PDA
View Full Version : Scratch Building, Aircraft Design, 3D/CAD
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. foam core wings
  2. Wanted: 1/4 scale Flybay plans
  3. Super Duper Joystick Airfoil
  4. NEED A BUILDER,,INTERESTED????
  5. Pfofessional Cut by Sarpolus??
  6. long ez plans
  7. Kit Cutters Inc.
  8. g to find out where the CG is CG Placement
  9. Harebrained Idea #4928
  10. F-17??? "Lithium Falcon"
  11. j-bolts
  12. Quest for fowler flaps
  13. Makeing my first plane..
  14. Wanted: November 1993 RCM magazine....
  15. crashed piper j-3 cub
  16. 3D Modeling of Flexible Parts
  17. Gull Wing on PZL P.11c
  18. Motor Box thickness?
  19. laminating foam?
  20. Help finding beaver plans
  21. building a scale model from scratch
  22. c-119 plans
  23. First design : I need some approval !!
  24. Lonestar Balsa
  25. Plans for a CAP 40-46 size, willing to pay, or an Extra or similar
  26. 3 view drawings
  27. Ziroli Eindecker or similar
  28. foam core fuselage
  29. Cessna 150
  30. DH-89 Rapide Accessories
  31. R/C STORE service/lack of
  32. cad software
  33. "sticker glue" ?
  34. Build a workbench
  35. need help... buiding a profile
  36. Message to moderator re Cruiser 60
  37. 1917 French Debruyere C-1, canard pusherb
  38. scratch buildiing
  39. f22 raptor rc construction start
  40. Tiger 2, my first kit and also the last
  41. Can I cut down the length of a fuselage?
  42. Wood Source and Kevlar ??
  43. Rotozip
  44. Cruiser 60
  45. How do cut your balsa?
  46. Need a machinist with a screw machine! HELP
  47. xb-70 wing droop hinge
  48. Need nylon bolts
  49. Autocad Printing
  50. QUESTIONS ON ENLARGING A PLANE FROM .15 SIZE TO ? 60 SIZE (A LAZY BEE)
  51. Poppet 48" Sports Bi-plane
  52. CANADIAN RC FLIERS
  53. great planes shrike commander plans
  54. 1928 Russian Giant Kalinin, K-7
  55. Which grade of aluminum for Landing Gears?
  56. RIB with lines outside
  57. mr.mulligan
  58. Sanding the wing saddle....a trick I found.
  59. ziroli stuka mods.
  60. SIAI Marchetti SF-260
  61. modelcad3000
  62. Build a Backwards Plane?
  63. Program Help
  64. Anyone recall an early 80's foam ring r/c aircraft?
  65. constant chord 3d plane
  66. hawker hurricane
  67. hawker hurricane
  68. Sheeting delta wings?
  69. Good, reasonably priced paint gun.
  70. 3 VIEW NEEDED
  71. help me design B2 stealth bomber
  72. WARNING!
  73. Midwest Strikemaster plans
  74. Close a file for plotter print
  75. Plans of the F-20 Tiger Shark
  76. How to construct to a build table straight line?
  77. Converting PDF to DXF for ACAD 2002.
  78. K&S Alumnum - what alloy?
  79. XP55 canard problem
  80. Wing sheeting dilemma?
  81. sorry wrong page
  82. Help with Edge540
  83. Selfbuild Piper cherokee
  84. scratch build thread with photos??
  85. Need pictures...PLEASE HELP!!!
  86. Plan built extended wing Lazy Bee covering advise
  87. Raptor A.S. plans available here
  88. Day Dream Believer Project
  89. Fairy Swordfish
  90. Step-By-Step Model Aircraft Design
  91. Japanese R2Y
  92. Landing Gear Placement
  93. Help in UGLY STICK construction
  94. Fully automatic gear doors for 25 cents
  95. Hot Wire Cutter Help Needed
  96. Questions re. 76" Lazy Ace wing construction please
  97. plans for an edge 540
  98. Selfbuild PIPER CHEROKEE
  99. My first plan build. FlyRC PA-18 Cub
  100. plugs for Molds
  101. Cheap mock-ups before cutting balsa....
  102. Plans for the Right Angle from May 2004 AMA Mag
  103. your experties needed on a restore
  104. Yak-23 (Flora)
  105. first scratch built
  106. MOVED: Wind tunnels
  107. Scaling Plans
  108. Built up DLG plan/build-album: QuickFlick-II
  109. U Can Do plans
  110. What exactly is "Dutch Roll"?
  111. List of builders ?
  112. First Giant Scale - Need Construction Help.
  113. .25 Spitfire Mk II - need advice
  114. FRANK NOLL 38% CHRISTEN EAGLE
  115. Cordless Slotmachine
  116. locating tail mean chord? Tail Volume Ratio
  117. Balsa Suppliers
  118. Frankfort Ky has a Hobby Shop now!
  119. Scratch building
  120. Do Autocad programs help size structural parts?
  121. Changing Plans Sizes
  122. Whats Better And Why??????
  123. Cadalyst review of Design Cad
  124. got me an idea...
