PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92
  1. Kraft Family Photo
  2. jr nes 401
  3. Airtronics Blazer Sport
  4. Servo Torque
  5. TX range problem
  6. Throttle Curve for 10SX
  7. 9c ?
  8. Seeing a lot of Digi S9252 servos cheap lately. Do they work?
  9. Older Airtronics Gold Receivers (help)
  10. An Idea better than PCM Failsafe
  11. best JR radio for Ultra Stick 40
  12. sanwa 1322 same as airtronics 94322??
  13. newbie ?: servo travel
  14. To go digital or not to go digital... That is the question...
  15. Status of Airtronics/Sanwa?
  16. Peak charging a Futaba 9C?
  17. hitec eclipse
  18. Hitec Eclipse vs Futaba 9C
  19. Question on the 8103 programming
  20. Buddy Cord Compatibility
  21. graupner
  22. Cell Phones ?
  23. Flappron Problem
  24. futaba 9chp or jr 10x
  25. Airtronics 94258
  26. JR 8101 Servo -any info?
  27. Programming book for Futaba Super 8?
  28. Hitec Eclipse VS Futaba 8U
  29. Expert Servo's
  30. JR 10 SX to 10 X upgrade
  31. Hitec Eclipse VS Futaba 8u for Ultra Stick
  32. A Novice Question
  33. mixing servos on the futaba 6XAS
  34. three wire servos
  35. JR 10 sx trainer?
  36. Radio Age HOW OLD IS TO OLD???
  37. Hitec Servos
  38. on board microcontroller
  39. dual conversion
  40. futaba 6xas band change
  41. Water proof transmitter question
  42. Multiplex, how do they get 12 channels??
  43. Futaba micro servos
  44. 8231 digital servo failure
  45. Progaming flaps on the Ultra Stick 60 help
  46. Please Stop !!!
  47. Searching For Interference Sources (links inside)
  48. JR Xtal sources
  49. Question for you radio experts. Need your opinion
  50. Prism 7 vs Eclipse
  51. nicad conversion
  52. JRs more sensitive to getting hit?
  53. Coreless Servo Motors?
  54. NIB JR 652 $185.00 Great deal from Chief Aircraft!!!
  55. Problems with the Futaba 9ZAW-WC1 changing from PCM to PPM
  56. FMA Co-pilot
  57. Futaba PCM 1024 receiver
  58. Fractured 8U antenna mount
  59. So how far do you guys go on range checks?
  60. Hitec receiver antenna??
  61. What have I got here
  62. Radio Wont Work At Full Throttle
  63. hitec 5945's or 5925's ?????
  64. antenna-down causes damage?
  65. Multiplex Pico interference
  66. G.W.S. Servos
  67. Thumbs, Or Thumbs and fingers? Please vote
  68. receiver
  69. multiple freqs at the field at the same time
  70. Purchasing a Radio
  71. JR 8103 programing question
  72. Post crash problems?
  73. Futaba 9ZAP WC1 Question
  74. JR Buddy Boxes
  75. Tower Hobbies Servos
  76. Futaba 8UAF Radio Flap Setup, HELP Please
  77. Two transmitters on- plane flew great?
  78. JR Expert Servos any good?
  79. Radio Transmitter Problem
  80. Futaba S5050 High Torque Digital Servo
  81. Futaba FP T8A P PCM 1024?
  82. Jr 10x
  83. JR 652 Help
  84. Schematic for Failsafe
  85. 9C Rx assignments
  86. futaba servos fit
  87. Hitech Lazer 6 and elevator trim
  88. Seeking Sanwa M-Zechs Userīs Manual
  89. Bought the Venture CP now I need a radio
  90. Futaba 8U Question
  91. 50 mhz radio thoughts
  92. antenna question
  93. Expert Ex-100
  94. PCM vs FM TX Module
  95. t9z wc2
  96. clevices?
  97. Pcm Vs Fm
  98. Metal to metal interferance
  99. Help! Receiver Antenna was Cut off
  100. transmiter case
  101. Help, My Servos are Posessed!!!!
  102. Hitec Eclipse 7 GLID mode Programming Bug Announcement.
  103. Futaba S9253 works with GY240?
  104. Hitec Eclipse 7 GLID mode Programming Bug Announcement.
  105. Good place to buy servo's?
  106. What does "X" Year Warranty Mean
  107. Futaba 9C and others
  108. Futaba radio stopped working in flight
  109. radio work
  110. Futaba 9C series: problem or rumor?
  111. Help! Servo Jitter Problem
  112. Instrument Panel Decals
  113. crystals
  114. Can I connect ailerons to CH 1 and ch8?
  115. HiTec Futaba compatible?
  116. Retract Servo triggering?
  117. anyone know JR631 radios?
