PDA
View Full Version : RC Fuels
Pages : [1] 2 3 4 5 6 7
  1. Simple diesel homebrew
  2. FAI Fuel question
  3. Air Brake Deicer????
  4. propolene oxide fuel additive
  5. S&W fuel ?
  6. HPI fuel substitute
  7. Fuel tank
  8. Making Nitro Fuel at Home?
  9. Where to Buy 4-Stroke Fuel in Orange County CA
  10. Sport Flying Glow Fuel Recommendations
  11. Oil/Fuel additives. Snake oil or maybe something useful?
  12. castor oil for homebrew fuel
  13. klotz oil for mixing
  14. Source for methanol
  15. Zinc Additive
  16. Protech Daytona 3D Heli Fuel..???
  17. How to mix 35 % & 15 % to = 25% ?
  18. fueling station
  19. 0% Nitro for glow four stroke on cdi
  20. leftover r/c car fuel
  21. Fuel mix calculator
  22. Diesel Home Brew Question
  23. Methanol vendor in NE Illinois, SE Wisconsin?
  24. A question for glow fuel mixers
  25. Leftover Nitro fuel
  26. Slimline Products (Fueling Systems)
  27. Changing from 10% nitro fuel to 5% in an OS46
  28. Where to buy Sig Fuel in Tx?
  29. Multiple Feul tanks on Switch
  30. Are you being short changed on glow fuel?
  31. Question on DB Products Six Shooter fuel pump
  32. oil content test
  33. Looking for a good 2-stroke oil for smaller Gasoline engine
  34. Can 15% Heli Niro fuel be used for Y.S. .91 enngine instead of 20/20
  35. Crystalline substance in fuel tank
  36. Sticky for fuel mixing supplies?
  37. A Question of Greed?
  38. Redline 2t methanol oil
  39. "Pump" cap on nitro fuel
  40. Currently Available Fuel
  41. Car fuel for a boat?
  42. Cox Super Power 1/2A Fuel 25% Nitro Quart
  43. Single or Multiple Fuel Pumps?
  44. Propylene Oxide
  45. Roto Flow tanks
  46. S&W is now SPL Fuel???
  47. converting 30% nitro
  48. Mixing Glow Fuel
  49. Can I lower Nitro % in Cool Power?
  50. Nitromethane find
  51. Oil content in Wildcat Helimix 20%
  52. Check my fuel math?
  53. ML-70, Klotz, Aerosave; which tolerates best high temperatures?
  54. Mixing
  55. where to buy fuel?
  56. White film on/in new fuel line tubing.
  57. Electric Fuel pump fix
  58. Byrons 10% Aero gen 2 Safe To Run?
  59. Wildcat 2&4 stroke 15% for break in
  60. MORGAN MV and other Morgan fuels
  61. Will mixing fuel brands damage glow plugs ?
  62. Windshield washerpump ?
  63. Replacing the Air in a Jug
  64. OK fuel guru's....here is a tuff one
  65. Mobil Jet Oil II mixing with Methanol
  66. no nitro fuel and will it dissovle paint?
  67. Nitro fuel shipping !
  68. Coconut oil for glow fuel??
  69. What brand of Meth. Fuel do you recommend
  70. Fuel quedtion please!!!!!!!!!
  71. Food coloring as fuel dye...
  72. Synthetic oils soluble in methanol besides klotz?
  73. Toledo Weak Signals Wildcat Fuels
  74. Torco Fuels' 100% nitro - anyone have problems?
  75. Bad glow fuel?
  76. Turbine/Castor Oil for K&B 1.00 DF engine
  77. Lube percent on package?
  78. coleman camp fuel (white gas) to help winter starting
  79. How to keep castor from seperating in cold?
  80. Difference between 2 stroke and 4 stroke fuel?
  81. TEST: How nitro content effects RPM
  82. Fox Manufacturing- Castor oil
  83. nitrorc.com
  84. Hyper Fuels
  85. Methanol prices
  86. FUEL CONTAINER JUG QUESYION PLEASE:
  87. Toying with the idea of blending my own fuel, need tips
  88. Nitro/oil content
  89. 2 stroke fuel in a 4 stroke engine
  90. Silicone fuel tubing turned "soft & gummy"
  91. Nitro Fuel, where to get it??
  92. HELP! - Looking for MSDS for Norvel fuel
  93. Newbbie question
  94. NITROMETHANE SUBSTITUTE.
  95. E85 might be E70 ???
  96. Fuel mixing advice
  97. Cool Power Fuel
  98. paint thinner OK in nitro container?
  99. methanol and alcohol
  100. Homebrew fuel dyes
  101. cool power synthetic oils, which grade to buy?
  102. Source for Nitromethane?
  103. canola oil
  104. what synthetic oils are out their?
  105. Optifuel or Rapicon?
  106. Difference between 33% and 30 % fuel
  107. Difference between 33% and 30 % fuel
  108. byron fuel help
  109. Cool Power Fuel
  110. What fuel for Thunder Tiger 40?
  111. Difference between 10% and 15 % fuel
  112. Fuel prices at Toledo Air show
  113. anyone use redline oil?
  114. where to buy cool power oil?
