- What is you using for paint?
- Voyager aircraft
- Blohm and Voss 215. Late WW2
- RCM Magazine Ta 152 H by David Andersen
- FOKKER build
- I NEED HELP FIGURING OUT A CG
- The ultimate work table
- Calculating wing area
- 42% design help
- Adjustable tailplane incidence mechanism
- source for light ply?
- CAD help
- Kit cutting
- first scratch build, (autocad)
- Foam for wings, where do you get it?
- Lockeed Altair Plans
- -large scale b-29 plans
- KI-61 Split Flap help
- A-10 Project
- scratch building a F-111
- epoxy strength vs cure time
- FOR ME-262 FANS
- Using Foam Core for Profile Fuselage?
- contest balsa
- c/g vs. wing location
- Free Yak 54 Plan
- Laser Cutting Machine
- wortmann airfoil help
- hey guys my 1st attempt at sctratch building
- PLANS TO CNC
- Keeping CA "dry"
- Free CAD Pilatus Turbo Porter plans DL Link
- Building Cosmic Wind 1/2,6 from scratch
- Help me Build a Yak 54
- Airplane Design Software (CAD)???
- Working with a Plan
- Control Surface Loads
- scratchbuild ducted fan
- plans edge 540
- Do u know good RCM plans ?
- What is a PBF? This flying flat piece?:)
- new CAD designed electric pusher
- Where to get 3-views & info???
- Starduster Too by Dario Brisighella
- Sandable Glues?
- large dihedral and wing tubes
- Sky Van Plans
- Airplane to go around a ST 90
- where to locate dummy exhaust for a P51D
- Way to go Laser Arts co.
- Best material for windscreen?
- Little Red Vac Vacuum Forming Machine Question
- solidworks
- NEED P-47 CANOPY FRAME BUILDER
- .25 Fw-190
- The Edge 540 P
- Cessna 172 CAD plans
- scratch building a hooker
- CG on flying wing aircraft
- Engine thrust Angles
- Air-Tractor 401
- Want to buy: ARC wings
- Vacuum forming question
- Big Apple
- Custom gears
- Foaming for Newbies
- Australian kit cutter
- I look for a software for planing planes....
- old bipe and cg
- FUNTANA WING PROFILE
- Cad Plotting
- airfoil type dynaflite mustang
- Newbie wishing to jump in the deep end.
- Airfoil
- ROTATING 2D PROFILES ALONG THE X,Y,Z AXIS IN INVENTOR
- fuse jig
- Plane Geometry
- 3D surface modeling expert help needed!!!
- Building a foam wing from scratch
- Balsa Cutting Technique advice
- fibreglass fuselage no wings where to start
- thjisRC Trike
- working with depron/zepron sheets
- Wanted a Pitts plan. Help
- AirFoil design comments needed.
- canard speed plane, airfoil selection and oppinion needed
- How to work with Plan^
- Find NP and CG on a FSW canard with lifting body
- S2B Pitts Special
- Graupner Showflyer Airfoil
- Resizing Balsa
- Who does a nice job cutting from plans
- CorelDRAW 9 Help!!!
- Determining CG on scratchbuild.
- MOVED: tiny rc planes
- Semi Scratch Built?
- Design Question / Help
- wantin to build a second plane scratch
- Anybody have the hots biplane plans?
- Question. Changing materials when enlarging plans?
- Culver "Cadet" LCA. I need Help!
- Wing and rear incidence
- ERIC FEARNLEY'S GRUMMAN HELLCAT F6F PLAN WANTED
- Custom landing gear question.
- Horten free plans
- Scaling down plans?
- looking for plans?
- need a cutter for foam wings
- crop duster
- To the moderator
- One Design/DR-107, DR-109
- print dwg and dxf files?
- Scratch Building?
- Building around powerplants of unknown size?
- Questions on enlarging Spitfire plans
- Converting dxf file back to naca format
- 45% Long Ez Project Progress
- CG Question: Which adds more weight to nose - move wing forward or back?
- GOOD SOURCE OF FOAM BLANKS???
- Trace/transfer plans onto wood
- Pictures to DesignCAD
- Beech Staggerwing Plans
- A-10 Project - Progress/ Questions
- ENGINE DRAWINGS
- wing tube diameter
- epoxy and blind nuts
- An Ugly Duck?
