PDA
View Full Version : Foamies! - RC Electric Foam Aircraft
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13
  1. Avios Albatross HU-16 Flying Boat 1620mm (63.7") PNF
  2. B17
  3. f4u corsair 1700mm.
  4. Angry Bird Power Help Needed
  5. Avios Spitfire MkVb (fast/slow passes and scale aerobatics)
  6. Dollar Tree foam board, remove paper skin or not
  7. Durafly Centennial T-28 Maiden!
  8. Durafly Bonanza V-Tail 1940ís civilian passenger plane
  9. servos
  10. What are the essentials for Foam Construction?
  11. Is this glue Foam Safe
  12. HK J-3 Navy Piper
  13. RA Cores EXTRA - Carbon Fiber Mods
  14. Durafly Supermarine Seafire MkIIb 1100mm (43.3") PNF
  15. FMS Sky Trainer Flap Control Issue
  16. Foam Airplane Conversion
  17. Durafly Slow Poke 1200mm (47.2in) PNF
  18. H-King Bonsai II FPV EPP Wing
  19. F6F glue n go maiden
  20. F35 glue n go maiden
  21. skipper XL 225 km/h
  22. HK Durafly Spitfire Mk24 V2 1100mm
  23. Parkzone SE5a
  24. Share video of your electric Warbirds in actions.
  25. Fms 1400mm silver t-28 nose gear box replacement
  26. maiden of my giant four engine cargo 3.4 m wingspan
  27. Zagi
  28. whistle for rc plane
  29. prime jet 8
  30. Glassing the freewing p-51
  31. my eagle
  32. fun jet multiplex
  33. Scratchbuilt Canard Success
  34. slowly
  35. imperial star destroyer maiden
  36. FMS PC-21 Pilatus
  37. cargo twin depron
  38. YAKZILLA 9mm XPS 3D foamie maiden
  39. MFG list??
  40. FMS P-51D Mustang V8 .... 4250 - 540KVA motor
  41. big flat ultimate
  42. HK Tundra on floats!
  43. FT spitfire maiden flight
  44. aerosky 185 by nitro planes need cg and other info
  45. four engines giant foamy maiden flight
  46. replacement for hyperian sniper
  47. freewing stinger on 7 cells?
  48. Top R/C 750 mm F4U Corsair parts
  49. Torpedo (Model Aviation, January 2017)
  50. Need HELP PLEASE
  51. 1100mm Warbirds....Where are they?
  52. 2 virgin planes
  53. Quick Tech Sumo Flight , maximum fun !
  54. V-22 Osprey Foamie
  55. polaris XL
  56. polaris XXL
  57. HH's S;ortsman S+ Setup and C.G. fixes
  58. Taranis Radio Setup of Horizon's BNF Mk XIV 1.2 M Spitfire with ARA636A Rx
  59. angry bird try to shoot pig
  60. HobbyKing Hall Cherokee 1.7m EDF glider
  61. my eagle foam chase by buzzard
  62. chicken
  63. puffin depron
  64. pelican depron
  65. FMS P51 57 Inch Version 8
  66. Battery ESC Upgrade for Eflite 1.2M T-28
  67. Flyzone Switch CG question for low wing config
  68. Foam safe CA or Hot Glue?
  69. How to cut v groove?
  70. CorsairWS
  71. X-2 Autopilot with GPS RTH(Return to home) Test
  72. F22 pusher plans scaled up to 80 inch
  73. NEW Durafly Mk1a Spitfire
  74. Art-Tech Pilatus PC-6 Turbo Porter!
  75. Volantex Ranger - Build Log
  76. Another Nutball
  77. SuperFly 38" wide help
  78. different props
  79. 1300mah 3s...what to build?
  80. Rochobby Waco
  81. Replacement Props/Blades for Airfield/TopRC 800mm A1 Sky Raider!!
  82. HELP! Can't get plans off the foam.
  83. New Catagory
  84. New Plane
  85. 2 to 3 blade prop
  86. How do I glue plans to the foam?
  87. What're the differences in Depron and EPP foam?
  88. Packing or insulating foam OK?
  89. Hobbyzone Super Cub Brushless Motor Upgrade
  90. Masking and Painting Foamies?
  91. Best Adhesives for EPO Foam
  92. Multiplex Fun Cub
  93. Selecting Prop Size
  94. FMS 1400 mm j3 cub surface throw settings
  95. Durafly EFX Racer Review!
  96. Hobbyking BFG 1600
  97. 3D Foamy still alive?
  98. SCRATCH BUILT Vs Store bought foamies
  99. Scratch built foamies?
  100. FOAMIES in various shape and size
  101. Fun Fly with Parkjets; Free Design Plans
  102. Twisted Hobbies 32" foamies
  103. NitroPlanes - Shop at Your Own Risk
  104. covering
  105. E-flite carbon-z splendor-maiden flight attempt issues
  106. FLYZONE DR-! discontinued
  107. D.L. Engineering Design Plans
  108. EPP Planes
  109. carbon cub ss question?
