PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92
  1. Futaba 6XAs Programming, Flaps 6ch knob HOW???
  2. RX battery on/off switch
  3. Best Bang for the Buck?9CAF,XP8103, X-378, or Eclipse w/spectra
  4. Need technical details of how radio and esc work
  5. i know I know
  6. Futabe TX + Hitec RX + Hits
  7. Does anyone make this?
  8. Hitec Eclipse W/Spectra or Futaba 9CAF
  9. Servo Survey...
  10. RD6000 Throttle Problems...again and again!
  11. Hitec Prism 7,,the older version
  12. Can JR Equip handle more than 6V?
  13. Buddy Box for an 8UAP using 7 channels??
  14. Antenna Routing
  15. 6v Regulator Causing Jitter.
  16. Hitec Eclipse And JR
  17. RoyalEvo or mc4000
  18. RAdio Mixing
  19. JR servo question
  20. Radio Modes
  21. Problem with receiver R 149DP and JR servos
  22. Can you use Futaba receivers with JR?
  23. Range check question
  24. Cirrus servos.
  25. heli channels
  26. Digital Servo question
  27. What servo for average aplication
  28. CF pushrods causing interference?
  29. Recharging NiMH Batts
  30. Radio Hits!!!!
  31. Futaba Hi-torque Servos
  32. Airtronics Vision 8P how to set up flaperon
  33. Voltage for Hitec digital servos
  34. Hitec Crystals in Futaba Receiver ? ?
  35. See if you can figure this one out.......
  36. Servo Reverser
  37. Futaba 9CHP
  38. Most Common Configuration?
  39. Dual elevator Eclipse
  40. radio & servo ?
  41. One or Two receivers ???
  42. Program Futaba 6XA
  43. Grease for servo gears
  44. any body using a JR Max 4 AM ???
  45. JR servos dying
  46. Futaba 9ZAP and gear servo travel
  47. RX Battery Pack location
  48. JR servo specs??
  49. Hitec eclipse
  50. 9c Rubber Hand Grips
  51. futaba 6xas
  52. Futaba 8UA Programming problem
  53. HELP!!!! Futaba 1024 9ZAP WCII
  54. I am questioning my 8103...
  55. HELP! with new Futaba 9CHP radio
  56. JR servo's 4021
  57. Aristo-Craft
  58. Airtronics Radiant Aero-Heli??
  59. Mini servo SLAM DS3421 vs HS5245
  60. Who's got the best prices on r/c wires?
  61. Airtronics Radiant P
  62. Radio Info Needed
  63. Hitec 225 Servo question
  64. Where can I buy some servos ?
  65. Airtronics Radio
  66. Is my thought correct?
  67. Help with new radio purchase
  68. Changing a radio from surface to air
  69. Jr 3810
  70. JR8103 and Ultra Stick 60 Programming
  71. How to make Dual Rates?
  72. Hitec 555 5ch receiver-adding ch 6,7 or 8
  73. Need Help!!!
  74. Books on JR 8103 ?
  75. Dual aileron servos not acting right
  76. Dual Rate Switch. JR PCM 10SX
  77. Futaba 12 channel?? Rumours?
  78. What to do if you break your rx antenna?
  79. PCM ?
  80. 9CAP "hop-ups"?
  81. New Futaba 9C pics anyone ?
  82. JR 8411 servos
  83. Book that explains computer radios and various mix options (what they do)
  84. servo reversing
  85. JR XP8103 Receiver
  86. Futaba 9402 plastic gear stripping
  87. What size arm screw thread do I use for the Futaba 9402?
  88. rc Dymond
  89. strange things a-happenin'
  90. pachage received
  91. Hitec 555 5ch receiver-adding ch 6,7 or 8
  92. Do I need A Bigger Battery Pack?
  93. How much current will a rx power bus handle? I want to put in all digitals....
  94. Servo Extentions
  95. Tune or Not
  96. Radio South radio repair ?
  97. Single Conversion & dual conversion xtals
  98. Datasafe2 interface problem:
  99. servocity
  100. PCM and metal noise
  101. Big plane, big servos, little problem
  102. 9201 Futaba servo What are the specs on this servo
  103. Possible Radio or ESC trouble???.... 1/10 elec. RC - Can you please help???
  104. Futaba Conversions
  105. Hitec "+" arms...
  106. JR 347 receiver
  107. futaba 3003
  108. Hitec HS-55's defective??
  109. Futaba 8UAFS - reset model data?
  110. Antenna wire fatigue
  111. HS300 Servos
  112. both are fine
  113. TXs only!
  114. Airtronics RD6000 Ail/El trim
  115. My Reciever Quit Working
  116. How do you connect two JR servo's together
  117. Radio?
  118. Any idea what's wrong
  119. 5 channel receiver / dual aileron servos?
