- looking for a not4sale wing
- Double Taco Build
- Diameter of Carbon Fiber Wing Tube
- Wood size when enlarging the plane.
- Wood Suppliers
- Mods Questions for SIG Kadet Seniorita
- Ercoupe 3 view dwg.
- Scale a Typhoon 3D
- Canard
- Low Wing Telemaster
- Need an Artical from MA News,
- Vintage Airplane plans.....Free to good home
- turbocad le ?
- How do I add Nav. lighting covers?
- Own design scratch built X-Fighter Racer
- Ace Whiz 40 Scratch build questions
- Experts - question with CG on scratch build...
- Building Edge 540 look clips
- Anyone Need A Pen Plotter To Print Plans?
- Who's Good At Math? (Need An Upscaling Size Formula To Build Design Larger)
- Jetco F7U Cutlass FF Plans Wanted
- Violett Pattern Prototype - Blast from past
- How can you transfer plans?
- 60 inch balsa sheets
- MOVED: What makes a high wing "high"
- Best covering material for 96" powerhouse
- Scratch Built Pitts
- Huge KAOS Questions
- Steerable nosegear help
- what should i know about scratch building before i start?
- Taco II Resize?
- Last Flight of theKrazy Kanard
- crazy scratch build
- Wood for model
- Helicopter CAD models
- Dual Engine Single Line Thrust Models
- Kitting 4*60 and Ulta Sport 60
- DWG, DXF Conversion made easy
- Fledgling Plans
- "Wanted"- Ace R/C 4-120 Plans
- super decathlon
- Winshield material for my 1/4 scale
- .46 aerobat plans.
- WANTED! Oscar, Shinden and Val
- Materials Question: steel tubing
- ENGINE QUESTION
- Sig LT-40 help
- Pipe Bomb
- CAD program for model airplane design
- V-22 Osprey Drawings
- TurboCad 10 or 11
- Diamond grit bandsaw blade
- HELP!!!! Pilot .40 size Plans
- Sailplane Wheel Retract
- mistaken post sorry
- Twin engine Sig Kadet
- need help
- Mould making for fiberglass epoxy
- NUTS, BOLTS, etc
- wanted curare 60 plans(cad)
- Where can I buy metric balsa in the US?
- MR MULLIGAN PLANS
- Want Opinion - First Building Project
- help with delta wing design
- Inventor Design Process
- Best way to fill gaps in foam?
- OMP yak 65'' similar copy HELP
- Solid Model
- Circular saw, good - bad ?
- Navigation Light System
- ENGINE OFFSET
- Planos (Drawing) de (of) Beechcraft 1900 and Fairchild Metroliner III
- A3/A4 dot matrix printers
- Flight Box plans ?
- piezzoelectric vibration dampers
- need help
- approximating cross-section formers from 3-views?
- Coverite and matching paint
- Drive Shaft for a BD-5
- airfoil cad file
- PVC Airplane
- Covering help
- Looking for radial engine CAD drawing
- Drying clue in foamwing..
- BALSA PLYWOOD????
- Scale airliner plans
- A foolish question for KC
- ONLINE BALSA SUPPLIERS
- leonardo de vinci
- 86" Delta
- First advanced design
- Dirty Birdy 40 plans?
- Airbus A380
- Drawing your own plans using plastic models
- Conversion Raster to Vector to DWG
- Cristen Eagle plan giant scale
- CAD Question
- Modeling Software
- Carbon Fiber Expoy???
- Enlarging Pepino's Larid Super Solution
- balsa wood quality
- plans for glow powered foamy?
- Flaps on Lazy Ace
- wing saddle help
- Extra 300S Scratch Build Thread
- Great Planes F-14 Tomcat
- Does Hanger 9 UltraCote Paint stand up to Gasoline?
- Where do I buy Fiberglass cloth
- Su35 (Su27) plans HELP!!!!
- How many G's do RC planes experience?
- Painting balsa?!
- Building for first time
- help with elec. plane idea.
- alternative to push rods??
- C-17A Globemaster
- Good referrence plans
- 96in ws Islander Twin
- Vacuum Forming hints/tips
- Need help sticking plastic films
- IC Pusher 15 King Cat
- WingMaster or Compufoil
- RCM Big Bird Too
- Flight Report (folow up to "my first attempt")
- Motorized glider
- Tiger Sport
- Dick and Nadine made it -- barely
- 3D airfoil needed - where to find?
