- Scratchbuild a Curtiss Hawk III (BF2C-1) in 1/4.5
- Hysol vs. 30-minute epoxy w/microballoons
- Thinking of useing carbon fiber tube for leading edge of elevator.
- hinges
- Looking for F14 Plans
- Good laser cutting job from Lasercut USA
- Wing servo mounts
- Good place to copy plans 1:1 or enlarge them.
- Gee Bee Z (my homemade)
- First Time Building from Plans - Grumman Cougar Twin
- Checking those drwaings before sending them to the cutter. using 2d CAD
- Starting New Project RCM Cessna T-50
- Grumman Cougar - From Plans
- Top Flite Seafury Ribs and former templates wanted
- Ultra Stick 120
- If only one saw for scratch/plans building, BAND or SCROLL... which one to go with
- Blender-Tutorial for a RC-F-104 Starfighter ready for 3D-printout
- C/L to R/C with an I-Beam Type Wing
- How do I find my CG of my scratch built delta wing before I fly it ?
- Cnc Foam cutting with Arduino - Development log
- AJ Savage plans by lewis pencoast
- Help with finding Golden Era Plans by Lewis Pencoast
- scaling up
- Plan for Lockheeed L188 Electra.
- Good Place To Buy Balsa
- Fuse Former Question.
- Satisfactory power to weight ratio for sport flying .
- Plan Modifications
- 2007 to 2010 Workstation
- pica kit parts needed
- Question about cutting parts from the plans
- devSim Cnc Foam, a new free application
- Pitts Special plans
- Decals
- someone to cut foam cores
- Box-o-plywood or Box-o-balsa
- Speedwing dart
- Bud nosen mr. Mulligan windshield.
- A10 Thunderbolt II Scratch Build
- KFM6 wing help
- Building a wing from scratch (no plan)
- Ugly Stik Wing
- Would someone here cut some foam core wings for me?
- S.T.A.R.S. Fokker DVIII build
- Cessna L-19
- 120% TF Red Box P-40 in 21 Days
- Pitts 12 41% Trueworthy Plans bigairplanes
- Looking for Canard Stick CAD plans
- SW or iges F-15 CAD
- Super Sportster 90-120 and Easy Sport 60 from plans
- Feiseler Fi-156 Storch 1/4 Scale CAD
- Faded plans can you restore them? Trick to getting color back
- Aerodynamic design
- Big flying wing design
- Wing joiner
- microlight wing plans
- MayDay, I mean Maiden Flight
- Free-flight to RC B-36
- Templete
- First foam rib plane design
- LOCKHEED S-3a VIKING TURBINE INCLINATION
- washout question
- North American T-6F Texan 62" 1/8 Scale
- Tricycle landing gear mains angle of attack?
- Wing Design Program I'm making
- Isabella Electric to ENYA Conversion
- Allen's Ziroli B-25 101" Build Log
- Escapade
- Twice the Spirit of ST. Louis ?
- Big Hots (91") Bill of Materials
- Laser Scan Service
- Amazing New 3D printer
- OPtions for Enlarging Plans
- Boeing 727 question
- Goldberg extra 300
- Aircraft wing design questions
- Big slow floater for 60 PAW diesel that can swing a 18" prop
- Airbus A321 scratch build
- G M Sunbird
- NotForSale plans??????????
- foam floats
- Savoia-Marchetti 56. My lifelong obsession!
- Building Tips and Tricks Sticky
- Giant Scale about 50%
- 72" spitfire from 1/4 inch foam
- i just want to be clear on this.
- 71 inch wing on a trainer meant for a 64 inch wing,....any problem ?.
- Custom Zagi HP-60. Build Thread!! GoPro Canopy with Carbon Spars
- larger version of Miss 2 with ailerons - dihedral ?
- We may not be able to this anymore...
- too heavy ?.
- Balsa nose cone construction
- Super Contender Build
- Don Muddiman Flying Machine???????
- putting stringer notches in polyline or regions.
- Ov10-D 96"plan
- float plane down thrust
- tricycle gear placement ?.
- AutoCAD 14 Incompatible With Windows 10
- Scratch building flying boat
- Pull-Pull cable routing
- Scratch Build Electric Conversion Based on Midwest Super Sweet Stick .60
- Tail Skid
- 1:8.5 mu-2j
- Pusher thrust angle
- 3D Laser Scanning
- enlargeing plans
- Polecat rc plane
- Cessna 188 Ag Wagon
- 130% Lazy Bee scratch build...complete build
- cg question
- Doc Mathews "Big Old Bipe" plans wanted
- make an offset fowler flap linkage
- Fpv 49 flying wing
- Modifying AW Pitts Python 50 cc
- Light Lite Ply
- Darth vader secretly filmed in his latest death machine protected by stormtroopers!!!
- Hand made aluminum wheels (With Bearings)
- Ambroid gone?
- Design Tips for Lighter and Stronger Builds
- Hemlock spar size?
