- Gluing Wing Halves
- Just got some very old plans, Kinkos still the best bet for copies??
- Building with wing tubes?
- 1/8TH SCALE E2C BUILD MACHE PLUG CONCEPT
- looking for plans for a 40-60 profile plane
- Router Table: Recommendations needed.
- DH88 Comet Plans
- Control line
- Blue foam plane
- Need Magnetic Building Board help
- What tools?
- scroll saw
- Nice 3 Views
- Balsa Suppliers
- Trailing Edge Stock & Tapered Aileron/Elevator
- WinTopo Use
- Sig 4*120 Question...
- Ever built from the agmaster plans available on the net.
- Cardinal RG Plans?
- balsa wood
- 1/9th B25c Build
- spar notches on formers and ribs, best way to cut
- 1/6th Scale Ryan STA- Phillip Kent Plans
- Semi Scale MD500
- camera plane i want to build
- busken Jungmeister
- RCM Files: Fokker D-VII???
- Clasic pattern
- Modeling software for Intel Macs
- Gee Bee Y plan
- Croc-A-Nard
- Looking for basic 2D cad program
- Books and Resources for Design
- Up-sizeing Andy Lennon plans?
- who makes undercarriages
- digitizing plans
- Cessna 210
- Douglas F4D Skyray CG & Plans
- Miss Texas Build..HELP!!!!!
- p-38 plans
- Removeable Tail Booms
- Flying Models Magazine F-86 plan article
- Sporty scale biplane for 15cc 4-stroke.
- Rib Spacing Question
- Another CG Question
- how to fix a small bow in a built up aileron
- How to creat an airfoil with solidworks???
- Fokker E.III 1:12 Scale Depron Scratch Built
- TurboCAD question
- Anyone know where I can find plans to scratchbuild a park flier?
- Which way should the balsa grain run in relation to
- RCM Cloud Dancer 120
- Which Airfoil???
- extra 260 3 view needed
- CG Location???
- autocad Inventor 10 pro 2008
- OV-10 Bronco electric
- Lone star balsa fire
- Need CAD models of electric components
- Cessana Caravan Plans?
- LONE STAR BALSA BURNS
- Curare from MAN plans
- Bud Nosen "Champ"
- Cessna plans
- Correct Wing Spar Mat. ?
- CAD or Solidworks and how do I
- Molding with silicon or poly resin fiberglass?
- 47% Cassutt Racer Structural Question
- Turbo Cad 12 - Planes and snaps question
- bird dog plans
- 1/32" wing sheeting
- Scratch builders .. your openion please ?
- Linear Jack Screws for Retracts
- 42% SMITH MINI PLANE SHORT KIT
- REFRESH MY MEMORY
- T-tail modification for Senior Telemaster ARF
- Das Ugly Stik Plans?
- Scale Pocket Hinges
- drive shaft for a .45 engine...anyone..?
- Throw outs....
- Need Help finding Hobby Helpers plan 568--Mooney Mark 21
- Drag Rudder Designs ??
- Falcon 56 stab airfoil
- 60" Scratch Telemaster Stabilizer question
- help finding balsa
- 3-View Of FAI/F3A Pattern Models
- 1/4 Scale Sukhoi SU-26 Ailerons
- Trailing Link L/G Availability
- Palmer plans BD-5D
- What masking tape for painting
- Making flaps from strip ailerons
- changing tapered to constant chord?
- Transferring template to wood?
- turbo cad 11.2 deluxe
- RCM Plans Corkscrew
- what should i do
- To make rounded fuselage easily
- Model airplane design library
- FRom CAD to Construction
- 737-700
- Miss Texas with OS 120 Surpass
- hope this is the right place.. how to kill dihedral
- Need a canopy
- Custom Foam Planes
- I need help with scaling up a plan...
- HOW DO I CLEAN ?
- TurboCad ver. 9 questions
- Wing profile question for E-bipe
- Plan help!
- Bleriot XI. plans ?
- This might be a dumb question...
- Hostetler Cessna 150
- Need a kit cut
- DIY CNC Milling/Router machine
- Alluminum vs PLy
- Miss Texas Wing HELP!!!
- Heinkel He-162 Salamander build
- Looking for lite ply or doorskins
- PDF file maker
- First scratch build
- Wing fairings
- THREADED CLEVIS
- Foam wing tube cut out
- Laird-Turner LTR-14 Meteor
- Need help. Wing joint tube advise needed.
- C2A SCRATCH BUILD
- Where to buy springs for struts?