  120. Futaba with JR?
  121. Futaba
  122. Himark Servos
  123. HS5645 Digital vs. HS645MG
  124. SErvo Repairs
  125. Pcm ?
  126. Hs 5945
  127. Faulty Servos
  128. Hobbico CS-65 High Torque Standard 2BB Servos(anyone else having problems)
  129. jr 652 progamming flaps
  130. receiver
  131. quad flap configuration on a JR XP662-HELP!
  132. Phenomenal Customer Service from Hitec
  133. Airtronics to Futaba
  134. servo compatiblity
  135. Servos chattering
  136. Bad Batch of Hitecs 545BB ???
  137. Computers & Radio Control
  138. Fly JR with Futaba?
  139. 2-servo elevator
  140. 10X flight mode/spoiler question
  141. Using co-pilot to train?
  142. Broken Switch on Futaba
  143. Futaba FP-T7UHP, need manual
  144. Servo kick-back
  145. futaba pro dad reciever
  146. How do you like your stick tension?
  147. What a FMA Co-Pilot looks like inside!
  148. 10X Question
  149. Does anyone hav a NEW EX-1 Mars For Sale?
  150. Servo Extensions
  151. 9z Wcii
  152. Opinions on XP-8103
  153. 8u timer triggered mix
  154. Hitec rotate diff. than Futaba?
  155. Airtronics M8
  156. 8u dual elevator servo mix
  157. Hitec Servos
  158. Hitec HS-81 Micro Servos
  159. R149DP Problem
  160. JR or Futaba
  161. futaba ham band radio question
  162. Need help with glitches
  163. Futaba Attack
  164. 9ZHW question
  165. Jr 8103 programing for Zagi 400x
  166. Futaba Synthesizer module?
  167. Futaba T8UAPs Program question
  168. Lowest Prices on Jr 10x radios??
  169. High Tech 5645 servos
  170. 9zapwcII trim memory
  171. ICOM R2 receiver
  172. 9C throttle spoileron mix question
  173. mixing analog and digital servos
  174. Servos for dual elevator setup
  175. Price for JR- 10SX PCM heli radio.
  176. Futaba 9C Knobs and Sliders
  177. Pardon my dumb question--but---
  178. Ann Marie Futaba 9 c addendum does not print
  179. Need Rx for Futaba FP-T7UAP
  180. Hitec Prism Radio
  181. 9 ZAW Diode bypass
  182. Futaba campac blueprint help
  183. Hitec Rx crystal question
  184. converting f15 to electric fan
  185. Interview with Jason Shulman - Need Questions...
  186. Whip type Antenna (HELP)
  187. buddy box debate
  188. looking for crystal exchange business
  189. electronics longevity
  190. Stylus or ?
  191. Which servos to use on Intruder?
  192. Glitch Counters
  193. Range check has been reduced, thoughts?
  194. Dymond Servo
  195. JR 811 w/Futaba?
  196. futaba transmitter + rcd receiver
  197. PCM Vs FM
  198. Radio fixers in Ohio??
  199. Need info about Challenger 720 receiver?
  200. Airtronics Z-Connector Versus Futaba J-Connectors
  201. 8UAFS throttle trim problem
  202. Computer radios
  203. Dual conversion receiver range
  204. Hitec metal gear RF problem
  205. BIG Servo Horns...
  206. HELP with JR wiring please
  207. futaba BB plug question & tranny problem?
  208. FMA RX Dip Switch Settings for Neg Shift
  209. 2 radios same channel, servo trim?
  210. JR Max 6 Dead?? Fuse?? Diode??
  211. used reciever
  212. Crystal Swapping
  213. Hitec Flash 5 Expo?
  214. how much torque do I need?
  215. 8UAFS vs. 9CAF
  216. Cub
  217. Dual Conversion, Single conversion, etc! What does it mean?
  218. RC connectors where to buy quantity
  219. Airtronics contest HH servo info please
  220. JR or Hitec receiver???
  221. Long battery cord
  222. 6xas and dual elevator servos/miracle y
  223. Futaba reciever and crystal for sale (sold)
  224. G.W.S radio gear
  225. Charging Tx and Rx batteries
  226. selecting the best !
  227. PCM to FM with 9C
  228. gws piezo gyro problem
  229. JR Alpina pcm Range problems
  230. Operating Ailerons from two channels
  231. Futaba 9Z programing trouble
  232. Retract Servos
  233. JR RX crystal differences ?
  234. Futaba 8U
  235. Info needed on rx antenna
  236. Servo accutator
  237. rd6000 compatability
  238. vanguard PPM?
  239. Flapperons
  240. Futaba digital servos recommandation
  241. Boosters on extensions for servos with long runs
  242. DAD Servo-Need info
  243. buddy box interchange between brands
  244. Servo Reversing and getting crossed
  245. VG 6000 6 Ch.?
  246. 2 elevator servos and an 8UAFS
  247. Can someone help me make some sense of exponentials?
  248. trainer system ?
  249. Hiktec and Futaba
