PDA
View Full Version : Scratch Building, Aircraft Design, 3D/CAD
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. If you had to pick one saw to have for scratch building. What would it be?
  2. Meister Plans - Can they be copied?
  3. Control line to RC. Any modifications?
  4. Control line to RC, what modifications?
  5. American Flag Trim Sceme
  6. foam cutting
  7. How Do You Post A Zipped DXF File
  8. Need Help Improving These plans!
  9. Looking for shaped strut material
  10. CAD shoot out
  11. 'Flying Tail'
  12. Will gasoline damage blue foam?
  13. Question about PDF Printing
  14. new to scratch building...
  15. more CAD, please answer
  16. Have you ever created an internet plan?
  17. Im looking for plans for a wild thing combat plane.
  18. more CAD help
  19. Good plane for first scratch build
  20. Blowing up plans
  21. Measurements for Ziroli F4U
  22. Retractable landing gear
  23. how to reallign my planes tail
  24. Bipe Wing Placement & Balance?
  25. scratch building materials
  26. Mystery Wings
  27. Good Symetrical airfoil?
  28. Raster to Vector question for Autocad users
  29. Mike Pastro's CT-114 or F-18
  30. Ladies and Gents...Meet the High Octane
  31. AUTOCAD!!!!!!!!!!!!!!!!!!!!!!!!
  32. RC modeler Plans
  33. Can this be done?
  34. Have you ever built from internet plans?
  35. Wanting to build my first R/C. Please Help.
  36. deciding servo needs.
  37. F16 undercarriage drawing
  38. PLEASE READ!!! i need help
  39. Now that winter is upon us...
  40. Looking for Lee Richter
  41. Canopy & landing gear for a Super Kaos
  42. dxf program
  43. Foam Cutting Service/Provider
  44. CG
  45. YAK 55 plan needed
  46. Cutting kits and balsa suppliers?
  47. EE lightning plans (again)
  48. Foam Cutting Service/Provider
  49. Plans for Bi-Plane?
  50. wendell hostetler cessna 150
  51. Advice for an oldie newbie
  52. Balsa density & strength reference
  53. new at scratch building
  54. Home-made Quest 50 (CMPro)
  55. Ziroli Ole tiger Cassutt Racer need Info !!!
  56. Junker J9 (D1)
  57. Motor characteristics
  58. AutoCAD fonts in published plans?
  59. Design & construction of Frise (Friese) ailerons?
  60. Curtiss D
  61. Designing a dual engine .15 plane...
  62. My new desing
  63. Help a beginner with his Hawker Typhoon
  64. Rearwin 8135 Cloudster - know of any plans?
  65. What size should the tail be?
  66. Small trainer design inputs?
  67. Yak-55M Color Scheme Help
  68. Grades of Balsa
  69. any plans for the flair tauba i could copy or buy
  70. line drawings with cross sections
  71. QB20L
  72. Wing flex
  73. WHAT BATTERY & CONTROL PANELS DO I NEED FOR A FIELD BOX?
  74. Cutting parts, balsa selection, carbon fiber reinforcement...
  75. Extra 300S
  76. Lightening Holes
  77. Waco E building instructions.
  78. Any plans available for Airbus's Super Guppy
  79. Searching for Twin fighter Info
  80. What plane is this?
  81. WHICH TX SHOULD I USE?
  82. plans for studacher
  83. Blowing up plans?
  84. Nacelle sanding
  85. Is covering of the fuselage necessary?
  86. CAD help
  87. How to make a foam wing cutter?
  88. Problem with DXF to PDF
  89. Engine size ??
  90. RCM Das Ugly Stick
  91. How to describe the section of a fuselage from a plastic scale kits?
  92. bruce lund models staudacher s-300 d
  93. Building a Boeing 737-600
  94. Building Pfalz DIIIa from Alan Spievak Plan
  95. putting paper plans to wood
  96. where to start???
  97. Allowable Stress For Spruce Spars and G Loading?
  98. Tucano construction article
  99. RCM plans
  100. Where is the best location to make a connection?
  101. Alternate foam core wing skin material?
  102. Big Ultra Hots
  103. making a 96" wing 2 piece
  104. MOVED: Scratch build slotted flaps
  105. RC Parts CAD
  106. SU-26 Model Airplane News Plans
  107. problem insert DXF in drawings
  108. LOOKING FOR LASER CUTTER FOR OV-10
  109. RCM&E "Honeypot" biplane
  110. adhering canopy to plane
  111. Lear Fan 2100
  112. common rc cad file repository?
