Radio 6CH HELP
  170. Hydrimax rcvr battery pack
  171. Question on Gold Stickers
  172. futaba rec to servo conn?
  173. PCM Or FM with digital servos(8411)
  174. hitec focus 4 manual
  175. Need antenna mods for use in large pipe (underground)
  176. JR X-378 et al!
  177. please help me, I need to find right battery size for my airplane!!!
  178. FP-T8UHXS for sale new?
  179. JR 8411 digital servos
  180. The tail of two Transmiters
  181. Digital servo making noise?
  182. Bad Hitec digital
  183. Shot Down?
  184. Ace R/C Pulse Commander
  185. :)
  186. Slow Transit Time Servo
  187. Who wants a Stylus "10" from Airtronics?
  188. Airtronics Infinity 1000
  189. Receiver wire stripped...
  190. Antenna inside fuselage - conflicts with servoleads?
  191. Need Help On This One
  192. Hitec servos - opinions on these?
  193. Repair damaged servo lead?
  194. Frequency shift I am confused
  195. MRC servo wire ID
  196. Futaba 8UAP stick springs.
  197. computer radio programming and functions
  198. Airtronics SR series Tx
  199. Ok I need suggestions for this dilema
  200. transmitter help
  201. Radio range
  202. Futaba 8UAFS Programming 3 way switch
  203. Limited gain on dual rates?
  204. AM vs FM radios
  205. Black Wire Desease
  206. surface computer radio?
  207. JR Data Safe and XP
  208. Radio Interference NEED HELP!
  209. JR 549 FM receiver problem
  210. Hitec Laser 4 or 6
  211. Servo Futtering ??? Radio or Battery????
  212. JR Transmitter display dead
  213. JR datasafe
  214. charger
  215. 7H1 directions needed
  216. Kraft Radio
  217. Powerbox or Emcotec?????
  218. severed receiver antennae repait
  219. New guy advice about radios
  220. Help! Did I fry my servos?
  221. Multiplex 3030 - Need Help with Servo Centering
  222. Which radio do you think is better?
  223. How good are Hitech servos ?
  224. Desperate plea for suggestions/help!!
  225. Ult Stk 60 & JR662 Flaperon set up
  226. Old Futaba Radio Help Needed
  227. MC-24 software error
  228. receiver multiplex uni 9
  229. Groupner MC20
  230. Ann Marie
  231. 9 th ch on Futaba 9C
  232. Servo bounce?
  233. newbie crystal question
  234. ACE R/C Servo Master - Whatzit anybody remember?
  235. Futaba radio
  236. 4.8 V as 6 V
  237. jr ner-233xz
  238. Polk's Tracker Radios - any good?
  239. I'm looking for Royal Evo manual
  240. Tower radio battery
  241. Futaba R127DF schema
  242. crystals and radios
  243. G2 Cord as Trainer Cord???
  244. JR's R700 Receiver
  245. JR compatable reciever
  246. Futaba 8U or 9C ?
  247. Which servo to buy?
  248. Hitec HS-5975HB
  249. Royal servos - Can I use them with JR?
  250. 9C Grip Installation
