PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92
  1. gyros, gyros,gyros,
  2. Servo Horns for old KO / Kraft Sport servo's
  3. Fut 9C for sailplanes heli or acro version
  4. New Radio's That Have Crow Capability??
  5. shiftable rx
  6. JR to Futaba
  7. Legal / Illegal tx...
  8. Flying wires=Loop Antenna???
  9. Battery for Eclipse 7 / Spectra module ??
  10. Eclipse 7 - quick question
  11. Alpha Four Charger
  12. Servo "Pot" Cleaning ?
  13. Piezo Gyros
  14. Profi 4000 or MC24 or Other
  15. Jr radio w/ Futaba buddy box???
  16. Vibration insulated Switch mount
  17. Tiny Throttle servo.
  18. Best Servo for the money (cheap)
  19. Correct length for antenna (JR FM)
  20. FYI Using the FMA RFD1 Replacement RF Deck in units other than ACE.
  21. Futaba TX switch broke
  22. Vote: Like or don't like dedicated support forum format?
  23. 6x LCD almost out ???
  24. FP-T8UAF -tower hobbies
  25. servo chatter
  26. Futaba PA 1 assistance
  27. Were You At Rc Country Swap Meet?? Please Help!!
  28. FM or PCM Whats the diff
  29. Kraft or ????
  30. adding another plane
  31. 8UAFS Help in Special Prgm.
  32. Dream World
  33. What servos should i use?
  34. Help with Radio terms
  35. T6XA Flaperons with 5 channels?
  36. JR G-550-T + Hitech 605-BB
  37. Airtronics 94554 Servo Info?
  38. 50mhz ?
  39. Mike at Toledo
  40. Futaba PCM Receivers 138DP VS 148DP
  41. Contact Multiplex!?!??!?
  42. MPI 460MG servos glitching
  43. moved
  44. question about the 9c
  45. DELETE
  46. Futaba 9CAP
  47. 9Z Upgrade
  48. Futaba 9C and also cool tx cases
  49. Testing Servos ??
  50. What should I get
  51. Airtronics Buddy Cord
  52. Futaba Pilot Assist and JR - compatible?
  53. range check
  54. hobbico cs-71 super torqe metal gear ball bearing servos
  55. 9C color?
  56. Servo worn out?
  57. Easy question, I think.
  58. Ace Trickle Charge ?
  59. JR charging diode
  60. Futaba Super 8 VS 9CA
  61. 8U-E-Sailplane w/ Motor & CROW! Help.
  62. Futaba 12 Channel Radio
  63. Can you believe this NUT bought this
  64. JR Galaxy PCM8 Question????
  65. FMA Co-pilot
  66. Dual Rate Set Up
  67. 9z Transmitter Batterys
  68. Q. for Mike (Hitec guru). Why the Prism makes servos to buzz ?
  69. JR Datasafe
  70. Help Help !
  71. What kind of rx is this? Very odd.
  72. Hitec HS-5925 MG Failure - Attention Mike.
  73. Futaba FG series model FP-T4FG
  74. Futaba Wall Wart Charger - Airtronics Compatibility??
  75. Please Delete
  76. Waterlogged RX and servos
  77. Channel 11 & 60 the ends, are they no mans land???
  78. Eclipse 7 Transmitter with Spectra
  79. Narrow band to wide band
  80. Hitec to Futaba trainer cable, possible ?
  81. Rudder Pull-Pull System Pictures
  82. Futaba 6 channel radio
  83. At a crossroad, Stay with Airtronics or change to Futaba!
  84. Futaba 1024 PCM 3PB
  85. Dumb about digital trims, 9C
  86. Digital servos on 6 volts
  87. Futaba FF9 or JR 3810 ADT???
  88. Jr Pcm 10
  89. What was your first Radio?
  90. Crystal Swap
  91. Buddy-Box Compatability
  92. Torque ?
  93. reciever sing/duel conv.
  94. JR Crow Setup
  95. Using old airtronics servos with a Futaba receiver?
  96. Radio glitch ch41
  97. Hitec Digital Servos
  98. Servo grease? Will clear silicon work?
  99. Radio Failure / plane lost
  100. Nose wheel steering in a V-tail set-up ?
  101. What can I do with old Kraft servos
  102. Hitec / Futaba Receiver Crystals?
  103. Best radio for helicopters and airplanes?
  104. JR 622 & quad flaps ?
  105. JR 783 Radio
  106. Elevon Differential on Eclipse 7?
  107. Convert Airtronics to Futaba
  108. 9c switch switching question
  109. Crystal exchange service
  110. legal frequencies
  111. Futaba Radio/Servo pricing question
  112. 5125MG Digital Wing Servo
  113. Dual Conversion Crystals ????
  114. Futaba FP-T7UAF & 8U/9C Compatability
  115. Hitec w/ Futaba?
  116. servo confusion
  117. 225 metal gear vs nylon gear
  118. Airtronics Radiant Manual Needed
  119. chargers- simple question
  120. Jr 783
  121. Hitec/Futaba RX Compatability
  122. ServoCity???
  123. ServoCity???
  124. Hitec Flash 5 / Prism 7 ????
  125. opening jr 10x?
