PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92
  1. PCM compatibility
  2. Using a Futaba 9CA radio with trainer box?
  3. Calculator wall charger as receiver charger?
  4. Xp652 Jr
  5. Thank you, but do I need a regulator
  6. 6 volt DO I NEED A REGULATOR
  7. greater than 300 oz of torque
  8. Cheap Buddy Box???
  9. Sanwa RD 6000 buddy box cable!
  10. Servo Movement - unwanted
  11. futaba 9chp
  12. Vanguard buddy box problem
  13. 9Zwc2 Airbrake question
  14. Anyone make a 6 volt wall charger?
  15. Futaba S-33 servos
  16. Service Problems
  17. at what voltage should i stop flying
  18. Antenna routing and metal control rods?
  19. Using 10X or 9Z with Multiplex IPD Receiver
  20. Old Futaba items still needed...
  21. Hitec Digital Problems
  22. JR Max computer
  23. Looking for switch that uses a pin for off/on
  24. Servo current draw & power supply
  25. JR 8103 Set-Up
  26. Old radio; can you identify it?
  27. dual Elevator servos, setup?
  28. ultra stick/Futaba programming
  29. servo adapters ?
  30. Hitec digital servoes not working on y harness
  31. Where to find frequency flags
  32. XP 8103 Mixing
  33. JR Radio Buddy Box System Help
  34. Flying Jets witha a 9C
  35. 8411sa
  36. Futaba 9 CAP Vs JR 3810 ..
  37. servo plugs
  38. Hitec 5645 digital servo info
  39. JR radio question
  40. Ultra Stick + Futaba 8AU and 9C
  41. Zagi on buddy box
  42. Antena
  43. Ok, who bought them? WHO DID IT! ?
  44. Shift Selectable RX
  45. airtronics
  46. help with gws receiver
  47. Any one running 6.0V? Is it worth it?
  48. Classifieds
  49. What's best for a 72+- oz. torque in a futaba compatable servo??
  50. Powerlines
  51. FM or PCM crystal - futaba
  52. comfort important?
  53. 8u/9c not overcamming thr with elev/ail to thr mixes
  54. Range Checking,how far!
  55. Resolution/ centering accuracy of micro servos.
  56. Should I buy a 9Z or 10X?
  57. Servos and Elevator
  58. PCM Range check???
  59. Traxxas Radio Trouble
  60. FM/PCM Single/dual band..explain please!
  61. Throttle Cable Choices???
  62. JR 652 Dead???
  63. Futaba receiver high or low 72Mhz
  64. JR 10S manual - aircraft
  65. Jomar Battery Backup
  66. How Many mah will be best with 5 digital servos
  67. Decreased range when using 6v reciever packs.
  68. How to tell crystal manufacturer
  69. Servos - use which for what?
  70. Futuba 9C - Round bits don't go into square holes!
  71. Custom Mixing
  72. Ultra Stick with 9C
  73. FMA Co pilot
  74. crimping tool cheaper @ radio shack
  75. Connecting a Futaba to a PC...possible??
  76. mode 1 teacher and mode 2 student ?
  77. HiTec Flash 5?
  78. Shelf life on unused nicad's pleas help!!!
  79. Tower Servos
  80. E-Bay auction is not from ServoCity!
  81. Digital servo squeals
  82. JR radio glitches with Gas motor plane .... HELP<<<<
  83. Need a Futaba Campac?
  84. hs77 in gp pitts
  85. The ultimate EBay scumbag!
  86. Which solder joints look like FACTORY joints?
  87. Bent Antenna!!!
  88. Futaba S3106 torque?
  89. Jr Radio's
  90. Frequency changing
  91. Anyone remember the EGAS on-board glow drivers?
  92. Is this any Good Hobbico Command 7 Channel
  93. Should I or shouldn't I
  94. Receiver question(s)
  95. digital voltmeter
  96. 24" and 36" servo extensions: What to watch for?
  97. charging transmitter battery
  98. what type of batteries to use on rx and ignition.