  118. How reliable???
  119. Airtroncs xl problem
  120. Multiplex Radios
  121. Futaba 9 Cap Pcm
  122. 8103
  123. Jr 783
  124. Toggle Switch
  125. JR 8103 vs Futaba 9CA? Help me decide...
  126. Old Airtronics Vanguard VG6DR Tx
  127. Who has the best prices on JR servos ?
  128. Stabilant 22....electrical conductivity enhancer
  129. Does 8u PCM RCVR work with 9C?
  130. Hitec Lynx 3d
  131. Has Futaba ever made...
  132. Voltz servos
  133. Battery Placement
  134. Futaba 8UAF model change
  135. Glitching servo
  136. 8411s on Futaba PCM RX, bumpy motion
  137. Ever had a problem when swapping crystals?
  138. JR on 6V
  139. Stupid radio.
  140. hitec hs55 torque enough?
  141. JR 10X or JR10SX
  142. Simple Nice Transmitter Tray
  143. what servos should i use????
  144. Upgrading radio Graupner , Multiplex or JR. (any comments)
  145. swap crystals 9c <-> 6X ??
  146. JR Radio
  147. One heck of a deal !!
  148. Futaba 6XA Diode
  149. range checks and aftermarket gear`
  150. Futaba 6XAS - Flap control
  151. I'm new to 10X programming
  152. H9 33% cap servos??
  153. Fixing frayed Antenna
  154. TX vs. RX
  155. Receiver/servo power supply/voltage regulator
  156. SPecs for JR 4031???
  157. Which is better?
  158. Y connectors
  159. Futuba
  160. Hitec HS-81 Servo
  161. Jr X378
  162. Opinions on 9ZAS WC2
  163. GWS servos good or?
  164. Lowes TX cases
  165. Jr 2721 conversion
  166. How much is a 64K CAMPac worth?
  167. Checking Actual Servo Torque
  168. damage from magnetic field???
  169. Radio Glitch problem
  170. Long Wires Other Than Servos a Concern??
  171. Futaba Super 8 Range Testing
  172. Bigger battery, new charger needed?
  173. Flying Late 50's vintage R/C ?
  174. Post-crash testing of receiver and servos
  175. Jr622+ner226x+h9 Ustick=lost Again
  176. Sig Something Extra
  177. Fuel soaked rx
  178. Changing Channels
  179. Hitec 5625 and 5645 in Dave patrick 330L.
  180. Schematic for Futaba 8UAPS
  181. arrrgh
  182. futaba 9c
  183. JR 9ch pcm SS
  184. Hitec Feather receiver - JR/Air't
  185. 9ZAP switch change
  186. When you buy...
  187. 35A and 35B bands
  188. Wide band radio help
  189. Hitec supreme
  190. Sanwa radio!!!!!!!
  191. Futaba 9204 Gearsets
  192. Servo control horn screws
  193. Flapperons setup with JR783
  194. Hitec Servo Arms?
  195. Megatech Radios: Positive or Negative Shift?
  196. T6XA Manual Needed
  197. 9zWCII MSTR MIX mode and links
  198. Servos for Midwest Extra
  199. Interference
  200. radio south? is that the place?
  201. How do we test new servos before flying???
  202. servo gear grease??
  203. Hitec Digital servos!
  204. old reciever AM need servos w/ old connetors to fit reciever.
  205. Radio training ??
  206. Problems with brand new Hitec servos.
  207. 4.8v or 6.0v...that is the question.
  208. Need help repairing Airtronics servo wire
  209. Does anybody know of a good multiple receiver battery charger?
  210. Multiplex Digi -vs- Hitec Digital -vs- JR
  211. dual futaba pcm recievers
  212. Sanwa Equipment
  213. FM or PCM with G38?
  214. JR 8103 dt help please!
  215. strange hits near power line
  216. Flash 5X throttle cut
  217. receiver reversing throws?
  218. 10X Tx shuts down????
  219. Schematic for Futaba 8UAPS
  220. Servo Voodoo??? Losing airplanes....
  221. 9ZAP WCII not working. HELP!
  222. Hitec Flash x 4 or 5
  223. Swapping crystals
  224. Hitec screws & stuff
  225. JR 631 Flaparons
  226. 9C trainer/buddy port pin lay-out
  227. Rubber Ducky Antenna's
  228. JR 652 mode change
  229. Futaba 8UHFS does it work with 127df
  230. T6XA with Crow possible?
  231. Trade a 9Z for a 9C
  232. Sanwa rd6000 manual wanted
  233. Multiple aircraft Radio
  234. JR 10 xxxx progression....
  235. How to mix flaps and elevator
  236. Multiplex Evo 9 /12 specs. to print out
  237. gyro problems
  238. 8UAPS-tower-annmarie-cross
  239. 9204 Gears
  240. JR652 aileron set-up
  241. 9 chan RX, FUtaba, Multiplex, others?
  242. Cost to check a rx and replace its case
  243. RD 6000 Super Programming Question
  244. Check this out!
  245. Hitec spectra module and futaba 8UAFS
  246. single /dual/ what is it?
  247. servo arm centering
  248. kopro po module
  249. JR10SX2 Problem
  250. Where can I get Jr Transmitter Parts??