- Sabre XLT Giant Scratch Built Turbine Flying WIng
- Lockheed Electra 12A Build
- B-17 Build
- Finished Avro Lancaster - 5' wing span
- C-47 / DC-3 - Build
- De Havilland Mosquito - Build
- Free Foam Board Plans
- Airtronics Jetfire 20
- Looking for an online wood suppy house
- 1/3 Cub Build
- Kwik Stick I
- How to cut out for muffler
- Bench
- DHC-3 Dehavilland Otter
- Stitts Sky Baby-A Giant Among Lesser Planes
- Looking for trainer plans
- DTF trainer build
- 3-D CAD model of .40 size glow engine needed
- Globe/Temco Swift
- How to Determine Engine Placement?
- Royal Marine scratch built seaplane
- Corsair canopy
- Scratch building a foam Wing.
- 0.014" size difference between wing joiner and wing tube ????
- 15_20cc gas power Telemaster
- Baby Ace 3600 mm 3D Design from zero to a new giantscale kit
- 8 foot De Havilland Caribou plan
- Wing panels with difference deg. of incidence
- Scratch Building a H9 UltraStick .40
- Jetfire 20 plans
- Balsa
- Not so commonly mentioned Useful tools?
- Lanier Shrike 10 planes wanted
- Washout issues
- 30" KFm wing motor/batt/esc selection
- See Electric Self rotating Wing
- Most rare rc plane ever!
- Jerry's Little Boy or Jerry's Big Boy
- Kit Cutter recommendation
- Reverse Flying Wing Project
- 2006 ama lj7
- Designing with Photoshop 7
- Epo-Grip Beat The Heat Summer Sale ends Friday
- Gas welding 4130 tubing
- Plans printing service
- Skyvan aileron and flap questions
- Scratch built cessna 182 quarter scale
- laser cutting business,,,
- USAAF WWII Stencil Lettering Sizes?
- Building Question
- looking for a soldering station recommendation
- How much prop to ground clearance should I have.
- Flying lawnmower plans needed.
- Britten Norman Islander
- Replacement for Dremel Moto-Shop Jigsaw
- Cap 21 canopy
- Foam coors cut
- How many hinges to use
- Does my 2m Decathlon need wing struts???
- Searching for info on OK Models Pilot 1/3 pitts and traced parts
- FPV Worthy Canopy for Great Planes Cherokee
- Modified DC Gyro Plans Build
- Affordable night flying LED setup from dollarstore
- How to continue with RC Model Making in a Condo Apartment?
- Solid landing gear - suggestions?
- Serching for a Big Stick plan
- DLG Glider plans
- Great Planes Electrostreak plans?????
- Backwards Airplane?
- Making Templates from plans
- RCM Plans DAS UGLY STICK 1985
- IMAC and PATTERN
- f-117 plans?
- f117
- FRCFoamies Alpha Jet V2
- Brodak Wing Jig
- Electra 10 e
- "Sol Simple" Solar powered park flyer
- Kadet JR Changeling ODO
- 1/4 scale Cessna 182 Scratch build diary
- Wing Tube Design Tips
- hand held scanners
- Where to buy Plans now a days????????
- red wood
- Foam Supplier
- Sizing wing tube
- Airfoil selection for a P26 Peashooter
- flying plank wing- first time build
- Looking for plans of a Corsair F4U with folding wings??
- creating cross sections from orthographic drawings
- BeechCraft 350i King Air
- ? use finishing resin to laminate ply doublers?
- Scratch Building a 72" Top Flight Contender
- Scratch build "Bertha"
- Telemaster Airfoil Type?
- S.R.W. Conversion for Motorized Tail Rotor Helis.! See How to on You Tube
- Enlarged 104" Kadet build; flap, dihedral and aileron questions.....
- Aeromodeler Mag pull out plans
- Cessna T-37 plans
- Fokker D7 WWI Biplane built from foam board.
- Jim Pepino's P-39 80"
- Scratch build Super Sportster 120
- .15 size Ultimate plans
- Maxey Hester's P-63 King Cobra
- David Scott's Slow-N-Low
- design questions
- Building Light but strong
- How would you duplicate a canopy?
- Star Wars X-wing plan attached
- CAp 21 canopy
- Component parts alignment in AutoCad
- Draftsight Problem Can't Reactivate; Help!
- Clancy Aviation Speedy Bee
- A build inspired by Noel Rozelle's "Joy Stick"
- Wing template
- XB-70 Any one
- Foamy flying wing
- DutchRC's how to scratchbuild a simple plane
- William F. Kerka Drawings
- Brian Taylor P-51D 69"ws Plan Quality
- Cessna 208
- Back in the Hobby
- Scratch Build Ziroli P-38
- Another 50% Build, need X-Wing Plans
- I am drawing plans for a tri motor bi plane
- RCM Plans #1111 Basic 60
- Decision time: Foam core or traditional balsa rib wing?
- Hooker 60
- sheeting a wing with balsa
