View Full Version : Electric RC Helis
- Upgrade parts for Walkera #36
- ESKY WALL BATTERY CHARGER?
- New Blade CP Tail Motor Test Pilots
- High strength main shaft
- blades
- HELP PLEASE!!
- jr g460t sport gyro, will it be good for a shogun
- AFPD and TREX Model?
- Problem with yaw right after new 4-in-1
- honey bee cp2 help needed
- Honeybee tail motors
- help needed
- recommendations on new chopper/simulator
- Balde CX "touchy" after rebuild
- how to test blade / honeybee servo
- SWIFT CONTROLER SETTINGS ETC...HELP.
- Blade CP climbs in forward flight after Bell upgrade?
- Blade cp tail rotor housing
- Blade cx
- Shogun 400 newb, whats everyone think of these?
- Servos Blade CP
- Would the honeybee cp2 radio work with the MX400 Pro EP helicopter?
- Any one have a Kyosho EP Caliber
- Pinion installation
- 7.4v 1300 mAh Li-Po vs 8.4v 900 mAh NiMH...
- MX 400 Pro
- digital tail servo
- Blade CP/Venom 3D Head Block
- Could this be the reason I've been crashing so much !!!!
- Optic 6 Heli set-up
- Noob.....blade cp
- Help the noob choose
- What engine and battery
- Walkera Dragonfly #36, #39, or #60
- purchasing the BCP bell hiller in separate parts
- Blade CP, Almost No Collective
- Blade CX on 9303
- Blade CX rudder won't trim
- Shogun V2 Brushless & ESC advice
- RC-Expert.com any good?
- 3-cell lipos on CX
- best low dollar radio for 400mx....help?
- G3 Real Flight Sims
- Went separates, tail going crazy
- will FMS help...? anyone...
- Will battery run Brushless?
- BCX tail drift & maintaining altitude
- AFPD do any heli's fly like CX or CP.
- Reflex Simulator
- How to set up the DX6 for GY400?
- EFLH1240 shafts are in!!
- X400 Vs MX400
- Blade CP head assmbly question
- Buying Help
- Charging batteries
- Changing to electric
- Is this broken?
- Video: Twitchy Blade
- Is this a copy
- Discussion - Check out my noob video of my BCX.
- Need help with Piccolo
- HB CP 2
- 7CHP IDLE UP
- landing gear for blaade CX
- HB CP2 Seperates
- Honey Bee CP2 Pitch Control Arms - Please Help!
- HB2 GOING CRAZY!
- esky lama, dragonfly no5 ,,need parts
- Blade CX Tail Stablity...
- Honey Bee King or Honey Bee Cool
- Spindle replacement
- Blade CP Questions
- Trex 450 XL programming setup
- NewBee needs some help
- blade 4 in 1 help
- Which second heli
- Helihobby and blade cp frame
- BELL UPGRADE BREAKAGE
- Blinging my Twister 3d....
- New Blade CX -- RED LIGHT!
- control board fault?
- Blade CP Pitch Poll
- Easy Blade CP Head Assembly Balancing
- Trex or X400 payload capacity
- Micro Heli Gear Pitch?
- BCP 4-in-1/servo Question
- Honeybee CP2 8 tooth pinion question
- BCP Interference or broken 4-in-1?
- hyperion product
- Blade CP/Honey Bee CP2 TAIL MOTOR FIXES
- GP4300
- What's Next?
- Blade/CP2 belt driven tail rotor conversion!!!!!!
- Blade CP Help in Vancouver
- 7chp with blade cp
- MX400 Alum Head
- BCP Motors Not Running
- Twitchy BCP
- CX LiPo Battery Questions - Help Me Please
- MX400 Motor size
- BCP Super Landing Gear Kit Arriving Soon
- Blade CP, heading hold gyro
- Blade CP: Longevity of main motor?
- Wing Tote Micro Helicopter Tote
- Trex, JR radio problem
- Anyone tried one of these yet?
- Bell Hiller Seperates
- NIGHT FLYING T-REX'S THIS SAT IN ALABAMA
- Blade electronics problems
- Help on second Heli choice.
- Nose-in Hover Poll
- Scope Tech Type X RC Helicopter
- Lipo Connector
- HoneyBee Cp 2 Exploded
- Blade CP Crash...
- Just hovered BCP a little
- blade cp with spectrum radio
- honeybee cp2 transmitter pic request
- adjusting tail gyro gain
- awsome upgrade for any 400 size heli!!!!!!!
- HoneyBee CP2 Problems
- Does the MX400 have a problem with the plastic center hub?