  110. Foam board F-4 phantom
  111. I need some quick advice on a suitable foamie
  112. Paint, dye, color for foam
  113. RC Superhero build
  114. best motor selection for 270g 3d foamie
  115. Fms t-28
  116. Hobbyzone Super Cub - Maiden Flight Crash
  117. Parkzone Sensei Servo?
  118. Blitzwerks Wildcat???
  119. 1100mm EPO Warbirds
  120. Slab wing delta designs
  121. Easy Tiger foamies??
  122. PZ UM P40 vs T28 in upwind turn
  123. PZ micro P-40 in high wind
  124. Old Zagi 400X battery upgrade options?
  125. Nitroplanes mini pop wing
  126. APPRENTICE Rx
  127. PZ micro T28-safe glue
  128. FX-61 Phantom Wing
  129. I Need a New Instruction Manual Book for my Nitro Models DYNAM SR Trainer ARF
  130. A few glue questions
  131. Anyone have a HK 1875mm B-17? Need help with wiring
  132. PZ F4F Crash On Maiden....*** bad guy Propeller
  133. Foam hinge repair
  134. Getting a new FMS 1400mm Trojan
  135. Walmart glider conversion
  136. Air-Tech 2M P-51 Mustang
  137. No more chicom foamies for me
  138. Choosing the right radio
  139. Making a join on a foam wing that is removable
  140. Fox am
  141. Airfield P47, recommend a motor
  142. Flight Charactoristics
  143. Multiplex Twister CG
  144. FMS vs Tower Hobby
  145. Is There ANY better Foamy Glue?
  146. FFF Plans? Easy, Slow, a little on the big side.
  147. I was wrong about foamies
  148. Banana Hobby folding wing F4U Corsair NEW RELEASE
  149. Need help building plane/jet!
  150. EPO Foam Warbird: Glassing and Painting
  151. DH Beaver Review
  152. Apprentice 15e Loss of signal?
  153. super cub
  154. 2 Awesome Planes
  155. Super Cub LP Engine Cut off
  156. Delta Wing with Gyro ?
  157. Cutting matts
  158. Dynam P 47 retracts
  159. Wings
  160. Zero Comparable to ParkZone Warbirds?
  161. Inexspensive Carbon Tubes
  162. Titan Air Hog Stunt Glider
  163. Dynam electric motor only chatters
  164. CG Formosa 2
  165. Hinging control surfaces on Depron
  166. Strapping Foam Wing with Drywall Fiberglass Tape
  167. glider twin motor thrust
  168. Props for my foamies
  169. My Foamies
  170. Polycrylic seems to make my wing stronger
  171. Dynam T28 Lights
  172. Which receiver plug-in number goes to prop, elev,rudder,alerons?
  173. Top Flite Mini Contender
  174. 1250 mm foamy!
  175. How do you get paint to stick to foam
  176. Aerosky Duke B-60
  177. FMS B-25
  178. Cessna with two EDF's Skyartec N9528 Kiwi style
  179. GP VFO Programming for Spektrum DX-8
  180. FMS
  181. Phase 3 U2 - what servos to use?
  182. Large Foamie Airplanes - who makes them?
  183. Flyzone Switch mods
  184. Nakajima C6N1 Saiun Scratchbulit
  185. Epoxy on A Foamie ?
  186. Foamy Learjet plan
  187. what material to build up fuse at firewall
  188. Trying to Find: Monsoon RC & Little Thunder
  189. X - UAV B17
  190. What Kind of Foam to Carve
  191. CA Hinges Okay To Use On EPP?
  192. RC Foam Glider Converted to Brushless R/C
  193. Multiplex Easy Star II
  194. Old Yak 55 foamy ?
  195. AW FW10 Quadraplane, when three wings are nor enough
  196. horizontal stab warp
  197. Banana Hobbies Bipes??
  198. Chosing the right glue
  199. Does 3D Prop size matter? 130g Motor at 14x7 for 3D HobbyShop EPP Yak 48"
  200. 4d Hydro plane
  201. Airfield 1400 mm P-40
  202. nitroplanes Stuka 1400 mm
  203. Unique Models F4U-4 Corsair 1200mm Build Guide
  204. 3d Profile Plane decision
  205. Unique Models F4U-4 Corsair
  206. RClander new series metal electric retract
  207. Cox Sky Ranger RTF
  208. FMS T-28 1400mm Trojan
  209. Need some Help - I want to buy a good Foamie
  210. Apprentice 15e
  211. Multiplex Parkmaster power combo
  212. Dynam PBY Catalina
  213. Super Cub upgrade BL
  214. NEW HOBBY FOAM SUPPLIER MPF
  215. zagi type wing
  216. What is Best Motor/ESC/Batt setup for Ikarus F3A 3D Depron Foamy?
  217. My own Hobbyking Parket
  218. 84Hobby.com Outstanding Customer Service!
  219. zagui configuration engine
  220. engine for my zagui!
  221. Dornier Do28 Skyservant Scratchbuilt
  222. Junkers Ju288 Scratchbuilt
  223. Dynam Skybus AKA DC-3
  224. Zagi HP problem at full speed
  225. Zagi 60 Tazz
  226. GWS Cub with custom paint on 3s.
  227. Need plane for my electronics!
  228. Can someone suggest 3D foamie plans?
  229. Hinge preference
  230. Motor problems! [Spektrum]
  231. Thick or thin?
  232. Twinstar with 4 cells and brushed motors
  233. My 55mph funjet
  234. Too Windy To Fly Your Foamy? Maybe Not! Try this!!!
  235. FlyingStyrokit Spir Mk IXc manual
  236. Looking for the right plane....
  237. HobbyZone SuperCub turning problem
  238. Airfield 800mm F6F Hellcat
  239. "brandnew" Sirius eleven by Robin Trumpp
  240. Is 10A too much power?
  241. The Carnage!
  242. Warning: Flyzone Sensei wing bolts
  243. foam glue and options
  244. foam cutter power source
  245. WATTFEST 2011 Tampa Florida
  246. want to buy ready to fly used wing asap
  247. Not sure which plane is best for me
  248. Foam?
  249. easy way to get the paper off of foam
  250. Electrical Help or Opinon Needed
