PDA
View Full Version : Tachometer Readings
Pages : 1 2 3 [4]
  1. What's The Gain With Break In??
  2. 3W 106 numbers
  3. How to use a Tachometer
  4. Anyone Have A Extra Tach They Could Part With?
  5. what tach are you using?
  6. Irvine 39
  7. Base line tach reading question??
  8. Magnum 52 xls
  9. APC prop change...
  10. Kioritz 16cc prop question...
  11. Idle RPM
  12. Magnum 46 Xls & Tower Muffler
  13. Tower Tach
  14. Enya 50CX with 11X8
  15. FPE 2.4 standard ignition
  16. Magnum 61 XLS RFS vs. Saito 56? Pls. post readings...
  17. 10x6 or 11x5
  18. Os 30 Fs
  19. Need A Good Reliable Tach
  20. Rcs 180
  21. Watch out, The Chinese are coming
  22. Saito 72 APC 14x4W ?
  23. 16,000 with a 10X8 on a Jett 60. Anyone done better? (revised 5/15)
  24. OS 50sx w/apc 11x6
  25. What's the most rpm you have turned a 10X8?
  26. Tachometer Readings in General
  27. Speed Props for a .47???
  28. Da-50
  29. MOKI 1.35 Tach readings please
  30. Stihl 108 (34 cc) conversion
  31. Want opinions please....
  32. OS 1.08 Breakin
  33. Norvel bushing 25 peak rpm ?
  34. Ryobi 26cc four stroke
  35. Saito 56
  36. Tachometer Supplier?
  37. Tach Readings for YS 1.10?
  38. YS 1.40 Sport RPM?
  39. YS 45 w/ tuned pipe
  40. Fugie BT-64 Test run
  41. St G90
  42. 46FX with plasma liner
  43. Irvine 53, Macs Muffler
  44. 33,200 RPM Idle
  45. Os 65la!!!!!
  46. Preliminary TT Pro .61 Readings
  47. Please post your OS 40 Surpass readings (and FA-40A Saito to compare)
  48. Do you really need a tach for breaking in a 4-stroke
  49. Asp 120 Fs
  50. Post your bme 50 readings please
  51. Saito 65 Tach readings
  52. MVVS .61 tach reading with bolly 11.5x7
  53. Fuji Bt 50
  54. G-62 Readings
  55. Saito 65 / OS 52
  56. Mvvs .49
  57. Magnum 52 RFS tach reading
  58. Saito 72
  59. Zdz 50
  60. Magnum XLS-40A .40 RC BB
  61. Tiger Shark .52 BB
  62. MDS .48FS Pro BB
  63. Magnum XLS .46BB
  64. OS 120 Surpass III Pump
  65. saito 56
  66. 2-stroke .75 engines??
  67. Oldie but goodie Q40
  68. prop choices
  69. YS 91 AC Tach Readings
  70. ASP / Magnum / SC 91 Four Stroke
  71. Os 15fp
  72. satio 180 rpm's?
  73. DA 100 Thrust in lbs?
  74. Da50r
  75. Moki 1.80 tachometer readings
  76. ST GS40 Tach Reading
  77. Os Fs 120
  78. Os 52 Surpass
  79. Bme 50
  80. Tach and thrust readings for the Saito FA-91
  81. Engine tach readings
  82. Super Tigre 29
  83. OS fx91
  84. Magnum 30 vs. 26 surpass readings posted
  85. YS110 numbers
  86. Need Zenoah G23 numbers
  87. Pro Size Please for SC 52 4-stroke
  88. 3W 100 readings....
