- Converting PDF to DXF for ACAD 2002.
- K&S Alumnum - what alloy?
- XP55 canard problem
- Wing sheeting dilemma?
- sorry wrong page
- Help with Edge540
- Selfbuild Piper cherokee
- scratch build thread with photos??
- Need pictures...PLEASE HELP!!!
- Plan built extended wing Lazy Bee covering advise
- Raptor A.S. plans available here
- Day Dream Believer Project
- Fairy Swordfish
- Step-By-Step Model Aircraft Design
- Japanese R2Y
- Landing Gear Placement
- Help in UGLY STICK construction
- Fully automatic gear doors for 25 cents
- Hot Wire Cutter Help Needed
- Questions re. 76" Lazy Ace wing construction please
- plans for an edge 540
- Selfbuild PIPER CHEROKEE
- My first plan build. FlyRC PA-18 Cub
- plugs for Molds
- Cheap mock-ups before cutting balsa....
- Plans for the Right Angle from May 2004 AMA Mag
- your experties needed on a restore
- Yak-23 (Flora)
- first scratch built
- MOVED: Wind tunnels
- Scaling Plans
- Built up DLG plan/build-album: QuickFlick-II
- U Can Do plans
- What exactly is "Dutch Roll"?
- List of builders ?
- First Giant Scale - Need Construction Help.
- .25 Spitfire Mk II - need advice
- FRANK NOLL 38% CHRISTEN EAGLE
- Cordless Slotmachine
- locating tail mean chord? Tail Volume Ratio
- Balsa Suppliers
- Frankfort Ky has a Hobby Shop now!
- Scratch building
- Do Autocad programs help size structural parts?
- Changing Plans Sizes
- Whats Better And Why??????
- Cadalyst review of Design Cad
- got me an idea...
- Airfoils for fast airplanes?
- AIRliner cheap
- next in line to finish
- My 61" Fokker Cll, 2 passenger
- What Material for Wing Ribs?
- GWS moter and gear use
- Coroplast B1 Bomber
- Super Hots with removable wings
- Looking for plans (dxf/dwg) for SpaceWalker (46-60)
- Ziroli B-25 (.15 to .19) size...anyone heard of it?
- METEOR PLANS
- RC Sportsman Mag Plans Where to get - October 1979
- don't know if this belongs in here but . . .
- What would be needed to make your own retracts?
- Foam core wings
- Newbie to CAD needs help
- Pitts M12 26% plans available soon
- plotters and autocad
- pusher configuration
- Choosing the right Saito?
- My latest design...
- Do you think this will fly?
- how do you draw cross sections when there are none??
- TRACING OUT TEMPLATES?
- Removable Wing Halves
- Looking for CNC Epp glider plans
- Hall Buldog Plans
- Basic CAD --> CNC question
- Help with Balsa Sheeting
- CAD/CAM question
- Top Flight Bananza
- plans for a Cessna 195 1/4 scale or larger?
- Which epoxy for firewalls?
- Edge 540 Plans
- where to find plans for batplane.
- old paint
- Carl Goldberg Sukoi Wing
- Four Star 60 wing cross section
- de Havilland Chipmunk ??
- parts of layers moving behind in cad!
- CHRIS GOLDS PLAN how to get
- The science of lightening wing ribs???
- building/airfoil for Savoi Marchetti 55
- looking for de Havilland DH 2 plans
- Importing Airfoil plots to TurboCad
- Kingfisher: Laser Cut Parts ??
- Compufoil Question
- funtana clone
- Cutting formers question
- UltraTwig (UltraStick 60 scaled down 1/2)
- Lazy Bee, Wood size for plan resize / scratch build
- CAD templets
- query on wing thickness 4 my 300L
- Human BioMECHANIC data for aircraft.
- B29 wing profile, 180 cm wingspan
- Looking for plans for either a Laser 200 or AKRO Z
- MOVED: Designing a Sailplane
- Info on old Goldberg SKylane (70's) wanted - windows
- Nosen Trainer Plans Wanted
- Does this sound doable?
- GP gee bee profile plans
- Aileron/flap hinge info for RCM Agwagon (365)
- Citabria Plans
- 3d Engine CAD
- Pylon Racers Plan
- How do I get started?
- What do you think of this program?
