- Flight Box plans ?
- piezzoelectric vibration dampers
- need help
- approximating cross-section formers from 3-views?
- Coverite and matching paint
- Drive Shaft for a BD-5
- airfoil cad file
- PVC Airplane
- Covering help
- Looking for radial engine CAD drawing
- Drying clue in foamwing..
- BALSA PLYWOOD????
- Scale airliner plans
- A foolish question for KC
- ONLINE BALSA SUPPLIERS
- leonardo de vinci
- 86" Delta
- First advanced design
- Dirty Birdy 40 plans?
- Airbus A380
- Drawing your own plans using plastic models
- Conversion Raster to Vector to DWG
- Cristen Eagle plan giant scale
- CAD Question
- Modeling Software
- Carbon Fiber Expoy???
- Enlarging Pepino's Larid Super Solution
- balsa wood quality
- plans for glow powered foamy?
- Flaps on Lazy Ace
- wing saddle help
- Extra 300S Scratch Build Thread
- Great Planes F-14 Tomcat
- Does Hanger 9 UltraCote Paint stand up to Gasoline?
- Where do I buy Fiberglass cloth
- Su35 (Su27) plans HELP!!!!
- How many G's do RC planes experience?
- Painting balsa?!
- Building for first time
- help with elec. plane idea.
- alternative to push rods??
- C-17A Globemaster
- Good referrence plans
- 96in ws Islander Twin
- Vacuum Forming hints/tips
- Need help sticking plastic films
- IC Pusher 15 King Cat
- WingMaster or Compufoil
- RCM Big Bird Too
- Flight Report (folow up to "my first attempt")
- Motorized glider
- Tiger Sport
- Dick and Nadine made it -- barely
- 3D airfoil needed - where to find?
- Fling Wing
- Giant Precedent 240
- My first attempt
- electric engine as generator
- Enlarging plans and what to watch for
- SLIDING CANOPY??
- Determining CG - How's it done?
- Profils
- Free plans for a .40 size profile
- building a foam wing is this stuff ok to use as covering?
- ENGINE SIZE vs WING SIZE/AREA
- Can anyone share the funtana 40 build plans???
- tile it program
- Two Piece Wing and Stabilizer Design...
- Nylon wing bolts - big airplane
- flightskins still exist?
- Hostetler Decathlon
- Zenoah G-62
- Looking for Gee Bee "Z"....
- High wing aircraft with Long tail moment for 3D Flight
- The Hots
- Help with a wing
- Delta wings in formation
- Foam wing structure question
- effect of fuse length, stabilizer surface area
- shoestring yellow jacket
- Small
- Canopy Frame
- cad request - automotive related ... need plans
- The Staggerwing Cometh...
- Hurriacane Katrina
- SCRATCH BUILT WHAT'S THE NAME
- Hurricane Katrina
- 3-views Piper PA-36 300 Brave
- Kit Building Service
- Blowing up 3views?
- A Hinge and a Monocote Question
- Finding what the CG is on a built model?
- Airfoil for Funtana
- Ryan Fireball
- Funflyer
- .. flower foam Zagi ... sort of lol
- Aeroplane Monthly 07/79
- "Missle" style fun fly design
- Modelcad
- shoestring racer
- How do you balance a canard?
- My latest scratch build - In Progress , Have a look and lend a hand
- catalina Cleveland model
- Transfer from plans to wood.
- first attempt.....
- Foam Cutter Drivers and Stepper Motors
- 3D CAD Parts for Turbine Heli
- my cnc
- FOAMIE STRYKER!!!
- CULVER CADET PLANS WANTED !!
- Calcomp DrawingMaster Plus plotter ????
- First Scratch Plane
- STRUTS FOR GLIDER or NOT
- looking for a plan for a 62"semi symetrical trainer wing
- Scale Landing Gear
- wierd plane?
- Laminating Balsa/Ply
- best 180 sized motor
- foam wings-where to get them
- monoplane to biplane do's and dont's
- Importing Profili airfoils to CAD14
- Would it be wise to attempt to scratch build a 2nd plane from a kit?
- WHERE CAN I DOWNLOAD COCKPIT IMAGES
- skippy G2 completed
- scratch mini beech starship (wysiwyg scale)
- resizeing plans
- The Enterprise is complete (pictures)
- SPOILERS - HOW DO I FABRICATE
- Mini Kangaroo
- CG on an odd shaped wing
- How to convert a conventional-tail to a V-tail
- New Plane need some help.
