View Full Version : Electric RC Helis
- Help I have a Helimax MX400
- Any codes from xheli?
- 1st Outdoor maiden!
- ef sabre transmitter compatability
- Bored of my CX2. What now???
- I'm ready to upgrade from my Falcon 40 - What to buy?
- How to charge batteries.....
- Exceed Eagle 50
- LiPo Battery Sources
- Should I get AR6100 or AR6200
- telebee gyro 30 bones
- helicopter work stand
- Need a Challenge?
- Battle of the 200's GAUI 200 vs T-REX 250
- Innovator MD530
- static discharge.
- Castle Creations Pheonix 35 Settings
- Training gear on Sabre shaking really bad!
- Anybody know the Exceed BlueRay 450 2.4 GHz 450PE?
- lipo battery size for EF Sabre
- T.T. Innovator MD530 just had 2nd flight wow !!
- Tailboom jerking, what to do!
- Digital or Analog???
- HDX 450 Maiden Flight
- Thunder Tiger Mini Titan E325
- Is a sagging tailboom normal?
- exi for $50 2 days only
- EXI 450 LE
- Chypher 3D
- battery questions for LMH corona
- exceed legend or blueray any good? Opinions?
- Belt CP Gyro problems !!~~
- replacing mainframe on EF Sabre
- Heads-Up on Spectrum DX6i Tx
- My experience with Caliber 120
- a great deal from heliproz
- Question about batteries
- Copterx 450 or any 450 helicopter - whole tail gear case swining at high throttle speed..
- The Mysterious TG-450 Review
- Recommendations on Outdoor Heli
- RC Heli Mechanism?
- Chaos RC is a SCAMMER
- Anyone using the GAUI flybarless head on MT
- esc on trex600e
- first post and first qustion.., twistr 3d storm.
- EXI 500
- A heli noob saying tks/noobs pls read this
- Ikarus heli
- What should I upgrade first on the belt cp
- Hurricane EP550 Pro Vs Outrage 550 CF Pro
- What electronics to use in my EXI 450?
- Tail servo end point adjustment????
- Raptor E550 build- gyro/servos?
- T-Rex 450 as first heli?
- What is ATV adjust ment on the gyro? how does it affect?
- Telebee RCE-500X position - where to face?
- motor and esc getting hot
- what is a good brushless motor for helipro?
- which blade to go with trex 450
- servo prob
- Century Swift 3D 6-Channel 2.4GHz RTF
- falcon 40 recever glitch solved !!!!
- again.....dx6i binding probs
- EOS0606I AC/DC charger question
- CopterX electronics - any impressions?
- Picco Z Lipo
- Motor-ESC-Battery setup
- DX6I GYRO QUESTION
- Orange Landing Pads
- next step up from the srb quark
- Servo Twitching
- Heli Noob here! Please help
- DX6i users....binding prob....
- POWERTECH ESC MANUALHELP
- 2008 Black Hawk 450
- Here is the ultimate heli test
- flasher 450 -anyone bought it?
- Looking for a lipo charger for belt cp
- Need to now axe or blade
- Copterx 450SE Up and running again
- Mini Titan e325 crazy Shaking problem
- ESC 35A good one, brand to buy
- Trex 450 painting
- which one would you choose over? DX7 or Futaba 7c
- Copterx 450SE First loop attempt!
- Real Flight G4 question
- Anyone has this Futaba 7C 2.4GHz Helicopter Radio System
- Axe 400 vs. Blade 400
- Flasher 450 PE 3D?
- exi 450 pro review
- tt innovator
- Hs-65 installation, Im confused?
- Copterx 450SE 3d mode
- HELP HELP please!! normal throttle curve, normal pitch curve and pitch gauge setup please HELP!
- battery C rating and esc how does it work???
- Copterx 450SE Stripped Main Gear
- Ok - help with servo arm position respectively to the throttle stick
- thought I knew what I wanted but now im confused again?
- DX6I HELP
- car battery charger
- MSH Protos just finished!!
- A 4 Channel Micro Helicopter Video Scene
- DX6I SET UP HELP HELP
- Esky Honey Bee FP 4 in 1 blinking led
- New Mini Titan!
- 4 Channel Indoor Stunts with a PicooZ
- WHAT IS A GOOD 450 SIZE HELI
- Which other better, more durable brand of micro servo can I use rather than towerpro sg90 9g?
- My Esky Dauphin 4CH Heli goes out of control violently! VIDEO
- axe cx micro, is it worth buying?
- Flybar for Copterx Black Angel
- I just purchased a black hawk 450se.. do you know....
- x
- Helicopter for AXI 2820/10
- Venom Mantis
- Caliber 120 The Facts
- what the differences of standard servos and digital servos?
- Please help for My 450 rc heli keeps rotating problem
- Stable PicooZ by fitting a 2.4Ghz 4-in-1 and tail gyro
- copterX CX180F mini review
- Why Is HeliPro Hard2Find?
- Airtronics 8000RD FHSS - Good for E-Helis?
