View Full Version : Electric RC Helis
- aerohawk and jabo
- Equipment mounting
- Equipment Mounting
- more aerohawk wabble BUT,
- aerohawk replacement motor
- crappppppppy mixer
- Standard HB/DF power connector no good?
- Hummingbird Maneuvers?
- Attaching HB tail to new frame
- Century HummingBirds
- mixing board alternatives and prices
- Swashplate question
- Aerohawk mixer/gyro board
- e-flight.co.uk.......what's happened?????
- Jabo (Feda Dragonfly) Question
- Ducted Fans (EDF)
- Tail rotor motor
- Hummingbird Hughes 500E Body
- Jabo Electric Heli HELP
- Aero-hawk
- Newbie : GWS PG03 Gyro Problems
- Eco 8 scale bell 222 body
- separate set up not working
- ECO-8 SCALE FUSELAGE
- High authority tail motor for AeroHawk?
- Megatech Helichopper, What do you think?
- Aerohawk mixer problem solved... Thanks Hobby-Lobby!
- Skylark Vs Aerohawk?
- Eco 8 Tail Rotor
- pro peak charger
- Flying the Quick EP10?
- Quick EP 10
- Lipo low volt indicator
- thinking of getting a JR voyager E
- Going separate..need help, please!
- My latest Mod and Layout for my Dragonfly
- What's the smallest space you've learnt in?
- Wich one do u think is the best!?
- My New Tail Section for Dragonfly.
- My Stupidity and Itchy Finger Kill my EDF50B
- FEDA/GWS Dragonfly and LiPo - Awesome
- JUST BOUGHT A JABO(upgraded dragon fly)
- Diagram for installing PCB board AeroHawk
- Switch on tx then plug in batt.....why???
- Sick of heli makers knowingly selling crap
- Gyro Adjustment?
- Dragon RC Helicopter: Same as the Aero Hawk?
- Is there a cure for the HB tail?
- Help! Mixer & Speed Controller Burned
- ECO Piccolo bodies 4 the dragonfly
- Rudder, Aile, Elev set up??
- FMS and AeroHawk
- OC Heli Club?
- Training gear........ Throw it away!!!
- throttle sub trim?
- Hormet blades on a HB?
- BTT Cupid might have better design than Dragonfly/Hummingbird
- Throttle clicks, yea or nea??
- Be sure to charge your transmitters!!!
- Help - New GY240 feels like worse than ESC Mixer
- Question on Capacitor
- Charging time
- hb pitch curve
- main rotor shaft diameter
- a leaf in the wind???
- Mode 1
- new Hummingbird cp comming soon
- PICCOLO REVERSE ROTATION! WHAT I DO WRONG??
- Arming ESC
- wanting to go seperates
- gain 4 the dragonfly i need help
- Dragonfly swash limited movement
- Hard to fly or just hard to set up?
- Help - Which selection is the best for brushless
- Cupid
- Are Parts Interchangable?
- Assembling a Piccolo Pro
- Sky Hawk Setup
- WTB brushless Corona
- Himax & Hummingbird - I'm THAT close: Opinions?
- AERO HAWK HELI SUCKS
- BRUSHLESS MOTERS 4 DRAGONFLY
- flybarless heli
- Drifting DragonFly
- DIY Dragonfly Shaft Collar
- HB +cp+help!
- 14.2 oz bird!
- *Aerohawk Owners Poll*
- What motor do you get from J Perkins for the piccolo pro??
- E-Flight UK?
- Your Electric Heli model & Components here.......
- HB Direct drive woes
- modified hb blades!
- Tricks and stunts to do in the air with aerohawk
- I just saw some rc helicopter videos and now I'm interested.
- Hummingbird boom
- Aerohawk electronic??
- Etec 1200mAh and Megatech charger?
- bout ready to trash my hb!!!!!
- DIY hummingbird landing gear
- Piccolo and Hummingbird
- Cupid
- home made hornet 2 blades $5 to make
- 280bb +replaceable springs +brushes+kokam 1500 7.4v
- Experimenting with tails
- aerohawk main shaft
- Looking to buy a used Piccolo Pro in the Texas Area
- need advice on a new piccolo
- BEC in micro heli's
- OK, I admit it. It ain't easy
- Looking to buy a used Picco Pro.
- What is your total flight time?
- Aerohawk vs the Fun Piccolo
- Jabo Heli main shaft balance
- Jabo Electric Heli balance
- Upgrade receiver & Tx, need advices
- gearless direct drive helicopter motor
- homemade flybar
- Cybird N-370 with 8 Teeth Pinion Motor.
- Similator for FEDA Dragonfly ?
- Better to learn on?
- Aerohawk head oscillation problem.
- MY LAST HUMMINGBIRD UPGRADES
- Which small elect. heli should I buy?
