PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92
  1. Datasafe Radio to PC software
  2. Graupner/JR MC24 Information
  3. Hobby Shop in Seville Spain
  4. Futaba 9C and ATV
  5. Servo replacement for Futaba 9202
  6. Spectra 75 in a 5UAP
  7. *Always a Brand Guy*
  8. Eclipse 7 is it not what we thought it would be or are we expecting to much?
  9. Servo City Web Site......HELP!!!
  10. Why buy an analog servo?
  11. damp receiver junk or not ?
  12. Great Planes Pitts Glitches
  13. JR Galaxy NER-J329M RX with 6V Batt
  14. MRC Radios
  15. Best price web sites for radios?
  16. Frequency Change by Crystals Only?
  17. Aileron Servo for Midwest Extra 300
  18. Jr Rx
  19. losing reception at a certain place???
  20. What are symptoms of serovs with bad centering problem?
  21. Recommended Radios
  22. Airtronics and coil ignition(Gassers). I'm having problems.
  23. Range check
  24. servo mods
  25. Airtronics Rd8000 ?
  26. battery pack questions
  27. Homebrewing a SINGLE STICK radio of your very own...
  28. rc radio frequencies
  29. Transmitter electronics question
  30. Servos- when and why
  31. optical isolater ??
  32. "Poles" in a servo..
  33. Hitec Service is Great
  34. TX won't charge
  35. Futaba 9C dual elevator sservos
  36. What exactly happens when your Rx battery dies?
  37. Do I really need digital servos?
  38. servo failure
  39. Disabling the ratcheting throttle on 9C
  40. Hitec Customer Service
  41. Futaba 3PJ Tx 40mhz and KO Propo KR-301F 40mhz 3ch FM Rx
  42. What's a Flight Condition?
  43. Can this Transmitter be upgraded?
  44. Digital servo fail safe w/o programmer
  45. Converting 9C to JR
  46. mixing digital and standard servos
  47. All servos on 6 v??
  48. Servo Tester Recommendations
  49. Anyone using HS-5945MG's on a 40%?
  50. Jr X-378
  51. Futaba vs hitec
  52. Futaba 9Ca w/hitec
  53. ClonePac installing need help
  54. 9151 vs 9450 digital futaba???
  55. Which servo for retracts
  56. Futaba Receivers
  57. 8103 Help
  58. Gliders and jr 10x(airplane version)
  59. Wiring CS-80 servos
  60. Range Problem.... C.f. Fuse
  61. PC to R/C interface
  62. Glitch's
  63. Futaba electronic parts
  64. Antenna Placement
  65. I have a 600mahtx batt, and what to upgrade to a 1000mah, will factory charger work?
  66. Advice on best radio
  67. Soldering Leads Directly to Servos
  68. Crystal Testing?
  69. Best digital servos
  70. Tracker II ????
  71. "After-Market" receivers...
  72. Futaba Rubber Hand Grips 9C Transmitter
  73. Metal servo arms for metal gear?
  74. Broken antenna
  75. airtronics and hitec
  76. Futaba Skyport 4 Upgrade?
  77. Futaba 9ZWC Verses Jr 10 X
  78. How 2 mod Tx from on/off throttle to variable throttle?
  79. boost/buff extension
  80. 5 ch single stick?
  81. Coreless vs. non-coreless
  82. JR receivers
  83. General Radio questions....
  84. Futaba Rx with Hitec Digitals. Problem??
  85. Airtronics RD 8000???
  86. Hitec servos
  87. jr/hitech
  88. Who Has The Best Prices On Servos?
  89. Multiplex FL Wing Servo Mounting?????
  90. GWS servo disclaimer
  91. Receiver Problem?
  92. multiplex Royalevo
  93. Futaba 9C with other rx
  94. Hitec Spectra Module in Futaba 8uafs?
  95. Dual Rx / Dual Batteries
  96. Digital servos squeaking ! What's going on ?
  97. Digital servo questions
  98. JR 507 servos
  99. Most popular Radio at your Field?
  100. RD 6000 Help
  101. Never mind
  102. Futaba FG Transmitter Gimbal Problem
  103. Compatible frequencies for Australia AND US
  104. Trouble With MPI Servos?
  105. Hitec Flash 5x and elevons?
  106. JR Radios
  107. Which Radio features are needed?
  108. JR 8103 mixing function question
  109. You guys had me scared on HS-605BB
  110. Current rating for the RX bus
  111. Request: JR DataSafe software.
  112. How good are the switches we use?
  113. JR R700 - Futaber 9z -> HELP
  114. severe glitching problem
  115. Where to get a 9C only
  116. Replacing TX aerial on a 9ZAW WC2
  117. best price on 9za wc for planes ?????
  118. Receiver Interference with Engine half throttle and more?
  119. JR Buddy Box problems
  120. Stick tension on Hitec
  121. New gears for airtronics 4731z
  122. JR Xmtrs
  123. JR 10SX2 vs. 10X
  124. Can I use FUtaba servo on JR rx?
  125. Futaba S-9303 question-? problem?
  126. Schulze receiver (alpha) in Fuel plane?
  127. Multiplex Evo
  128. Your Opinions needed.
  129. Have you ever seen the inside of a crystal for your TX or RX
  130. New JR DS8311 specs
  131. Hitec digital lockup - fact finding mission
  132. Drifting Servo
  133. 72/75mhz difference
  134. 9202 servo buzz?
