View Full Version : Electric RC Helis
- Hornet CP & Rip Van Winkle
- How come??
- Tx and Rx combo for the Walkera #35
- 400dh on shogun clone
- X-400 vs T-rex 450Xl and Futaba 7CHP deals for a beginner
- rc-expert.com
- When did you start to fly inverted ?! :)
- Help - where does the esc connect?
- Honeybee 2-Switch Crystal? Change Freq?
- shogun tail output shaft -brass gear or nylon bevel gear
- Brushless getting HOT
- Trex in the wind
- R/C Heli Newbie
- DragonFly 22A & Li-Ion 1800mah batterypack
- Should I stay with my FP heli, or get a new CP heli?
- First time flyer
- iFixed pitch flybars position on dragonfly #4
- Best deal on a TREX package maybe with radio?
- shogun canopy
- Is my gyro dead?
- Newbie ... What would you say IF...
- another newbie !!!
- Hornet II, motor TOO big?
- governing ESC needed for 3D?
- Main motor for Dragonfly
- New E-flite "Blade" CP
- Wandering TREX Tail
- Adding xtra channels to esky
- buying radio, please help
- Blade Replacement Parts
- How much $$ for lipos
- New EF Blade (Excited)
- Esky Honey Bee 2 CP (HB2) and Hitec Eclipse 7 setup with separates
- t-rex
- trex in canada
- Questions on Avionics for a CCPM heli?
- main rotor wont turn off????
- Walkera 35 voltage question
- Position of horiz fin critical?
- Hummingbird sway
- TREX
- Jabo mains fast charger help!
- use a seperate gyro with esky 4in1 box
- I want to get a Heli
- newbie with big ideas
- Walkera 35 Z400
- which ECS, to Governer or not to governor
- WHERE TO MOUNT ELECTRONICS IN PICCOLO
- Newbie Trex Question
- high quality helis
- align 25 esc w/4 servos
- Single or dual conversion
- Servo for tail rudder
- esky airwolf
- Walkera #4 meets GWS Dragonfly :) Nice flying hybrid..
- shogun reflex model
- Walkera 35# new radio
- Feda Trainer parts?
- HoneyBee 2 Power surges?
- X.R.B. Hirobo Glitching
- Walkera 4's Reciever
- Any advice appreciated
- Temporary Gear fix?
- shogun brushless q??
- Gasser to Electro transition
- welded bearing
- what about Navi light (LED)
- Best second heli? First was an XRB
- New T-rex 450XL has arrived!!!
- forward...forward left....back..back right
- Other Micro Helis? Blade CP RTF?
- T-rex and Fut 9CHP
- Check it out!!! New heli??
- Helicopter Recommendations?
- Good RC Sims?
- HobbyJapan2000
- REUSE the walkera TX???? Dragonfly
- pe main blades for e-sky honeybee 2(cp)?
- Aint nothing like the feel of a new Heli... :) (Walkera 4 rebuild)
- TWISTER SET UP WITH MY TX
- HoneyBee swashplate
- Pitch/throttle curve Zoom/Shogun with Himax 2025-4200
- Hornet II, enough heli, not enough stuff!!
- NEW WALKERA 45 HAS ANYBODY BOUGHT THIS MODEL???
- Zoom 400 uncontrollable. What did I do wrong?
- has anyone tryed this sim
- CC25AMP ESC /THUNDERPOWER 2100MAH
- Graupner w/UNI-EXPERT Mechanics Electric
- Brushless motor problem, need advice??
- Hobbico Quick field charger question
- Will std. digital servos fit/work with eco 8
- XRB rear motor cooling mod
- walkera #35 battery ?
- Could this be the problem?
- Hummingbird CP
- Queation about mega motor temp.
- ARK X-400 Combo kit
- HoneyBee 2 LiPo -Collective adjustments???
- Esky HoneyBee CP2-Tail rotor problem
- t rex scale bodys
- DragonFly 4 Weight Reduction
- stabilizer bar replacement - Kyosho M24
- Stripped Dragonfly
- Co-pilot + HB2 TX
- ECO-8 finally where I want it
- Please help me:
- Kyosho M24 Alternate Replacement Tail Motor
- I need Hummingbird HElp!
- Dragonfly XRB sideways motion unresponsive, though servos are working?
- Wild Wheels Helicopter
- Anyone used a CSM HLG200 Heading Lock Gyro???
- looking for honey bee 2 sim download
- 3 wires speed controller
- training gear
- hb2 about to go................
- Trex tracking problems
- 25amp
- Trex 450XL CCPM ???
- anybody using walkera transmitter????
- spirit eolo pro
- fixed pitch with out tail motor
- TREX BLADE TRACKING PROBLEMS
- Walkera Dragonfly 4 CH Electronics
- New Idea! I'm Tired of Broken Skids!!!