- How do you cut multiple pieces?
- Designing Software
- Strenghten free flight plans for glow motors
- foam wing idea?
- sizing engine
- (eps) expanded polystyrene foam
- Cessna 177
- Need advise, how to cut ailerons??
- Resin and CA
- Wing Ribs
- WING TIP EXTENSION HELP
- Elevator Control Horn
- Site For Anderson Kingfisher Plans?
- Fike Model E information
- wing joints
- 3 views of Robart Horns
- How to export airfoil from autocad to a ".dat file"
- can-aero toucan
- Scratch STM, two-part wing, joiner tube needed
- Plans for CNC hot wire foam cutter?
- Landing Gear width
- Why did it change scale?
- source for 60" balsa sheet?
- Where to get Leading Edge LE stock.
- Trainer Plans ?????
- Fowler flaps
- 41 % ShoeString
- Speed sport plane
- LOOKING FOR A SPECIFIC SET OF PLANS
- Metric to Imperial in CAD?
- Fuel Proof Paint For Koverall
- Why does it do a thinning process?
- Cad software
- Roger Teagarden - Modeling Tips
- Seeking aircraft design+R&D+flight sim software
- from compufoil to laser cut ready
- Fiberglass Parts
- the Prairie Duster
- What plane is this????
- Mooney M20
- New Builder
- cowl airflow
- Impressive Scratch Build
- Cheapest suppliers?
- First large scale project
- Mounting an engine requiring right thrust
- Blue Hots
- Scale Fabric Question
- Um yeah, about that Falcon .25 plan...
- rib spacing
- Scratch build Beechcraft King Air 350 - Help Wanted
- Making an Eppler 423 airfoil out of fanfold
- Does anyone draw CAD plans from a 3 view
- Rocket Powered Shuttle
- Walter Burgin .60 Pitts "Little Stinker"
- Anyone got a Pdf or excel metric to imperial convertor
- Where can I find T pins??
- Giant Stick plans
- Katana S
- Cutting formers??
- 1/8" and 1/32" Ply?
- Rebuilding fuselage
- Building a wing
- Split aileron/airbrake. Anyone?
- extra 300 .46 size
- Extra 300 150 cc gas plans free download
- Need Funtana 2m plan! Please help!
- .25 plans trainer-sport?
- ROCKET POWERED FLIER
- 1/4" hardwood or 3/8" balsa wing spars?
- Do you have a set of CAD (.DWG or .DFX) plans for a Super Kaos that you'd be willing to share?
- 50cc Extra or Yak airplane?
- Digital Pulse Meter by Kenneth A Jesser
- Looking for plans/Miss Texas
- Gee Bee 3
- PROPELLERS -- RIGHT WAY - WRONG WAY
- Jerry Nelson S-1 Pitts Special
- Microlux Tilting Arbor Table Saw
- At-6 plans?
- MODERATOR: please delete, I will repost in another forum.
- Thinking About an Older Version of TurbCAD, but I Have ???????s
- Long EZ
- Jerry Smith's SPOILER plans
- Turbocad 11.2 Deluxe printing problem
- DON SMITH PLANS
- Swept Forward Flying Wing
- Sunil Rikhye's Edge 540
- What to use for filling in
- Looking for a builder, Ziroli P-40
- turning a one piece wing into a three piece wing
- Yak 54 plans
- how much does it cost
- Skyray 48 (X-48B Blended Wing Body)
- 3views and other info
- .60 Pitts
- Scratchbuilding a bipe from internet plans - MY FIRST!!
- Shinden plans
- Super Sportster Biplane Wing Help
- pt 19 scale 3 view
- Balsa Wood Quality
- F-18 E/F Super Hornet 1/6
- !/4 scale Spitfire
- Big Diameter Sanding Disks
- Airplane got too tall, need help stabilizing it in flight!! please help!!!
- Sukhoi 26 rudder coupling
- Where can I obtain Dec 75 issue or RC Sportsman Magazine
- Wheel Pants Attachment ?
- Scratch build F4U Corsair
- Foam wing cutting
- Low cost project... Foamy F9F Panther build thread.
- looking for a way to secure the wings to the center section
- Which CAD prog if u had about $99 to spend?
- airfoil
- Phenolic Wing Sockets
- How do you create the formers from a 3 view?
- Martin-Baker MB5 Plans Enlargement
- Edge 540 plans...
- Free CAD Programs
- citabria plans
- ARF
- park flyer scratch build questions....
- Twin rudder versus single rudder design questions
- Ace Bingo HELP!!!
