PDA
View Full Version : Tachometer Readings
Pages : 1 [2] 3 4
  1. Tower 75 rpm figures?
  2. ST G45 and Magnum 46XLS
  3. husky 4.4
  4. My new tach
  5. cheapest tach that works
  6. TNC tachs
  7. G38,,, "prop size has been edited""
  8. O.S 1.60 Twin Owners. Post your tach readings
  9. mvvs 49 with tuned muffler
  10. Airwild Hobbies Wild Gage tach /voltmeter
  11. Fox .15 slant plug
  12. Enya .61CX
  13. Super Tigre 51
  14. gms .25 9x6 Apc
  15. Thunder Tiger 120 Pro RPM numbers
  16. How to tach
  17. Saito Valve Float
  18. A Good Prop ?
  19. OS 1.08 davis diesel conversion 18x8
  20. APC 8x10 prop question
  21. 25FX
  22. OS FS-200
  23. OS 25 FX prop
  24. Need a prop for OS 25FX
  25. Measuring Actual Thrust
  26. Saito 56
  27. Royal Electronics Analog "ProTach"
  28. Webra 15cc P5/Speed-P5/ Performance
  29. BGX Performance
  30. Zeroing a tachometer
  31. Saito 65
  32. Magnum .91XLS
  33. MVVS/EVO 26
  34. ASP 28A readings
  35. Fromeco TNC Tachometer question
  36. Os 70 Surpass II?
  37. OS 65 LA
  38. Moki 61 LS w/pipe
  39. RPM of Heli OS.91SZ-H vs. Aero.91FX
  40. Tacho Reading methods
  41. Supertigre GS40?
  42. Thunder Tiger GP 25
  43. Saito .62a
  44. Magnum 61 fs
  45. Enya 120R Tach #'s
  46. Question - Mini Digital Tachometer
  47. OS 55ax
  48. Super Tiger 51
  49. Tachometers
  50. calibrating the Ace Tachmaster II
  51. APC VS Master Airscrew Props
  52. ASP 52
  53. Tach on TH motors
  54. ST G3250 readings?
  55. GMS 1.2
  56. RMX 40 with Jett Stream Muffler
  57. O.S. .46FX with Zinger 12x5
  58. MVVS .12 Tach?
  59. OS20 Four Stroke info for Texaco
  60. OS 52 Surpass II Tach Readings
  61. 4 blades prop
  62. RPM for DA 50 and NX 22x8
  63. Magazine Engine Reviews
  64. Saito FA-40a
  65. New Irvine 53 from OS
  66. GMS .47
  67. Magnum XL-180 RFS 4-Stroke, Post your tach readings
  68. Brillelli 40GT & APC 20x8 prop
  69. Gemini info needed.
  70. SK Engines
  71. MVVS 35cc gasser
  72. 3W-50I
  73. Enya 53 on 5% nitro 22% oil
  74. BCMA SPE40
  75. Idle RPM .45 engine
  76. DA-100
  77. Saito FA-82a
  78. Saito 100's
  79. TT 54 FS
  80. Quadra 35 on tuned pipe.
  81. OS32F, any other 32's?
  82. Jett .76L
  83. Brison 3.2
  84. OS 46 AX readings?
  85. os 60 FSR
  86. Please post Saito 125 rpms..
  87. 3 blade on Tower .75
  88. G-62 with tuned pipe.
  89. tach choices
  90. Readings for a ST 51 engine?
  91. K&B .40 R/C 4011
  92. Zenoah G-23 conversion 8600 rpm!
  93. Irvine 72 tach readings
  94. TT Pro 40, APC 9X7, 9X8, 9X6
  95. Homelite 25cc
  96. Chart (Thrust vs. Engines)!
  97. My .15 shootout AP OS LA and CV-A
  98. OS 70 Surpass II
  99. Magnum 15
  100. Thunder Tiger GP 25
  101. OS 46 LA
  102. PAW 1.49cc diesel R/C
  103. Tach range: ST 90 ringed
  104. Saito 325 Radial RPM
  105. MOVED: Super Tigre 90 Prop: which one?
  106. Super Tigre .51
  107. Evolution 61 NT
  108. Saito 120 static rpm??
  109. O.S 1.20AX Owners. Post your tach readings
  110. mvvs 26 gas numbers?
  111. have you tached your mvvs 49???
  112. Laser 150 four stroke glow results
  113. Laser 240V Twin glow results
  114. FS-48 Tach Numbers and Idle Question
  115. Cermack One Touch? Any comments?
  116. RPM reading for ZDZ 160 B2-Rv?
  117. Tach Readings for OS 61 SF ABC / 61 FX
  118. MVVS / Evolution 58 tach Readings please.
  119. Post OS 91 FX tach readings.
  120. TT GP15
  121. stock magnum xls 52 rpm?