- GWS Dragonfly ESC Mixer Red/Green LED Indication
- So how long do brushless motors last?
- Two-bit Circuit Board Analysis
- main shaft length
- piccolo fun nose in flying
- HB Hovering Gripe
- Sites for a cheap price Aerohawk?
- Which LiPo??? Concensus
- I want to buy one dragan fly III or IV or p
- Please post your Helicopter Pictures
- Tail motor specs
- hummingbird brushless setup
- brass pinion reuse?
- Kontrinik ESC: How To Pls
- why does my piccolo always crash outside
- Aerohawk vs HB vs Fun Pic
- HB help!. Wont stop spinning.
- Transmitter lpt cable for FMS
- HB frozen solid.-PLEASE HELP
- Dragonfly not working. Help!
- What do heatsinks do?
- Desperately need help - MS Hornet!!!
- brushed motors
- No response from Servos PLEASE HELP!!!!!
- Aerohawk Tail problems
- eco 8
- 120 HB template
- Smartech Aerohawk
- New site for HB owners!!
- Tail wing kits
- Have gone with Seperates need advice
- Dragonfly / Hummingbird Swash Plate Mod
- hb board fire!
- WERE CAN I GET A FUSELAGE BODY FOR MY AERO HAWK??
- OK, these motors just don't last - now what
- Shock absorber for landing skid
- Will piccolo tail rotors fit an aerohawk?
- Where To Buy Aerohawk Parts
- Antenna routing/mounting
- Good report on Nimh, nicad, and li-ion/li-po's
- Just for laughs...
- Anyone seen the ECO-Lite
- HOME MADE LITHIUM PACK
- Control in Ground Effect (GE)
- 310 tuning motor for piccolo
- AEROHAWK HELP
- Ranger or UH-1 body wanted for HB
- Flying time on Piccolo and Lipos?Help plewase!
- Sky lark parts in nz
- Inexpensive Hi-Freq. Tailrotor ESC
- Have you made a custom tail boom skid?
- If you wanna save a couple bucks on an upgrade
- Nothing is wrong with the Aerohawk.
- pinion size for li/ion
- Wobbly HB!!
- Aerohawk pre-flight Setup! Please Help
- Training Conventions: CP vs. FP
- direct drive tail
- Is really better LiPos for piccolo?
- Wanting to get into RC Heli's
- is EVERY store out of main rotor heads for dragonfly/hummingbird
- Brushless Motor for Piccolo Pro
- Re-use parts from whisper
- brushless on an aerohawk?
- Aerohawk, Can't figure this thing out! Help!!!
- hb bird tail wont stop
- tips and tricks
- micro heli tail motors
- feda dragonfly+fms
- Dragonfly Sputtering
- My Robbe Eolo Site
- aero hawk
- Odd things happen when flying in the cold??
- Hummingbird Screws-=====
- Feda Dragonfly FS
- need 2mm carbon fiber rod
- FEDA vs GWS
- HB Rotor triming.
- Note for new hummingbird buyers!!!
- fun piccolo tail motor problem
- Interested in heli
- Two new addon to my Dragonfly today
- CNC Super CCPM Head
- How to convert Humminbird 370 to brushless
- Don't Hover when u are sober.
- AeroHawk Problem
- Question for fellow DF owners
- Castle Creations Phoenix - 45 Programming
- Hummingbird or Piccolo?
- Any suggestions in purchasing a Micro Heli
- HB long blades on V1?
- Just brought a piccolo
- Seeking Fixed Pitch Helicopter
- dragonfly-ducted fan
- Feda dragonfly board
- Zhen Hua Radio and FMS really works!!!
- Rotor Mast Tolerance?
- symmetrical blade ideas HELP PLEASE
- symmetrical blade ideas Need some help
- symmetrical blade Help please
- Aerohawk tail mixer anomaly
- Radio for a heli
- Cutting the rubberpipe to free the swashplate on aerohawk
- Aerohawk problem using lithium ions.
- AEROHAWK Lithium Poylmer question
- Help needed With Swashplate mod for Dragonfly
- Broken ball links! A fix to 'em all!
- My first DIY repair, what do ya think?
- Hummingbird Questions
- Getting too much tail, and not the good kind
- how to stop a drifting aerohawk
- my Aerohawk has come but i need help please
- AutoRotation worth it???
- Laser 6 Transmitter
- Are they keeping this a secret ?
- How do I set-up Seperate ESCs
- ebay "heavy left" & HB Parts
- HB battery holder
- humming bird problem
- Charging Aerohawks battery
- burn out 1st brushess 2nd?
- Li-poly Hummingbird upgrade
- will the pico bord fly the hb
- Jury-rig repair suggestions needed please
- Things not to hit w/ your heli
