PDA
View Full Version : RC Radios, Transmitters, Receivers, Servos, gyros
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92
  1. Anybody using Hitec 625/645 servos?
  2. futaba 9C screen contrast adjustment
  3. receiver battery connection?
  4. servo ratings
  5. humming servos
  6. jitter
  7. TQ radio for traxxas nitro 4 tec
  8. Airtronics Servo Buzzing at idle
  9. Radio recommendations??
  10. Graupner MC24
  11. Delete
  12. receiver antenna
  13. Futaba Receivers
  14. JR 610M receivers any good?
  15. hitec servos
  16. servo arms((((help))))
  17. Best place to buy Airtronics?
  18. Discharging without cycler
  19. Rx battery size????
  20. Pulse width reader
  21. Lithium Ion for Tx
  22. Single Stick
  23. Mode1 vs. Mode2
  24. Futaba 6XAS - Airbrake
  25. Reversing servos
  26. Futaba trainer switch
  27. Futaba/Hitec/Aritronics
  28. Jr X-347 PCM C or Z
  29. Futaba Tx Module crystal changable?
  30. Need help with Airtronics Radio
  31. fitting Futuba servos to JR receiver
  32. Hitec HS-81 failure rates???
  33. Making Futuba servos fit JR receiver
  34. JR 652 Transmitter A weird Issue
  35. Old Hitec radio problem
  36. crystal exchange web site
  37. Are you guys happy with your Hitec Digital servos?
  38. Single Rate and Dual Conversion receiver and crystals???
  39. Jr Xf622
  40. JR Crystal Questions
  41. Futaba vs. JR vs. Hitec vs. Multiplex Which do you use?
  42. Delete
  43. FUTUBA 9ZCan someone telll me c
  44. Mini Servo's On Throttle?
  45. Futaba's new lineup...
  46. Info on old Futaba radio wanted....
  47. Please Help! I am so *&^%# mad!
  48. Futaba 8UAP glitch
  49. slowing servo speed for retracts
  50. Futaba 9C any thoughts
  51. System report - Good or Bad?
  52. Hitec, JR, Futaba Radio
  53. JR Rx question
  54. Problem with Hitec 5625
  55. Futaba 8uaf 8uafs difference
  56. What did I do wrong?!?!?
  57. JR 10 SX Fuse
  58. Futaba 8 super dual-rates question
  59. FMA receivers
  60. JR or Fut comp radio
  61. Transmitter Stand?
  62. gws receiver
  63. using digital servos
  64. Hitec 5125 servo. - When ??
  65. Hitec Spectra and the Futaba rx
  66. Futaba 8u/9z module question
  67. Eclipse-7 vs. Futaba-8S input please !!!
  68. slow down servo
  69. I have problem
  70. Futaba TX Modules
  71. JR 10x module?
  72. futaba FP-s24L IC SERVO
  73. 9zwc2 mixing question
  74. JR Digitals----GONE
  75. can futaba 7 pcm tx can be used with fm receiver??
  76. need manual or info on old Galaxy computer 8 pcm
  77. Old Futaba Servos
  78. Are HES servos any good?
  79. futaba 9CA Questions
  80. Hitec Servos
  81. Mp8000
  82. Futaba 9Z and CamPac
  83. Which servos to use???
  84. I miss my MicroPro
  85. rx battery size?
  86. Airtronics Z and old compatibility
  87. New to computer radios (expo?)
  88. 72mhz to 50 or 53mhz
  89. new radio
  90. How to use Expo
  91. Airtronics Radiant
  92. Airtronics Vs The Others
  93. Reversing Digital Servos
  94. which radio
  95. ever heard of 'Dads' type/brand of reciever?