  122. Webra 55 with tuned muffler
  123. 3W 150 w/3w 32/10
  124. SH15
  125. New ST 2300, impressed:)
  126. Satio 125
  127. engine ground rpm vs. Airborne rpm
  128. Best 3 Blade Prop for an OS 91
  129. OS 120AX readings? Anyone?
  130. YS 60 and tuned pipe tac readings
  131. Homelite 55cc Conversion, not bad
  132. ST G.61
  133. MDS .48
  134. YS 45SE Well Used
  135. Max. RPM from OS FS-120 III?- Please Help!
  136. Will a Hobby R/C tach do the real deal?
  137. Saito 220 or YS 160 DZ?
  138. Evolution 45 Power System
  139. OS 40 LA
  140. SAITO 100, ANY TACH READING WITH 30%HELI AND 15X6MA?
  141. Magnum 70, 80 and 91 RFS trhust?
  142. OS FS70S
  143. Enya R155
  144. Spinner size vs rpm
  145. Jett .60L
  146. AP .15 Yellow Jacket
  147. Norvel AME .15
  148. O.S. FS70surpass II
  149. The Best Tachometer is Back TNC
  150. How would you rate 6300 rpm w/bambula 22-8 on 3.2 gasser?
  151. Irvine 72 RPM
  152. MVVS 1.60 Glow rpm readings?
  153. What peop for a Sachs 3.4 engine?
  154. GMS32 with pipe
  155. Tartan twin tach readings
  156. Saito 100 High RPM's w/ 15x6W?
  157. Saito 120 & 150 rpm
  158. Circa 1982 O.S. VF .46
  159. jett .91
  160. OS 1.60FX Tach Readings?
  161. Brison 2.4 Numbers
  162. saito 300 twin
  163. Saito 220
  164. AP09
  165. BME 50
  166. YS 140 DZ RPM data
  167. Glow 33 cc conversion
  168. SAITO 220 Tach. readings
  169. Taurus TS 42
  170. .40 LA props
  171. G 38
  172. homelite 25 cc
  173. MVVS 58
  174. Webra 91 P5
  175. what props on a saito 100??
  176. 3W 106 w/KS 1060s
  177. Tach readings position "anyone"
  178. OS FS120 Surpass3 w/pump rpm
  179. ZDZ 80 RV Single
  180. ZDZ 80 B2 RV Twin
  181. Name your tachometer
  182. os 46 ax
  183. Master Airscrew G series
  184. Engine Dyno?
  185. Enya VT 240
  186. YS 63S
  187. OS 46 FX
  188. Saito 72 rpm
  189. O.S. FS .30 S
  190. Webra Speed 35
  191. Need a Tach
  192. ASP vs OS 1.20 tachometer readings
  193. SK .80
  194. Magnum .91FS!
  195. TT120 SE
  196. Desert Aircraft 100 best muffler
  197. YS 120 NC RPM
  198. Ys 45 2-stroke
  199. ST 3250
  200. Magnum .91 4s
  201. YW-24
  202. YS DZ160
  203. Tach Question .....
  204. My ST GS40 reading
  205. ST G51 w/ 11X6 or 11X7 readings/readings in general
  206. Saito 180 performance
  207. saito .72 performance
  208. thrust measured for various props
  209. ST3250 Tach Readings
  210. fuji 32b rpm.s
  211. Saito 150 Tach Readings
  212. YS 1.10FZ Tach readings
  213. G-62 TACH READINGS?
  214. 50cc, 3-blades
  215. MOVED: os bgx prop
  216. Norvel Big Mig .15 Tach Readings Anyone?
  217. AP .15 Tach Readings
  218. What is your 60 2c and 90 4c prop/tacho like?
  219. Saito 170 3 cylinder radial
  220. Cyclon PC1 (original) .15
  221. Profi Kozjol .15
  222. BGX 3500 TACH READINGS
  223. K&B Screamin'-48
  224. Saito 30 Tach Readings
  225. 3W-75i
  226. 3W-150B2TS rpm
  227. DA 50R rpm
  228. Zenoah G26 with APC 16X8
  229. Enya 50CX
  230. OS 32F - what should be the tach reading?
  231. Anyone with ASP80 FS tach reading?
  232. Magnum 46 XLS
  233. Saito 180 tachometer readings?
  234. Please post OS 120FS III rpms..
  235. Saito 1.00 RPM
  236. Hobbico reading on my Saito 72
  237. Hobbico tack – gain adjustment?
  238. Super Tigre G90
  239. MVVS 26 cc (1.60) Glow Engine, standard carburettor
  240. Magnum 52 XLS
  241. Ryobi RPM
  242. Magnum XLS .46
  243. O.S. 160FT Gemini
  244. ZDZ 40 RV-L
  245. Brison 2.4 tach numbers
  246. ST 4500 Tach readings
  247. ZDZ50NG RPM data
  248. ROTO 35 Gasser Tack Readings
  249. Rossi 45 tach reading
  250. .52 - .82 4-Stroke Readings