- Blade on 9c problem
- Largest Heli
- I Got My Super Skids For My Blade Cp
- BCP Servo Question
- Blade CP problems, converting to separates
- silicone tubing
- Tail rotor probs
- neebie here, needs an opinion with this heli
- Twister 3d and gyro woes :(
- Blade Cp won't leave ground
- HoneyBee FP to CP conversion
- Blade CP w/Bell-Hiller Upgrade Video
- new to electric heli, need help with everything
- Help with custom heli
- spektrum radio in a Blade CP
- BLADE CP ACRO
- Making blade cp training gear and durability of the new bell hiller system
- esky or eflight ?
- Balled up my MX400 last night....
- Helimax MX450, when & how much?
- durability of cnc head or swash for blade / honeybee
- How to install aerobatic kit for Blade CP?
- Blade Forum
- What Next?
- Trex450XL power problem
- E-Power 11.1V 1300mAH 3S Li-Po Battery ?
- Century Hummingbird Scale Canopies
- dragon fly 3 small electric coaxil repair ideas?
- shogun belt conversion troubles
- trex vs shogun
- Hummingbird 3D Pro Short Video.
- quik g500t gyro question
- Blade CP/HB CP2 Alum frame
- Blade CX trouble...pls help diagnose
- Humingbird v3 battery question.
- 2 Helis, One Tx
- blade / HB CP 2 motor break in
- AeroHawk Main Motor Compatibility with Piccolo
- Direct Drive Tail for Aerohawk
- Blade CP with sloppy servo's
- MOVED: T REX SE SET UP / JR 6102
- MOVED: T-rex
- MOVED: T-Rex 450 SE or MX400 Pro
- Vertical Tail Fin BCP
- MX400 Wrench
- MOVED: Official T-rex 450 XL SE Thread
- Do I need special arms for the HS-56 in a T-Rex?
- Night Ranger II Problem
- MOVED: trex lives, need help setting idle up
- Ever setup the Align BCE-BL35G ESC?
- Well, I bounced of the gear...
- Eco 8 tail rotor assembly question
- Blade CX transmitter batteries
- Ball link for Blade CP aluminum swash
- Helimax MX450!!!
- Tail motor strikes again... Any advice on minimising damage ?
- Align 35A ESC Governor questions
- bcp want main shaft oneway bearing
- New Blade CP or Honey Bee CP2. Same Price.
- Which Transmitter for T-Rex XL CDE/CPPM?
- MX 400 Tailblade holder upgrade?
- Blade CP - Need advice on setup
- OK It's great now
- BCP Radds 2/3 Batt Whats going on
- cp shell
- Installing a Brushless on a HoneyBee CP2?
- MX400 pro and a Fuselage
- Use REVO mix and reduce proportional on 4 in 1
- 1st Battery of Radds
- Tether
- Make your BCP blades tougher!
- bladecp and hiller upgrade
- HB CP2 Question
- Broken? YES
- Heli milestone
- 7.4V 800MaH 2 cell battery
- main shaft
- couple of questions about my honey bee cp 2
- Shorted my lipo... now what?
- Gyro Setup Futaba 502
- Twister Bell 47 modfications
- tx's
- new brushless wont lift heli?
- pushing limits of my CC25?
- Blade CX HELP needed!
- losing tail authority on HB CP2
- INNER SHAFTS ARE IN !!!!
- Help Trimming HoneyBee CP2
- Programming info for MX400 Pro ESC?
- corona 120 battery and charger
- Internet waiting has helped me learn....
- Contrarotational Heli
- tail glitching problem
- heliguy.com
- Plan to buy a Hummingbird v3 100% RTF, Am I making a mistake?
- mx-400 capable of lifting 7oz?
- Trex servo ball
- T-Rex tail wag
- T-Rex450SE for Semi-Beginer
- Converting Dragonfly to my own electronics.
- Buy BladeCP in United Kingdom?
- Is this a good setup?
- DX6 for Blade CP.... HELP
- T rex can't lift off.
- t-rex tail on 401
- Simulator
- T-Rex at night + Video +
- what t-rex?????
- Eco 8 with Hitec optic 6
- + Video + Ion-X/NEU 1521 on 10s4p TP 5300's
- Two Choices for A Newbie A... or B...
- Help on setting tail on Trex
- Please please I need help with caliber M24
- Real Flight G3 Questions
- trouble with struts any suggestions?
- any way of telling if your mainshaft is bent without removing it?
- cheap brushless/esc combo do you recommend?
- Setup Question for TRex 450 XL and JR 6102
- Converting the CP to CX
- Sticky Collective???
- Cut-off voltage and other elec.
- HELP!!!!!
- FIRST HELI!!! HELP!!!
- Looking for quick reply
- 4050kv 430L in T-Rex SE?
- NEED HELP!!
- trex spins when shut off please help
- New to Helis-got a Blade CP---and read other posts--in-->
