- Anyone Using CompuFoil and TurboCAD Pro 11.2?
- Inventer Help
- Scroll or Band Saw?????Help
- Liberator plans
- scratch built 1/2a Uglystick( modified)
- Help tools
- J&B Access Panels
- Plans Wanted for 3d/pattern plane
- 3D cad newbie project
- how do I figure degrees of CG?
- Fusion and Foam don't mix
- Christen Eagle 3-view
- Tail heavy
- Help with arado 234 airfoil specs
- AIRCRAFT STAND/HOLDER FOR PAINTING?????
- Ziroli Vigilante
- Building Jets
- Sig Rascal Biplane
- Corporate Jet Plans
- homemade CG machine
- MOVED: Submersible jet engine powered gull wing stealth drone
- Extra 300S 50CC plans
- Retractable or fixed gear, Bomb drops, Mechanisms, and other flight accessories
- trim application techniques
- cloud dancer plans??
- Info wanted on Wayfarer Bipe
- Piper Tri-Pacer
- Jim Pepino's YMF-5 Waco
- Skymaster
- streching in autocad 2000
- Wing tube question
- Jr. Falcon building pics and questions. (first build)
- Foam ribs for giant planes help
- Yak 54 in TC 11.2 Pro
- Enlarging control surfaces-any negatives?
- Plans
- Scratch building in an apartment
- SF260 plans
- P-63 plans
- Effect of location of max camber on symmetrical airfoils?
- Filler Blocks 101
- Help with making airfoils Please.
- Read me if you buy balsa
- Real dumb balsa question from a NEWBIE
- Cessna 170 Plans Location?
- Practical Torque RPM Range for 1/7th scale 8lb aircraft
- Laser Cut Parts. from Cad.
- first scratch build
- Old(er) Modeling Magazines
- TurboCAD on sale
- Looking for Rapier plans...
- Slight Pickle
- fair price for building/painting
- RCM Aries XJM-120
- airfoil choices
- Balsa Shopping
- Sheeting
- First Glow Powered build
- 1/16" Lite Ply??
- Balsa Wood
- My scratch build Extra 300
- how do you make/attach support wires
- RIGHT;DOWN;UPTHRUST FUNTANNA 40
- Looking for a laser cutter
- Suggest.
- STINSON 108-3 VOYAGER 3D views wanted
- Want a good software to design wings.
- VTOL
- construction idea, is it lighter
- looking for phenolic tube
- WANT IDEA TO SCRATCH BUILD A TABLE SAW, FOR CUTTING SPARS, ANY ONE THERE.
- Alibre Design Xpress - free
- Jack Bale E-2C Aircraft Plans
- Carbon Tubes for Spars
- Cutting Ply parts
- P-51-B PONY Norman E. Meyers
- DXF into plans!
- Tom Miller Staudacher S300D
- Been There, Done That?
- 2 piece wing ideas?
- incomplete Extra 300s 60 size Plan need help
- Looking for Space walker plans
- Only One Wing Panel Shown?
- linkage rod for ailerons ?
- Z-poxy used to lay up glass - 2nd layer OF ZPOXY IS SANDED - NOW WHAT?
- Backpack Helicopter/VTOL
- 40% Piel Emeraude CAD help Needed
- Check out my Sport Model Sketch Book
- Vertical Stab Design
- Want plans for SPACE WALKER.
- I need Edge plan
- Cutting Foam Wings - Power Supply
- Scratch vs Plan built?
- is it possible to make a rc plane like this???
- Laser Cutting in Australia?
- My "Chunky" Build
- DeHavilland DH-4
- Anyone know of a service to cut foam from CAD data?
- strut attachments for biplanes?
- Tanzer
- I wanna Start Scratch building.
- FIBREGLASS IS SUPPOSED TO DO WHAT?
- Looking for Real Thing Plans
- Servo selection for 38" span 90 mph plane
- Wing Tubes - size and materials
- How to estimate finished weight?
- Airfoil considerations....multiple questions...
- My first build.
- Kit Cutters Discussion
- Lancair IV 3 Views
- what's a good co. for plans?
- Design plans for laser or hand cutting?
- FINISHING EPOXY - ORANGE PEEL
- solid model
- Fairchild F-91 Plans?
- plan for 25cc gas......help!!!!
- SCRATCH FOAM BUILDING PROJECT..PICS ADDED 2/14/06
- Looking for a set of GP RV-4 40 plans
- looking for a set of plans
- Great Planes Extra 300 40 size plans
- IMSI Instant Modeler
- 4 star 60 bi-plane : anyone?
- Aluminum wing tubes?