- how to use pitch gauge
- need help for simulator!!
- where to get exploded veiw on esky
- fp to cp on hunnybee??
- Gyro fell out while flying... :(
- Will this 5ch receiver work in my Zoom?
- will an Align 400S 2800kv Brushless Motor. work with x400?
- dumb t-rex question
- Shogun.. any assembly tips?
- esky honey bee 2 setup help ?
- honeybee bat problem
- electric helicopters
- mini Dragonfly #4
- esky hb2 cp problems
- Is this speed controller ok for a brushed Zoom 400?
- 4 in 1 reciever
- Are there any FP helis larger than a Corona?
- servo selection
- Honey bee spins to the left
- Need help on selecting TREX setup
- Shogun/Himax question
- New Carbon Fibre ARK x400
- e XRB tethered lama
- What Li-PO's to use with Hummingbird?
- berg 6 channel receiver ? or another lightweight?
- oard piccoboard gyro
- Is this a good deal for a first time electric heli?
- Corona LMH convert nitro to electric??
- copilot and trex
- Beginner Helicopters
- servo upgrade for the JR g500t
- "All Aluminium" Helicopter review.
- New TRex clone ???
- Anyone know where i can get an 18t 3.2mm pinion gear for my axi?
- ccpm? whats the difference between a shogun,etc. and a dragonfly 22a,etc.?
- li-po in honey bee fp
- lama only
- direct vs geard
- ark x400 and ccpm?
- Eflite Blade CP
- Upgrading to eco 8 from hummingbird v3
- hb2 main rotor
- canopies
- what sign?
- cp flown fp
- little help with DragonFly 22D
- Special Sale 20% off for Grand opening at HeliRUs.com Store
- esky honey bee fp questions
- can't land off my helicopter
- T-rex...motor won't start.(Cuts off)
- setting up honeybee 2
- Replacement parts for Walkera #35
- Hirobo XRB Lama Wireless
- any success with Carbon fibre blades and pmp head?
- Blade
- My T rex Flys great!
- New to helis
- how do i set up a brushless motor?
- ESky HB2 CP and Hitec Radio Setup
- esky shearing pin
- shogun in wind, how stable?
- ECO 7 problem
- Honey bee 2 replacement parts warning
- Jabo II or Dragonfly 22D
- Anyone suggest a plastics lubricant?
- XRB HIROBO
- Esky honey bee or walkera Dragonfly
- t-rex pitch curves,where are you at??
- Crashing My new JABO
- Walkera Z400 spinning
- esky honney bee 2
- X400 or new Trex450XL
- Blade tracking is very weird...
- Li-Po: Mishandled or Malfunctioning
- fms power to tx
- whats the best rtf kit to buy??
- Honey Bee 3D Questions
- Dragonfly #35 VS. Esky Honeybee 2 (only vote if you have both)
- Dragonfly #35 (z400) owners....
- z400
- NEW X Rotation MINI 4ch RC Helicopter like XRB Lama~d5 Ebay review
- Li-Po battery swelling
- honeybee fp wont work
- Shogun 400 - More Bad News
- ARK-X400?
- will this TX work with a FP micro heli
- FUTABA GY240 GYRO ADVICE
- trex tail problem
- Warehouse electric suggestions please
- ECO 8 Weird Head Issue
- how to dispose of li-po's
- Electric heli. suggestion
- Eco piccolo, problems with lift??
- WALKERA TRUE "BRUSHLESS" 35Z 400!
- getting tail motors to last
- Megatech Housefly Question
- Walkera 4 Fixed Pitch Heli
- Is Trex OK as is?
- RotoFly Main motor bad, suggestions?
- Ultimate Heli Test Stand And A Great Stool Too
- Cam battery for helicopter
- Brushed electric motor oiling and maintenance?
- motor runs reverse?
- 7cap vs. 7chp
- Micro heli with belt drive tail upgrade?
- Hummingbird 3D Pro Gyro Mount
- cheep heli for a beginer.
- preflight questions
- aluminum cnc ball bearings???
- Any experience with a FUN Piccolo or Honey Bee Heli?
- JR 347 Heli Settings
- raising head speed on trex
- T-Rex and Map Antenna
- How to set Proper Tail Input Gear Mesh for Zap /Shogun /Walkera?
- The ultimate RTF Walkera #35???
- heli radios help plzzzzzzzz
- Helihobby------Good or Bad
- Help the new Guy
- XBR HELP TAIL
- Zoom/Shogun 400 new paint job with pictures
- NEW WALKERA 45 MODEL WHAT ABOUT THIS PRODUCT???
- Lipo Source
- plz plz help
- GWS ICS-50 and ICS-100 lithium battery compatible?
- Check this out!