  113. professional/pre-made foamcutters
  114. Flat "foamie" Thoughts?
  115. New scratch builder
  116. Hostetler 27% & 33% Extra 300XS
  117. Classic Sport Biplane?
  118. sterling models spitfire mods
  119. F15 CAD MODEL -- WOW
  120. Scroll Saw Blades
  121. Engine Pod - how much support?
  122. MAC, and Area for 40" elliptical wing
  123. Please suggest a REPUTABLE Kit Cutter Company
  124. MOVED: Kingcat-Like Design and Build
  125. Re: Pond Plans- Piper Cherokee#29876
  126. Spaceship plans
  127. HOW DO I CONNECT?
  128. Long endurance airframes
  129. AMA Model#00987- The LJ-7 ;Is there anybody building this yet,Post pic's here.
  130. Lockheed Xp-58 chain lightning
  131. problem in open DXF generated WINFOIL in autocad2006
  132. Need NACA profiles in vector format (corel?)
  133. Building 1/8 scale F-16
  134. Where to find plans for BG 108 Taifun?
  135. Alien Aircraft extra
  136. The 3-D Dosage
  137. Bipe Wing Incidence Question
  138. Need plans for F-16
  139. Ceconite fabric
  140. Tricycle Landing Gear
  141. DO I HAVE A CONCERN A WITH THIS UNEVENESS
  142. Where to get planes for GP Ryan sta/m
  143. wich features for Compufoil?
  144. Help needed: Wing joint / fuselage subdivison
  145. MX2
  146. is this idea even feasable?
  147. balancing question,,
  148. FUEL SUPPLY HOOKUP
  149. which airfoil?
  150. What happened to the price of SolarTex
  151. D&L Designs Cap 231EX/232
  152. MONOKOTE or PAINT
  153. Scratch Build DAG1 Autogyro...
  154. Unique scale aerobatic airplane?
  155. .15 fp profile3d plane plan
  156. 100" Lysander: Engine & Servo requirements?
  157. HOW DO I ARRANGE MY SERVOS
  158. Wich airfoil??
  159. Fiberglass fuselages
  160. 747 Plans
  161. Dick Sarpolus' "Right Angle"
  162. Savoia Marchetti S.79 Plans -- 1/12
  163. Looking for good laser cutting service
  164. Funtana 2m building plan
  165. wing design programs
  166. First Scale Scratch Build
  167. Help-F-102 cross sections
  168. 200% size slow poke
  169. Bought a laser cutter. Need 3-D plans.
  170. Pilatus PC-21 3 view
  171. Looking for Funtanna plans
  172. Cardboard Stik
  173. Construction material inorder to save weight
  174. Scratch building 105" WS S Connie L-1049 (Pics added)
  175. rib profile HELCAT
  176. First Scratch build Plan?
  177. Midwest Citabria Clipped wing
  178. "Not For Sale" Plans
  179. 12 foot Mr. Mullagan Plans
  180. please help me build up my "dream"...
  181. Two piece wings for 1\3 scale Fleet biplane
  182. jbaccesspanels
  183. large block of foam for cutting wing cores - where to find?
  184. AIRACOMET Plans
  185. Looking for plans: YAK 52
  186. Scratchy Cloud Dancer
  187. RARE EARTH MAGNET CAUSING POSSIBLE PROBLEM ? !
  188. dxf files of 100cc twin motor??
  189. El pato Lucas ....CG location
  190. El pato Lucas ....CG location
  191. Up thrust and flying??? Please reply
  192. Where to get GOOD balsa ?????????????????
  193. are there plans for a Beechcraft Bonanza V35?
  194. NEW YORK Cradle of Museum photos HELP !!!
  195. Indy 400
  196. need help with 25 size Tiger Moth Plans by Flt Lt Gordon Whitehead
  197. fiber glass rods?
  198. fokker v23 -25
  199. RV3 4 three views
  200. C130 and C160 plans
  201. WHAT WOULD "YOU" CALL A GOOD .46 ENGINE?
  202. Looking for a builder!!!
  203. Designing a color scheme
  204. Making parts with a drum sander?
  205. Gotha 229
  206. 2 Part Question
  207. 3d model of heli???
  208. first scratch build questions
  209. A huge undertaking or an exercise of futility??
  210. Mini Telemaster Mods
  211. Cad plans for classic pattern planes
  212. Ag-Cat
  213. WHAT TO DO? !
  214. Middle Engine?
  215. Model Plane Plans from Scratch. Help!
  216. PLANS WANTED
  217. Mirage2000/F-1 plans wanted
  218. Funtana-like design help...
  219. Giant Scale Predator
  220. drawings suported rib for twisted
  221. MOVED: Relation of Stab on Flight Characteristics
  222. HOW WOULD YOU INSTALL THIS CANOPY
  223. steering mount 2
  224. STEERING MOUNT
  225. I'VE GOT THE PLAN'S....NOW WHAT?
  226. Cad drawings for engines, servos, fuel tank ….ect.?
  227. Opening dxf files in TurboCad Learning edition2
  228. Diffrence between cap 232 & cap 580 matt chapman??
  229. HELP ME PLEASE!!!
  230. Scroll Saw or Band Saw
  231. Free CADCAM software
  232. Lazy Bee
  233. aeronca 7ac
  234. 33% Cap 232 Scratch Project
  235. Radiator Material
  236. vickers fb 12
  237. A good, relatively inexpensive scroll saw for building?
  238. looking for any Exclusiv-Modellbau plans
  239. Holes in sheet brass
  240. Post Pics of Your Airframes
  241. vickers vampire
  242. J3 Cub (my first scratch build)
  243. Dremel Routing Guides
  244. Problem with B-29 rc airplanes
  245. RC Modeler Plans
  246. How to estimate finished weight?
  247. My first build.
  248. Name of program ????
  249. Looking for 3-view of Douglas F3 Skyknight
  250. Top Flite 182 RG gear mod - need info