- NEW TO ELECTRIC HELI
- Pitch gauge, blade setup but ...
- Stupid question: Castle Phoenix w/ BEC...Link through BEC or will the BEC get fried?
- Please help me out!
- Walkera Creata, Exceed BlueRay PE or Genesis 450PE which is better?
- main blade how to identify which side is up or down?
- which batteries can I use for this spec?
- is Sonix ESC same as Hobbywing ESC?
- Damn, Heli is hard.....
- i know i know... another NEWBIE QUESTION!!
- Throttle control Q.
- KDE Direct Aluminum Upgrades - New for 2008
- Blade 400, Blackhawk, or Falcon??
- Blade weight balance?
- Copter X 500 build
- Charger troubles
- Which Copterx?
- Xtreme Production Heli Parts
- Castle Phoenix 45...does it need a heatsink?
- Castle Phoenix 45 vs Castle Phoenix 45 HV
- Falcon Art tech 3D can't lift up...at max throttle I tried..
- FMA Copilot instead Helicommand?
- Mini Titan E325 navigation lights
- Guanli ep-200 heli a GAUI ko? but RTF with CCPM?
- Heli Shootout - Comparing 5 (450) Sized Electrics.
- Ka-Planes sale
- Trex 500 or Gaui 550
- Too pretty to fly...
- easycopter xs
- Looking for a good hobby shop
- Banana hobby
- Which Helicopter to Get?
- Broke teeth on main gear
- Beginner needs help picking mCX or CX2
- Iraq Fund Raffle
- main shaft replacement
- Just got an aewsome deal at Tower
- which heli/which flght sim
- Need stable indoor heli
- Futaba 6EX or Spektrum DX6i
- What do I upgrade to?
- First heli-help?
- Getting Back Into Helis
- Help Please!
- ground the boom to the frame
- Gaui EP200 or T-rex 250?
- Multi axis gyro?
- Thunder tiger mini titan
- GY401 with JR DS3400G on 450 class
- Ikarus cnc parts
- Buying battery from Ebay ok?
- Need help regarding the Esky 2.4G 4CH Dauphin
- new heli.
- Rave, Beam or Align V2 tail assembly which one is best?
- Indoor Electric Fly-In Denver Nov. 28
- Need to find a stable Heli
- 2nd Heli Options?
- Rc systems procopter 3d
- looking for a case
- Gaui Hurricane 550 Swash Servo Questions...
- xheli new 500 size heli
- Scale Cobra Body - for E325 Mini Titan
- Electric Scale Helis - Any Out There ?
- Know anything re: Phoenix 999 ?
- VENOM BEACON RTF Heli Video
- anyone fly a Skyartec wasp v3?
- Raptor e550 motor options
- increase battery time?
- e sky recever in a falcon 40?
- looking for 3mm pinion
- Piccolo V2 brushless upgrade
- Help a guy out.. First electric..9Z CCPM?
- Venom Beacon RTF
- Aluminum carrying cases for 400 and 450 helis
- new to helis
- mini titan metal head
- tips for better controller cooling
- heli for dummy me
- dx7 in a hd500 art-tech
- Futaba 6EXHP
- transmitter for g4
- changing bearings?
- good inexpensive 'micro' heli
- BIG Dragonfly flying in the house
- Best RTF 3d Heli?
- Headspeed??
- EXI 450 Spindle Shaft from xheli or better
- Futaba 3154 on 6 volts???
- Dragonus NVII and Elite
- EXI 450 kit. What other parts needed?
- Ninja 250 movie In Test
- A Good (FP) Fixed Pitch Heli?
- Keeping track of your charged batteries
- What's your sim, and looking for a cool heli.
- Trex 600 tail spin problem
- Art-Tech Typhoon Helicopter Just bought one anyone else have one?
- Need a E-Heli suggestion for my A123cells
- motor and esc. falcon 400 3d
- scale build, any ideas?
- Just getting Into Helis
- How Much Do Colors Matter??
- After the Blade 400?
- how to set up tail servo?
- Help to pick out heli
- Need Help Setting up CC HV85 on Trex 600 & X9303
- Best Inexpensive 325mm blades?
- What heli is this
- Just a thought
- Too many choices... HELP!!!!
- do you lose the flybar with three bladed heads?
- B432 Heli, interesting
- first person view heli
- Newbie help with Mini Titan
- Swift RTF or Ikarus Eco 7?
- HeliMax AXE CPv3
- Helo me choose a 450 Heli
- Best Bang for about 700 bucks
- Dynam Vortex / Dynam Orbiter
- What type of receiver do you use?
- Is this a good deal?
- EXI-450 discussions/mods/scale projects
- GY401 or Logictech 2100t??
- EXI 450 Is it a nice kit for the money?
- Dragonus Pictures
- Good beginner Build kit??
- multiplex cockpit mm for t rex 450
- Beginner Heli - I'm thinking about the Blade 400 and have a few q's...
- SJM 400/450 Anybody??