  89. Propeller Thrust Calculator
  90. 3w 70
  91. Walker-Sachs 4.2
  92. Tach readings Saito & Enya .80?
  93. NEW small Saito FA-40A in 30 case; anyone have one?
  94. 3w-106 27-10 Msc
  95. New YS 63 numbers.
  96. SC52 Tacho Reading
  97. A discussion about prop size and RPM using a ST3000
  98. What RPM to expect
  99. Comparison of new 4C 30's to 26 Surpass?
  100. Anyone got readings OS Fx 91?
  101. TT .15 GP reading?
  102. OS 46 FX, 11x5 MAS, both stock and Tower mufflers
  103. older OS 40 settings
  104. Is it just me or are the Big Cats cold blooded?
  105. Please post your tach readings for OS 120 Surpass III
  106. zdz 40b
  107. TNC Tach is Back
  108. 3W 75 rpms
  109. New Saito 100 / First 4 Stroke
  110. APC 17-6 Thrust?
  111. how many RPM's
  112. McCulloch 28cc Power output specs
  113. Tach Readings for 46fx with 11x6
  114. RCV 120 RPM readings.
  115. Moki Adjustable Pitch Prop
  116. Ivine 46 old style with pipe
  117. gasket
  118. Ryobi
  119. Os 1.40rx
  120. O S FP.60 vs. TT Pro .61
  121. O.S. 91 DF.. what kind of tach???
  122. Magnum XL 25A ABC, Please compare
  123. RPMs for OS 120 surpass III
  124. Da 100
  125. OS 91FX w/Jett In Cowl Muffler
  126. Brison 3.2 numbers
  127. Poulan 42
  128. os50sx
  129. Os46sf
  130. tachometer help!!!!
  131. Brisson 2.4
  132. MDS .48 Heli engine,moussecan,12.25x3.75 prop
  133. ZDZ 80 Three Blade
  134. .61FX & TTpro .61 tach readings ?
  135. Does anyone own a MVVS .77 ABC R/C GFS/R ?
  136. In flight RPM
  137. saito 1.50 tach readings
  138. Looking for good 3D prop for OS 160FX
  139. OS 61 FX overpropped -recommendations?
  140. 45cc homelite
  141. MDS 148 and three carb test
  142. Which Tach?
  143. Saito 91 FA
  144. Strong G-38
  145. Zenoah 26
  146. Modifying 10/11x6 to 7.25x6?
  147. 3w-50 tachometer reading
  148. 32cc homelite @ 10,522 RPM's
  149. Who have a 32cc Homelite engine?
  150. Old but going strong...
  151. bme44
  152. Post idling rpm as well ?
  153. Magnum XL 80RFS
  154. O.S. 70 FS (I)
  155. OS 32 sx
  156. G-23
  157. Zenoah G-62 tach readings
  158. Us 41
  159. Mvvs 1.60
  160. OS 91 Surpass II
  161. OS 50sx
  162. 46FX with 12x4
  163. Saito 270 II
  164. Irvine 53 with a mousse can
  165. YS 91 FZ vs Saito 120
  166. Saito 180 & APC 17x6 on Aeroworks PROFILE Extra
  167. OS40FP + Mousse Can
  168. Quadra 35 or 42?
  169. ST 2000 w/MS 16x10 & Mac's Pipe
  170. OS46FX with Macs Pipe
  171. Saito 72
  172. Elevation and Engine RPM
  173. Magnum XLS 91A BB
  174. Fox 2.4
  175. Saito 100 Tach Readings: Please Post
  176. Saito FA-30...the ".30 that thinks it's a .40"...!
  177. OS 61 FX Tach readings
  178. New OS 30 Surpass
  179. Engine won't run with throttle barrel fully open.
  180. Moki 2.10
  181. Globee tach, good or garbage?
  182. KB 4050 hot as they said
  183. MOKI 1.8 RPM Data
  184. Thunder Tiger 61 pro prop ?
  185. Saito 91
  186. can a MDS rev? erm... maybe
  187. FS-60 'Open rockers'
  188. MSD 1.48 With "New" carb :D
  189. Super Tiger G90
  190. Ys 63fz
  191. Homelite 25cc
  192. homelite 33cc
  193. Saito 450 Radial
  194. Jett 46
  195. Moki 1.8
  196. Os91fs I
  197. Jett FIRE 50 (with a question for you engine gurus)
  198. ryobi 31cc conversion
  199. Irvine .40 MKIII abc
  200. 61FX / Davis Pipe
  201. Webra Bully 35CC
  202. Ryobi 35 CC
  203. Super Tigre GS45
  204. O.S. 1.60 twin rpm results
  205. Jett 76
  206. A Tach for 2?
  207. Os 46 Fx
  208. YS 120 tachometer readings
  209. Zenoah G-62SL
  210. zdz50
  211. Saito 1.80. tach readings
  212. OS 46 SF 'Ring'
  213. OS .91FX with stock and Performance Specialties mufflers
  214. Ys 140dz
  215. Saito 72
  216. Tower .46BB, OS .32 SX, Mag .40 BB, Mag .15 BB
  217. OS 90FS II Tach Readings
  218. SuperTigre GS.40 owners Post your tach readings
  219. O.S 1.60FX Owners. Post your tach readings