- Fling Wing
- Giant Precedent 240
- My first attempt
- electric engine as generator
- Enlarging plans and what to watch for
- SLIDING CANOPY??
- Determining CG - How's it done?
- Profils
- Free plans for a .40 size profile
- building a foam wing is this stuff ok to use as covering?
- ENGINE SIZE vs WING SIZE/AREA
- Can anyone share the funtana 40 build plans???
- tile it program
- Two Piece Wing and Stabilizer Design...
- Nylon wing bolts - big airplane
- flightskins still exist?
- Hostetler Decathlon
- Zenoah G-62
- Looking for Gee Bee "Z"....
- High wing aircraft with Long tail moment for 3D Flight
- The Hots
- Help with a wing
- Delta wings in formation
- Foam wing structure question
- effect of fuse length, stabilizer surface area
- shoestring yellow jacket
- Small
- Canopy Frame
- cad request - automotive related ... need plans
- The Staggerwing Cometh...
- Hurriacane Katrina
- SCRATCH BUILT WHAT'S THE NAME
- Hurricane Katrina
- 3-views Piper PA-36 300 Brave
- Kit Building Service
- Blowing up 3views?
- A Hinge and a Monocote Question
- Finding what the CG is on a built model?
- Airfoil for Funtana
- Ryan Fireball
- Funflyer
- .. flower foam Zagi ... sort of lol
- Aeroplane Monthly 07/79
- "Missle" style fun fly design
- Modelcad
- shoestring racer
- How do you balance a canard?
- My latest scratch build - In Progress , Have a look and lend a hand
- catalina Cleveland model
- Transfer from plans to wood.
- first attempt.....
- Foam Cutter Drivers and Stepper Motors
- 3D CAD Parts for Turbine Heli
- my cnc
- FOAMIE STRYKER!!!
- CULVER CADET PLANS WANTED !!
- Calcomp DrawingMaster Plus plotter ????
- First Scratch Plane
- STRUTS FOR GLIDER or NOT
- looking for a plan for a 62"semi symetrical trainer wing
- Scale Landing Gear
- wierd plane?
- Laminating Balsa/Ply
- best 180 sized motor
- foam wings-where to get them
- monoplane to biplane do's and dont's
- Importing Profili airfoils to CAD14
- Would it be wise to attempt to scratch build a 2nd plane from a kit?
- WHERE CAN I DOWNLOAD COCKPIT IMAGES
- skippy G2 completed
- scratch mini beech starship (wysiwyg scale)
- resizeing plans
- The Enterprise is complete (pictures)
- SPOILERS - HOW DO I FABRICATE
- Mini Kangaroo
- CG on an odd shaped wing
- How to convert a conventional-tail to a V-tail
- New Plane need some help.
- Seawind 3000 dxf/dwg?
- Trying to build an F/A-37 Talon
- HELP : Foam cutting wire diameter ?
- Free Plans
- Does anyone remember this article?
- tchsuper cub wing joint
- Anybody got PDF format profile plans for a 46 engine or smaller
- MOVED: Large Ridge Soarer
- Weight difference between balsa and ply.
- Plans Ultimate CG or DP
- Plans Carl Goldberg Ultimate
- WHAT ARE YOU PRESENTLY PAYING FOR YOUR "CA" AND YOUR EPOXIES
- TO COVER WITH BALS - OR NOT?
- AirFoils
- Concorde Project
- Ultimate Bi Plane plans
- V-22 Osprey Plans
- "THE HOTS" from Model Airplane News
- Looking for free plans for a avro lancaster
- CAD/Laser cutting service?
- RC SWITZER PLANS--CURTIS CONDOR T-32-PLANS, DOCS & PHOTOS FOR SALE.
- Colour schemes
- Neville Shute's plane
- prop info needed
- HELP : Lear Fan 2100 plans ?
- INCORPERATING HOUSEHOLD ITEMS INTO YOUR BUILD!!
- Poplar vs. Birch Plywood ?
- HELP !!
- Decal design software
- push - pull cable setup?
- skippy g2 approval needed
- Virtual Fokker EV
- 1931 Stout Sky Car
- Starship Enterprise pictures
- Fleet Biplane
- Delta C/G
- Building a flat plate wing...
- 3D/4D Foam SHeet Flyers CAD Files
- Flight characteristics(sp) of a CARNARED
- help with cabannes on scratch built ultimate biplane
- Tipsy Junior Warped Fuselage
- kando40
- Model Builder Plans
- DB Matthews 4-20 Plans
- pointers for using turbocad deluxe?