- Seawind 3000 dxf/dwg?
- Trying to build an F/A-37 Talon
- HELP : Foam cutting wire diameter ?
- Free Plans
- Does anyone remember this article?
- tchsuper cub wing joint
- Anybody got PDF format profile plans for a 46 engine or smaller
- MOVED: Large Ridge Soarer
- Weight difference between balsa and ply.
- Plans Ultimate CG or DP
- Plans Carl Goldberg Ultimate
- WHAT ARE YOU PRESENTLY PAYING FOR YOUR "CA" AND YOUR EPOXIES
- TO COVER WITH BALS - OR NOT?
- AirFoils
- Concorde Project
- Ultimate Bi Plane plans
- V-22 Osprey Plans
- "THE HOTS" from Model Airplane News
- Looking for free plans for a avro lancaster
- CAD/Laser cutting service?
- RC SWITZER PLANS--CURTIS CONDOR T-32-PLANS, DOCS & PHOTOS FOR SALE.
- Colour schemes
- Neville Shute's plane
- prop info needed
- HELP : Lear Fan 2100 plans ?
- INCORPERATING HOUSEHOLD ITEMS INTO YOUR BUILD!!
- Poplar vs. Birch Plywood ?
- HELP !!
- Decal design software
- push - pull cable setup?
- skippy g2 approval needed
- Virtual Fokker EV
- 1931 Stout Sky Car
- Starship Enterprise pictures
- Fleet Biplane
- Delta C/G
- Building a flat plate wing...
- 3D/4D Foam SHeet Flyers CAD Files
- Flight characteristics(sp) of a CARNARED
- help with cabannes on scratch built ultimate biplane
- Tipsy Junior Warped Fuselage
- kando40
- Model Builder Plans
- DB Matthews 4-20 Plans
- pointers for using turbocad deluxe?
- TurboCAD Designer,
- how do I fabricate a set spoilers?
- Rotomotion 6DOF and Canard plane
- Good Scroll Saw?
- CONVERTING A FREE FLIGHT GLIDER TO RC - THE AIRHOPPER
- Sukhoi 29 and ACE
- 1/6 SCALE--DH-89 RAPIDE & RC SWEITZER PLANS
- Control Wing
- anyone willing to convert plans to cad?
- Katana
- What's On Your Drawingboard?
- What can I use for my work bench underlay to put pins into?was
- Push rods
- Laying up cowls and material sources
- Measuring a full scale plane cross sections for 3-views and plans
- Free trainer plans
- 1918 Pigeon Frasher Pursuit
- New project - 'Rover'
- Wanted: Funtana Plans! Help!
- L-19 Bird Dog
- Scratch building printer recommendations
- Building from scratch
- Learning About CNC Techniques
- Center of gravity
- help to sugest a trainer plan,
- Falck Rivets racer
- Setting up for EXPOXY? HOW?
- Is there a true working vtol jet rc ?
- Modeling a Varieze
- Group Project!
- Printing on Monokote?
- Hey, look at what I scored on eBay for only $47
- Monokote
- info on scratchbuilding projects
- hydro-foam boat
- AAM plans
- LARGE WING or SMALL
- Here is my newest design, What do you think?
- Covering iron
- CNC or Laser Cutter in Dallas or Fort Worth to Cut simple kit
- T-28B Trojan
- Can soemone help me findout CG for my scratch biuld?
- What do you think of this design ?
- AOA flaps
- Cad Cutter Hardwear
- Laird Super Solution
- control horns
- need help finding plans for a 1/7 scale Aero Commander Shrike
- 1/8 scale Blohm & Voss Bv 141 CAD Design & Construction
- working tiff file in cad?
- 1/4-1/3 scale Ryan STA plans??
- What Tools for Scratch Building?
- Plans to cad to CNC router (Ziroli plans)
- Ultimate Bipe Plans
- Recommend me my ideal park flyer...
- Delta Wing Designers/Builders
- aileron size?
- creating cross sections in cad
- Minimum electric power needed ?
- Flaps
- Aileron joint ?
- WASHOUT ??
- What would you make with these wings
- Jim Pepino´s Gloster Gladiator
- Foam Cutters
- Plan for ducted fan for .48 engine size
- Questions on Nacells
- Advanced Sport-3D design questions
- Fiberglass Cowling Fabricator?
- scratch building an edf
- Jim Pepino plans?
- Frame Fuselage Construction
- duration of flight