- MOVED: Twin ducted Fan Kit
- Top surface hingeing of elevons on eurofighter wing
- Ultimate bipe build
- GP Super Sportser 60 plans
- FINISHING EPOXY - HOW DO I PREPARE IT
- Bombardier Global Express BD700
- Want to make my own landing gear?
- Birch or Poplar?
- learjet 35
- spray adhesive?
- who have an accurate 3d view of the extra 300s
- WHAT IS THE BEST WEIGHT TO USE WITH EPOXY & GLASS
- mosher t-28! AWESOME
- Newbie Question
- Extra 300 scrachbuilt ???
- how about cheap online source for acid brushes
- Katana X & Extra 300S Plans
- What laser cutter are you guys using that is good and cheap, does ply and balsa
- Photo Etching?
- Great Details on Landing Gear Design
- 3 view drawings
- Airfoil shapes
- FokkerD7 Plans
- 1/16 28" p-40 warhawk
- Baltic Birch for Dihedral Brace?
- Delta wing design
- Scaling an Airplane - Artical in the AMA Mag?
- Jack Stafford 1967 Chipmunk Plans build
- where can i get free cad software
- wanted Plans for katana
- I Need Lite Ply in 8' Sheets--Where to Get?
- GP F-14 Tomcat
- Pusher Prop dirt clearance
- CA hinge questions
- Anyone ever flown something with a tail skid or non-steerable tail wheel?
- Anybody built this trojan?
- Does anybody have a set of Plans for a 27% ULTIMATE BIPE
- Enlarging LT .40 to Fit 25cc Glow
- Airfoil selection root vs tip: alternative to wing washout?
- White Lettering on Black Background
- Tapered wing with same root and tip airfoil: problem?
- KatanaX
- leaning AutoCAD 2000???
- Winter Sukhoi 29
- Free Flight -- Harbor Freight Build Challenge
- Kit Bashing--Need a Little Help
- WHAT IS THE BEST WATY TO CUT "GLASS"
- Need some compufoil help
- Ultrasport 1500
- Plug in wing tubes How to
- MX2?
- Foam
- Plan Request for weston magnum?
- Enlarging a kit
- Russian WarBirds
- Importing a Scanned in image into Turbocad Pro V11
- WINGS WITH DIFFERENT DENSITY
- Best way to make wing fillets?
- Anyone have any experience with HOSTETLER PLANS?
- building struts
- Minimizing twist in a wing
- Another quick TurboCAD question.
- Quick Turbocad Question!
- YAK 54 three view?
- Just an idea
- File format?
- Question about enlarging plans.
- Want palns for EDGE 540 please help.
- Holidays
- Control rod Sizing???
- What's the best way to share plans?
- ,,wondering about plans for scratch building larger jets??,,ie,,turbines??
- Foam Wings
- sig hog
- Printing Plans
- Aircraft design / newby
- HOW DID I GET A 1/2" WARP IN MY WING
- 60 Size plans for a A6M Zero?
- who cuts foam wings with Variac power source?
- turbine ? how they work
- Tips And Tricks for CAD Programs.
- Show us Your Tools!
- Lazer Cutter/Cloud Dancer 40
- Water jet kit cutting
- Feeling Hot, Hot, Hot
- Aileron Design and Building
- Looking for info on Chuck Cunningham's Blue Tango design
- astro hog plans.
- Airfoil coordinates into Profili software
- covering cub fin
- SENIOR TELEMASTER "legend or myth"?
- Kadet senior plus 45%
- covering cub fin
- 3D CAD Need suggestions!
- MAN 30% Laser 200
- Focke Wulf Fw56
- Need help figuring this one out.
- Source for thicker foam?
- What counts as scratch built?
- Designs or Plans for Small aircraft which can take a fair amount of weight
- Amerian Eaglet & Ultralight Kitten 3 view drawing?
- Ryan Plans Help!!!
- Dornier pfiel/ Arrow
- This was fun to build
- 30% Yak 54 Plans Needed
- Strange Problem
- Large balsa
- vacuum bagging - where do I start?
- Mono-coat
- HELP! - glider design for school project
- TrueView, True Convert and DWG Gateway
- F4U plans
- hand drawn plans to lazer cut parts???
- PT-19 1/5 or 1/4 scale plans
- Cessna Build Plans
- STYROFOAM (SPECIFIC)
- balance
- airfoil
- First scratch build RCM bingo???
- M.A.N. SU-29
- Template Material
- Wing tube
- Scratch building -sheeting foam
- What wood should I use?
- hihg wing trainer?
- 50 cc size Aerobatic with two piece wing
- UPPER WING COSMETICS
