PDA
View Full Version : PST Jets
  1. Looking for parts and advice for PST J1300R
  2. PST J600R EGT probe..... Need
  3. J600R Ramp Values at Sea Level
  4. PST B777 where are you guys?
  5. PST J600R shutting down? What could cause this?
  6. Proper way to start J600R with powermax
  7. PST J600R fuel Valve?? Needed
  8. Wanted Trigger Valve for Powermax Cans
  9. Which butan/propane are you using and where can i get some
  10. PST J600R turbine radio specs
  11. Fine Tuning Xicoy FADEC V10 and PST 600R
  12. J600R starts but will not run...please help!!
  13. Is Anybody Home at PST Jets Thailand??
  14. PST 600R Battery Question
  15. 1300 Starting Gas and quesiton
  16. Pst wings
  17. New PST 800 Starting problems
  18. "TOUCH of MAGENTA" -foamy, powered by PST600R
  19. pst 600r ecu problem
  20. SDU Checksum Error
  21. 1300 Data Terminal
  22. PST Support is alive and well
  23. PST600R Fails to begin start sequence
  24. High EGT during startup
  25. 600R Compressor Wheel
  26. repair
  27. xicoy au-605 FADEC default settings for pst 1300
  28. J1600R Over heat and shutdown !
  29. Hello. Revision jet??
  30. Hung Start PST 600r with only 6 hours run time since 25 hour checkup
  31. Reaction ARF Airworthiness Directive #4
  32. PST 600r Failed Start
  33. 600r starting
  34. PST 1300
  35. pst 600r wont excelerate when first started
  36. J600 -> J600R conversion
  37. Problem with PST600
  38. High temp shutdown PST1300R
  39. PST J1300 ECU,PLEASE HELP ME!!
  40. Thailand Customs
  41. Setting correct gas flow
  42. PST is moving to new facility 15-30 Jan 2010
  43. pst 1300 fadec upgrade w/new rpm sensor
  44. tems problem..
  45. J1300 Popping/crackling at top RPM
  46. deleted
  47. need pst1300 thermocouple
  48. ecu temp reads backwards
  49. ecu ??
  50. Shortening wires on turbine and ECU
  51. engine mounting
  52. Need Part
  53. Turn around time
  54. "Step Fail"
  55. Bad Gas SolenoidValve
  56. PST1300R: distance from tail cone to pipe
  57. Lubrication for PST600r
  58. PST Composite Reaction ARF, Model Airplane Directive No. 3
  59. Be on the Lookout for Lost/Stolen PST J600
  60. Idle Speed problem J600RHello Kraivuth,
  61. Parts for Panther retracts
  62. J1300R Oil requirements
  63. PST 600R Step Fail
  64. High Idle
  65. PST Composite Reaction ARF, Airplane Directive No. 2
  66. Fuel/Gas line inputs 1300R
  67. J600R shut-down on "set idle"
  68. Need Starter clutch for PST J600R
  69. PST 600 R Problem
  70. PHONE JACK ON TEMS BROKEN
  71. engine and pipe location
  72. Reaction ARF Directive - Flight control seams
  73. PST1300j Thrust Chart
  74. Connections on PST 600r question
  75. CG for the Panther
  76. Lengthening leads on the ECU?
  77. Starter motor for PST J600R
  78. PST New Year Holiday
  79. pst 1300 manual
  80. pst600 full speed setting
  81. ecu and fuel pump
  82. Kero Start?
  83. oil content
  84. New Turbine Repair/Service Prices
  85. Auto Gas Canister
  86. J600R Service?
  87. Ground Display Unit
  88. Mobile Jet 254
  89. I'm getting trouble with J1300
  90. 1300 flameout
  91. Data terminal not working
  92. 600R and Futaba 12Z
  93. PST 1300R cooling problem
  94. pst1600R
  95. replacement ecu for 600?
  96. PST North American Service Announcement
  97. Where to send for service?
  98. a123 battery for ecu
  99. 5 cell receiver pack reading "No RC" or Invaled RC on my GDT..
  100. 7.4 (2 cell) lipo for ECU?
  101. J600R start solved!
  102. FOD screen
  103. Clearence
  104. PST J 600 R runtime
  105. having problems?
  106. PST Service
  107. Out of email contact for a few days...
  108. 600R Flameout
  109. Hang up on start.
  110. Problem throttling up
  111. RPM
  112. J600R start problem
  113. 800
  114. PST1300 Thermocouple extension
  115. Faster throttle response? Throttle Curve?
  116. oil content
  117. Blue Grass Jet Jam
  118. pst600
  119. dealer with spare-parts in europe???
  120. Byton F-16 turbine mod
  121. PST J1300R questions
  122. Getting an* by EGT. Below allowable start.
  123. Fuel Pump line routing?
  124. about lost batterie
  125. PST contacts
  126. Funny sound during Start/Shutdown
  127. Long Term Storage
  128. Fuel Solenoid Option
  129. P600 shutdown mode
  130. PST contact?
  131. Idle
  132. EGT faulty
  133. pipe gap
  134. s/m f 18 pst 1300r
  135. FOD screen
  136. Thailand National Holidays-April 12-18
  137. Sputtering at idol
  138. North American PST Jets Tech support for March 7 - 15 / 06.
  139. Ramping Values
  140. J600R starter motor
  141. PST North America
  142. Kero start only?
  143. Few questions about PST engines
  144. Normal EGT for PSTJ600R?????
  145. Sticky fuel pump
  146. FTE PST J600R First run problems! Need some help!
  147. fuel valve, and servicing
  148. PST 600
  149. Need Help for Senior Design Project.
  150. 600R No Start
  151. J600R mounting straps
  152. first run
  153. propane solenoid
  154. onboard components
  155. flight time
  156. glow plug burn
  157. Pst 600r
  158. TEMS Fuse Holder
  159. PST 600 problem
  160. Marine TC-W3 Outboard Oil
  161. PST TEMS and new AMA rule
  162. Mounting Engine Inverted
  163. PST 600R cut out
  164. New V2.36 TEMS
  165. Starting gas
  166. Starting the PST 600R
  167. For those fearing true FULL auto start
  168. Contaminated Kerosene
  169. Latest V1.5.2 J600/R Manual
  170. Internal Gas Canister & Fire
  171. no answer from the guys in tailand?
  172. Website hacked!!
  173. Lithium Polymer batteries
  174. service & upgrade
  175. News Forum added to website
  176. Latest TEMS V2.34
  177. New Website and FAQ section
  178. PST J600 Accepted
  179. Deleted
  180. U.S. Certification and cold weather
  181. J600 Manual available on-line
  182. EGT leads extension