  115. CLEAN BURNING FUEL
  116. Wildcat to Omega, lost 500rpm and more
  117. Switched from Wildcat to Omega, lost 500rpm and more
  118. Help tuning engine with new fuel mixture
  119. Concensus on glow plugs/FAI Fuel?
  120. FUEL QUESTION PLEASE
  121. K&B Sportster .65 on FAI
  122. Ethanol Or Methanol? best for Mix? reasons why or why not?
  123. Can E85 give more power in a DLE-55?
  124. I live in a country where I can't get Methanol, any ideas for how to run a glow engine!
  125. Sig 20% Castor Fuel
  126. Poll-What are you paying for Methanol, Nitro and Castor?
  127. BYRON fuels question
  128. LEO .46 Glow Engine - home made fuel
  129. MAKE GALLONS OF 15 % GLO FUEL
  130. reducing nitro %
  131. MOVED: need help with diesel rc engine!! help asap!!
  132. E85 tank stopper?
  133. Lite Techniplate??
  134. fuel %'s
  135. Homebrew fuel
  136. Power Master Fuel prices??
  137. boat fuel
  138. What do you know about Big Bang fuel ?
  139. Castor blend ==>to==>Synthetic
  140. How to clean old fuel/oil out of a bottle?
  141. how do I remove Castor varnish stains????
  142. Magnum engine with synthetic oil.
  143. Fuel for a RL53
  144. Why castor oil?
  145. Need help finding a good tank (baffles, clunk)
  146. On a Saito 4-stroke, can you go from 30% nitro to 15% w/o damage?
  147. byron big tigre fuel
  148. Silkolene Castorene R40? Anyone tried it?
  149. Wildcat 20/20 vs Powermaster fuel in a Saito 100
  150. what is a good nitro fuel brand to use???????
  151. Glow Fuel
  152. Fuel shelf life?
  153. Ethanol intstead of methanol?
  154. Exhaust Gas Cooler, any point to it?
  155. Coolpower oil vs KL-200
  156. New nitro fuel shortage coming?
  157. Need fuel for Saito 100 now that Powermaster's gone
  158. nitro % help
  159. Adding ethanol to petrol 2 stroke mix
  160. dual tank setup
  161. Dave Brown product and support
  162. Sig castor oil separating.
  163. Spark ignition and fuels
  164. Mixing gasoline with methenol
  165. Nitro Fuel killed my grass
  166. Red Max fuel Info
  167. cars fuel
  168. 2380 or mobil jet II
  169. Ethanol castor oil
  170. where to buy methanol
  171. saito 150 fuel changing
  172. MEK at lowes
  173. Wildcat Premium or Premium Extra ?
  174. Toledo 2010
  175. Fuel problem?
  176. Kerosene and ether and a cox .049
  177. RECOMMENDED FUEL FOR A HYPER 21 PRO 8-PORT WITH BOOST
  178. Oil for my Raptor 30 V2
  179. Fuel for YS110S
  180. Eastern North Carolina Methanol Supplier
  181. Sig Synpower questions
  182. fuel compatability
  183. sliver swallow fuel
  184. 4 cyl fuel in a 2stroke
  185. Cool Power fuel and KL-200
  186. Fuel recepie , opinion needed.
  187. Is Powermaster still in business?
  188. Lowest amout of oil runnable?
  189. Cool Power 5 % glow fuel opinion
  190. 2 stroke oil for petrol engines?
  191. Cool Power Super T
  192. Omega or Cool Power for my Saito?
  193. Cooper Fuels alive anymore?
  194. How much nitro for a Four Stroke
  195. Nitro fuel storage.
  196. DO STRAIN ALL YOUR FUEL
  197. Omega fuel for a Saito.
  198. Can I store Gas Fuel?
  199. Fuel....good to read
  200. Incomplete fuel combustion?!!?
  201. How to color glow fuel
  202. fuel mixing container ?
  203. Castrol 2T for Glow Fuel
  204. PowerMaster fuel : no more in France ? in Europe ?
  205. help o'donnell 20% fuel turns yellow??
  206. Supertigre fuel
  207. For the chemical engineers out there.
  208. Duratrax red alert never again!!!!
  209. Where to buy glow fuel
  210. castor to synthetic
  211. 10% oil vs 12% oil - worth the price?
  212. Cheaper fuel vs. more expensive fuel?
  213. Mach-7 Fuel ?
  214. Which Fuel to use?
  215. Torco is making RC fuel now!
  216. Odonnel Race Fuel
  217. 4 Stroke vs 2 Stroke Fuel
  218. Need a fuel Answer
  219. where to get methanol/oil
  220. Fuel: YS FZ110S
  221. Rapicon fuel info?
  222. AFTER RUN OIL
  223. Klotz oil
  224. Catalytic reaction in ethanol/platinum is what percent of methanol/platinum?
  225. klotz nitro power additive
  226. Patriot Fuel
  227. Best 4Stroke Fuel
  228. blendzall ?
  229. were to get the best deal on castor
  230. Sig fuel mixed by volume
  231. Fuel still good
  232. Home Made Fuel %?
  233. Longest time to use fuel before it is old?
  234. Tower still carring fuel?
  235. Old Glow fuel
  236. 2% more castor
  237. Nitrotane oil content
  238. Traxxas Top Fuel oil percentage???????????
  239. TopFuel ? 90% Nitro Fuel ? Anybody uses that ?
  240. Cost of Glow Fuel this year
  241. Powermaster any good?
  242. Maxys Fuel
  243. Castor Oil Synthetic vs Natural
  244. Fuel Test Lab
  245. How much oil to convert"Car" fuel to "BOAT" fuel
  246. Powermaster Heli fuels ??
  247. Wildcat Toledo Show
  248. Mixing two different fuels together?
  249. Pennzoil GT Performance racing oil compatible with gasoline, methanol, nitro and diesel fuels....
  250. Alternative fuels for Nitro