  99. Need help with aileron servos
  100. Will the Futaba Fail Safe Unit work with a NIMH RX Pack
  101. Servo horn/arm screws??
  102. TX: Should I get an actual pack or just a battery holder/tray and some AA NiMHs?
  103. Thought sharing on transmitter costs.
  104. PCM fail safe
  105. Question about Futaba TX crystals - Please help
  106. Hitec servo jitter using 6 volt battery
  107. 8103 Blue Screen of Death
  108. Futaba Buddy TX Plug
  109. Fma S360m
  110. newbie
  111. Retract servo ?
  112. Changing modules from lo to hi in Futaba 9C
  113. Glitch from TX? Help
  114. Servos Question - Please Help
  115. futaba TX user Manual
  116. 9c radio
  117. Pcm
  118. How to tell if a radio is safe to use?
  119. GWS super servo
  120. Radio interference
  121. AM to FM conversion ?
  122. Cycling receiver battery
  123. airtronics infinity 600 tx, modules, recievers
  124. Futaba Fp-t5lk Am? Fm? Wide_narrow?
  125. Any comments on Hitec HS-77BB servos?
  126. In reference to "Splais" statement about Hitec servo's
  127. My question is similar to Ragz's question. Servo locations?
  128. glitching problem with Rx or tx,how to verify the problem
  129. The Futaba 9C series
  130. DAD Servos......Any good ?????
  131. Home Made Y harness
  132. Moderator needs to learn restraint
  133. Prism 7 - bad pot ?
  134. Servo terminology!!!??? torque vs. holding power???
  135. Do servos go bad?
  136. Futaba S148, S3003/3004, and Hitec HS-425BB differences
  137. Hitec glitches/full travel?
  138. Eclipse 7 spoilerons and flaperons
  139. Darn
  140. Futaba 9C Butterfly or flaps
  141. JR 8411 digitals and 6 volts?
  142. 10x-How many channels are 1024 bits
  143. JR 8411 digital's and 6volts batteries?
  144. Hitec Supreme Shift Select RCD 3800
  145. Loss of control at 50-75 yards! help
  146. T6XAS mixing ailerons
  147. Stylus, 9C questions
  148. Need help with T6XAS radio setup!!
  149. receiver battery draining quicker
  150. 53 mhz
  151. Gem 2000
  152. JR 10X versus JR 10S
  153. Will Futaba "J" work with JR?
  154. Computers
  155. JR 10X aircraft versus Heli
  156. Kraft Midwest
  157. Jr
  158. Bad servo??
  159. What Servos are you using with what RX
  160. Futaba T8UAF Question
  161. Radio Frecuency
  162. FMA Servos
  163. Servocity.com sent me digitals instead of 645's
  164. Futaba aerial length
  165. Tx Modules
  166. JR 378 Instruction Manual
  167. Futaba Charger__JR Transmitter
  168. Futaba versus JR?
  169. servo mount
  170. 10X compatable receivers
  171. Receiver for a T6XAS
  172. Airtronics 94394 Servo Specs/Torque
  173. Fed Up With Hitec Quality
  174. Are servos ever at "rest"
  175. Please Help: Futaba 6XA and Control Throws
  176. Battery plugin.
  177. Dual rudder servo's
  178. jrR700 receiver question
  179. Gws S03txf 2bb Servos.. Any Comments?
  180. Changing from Airtronics to Futaba??
  181. blown fuse on JR 421 EX
  182. Should this have been included in the Super 8?
  183. need help finding longer servo horns...
  184. JR Receiver's
  185. Antenna - Inside or Outside
  186. JR's Matchbox
  187. Best Bang for the buck?
  188. Alum. servo trays?
  189. Best radio for 3-D T6XAS vs Hitec /5
  190. Hitec HS-5645MG
  191. What should I do? (Buy a radio system or flight pack?)
  192. Frequency conversion chart?
  193. Receiver Wiring question
  194. basics of NiCD -- charging/cycling/discharging
  195. Spilt fuel on my 9 CAP :(
  196. Prices on JR Radios,etc.
  197. 8UAPS TX only
  198. Antenna wire guage and length
  199. eclipse and negative shift
  200. Swapping trims on Futaba Super 8
  201. Servo Jitter receiver or servo reverser???
  202. OLD Futaba Mixing?
  203. Servo / Linkage setup
  204. 10X Throttle Curve
  205. I need names of analyzers to track possible interference
  206. Best place to buy Futaba 9zap w2
  207. JR Nes 531 specs
  208. Polarity swap - OOOPPS!
  209. Help needed with Zagi Elevon setup using Stylus Tx
  210. Rubber duck twig for ground based radio???
  211. Radio installation
  212. Don Edberg manual needed
  213. GWS 8 channel receiver questions
  214. Weird Radio Interference
  215. WANTED: Airtronics Stylus expert
  216. What channel do you fly?
  217. alvtr on 8uap
  218. Servos on the go
  219. elevator mixing on futaba 8uap
  220. Any views on 'Dalasy Models' rx?
  221. 6 Channel Or 8 Channel Pcm
  222. Glitch only with engine running
  223. 9C and 9Z differances
  224. Airtronics Vanguard trainer system
  225. Digital Servos - technically why do they perform better?
  226. Well a Airtronics Rd6000 Control an Tower hobbies or Futaba receiver.
  227. Hitec Eclipse and Ultra Stick
  228. hitec 5945 squeals like a pig?
  229. Mystery ?? Radio
  230. will JR servos work with futaba RXs ?
  231. Tying knots in the reciever antenna?
  232. fm Vs. PCM
  233. Pull Pull Systems
  234. Futababa FP-r107g Receiver trouble
  235. jr PCM10X Vs futaba 9ZAWS (AIRPLANE)
  236. Eclipse 7 Question
  237. R114F technical notice
  238. Hitec Superslim compatible with JR 10X
  239. Futaba 9C tx with JR rx?
  240. Multiplex servos
  241. multiplex radios ?
  242. Transmitter and Receiver combinations
  243. Kraft Family Photo
  244. jr nes 401
  245. Airtronics Blazer Sport
  246. Servo Torque
  247. TX range problem
  248. Throttle Curve for 10SX
  249. 9c ?