  125. Airfoils for fast airplanes?
  126. AIRliner cheap
  127. next in line to finish
  128. My 61" Fokker Cll, 2 passenger
  129. What Material for Wing Ribs?
  130. GWS moter and gear use
  131. Coroplast B1 Bomber
  132. Super Hots with removable wings
  133. Looking for plans (dxf/dwg) for SpaceWalker (46-60)
  134. Ziroli B-25 (.15 to .19) size...anyone heard of it?
  135. METEOR PLANS
  136. RC Sportsman Mag Plans Where to get - October 1979
  137. don't know if this belongs in here but . . .
  138. What would be needed to make your own retracts?
  139. Foam core wings
  140. Newbie to CAD needs help
  141. Pitts M12 26% plans available soon
  142. plotters and autocad
  143. pusher configuration
  144. Choosing the right Saito?
  145. My latest design...
  146. Do you think this will fly?
  147. how do you draw cross sections when there are none??
  148. TRACING OUT TEMPLATES?
  149. Removable Wing Halves
  150. Looking for CNC Epp glider plans
  151. Hall Buldog Plans
  152. Basic CAD --> CNC question
  153. Help with Balsa Sheeting
  154. CAD/CAM question
  155. Top Flight Bananza
  156. plans for a Cessna 195 1/4 scale or larger?
  157. Which epoxy for firewalls?
  158. Edge 540 Plans
  159. where to find plans for batplane.
  160. old paint
  161. Carl Goldberg Sukoi Wing
  162. Four Star 60 wing cross section
  163. de Havilland Chipmunk ??
  164. parts of layers moving behind in cad!
  165. CHRIS GOLDS PLAN how to get
  166. The science of lightening wing ribs???
  167. building/airfoil for Savoi Marchetti 55
  168. looking for de Havilland DH 2 plans
  169. Importing Airfoil plots to TurboCad
  170. Kingfisher: Laser Cut Parts ??
  171. Compufoil Question
  172. funtana clone
  173. Cutting formers question
  174. UltraTwig (UltraStick 60 scaled down 1/2)
  175. Lazy Bee, Wood size for plan resize / scratch build
  176. CAD templets
  177. query on wing thickness 4 my 300L
  178. Human BioMECHANIC data for aircraft.
  179. B29 wing profile, 180 cm wingspan
  180. Looking for plans for either a Laser 200 or AKRO Z
  181. MOVED: Designing a Sailplane
  182. Info on old Goldberg SKylane (70's) wanted - windows
  183. Nosen Trainer Plans Wanted
  184. Does this sound doable?
  185. GP gee bee profile plans
  186. Aileron/flap hinge info for RCM Agwagon (365)
  187. Citabria Plans
  188. 3d Engine CAD
  189. Pylon Racers Plan
  190. How do I get started?
  191. What do you think of this program?
  192. Help me with my 3d plane, 3d screenshots
  193. door latch on Ikon monocoupe 90a
  194. Super Chipmunk
  195. Neat stuff from your local newspaper,,,
  196. Setting Washout
  197. Average chord/aspect ratio question
  198. CADD program?
  199. TurboCAD question...
  200. 75% Scratched built Electric MTK
  201. scaling down plans.....
  202. Help Please
  203. Building supplies at Harbor Freight
  204. Laser cutting files
  205. Laser cutting files
  206. anyone split a fusalage apart for transport?
  207. .46 3d plane in the works
  208. question for the experts
  209. Scratch Building a 3D Profile
  210. Trainer plans
  211. anything like the sig rascal?
  212. Triplane Ailerons
  213. how do i figure out how much servo for a given ammount of control surface?
  214. Taking things from 3D to reality?
  215. any info on these plans?
  216. Super Cub plans
  217. Spitfire Retracts??
  218. precedent t240??
  219. Any plans for 15-40 size 3D planes?
  220. Where to find plans for 540T?
  221. Guestimating weight
  222. Wanted … 1/4 scale SE5A Plans.
  223. cutting out templates
  224. Don't order plans thru RCStore.com
  225. piper pawnee
  226. Your Favorite Build
  227. Ace 4-60 fuselage plan
  228. How to cover this??
  229. 88" edf powered jet in process whata ya think
  230. Plans for a plane like the Verti Go 3d?
  231. Balsa wood supplier
  232. hinge point for full flying tail?
  233. b29 3view
  234. R/C Chair cockpit
  235. flying stabs
  236. Aliron on monocoupe 90a
  237. Smaller alternatives to props?
  238. an $80 bandsaw?
  239. how do you attach vertical tail to round boom?
  240. Giant Calmato (well giant....its only 1:1.35)
  241. stinson reliant plans??
  242. Yak 54 plans
  243. Need help on a Douglas A20A Havoc
  244. Laser Cutting from Paper Plans
  245. Laser Cutting from Paper Plans
  246. small fun fly/3D plane
  247. making templates and scratch building.
  248. Balsa Stripping Tool
  249. Edge 540
  250. 33% Super Skybolt . . ???