  96. Can I change from Low to High Band
  97. closed
  98. Hobbico servo's any good?
  99. Glitching
  100. Hitec radio systems, inexpensive and good quality?
  101. Airtronics Infinity D/R switch broke HELP!!
  102. JR precision servo
  103. JR Max battery charging
  104. airtronics servo question
  105. "Y" Harness with amplifier
  106. Mixing rudder,front gear and retract
  107. Tower Dropping the 6XAS
  108. Wanted: Futaba PCM interface/editor
  109. Jr 10s?
  110. Using Hitec RX with Futaba and JR TX
  111. JR R600 Rx
  112. What's My 10SX Worth
  113. Syth. Module for JR
  114. A.M. Radios
  115. Futaba 7UA vs. 7UG???
  116. Fiber optic ext.
  117. Precision Gyros
  118. What radio to buy...and where
  119. retract servo suggestion needed
  120. 9ZAP Radio programming
  121. AM Cross question: How to hook up Realflight to 9C???
  122. Aileron Extensions, Maxx Products, anyone used them?
  123. Twin engine throtle control
  124. Futaba 8U PMIX Switch
  125. Cirrus 900 XLC
  126. futaba
  127. Hitec Prism 7 mixing help needed
  128. Lithium battery change
  129. Servo Oscillation
  130. Servo Checker for setting up your plane
  131. What servos for 1/4 scale?
  132. What Battery do i need ?
  133. Hitec Servo Reversing??
  134. Futaba S-48 servo
  135. Vtail mixing And nose wheel steering
  136. Hitec HS-77BB servos - advice needed
  137. New Futaba 9 ch radio question
  138. antenna replacement
  139. hitec 5645MG servos
  140. futaba
  141. Graupner/JR MC24
  142. Futaba repairs
  143. Removing Rx from it's case?
  144. Futaba Radio ???
  145. jr servos vibration
  146. Rx Batt Voltage
  147. Need Help
  148. Pcm crystal for pcm rx?
  149. Homemade glo = interference?
  150. TX trays
  151. transmitter mode conversion
  152. Quad Flaps and Airtronics Super 6000
  153. Futaba FP-7UAP PCM 1024
  154. Servo extension DIY
  155. changing xtals
  156. Flaperons Don't Work
  157. Who makes tower servos?
  158. 27mhz radios
  159. Futaba servos - JR Radio
  160. Futaba crystals
  161. Dual Con. Xtals
  162. Antenna question...
  163. Futaba 6XAS
  164. Multiplex Radio Systems
  165. Hitec HS-645 High Torque Servo
  166. jr 950s recievers like new 265.00
  167. New plane flaperon setup & humming servos, min voltage for safe flight
  168. OH BOY Big problem, please advise...
  169. New JR X-378 radio
  170. JR Radio Repair
  171. Coreless Servos
  172. 9CHP on Channel 50? Where oh where are they?
  173. Futaba 9304 or 9001?
  174. Hitec Metal Servo Arm?
  175. Changing servo connectors
  176. What does "Mode" mean when refering to RC radios?
  177. FF9 Question -
  178. Hitec servo metal arms in various length?
  179. 9CAP or 8103
  180. JR 378 radio
  181. Radio JR XF421EX for park fliers/gliders
  182. jr servos
  183. Your thoughts on Expert servos needed
  184. Futaba Experts Needed!
  185. co-pilot systems?
  186. Intermittent jitter
  187. Defective Expert Servo Reverser
  188. T6Xas Dual Elvators?
  189. JR783-H9 Ultra Stick, Can't Get Crow-Help
  190. JR Radio Range
  191. 9ZAP question
  192. Control surface servo/load
  193. Completing old Futaba items collection -- please help!!
  194. Multiplex servo programmer
  195. Why use Hitec 525 when 225 appear to have better stats
  196. Dual Receivers.......?
  197. 9C question/ split elevators?
  198. Whip Antennas ???
  199. throttle servo location on gas A/C
  200. S148 or S3004
  201. FMA Direct service?
  202. Futaba 8U Modul
  203. Anybody using FMA Direct Servos?
  204. difference between futaba 8uap VS 8uaps
  205. PPM vs. PCM vs. FM?
  206. Two jumper blocks on my PCM receiver?
  207. Futaba FG series battery pack
  208. Single Stick Radio
  209. JR S-PCM Versus Z-PCM Receivers
  210. How do you wire servos for H9 Ultra Stick to Hitec RCD3800 w/JR Radio?
  211. desperate for a single stick Futaba
  212. futaba gya350/351 at 6V
  213. Are Futaba and Hitec servo arms the same ?
  214. Radical RC Servos
  215. Futaba 9C, flap positions
  216. receiver position
  217. Futaba Servo's
  218. Hitec 3500 and 3800 receiver ?
  219. HS-5625MG Hitec Servos
  220. Futaba 127DF or Hitec Superslim?
  221. Radio interference
  222. GWS Servos
  223. Programming knob 6 on 8uafs
  224. Need a JR8103 tip, q on 3 position switch
  225. Radio For Beginner
  226. well....
  227. JR 642 Programing
  228. Any place sell just he transmitter?
  229. Trainer feature on radios...
  230. How to test servos
  231. 9C programming problems
  232. 9Z WCII D/R and expo question
  233. gyro recommendations?
  234. Hitec Eclipse
  235. HES-1188P Servos
  236. very very strange radio problem
  237. JR 421EX....What's it worth?
  238. Hitec Supreme ?
  239. crystal switching
  240. rudder problems
  241. JR 8411 special application servo
  242. Dangerous Radio Problem
  243. futaba 8uap
  244. Servo motor idea
  245. What is another option besides Futaba 148 servos?
  246. NiMH in Tx dry cell holder.
  247. Jr 10sx
  248. Jr Xp8103
  249. need web page for M-tronix
  250. JR X378 Radio NEW Looks Impressive!