  135. 8411 recall
  136. Flash 5 Flaperons
  137. Dots on JR xtals?
  138. battery cover futaba conquest
  139. A question re.4.8v & 6v rx batteries
  140. That plastic velcro stuff
  141. Tower TS-65 Servo's
  142. Hitec Receiver Crystal in Futaba Receiver
  143. Hitec Flash 5X digital trim problems
  144. Anybody using GWS BP-110 servos?
  145. Resetting Hitec Digital servos
  146. Inverted function on Heli 10x
  147. Strange things happening to my Plane
  148. Futaba T6xas Question
  149. Old Radio Help?
  150. GWS servos-anybody use? Dependability?
  151. Which piezo gyro for hovering airpalne ?
  152. Futaba GYA352
  153. Bad Batch of Futaba 3004's???
  154. Futaba 9CAP question
  155. Digital Trim Questions
  156. Servo failure
  157. f.M. or P.C.M. ?
  158. Running One Servo Out Of 2 Rx Channels - Is It Doable?
  159. IGNORE antenna's
  160. Servo torque
  161. For sale or trade for a boat
  162. FMA reciever crash!
  163. Radio interferance
  164. Computer radio channels?
  165. Trainer mode on a Futaba 8uaf.
  166. Anyone got the new JR X-378 Tx yet?
  167. JR R600 Receiver Crystal Swaps--Any Problems?
  168. Ham bands
  169. Futaba crystals in Hitec receivers?
  170. Diodes in tx's, how can I tell if I have one?
  171. Gy 240 Help!
  172. HFP-10 Hitec programmer.....MikeMayberry
  173. hitec hs 700bb for 90" seafury is this servo ok
  174. JR 8411/8411SA Service Notice.
  175. Newbie wants to set up 9Z for Draganflyer III
  176. Futaba Crystals
  177. Airtronics RD6000 - is there a Heli and Airplane version?
  178. Hitec Eclipse 7 throttle expo?
  179. JR 8411's still sealed for sale
  180. Futaba RX fails in storage?
  181. RC Information for a Practical project
  182. Crystal compatability Jr / Hitec
  183. Are ProLine Radios Narrow Band
  184. Crystal compatability Jr / Hitec
  185. Hitec digital servos or programmers Please look!
  186. New flyer - What radio?
  187. Channel Lineup
  188. can I use my older airtronics servos with my new jr radio? wich leads do I flip?
  189. Can I change radio frequencies by switching crystals?
  190. Charging Diode in Futaba Super 7 radio
  191. Servo Reverser?
  192. accu-cycle plus calibration problem
  193. JR radio and flaperon. how to set?
  194. Futaba 9CH - Reliability, quality ?
  195. Trimming new plane
  196. WANTED: Feather reciever
  197. [URGENT]: Hitec Prism 7 trainer jack pinout needed
  198. Finding the torque you need
  199. Routing antenna past servos and battery
  200. Large surfaces oscillating quickly
  201. MC 24 buddy box tech questions
  202. High Band - Low Band?
  203. How many of you use "Servo Savers"?
  204. JR Receiver Advice Needed
  205. Radio needs tune?
  206. Futaba Modules Compatable?
  207. Futaba servo & receiver current drain
  208. 1/4 Scale Servos ??? Need Help.....
  209. GWS servos, anyone use them?
  210. 4.8v vs. 6.0v, is it a no-brainer?
  211. Best Hitec Servo 1/4 Scale
  212. 10 year old Futaba 7UAPS
  213. Any new JR transmitters in the pipeline?
  214. Crystal compatibility
  215. Electric Motor Power Serge
  216. 8 model memory? CAMPac ?
  217. 40mhz or 75 mhz??
  218. 9 Cap Campac
  219. Airtronic Recivers
  220. Futaba 9203 servo specs. ?
  221. How to Buddy Box a JR
  222. Downlink
  223. JR 8103 TX Who has the best Price?
  224. servos for a 60 ugly stick
  225. Futaba 9z bad 3 positions switch
  226. Galloping Ghost & Reed systems
  227. Hobbico Receiver
  228. Aileron servo extension wire size
  229. Accessory switch?
  230. Ham Radio Help
  231. 9C buddy box
  232. Why JR???
  233. tower servoes
  234. PPM or PCM that is the question Vote your opinion
  235. JR 347 question
  236. Single conversion FM problems.
  237. Profi mc4000 question
  238. Radio programming question.
  239. 4.8 and 6 v..what takes place when used at same time
  240. Hobbico CS-35 Servo Failures
  241. jr 783 range problems
  242. Futaba servos: 3001 vs. 3004
  243. Help programming this ESC
  244. Which one would you use???
  245. Receiver Ni-Cd capacity 4*60
  246. Changing to new channel
  247. Cirrus CS-80MG servos...thoughts?
  248. Jr 347
  249. GYA352 manual
  250. Anybody use futaba/robbe fs 250T digital servo?