- Help me with my 3d plane, 3d screenshots
- door latch on Ikon monocoupe 90a
- Super Chipmunk
- Neat stuff from your local newspaper,,,
- Setting Washout
- Average chord/aspect ratio question
- CADD program?
- TurboCAD question...
- 75% Scratched built Electric MTK
- scaling down plans.....
- Help Please
- Building supplies at Harbor Freight
- Laser cutting files
- anyone split a fusalage apart for transport?
- .46 3d plane in the works
- question for the experts
- Scratch Building a 3D Profile
- Trainer plans
- anything like the sig rascal?
- Triplane Ailerons
- how do i figure out how much servo for a given ammount of control surface?
- Taking things from 3D to reality?
- any info on these plans?
- Super Cub plans
- Spitfire Retracts??
- precedent t240??
- Any plans for 15-40 size 3D planes?
- Where to find plans for 540T?
- Guestimating weight
- Wanted … 1/4 scale SE5A Plans.
- cutting out templates
- Don't order plans thru RCStore.com
- piper pawnee
- Your Favorite Build
- Ace 4-60 fuselage plan
- How to cover this??
- 88" edf powered jet in process whata ya think
- Plans for a plane like the Verti Go 3d?
- Balsa wood supplier
- hinge point for full flying tail?
- b29 3view
- R/C Chair cockpit
- flying stabs
- Aliron on monocoupe 90a
- Smaller alternatives to props?
- an $80 bandsaw?
- how do you attach vertical tail to round boom?
- Giant Calmato (well giant....its only 1:1.35)
- stinson reliant plans??
- Yak 54 plans
- Need help on a Douglas A20A Havoc
- Laser Cutting from Paper Plans
- small fun fly/3D plane
- making templates and scratch building.
- Balsa Stripping Tool
- Edge 540
- 33% Super Skybolt . . ???
- Unchain my T-28
- X-wing fighter
- Lots of questions...
- fiberglass question
- Were can i get balsa laser cutting done
- hobby room
- Copying a foam core wing
- does any have a good cheap carbon fiber source
- AutoCAD "How-To" Question
- cad veiwer
- wing spars
- Brad Shepherd Designs??
- How to Setup Your Own Laser Cutting Templates
- modifying a servo to act as a larger jack screw
- Aeronca C3 Plans
- Tomcat prop jet
- 3-view sources
- Laser cutting parts in excess of 24"
- WTD Zlin 50 Scratch-a Plane Plans
- A-10 plans and a bad memory.
- A-10 Cowls
- Question about the planes tail
- Really easy custom canopy
- Laser Cutting in the UK?
- DXF files of Hi Torque Servos?
- info on CAD
- Pinked tape
- used plotter
- High wing to low wing conversion
- cyclone project progress
- Easy, beginner plans
- D & L Designs Plans?
- Crusader II
- Bud Nosen 1/4 Citabria
- hinge or cover first?
- Looking for recommendations on a 10" or 12" disc sander
- Really Stupid covering question
- radio interferance
- Bandito
- balsa subistitute
- Skinny Scale Helldiver
- WING SHEETING QUESTION
- Tracing over an image & "scale issues" in Auto Sketch = HELP PLEASE
- anyone have plans for a Sherpa aircraft ?
- 40 size ultimate biplane plans
- Need Help on power supply for foam cutter
- Making Molds?
- Fantrainer
- Will it fly?
- fixing Stab in Fuselage
- incedence meter question
- X Calibur
- Cabon fiber tube
- Shipping problem . . .
- Ziroli 70 inch P-47
- Shaping Foam???
- just had a crazy idea
- Double Impact
- HOW DO I APPLY DETAIL LINES AND THE RIVITS
- allowing for lift in the tail?
- Lite Ply
- wingloading in a turn or loop?
- Words Of Wisdom
- P51D with different details
- Cutting
- Wind Craft by Global/ Upgrade
- 3D Drawings in many formats for all kinds of aircraft ect
- autocad help, serial number
- joining two pieces
- bird of prey 3 view ?
- Flight of the Phoenix
- Need Retract Drawings
- how to import tiff files to cad?
- AERO RULE
- Boeing/McDonnell- Douglas X-35 version
- Just for the sake of asking.. How do you make the plans