  126. is is better to Y-Harness the aileron's or Rudder?
  127. Airtronics RD6000 - may be 8 ch.?
  128. :) FMA interceptor 2000 rx?
  129. Reversing JR servo
  130. Airtronics Radios
  131. Multiplex Dealer(s) in Canada
  132. hitec servos and JR reciever-6.0 volts
  133. Who sells Futaba 9CA Transmitter only!!!
  134. GLITCH in my Airtronics Elev. Circuit
  135. crystal question
  136. Attn. 9C owners...how are you setting up your radio's/switches?
  137. Is this RX wide or narrowband?
  138. 9CAp slider control
  139. Has anyone compared Futaba & JR digitals?
  140. Revist 7-Servo Programming for 8UA
  141. Centering HiTec 85MG servos
  142. Which Receiver 945 or 955
  143. Hitec
  144. Very Odd Hitec Flash Problem
  145. Futaba's synthesized module for 9C?
  146. Mixing TX & RX Brands
  147. Still need old Futaba radio gear!
  148. MPI servos any good?
  149. Futaba S-134 large scale servos ????
  150. Need JR Servo Specs On These Servos
  151. recevier antenna
  152. new futaba 9c
  153. Help needed for Airtronic 95554 servos
  154. Charging leads for Ace charger?
  155. trim steps on the 9C
  156. Super8 5 Point mixing, how do you link the trim????
  157. please close - problem solved
  158. JR 10x screen problems
  159. Servos
  160. Problem with Hitec and flight sim
  161. Futaba digitals
  162. ATV below 80%
  163. Intermittant lockout on JR 631
  164. Battery Voltage
  165. Reversing Futaba Servo
  166. Expert SL500 Servo
  167. Where to get a potentiometer to replace one used for trim in JR 652
  168. Frequency Info Help Im About To Jump
  169. Adding 5th chanel to Futaba 4 ch. tx
  170. crow and eclipse
  171. voltage regulator
  172. Best price on JR Servos?
  173. Futaba Super 7 Tx Battery and Cycler Question
  174. Who Sells Aluminum Servo Arms for Hitec Servos?
  175. sub micro receiver
  176. Battery Voltage???
  177. I need to know
  178. Help - Can a Futaba 7UAP hand a V-tail
  179. Beginner, Futaba 6xaps? + other ?
  180. 8u screen for parts
  181. frequency interchanges - hi&lo
  182. volt gauge indication
  183. Hitec Flash 5X
  184. Digitals: Jr/Hitec programmer
  185. Discharging FUT6AS transmitter pack
  186. www.futabarc.com/faq Use it? helpful?
  187. Futaba T6FG/K *** SOLD ***
  188. Servo "Buzzing"
  189. changing frequency
  190. Aileron servos???
  191. Diff. Between R127df And R148df
  192. Digital Servos
  193. Which entry level computer radio?
  194. Help On Dean's Antenna
  195. Radio problems. Help please
  196. Hitec crystal
  197. Hitec jr rx question
  198. Unidentified servo
  199. Measuring commanded servo position, is this a no-no?
  200. Futaba 9CHP Color?
  201. ALPINA PCM RADIO (jr propo)
  202. 9ZAP WCII programming help
  203. Mix & match hitec and JR
  204. Servos
  205. Hitec 545 vs 605
  206. bad power indicator or battery?
  207. JR8103 mode2->mode1 conversion
  208. Radio Range
  209. 9z futaba vs the WC2
  210. Receiver convert
  211. Making futaba extensions
  212. High Torque Flight Pack w/Premium radios VS.Transmitter Only!!!
  213. 6 volts and servo torque
  214. servo's go nuts!!!!!! lot's of gitter.. Why?
  215. How, Dual rudder servos, Futaba 8S ?
  216. 9Z's,what are they worth.
  217. 9c buddy cord
  218. JR 8411SA servo, is the difference noticeable?
  219. Lithium batteries
  220. JR 421ex question
  221. were to buy Hitec servos
  222. 9CA Cosmetic flaw Awesome Radio!!!
  223. Throttle conversion from Air to Heli
  224. JR X-347 Manual
  225. Airtronics servos on Other brands Rec
  226. Where to buy Airtronics Tx only
  227. HS 5625MG - What do I have?
  228. JR Servos compatible with Futaba Receiver/Transmitter?
  229. Fm Receiver & Pcm Receiver Crystals
  230. 9Z / 9C / 8U how to clean?
  231. Adjustable Detent / Stop on Non-Centering Sticks or Knobs
  232. Glitch solution on long servo leads
  233. Radio Frequencies
  234. Hitec Digital H.S. 5625 mg servo
  235. Looking for servo suggestions
  236. Narrow or Wide Band?
  237. Need Advice
  238. Glitches when servos are under load?
  239. hitec flash system X
  240. Wideband Explanation?
  241. Reversed the battery
  242. Need opinion
  243. How? Flaps with a JR 8103 HELP!
  244. R610m Jr
  245. Futaba 8 UAP up in smoke
  246. dots on crystal
  247. Help: hi band and low band
  248. Jr servos in futaba rec.
  249. vision radio upgrade
