- That plastic velcro stuff
- Tower TS-65 Servo's
- Hitec Receiver Crystal in Futaba Receiver
- Hitec Flash 5X digital trim problems
- Anybody using GWS BP-110 servos?
- Resetting Hitec Digital servos
- Inverted function on Heli 10x
- Strange things happening to my Plane
- Futaba T6xas Question
- Old Radio Help?
- GWS servos-anybody use? Dependability?
- Which piezo gyro for hovering airpalne ?
- Futaba GYA352
- Bad Batch of Futaba 3004's???
- Futaba 9CAP question
- Digital Trim Questions
- Servo failure
- f.M. or P.C.M. ?
- Running One Servo Out Of 2 Rx Channels - Is It Doable?
- IGNORE antenna's
- Servo torque
- For sale or trade for a boat
- FMA reciever crash!
- Radio interferance
- Computer radio channels?
- Trainer mode on a Futaba 8uaf.
- Anyone got the new JR X-378 Tx yet?
- JR R600 Receiver Crystal Swaps--Any Problems?
- Ham bands
- Futaba crystals in Hitec receivers?
- Diodes in tx's, how can I tell if I have one?
- Gy 240 Help!
- HFP-10 Hitec programmer.....MikeMayberry
- hitec hs 700bb for 90" seafury is this servo ok
- JR 8411/8411SA Service Notice.
- Newbie wants to set up 9Z for Draganflyer III
- Futaba Crystals
- Airtronics RD6000 - is there a Heli and Airplane version?
- Hitec Eclipse 7 throttle expo?
- JR 8411's still sealed for sale
- Futaba RX fails in storage?
- RC Information for a Practical project
- Crystal compatability Jr / Hitec
- Are ProLine Radios Narrow Band
- Hitec digital servos or programmers Please look!
- New flyer - What radio?
- Channel Lineup
- can I use my older airtronics servos with my new jr radio? wich leads do I flip?
- Can I change radio frequencies by switching crystals?
- Charging Diode in Futaba Super 7 radio
- Servo Reverser?
- accu-cycle plus calibration problem
- JR radio and flaperon. how to set?
- Futaba 9CH - Reliability, quality ?
- Trimming new plane
- WANTED: Feather reciever
- [URGENT]: Hitec Prism 7 trainer jack pinout needed
- Finding the torque you need
- Routing antenna past servos and battery
- Large surfaces oscillating quickly
- MC 24 buddy box tech questions
- High Band - Low Band?
- How many of you use "Servo Savers"?
- JR Receiver Advice Needed
- Radio needs tune?
- Futaba Modules Compatable?
- Futaba servo & receiver current drain
- 1/4 Scale Servos ??? Need Help.....
- GWS servos, anyone use them?
- 4.8v vs. 6.0v, is it a no-brainer?
- Best Hitec Servo 1/4 Scale
- 10 year old Futaba 7UAPS
- Any new JR transmitters in the pipeline?
- Crystal compatibility
- Electric Motor Power Serge
- 8 model memory? CAMPac ?
- 40mhz or 75 mhz??
- 9 Cap Campac
- Airtronic Recivers
- Futaba 9203 servo specs. ?
- How to Buddy Box a JR
- Downlink
- JR 8103 TX Who has the best Price?
- servos for a 60 ugly stick
- Futaba 9z bad 3 positions switch
- Galloping Ghost & Reed systems
- Hobbico Receiver
- Aileron servo extension wire size
- Accessory switch?
- Ham Radio Help
- 9C buddy box
- Why JR???
- tower servoes
- PPM or PCM that is the question Vote your opinion
- JR 347 question
- Single conversion FM problems.
- Profi mc4000 question
- Radio programming question.
- 4.8 and 6 v..what takes place when used at same time
- Hobbico CS-35 Servo Failures
- jr 783 range problems
- Futaba servos: 3001 vs. 3004
- Help programming this ESC
- Which one would you use???
- Receiver Ni-Cd capacity 4*60
- Changing to new channel
- Cirrus CS-80MG servos...thoughts?
- Jr 347
- GYA352 manual
- Anybody use futaba/robbe fs 250T digital servo?
- Futaba 6XAs Programming, Flaps 6ch knob HOW???
- RX battery on/off switch
- Best Bang for the Buck?9CAF,XP8103, X-378, or Eclipse w/spectra
- Need technical details of how radio and esc work
- i know I know
- Futabe TX + Hitec RX + Hits
- Does anyone make this?