- Fun Fly Wing for GP Venus 40
- Spruce or Basswood?
- Brewster Buffalo
- How to build light engine mount ?
- Delta aerofoil
- RCM Cessna Agwagon/T-6F
- Jerry Behrens Plans-Travelair 2000
- Easy flying Bipe plans?
- goin custom
- Egg-ship-one going for the Eggs-price
- CORELDRAW 11 PROBLEMS
- UK Balsa
- Need a math lesson
- giant scale aerobatic
- Foam Source
- Help Me with the Ziroli Texan plan! Might soon become Build Thread
- Cloud Dancer 40 Plans
- F3F-2 Grumman Biplane
- Horten Ho 229 Build
- CAD question
- P-40 B or C Plans?
- Which foam?
- Help with plan selection please
- Designing a sailplane from scratch - guidance needed =)
- chord??? please help
- does anyone have any plans i could use???
- hellcat
- Convert 3-view drawings to plans?
- Types of Carbon Fiber, & there uses?
- scratch vs kit
- 38%Yak 55SP kit or parts
- where to cut holes?
- Model Aircraft news: The Winglet - Flying wing
- POTENTIAL VTOL DESIGN: ANY IDEAS?
- Calling all machinists!!!!
- Sheeting Liteply with 1/16 balsa... how??
- Solidworks 2004 question
- Cad Printing Help???
- NEW SHEETING MATERIAL
- Making large sheets of balsa help please (Ryans Rebel)
- F/A 18 Hornet scratch built
- 40 size cub
- Delete
- CAD?
- For all you Pattern Flyers out there.....If you like the GP Venus you'll love this 1.20 size
- machining parts
- TurboCAD Learning Edition - Please Help
- Giant Extra Canopy and Cowling?
- Retracts in a scratch built A-10
- 38%Christen Eagle
- bad news for scrach builders & kit manufactures?
- ANY HOBBY MACHINISTS OUT THERE?
- JACK-O-LANTERN .46 POWER PLANE!
- Helio Courier plans
- DC-3 RIB CUTTING
- Asymmetric Airplane Design
- Cutting Foam, The Starship Enterprise will FLY
- MAN Plans
- 35% Extra plans
- Who Did Get the Free Extra and Edge Plans?
- Klarish Kits
- Enlarging Plans
- wingtiperons? whaya think?
- Copying Aeromaster Kit
- Has anyone tried this?
- Walt Mucha Mahler PJ295
- Northrop N9M Plans Availability
- Hobby Poxy II replacement?
- landing gear twist
- Help with George Miller A-10 Please
- PBY-5A Catalina landing gear ?
- Other sources for Plywood
- Templates for Servos, Engines etc.?
- hovercraft landing gear???? is it feasable
- Need help saving CAD file to CD
- C.G. on a delta wing?
- Using different wing now-need C of G Help!
- Free Extra 300 Plans
- Zlin 50L ... Test Flight
- Scratch building a DH88 Comet
- RCM Krier Kraft
- Original Top-Flite Mono Coat material
- Plans for Big Stik 60
- Funtana plans
- Best brand for CA glue
- Type of Lite Ply
- O15 and AO15 airfoils
- Edge 540, Extra 300, Cap 232, Yak 54, others?
- Vertigo - VTOL RTG (ready to go)
- Wing warps
- find design calculator...where..??
- Newbie questions
- X
- Any F-22 Plans?
- Wing skins
- Mikoyan-Gurevich MiG-15 plans?
- Any Giant scale Stagger wing plans out there?
- herculese c-130 project
- Which Cad program?
- Plans for a C-130 electric or Gaz
- Drawing Wing Ribs
- Bending wire
- 1/3 Tigermoth wing bracing?
- SOLID WORKS
- Leading edge sheeting
- definition of "overpowered"?
- Picture files in AutoCad??
- "Not For Sale" plans ect
- tailwind plans
- Need Some help with F14 Tomcat
- thrust line?
- fiberglass fuselage
- Block plane DIY project
- Tiger Moth 30%
- Smaller Plans for Cobra Bipe
- Big, big rudders
- MIG 29 Fulcrum
- does anybody know about Hal DeBolt plans
- The 44 MAGNUM, My Latest Design
- Delta CG and thrust?