- Hitec Eclipse W/Spectra or Futaba 9CAF
- Servo Survey...
- RD6000 Throttle Problems...again and again!
- Hitec Prism 7,,the older version
- Can JR Equip handle more than 6V?
- Buddy Box for an 8UAP using 7 channels??
- Antenna Routing
- 6v Regulator Causing Jitter.
- Hitec Eclipse And JR
- RoyalEvo or mc4000
- RAdio Mixing
- JR servo question
- Radio Modes
- Problem with receiver R 149DP and JR servos
- Can you use Futaba receivers with JR?
- Range check question
- Cirrus servos.
- heli channels
- Digital Servo question
- What servo for average aplication
- CF pushrods causing interference?
- Recharging NiMH Batts
- Radio Hits!!!!
- Futaba Hi-torque Servos
- Airtronics Vision 8P how to set up flaperon
- Voltage for Hitec digital servos
- Hitec Crystals in Futaba Receiver ? ?
- See if you can figure this one out.......
- Servo Reverser
- Futaba 9CHP
- Most Common Configuration?
- Dual elevator Eclipse
- radio & servo ?
- One or Two receivers ???
- Program Futaba 6XA
- Grease for servo gears
- any body using a JR Max 4 AM ???
- JR servos dying
- Futaba 9ZAP and gear servo travel
- RX Battery Pack location
- JR servo specs??
- Hitec eclipse
- 9c Rubber Hand Grips
- futaba 6xas
- Futaba 8UA Programming problem
- HELP!!!! Futaba 1024 9ZAP WCII
- I am questioning my 8103...
- HELP! with new Futaba 9CHP radio
- JR servo's 4021
- Aristo-Craft
- Airtronics Radiant Aero-Heli??
- Mini servo SLAM DS3421 vs HS5245
- Who's got the best prices on r/c wires?
- Airtronics Radiant P
- Radio Info Needed
- Hitec 225 Servo question
- Where can I buy some servos ?
- Airtronics Radio
- Is my thought correct?
- Help with new radio purchase
- Changing a radio from surface to air
- Jr 3810
- JR8103 and Ultra Stick 60 Programming
- How to make Dual Rates?
- Hitec 555 5ch receiver-adding ch 6,7 or 8
- Need Help!!!
- Books on JR 8103 ?
- Dual aileron servos not acting right
- Dual Rate Switch. JR PCM 10SX
- Futaba 12 channel?? Rumours?
- What to do if you break your rx antenna?
- PCM ?
- 9CAP "hop-ups"?
- New Futaba 9C pics anyone ?
- JR 8411 servos
- Book that explains computer radios and various mix options (what they do)
- servo reversing
- JR XP8103 Receiver
- Futaba 9402 plastic gear stripping
- What size arm screw thread do I use for the Futaba 9402?
- rc Dymond
- strange things a-happenin'
- pachage received
- Do I need A Bigger Battery Pack?
- How much current will a rx power bus handle? I want to put in all digitals....
- Servo Extentions
- Tune or Not
- Radio South radio repair ?
- Single Conversion & dual conversion xtals
- Datasafe2 interface problem:
- servocity
- PCM and metal noise
- Big plane, big servos, little problem
- 9201 Futaba servo What are the specs on this servo
- Possible Radio or ESC trouble???.... 1/10 elec. RC - Can you please help???
- Futaba Conversions
- Hitec "+" arms...
- JR 347 receiver
- futaba 3003
- Hitec HS-55's defective??
- Futaba 8UAFS - reset model data?
- Antenna wire fatigue
- HS300 Servos
- both are fine
- TXs only!
- Airtronics RD6000 Ail/El trim
- My Reciever Quit Working
- How do you connect two JR servo's together
- Radio?
- Any idea what's wrong
- 5 channel receiver / dual aileron servos?
- Futaba with JR?
- Futaba
- Himark Servos
- HS5645 Digital vs. HS645MG
- SErvo Repairs
- Pcm ?
- Hs 5945
- Faulty Servos
- Hobbico CS-65 High Torque Standard 2BB Servos(anyone else having problems)
- jr 652 progamming flaps
- receiver
- quad flap configuration on a JR XP662-HELP!
- Phenomenal Customer Service from Hitec
- Airtronics to Futaba
- servo compatiblity
- Servos chattering
- Bad Batch of Hitecs 545BB ???
- Computers & Radio Control
- Fly JR with Futaba?
- 2-servo elevator
